LM2575S-3.3 P+
Description
Features
The LM2575/6 series switching regulators are monolithic
integrated circuits designed for use in buck or buck/
boost regulator applications requiring accurate output
voltages over combined variations of line, load and
temperature. This unique series greatly simplifies
switching power supply design. The LM2575 has a
maximum output current of 1A and the LM2576 is rated
for 3A.
u Pin for pin replacement for Nationals LM2575/6
series
u DC-to-DC buck or buck/boost converter requiring
MI
JS
u
u
u
u
The LM2575/6 series miniconverters include a u
switching regulator and compensation network all within u
the same package. Just add a choke, catch diode and u
two capacitors to obtain an efficient DC-to-DC converter. u
CR
The current limit and thermal shutdown features of the
LM2575/6 series fully protect the device against
overstress conditions.
Applications
O
u
u
The LM2575/6 series offers an alternative to popular 3
u
terminal linear regulators by providing higher efficiency
u
Micro controller power supplies
Medical equipment
Industrial power supplies
Instrumentation power supplies
mi
Typical Application Circuits
Se
with reduced heatsink size. In many applications a heat
sink will not be required.
only 4 support components
Fixed or adjustable voltages
Preset output voltages of 3.3V, 5V and 12V
Wide output voltage range, 1.23V to 35V
82% typical efficiency @ 5V out
Wide input voltage range, 4V to 40V
Inhibit/enable control pin
Industrial temperature range
TO-220 and TO-263 packages
co
uc
nd
LM2576
L1
330µH
100µH
D1
3A
7A
C IN
68µF
120µF
C OUT
330µF
1,000µF
r
to
LM2575
www.jsmsemi.com
第1/12页
LM2575S-3.3 P+
Absolute Maximum Ratings
Parameter
Input Voltage
On/Off Pi n Input Voltage
Sy mbol
Maximum
U nits
VIN
45
V
VON/OFF
-0.3 £ VON/OFF £ VIN
V
-1
V
Output Voltage to C ommon (Steady State)
PD
Internally Li mi ted
W
Thermal Resi stance Juncti on to Ambi ent
TO-220
TO-263
q JA
55
60
°C /W
Thermal Resi stance Juncti on to C ase
TO-220
TO-263
q JC
2.0
2.0
°C /W
Operati ng Juncti on Temperature Range
TJ
-40 to +125
°C
TSTG
-65 to +150
°C
Lead Temperature (Solderi ng) 10 Sec.
TLEAD
300
°C
ESD Rati ng (Human Body Model)
V ESD
2
kV
Storage Temperature Range
CR
MI
JS
Power D i ssi pati on
O
Se
Electrical Characteristics
Parameter
VO
8V to V IN Rated
VO
VO
LM2576-12
Feedback Voltage
V FB
LM2576S-ADJ, VO = 5V
Max
Units
3.23
3.30
3.37
V
3.20
3.40
3.14
4.90
3.47
5.00
5.15
4.75
5.25
IO = 0.5A
11.76
12.24
15V to V IN Rated
11.52
12.48
11.40
12.60
IO = 0.5A
8V to V IN Rated
1.217
12.00
1.230
1.193
IB
VIN = 12V, IO = 0.5A
LM2576S-ADJ
1.243
V
V
V
1.267
1.180
Feedback Bias Current
5.10
4.85
r
Output Voltage
8V to VIN Rated
Typ
to
LM2576S-5.0
IO = 0.5A
Min
uc
Output Voltage
IO = 0.5A
nd
LM2576S-3.3
Test Conditions
co
Output Voltage
Symbol
mi
Unless otherwise specified: VIN = 12V for 3.3V, 5V and ADJ options and 25V for 12V option; VOUT = 5V for ADJ option; TA = 25ºC; VIN rated = 40V;
IO = 0.5 to 3A (LM2576), 0.2 to 1A (LM2575). Values in bold apply over full operating temperature range.
1.280
50
100
nA
500
www.jsmsemi.com
第2/12页
LM2575S-3.3 P+
Electrical Characteristics (Cont.)
Parameter
Output Voltage
Symbol
Test Conditions
Min
Typ
Max
Units
VO
IO = 0.2A
3.23
3.30
3.37
V
LM2575S-3.3
8V to VIN Rated
3.20
3.40
3.14
Output Voltage
VO
JS
LM2575S-5.0
VFB
8V to VIN Rated
4.85
5.15
4.75
5.25
IB
15V to VIN Rated
11.52
12.48
11.40
12.60
IO = 0.2A
1.217
5V
1.230
1.193
VIN = 12V, IO = 0.2A
50
VIN = 12V, IO = 1A (LM2575, 3A for LM2576)
nA
82
to
uc
fSX
47
52
r
43
LM2575, IO = 1A
LM2576, IO = 3A
0.9
1.4
93
98
Peak Current LM2575(1)
ICL
1.7
2.2
1.3
3.5
www.jsmsemi.com
kHz
62
1.2
DC
4.2
58
0.9
Max. Duty Cycle (On)(3)
ICL
82
ADJ, VO = 5V
Peak Current LM2576(1)
100
77
88
VSAT
V
500
VIN = 15V, IO = 1A (LM2575, 3A for LM2576)
Saturation Voltage(1)
1.243
V
1.280
12V
Switching Frequency
12.24
V
1.267
1.180
nd
h
12.00
5.10
11.76
co
Efficiency/Option
5.00
IO = 0.2A
8V to VIN Rated
LM2575S-ADJ
3.3V
4.90
mi
IO = 0.2A
Se
LM2575S-ADJ, VO = 5V
O
Feedback Voltage
VO
CR
LM2575-12
MI
Output Voltage
3.47
V
3.0
A
3.2
5.8
6.9
A
7.5
第3/12页
LM2575S-3.3 P+
Parameter
Sy mbol
Test C onditions
IL
VIN = VIN Rated
Min
Ty p
Max
U nits
2
mA
Output Leakage C urrent(2)
Output = 0V
Output = -1V
Qui escent C urrent(2)
IQ
JS
(On/Off Pi n = 5V)
ISTBY
5
10
50
mA
VIH
2.2
1.4
V
2.4
O
VIL
µA
500
CR
On/Off Pi n Logi c Input Level
30
12
MI
Standby Qui escent C urrent
7.5
1.2
1.0
V
0.8
IIH
VON/OFF = 5V (Off)
12
30
VON/OFF = 0V (On)
mi
IIL
Se
On/Off Pi n Input C urrent
µA
co
Notes:
(1) Output sourcing current, resistive load, no inductor or capacitor.
(2) Feedback = VO + 1.0V.
(3) Feedback = 0V.
r
to
uc
nd
www.jsmsemi.com
第4/12页
LM2575S-3.3 P+
Pin Configurations
Ordering Information
(1) -XX = Voltage Option. Available voltages are 3.3V
(-3.3), 5V (-5.0), 12V (-12), and ADJ (-ADJ), which is
adjustable between 1.23V and 35V.
LM2575, LM2576
MI
JS
TO-263-5
Pin
CR
TO-220-5
Function
VIN
2
OUTPUT
3
O
1
C OMMON
FE E D B A C K
5
ON/OFF
TAB i s C OMMON
co
Block Diagram
mi
Se
4
r
to
uc
nd
www.jsmsemi.com
第5/12页
LM2575S-3.3 P+
Typical Characteristics - LM2575
CR
MI
JS
O
mi
Se
co
r
to
uc
nd
www.jsmsemi.com
第6/12页
LM2575S-3.3 P+
Typical Characteristics - LM2575 (Cont.)
CR
MI
JS
O
mi
Se
co
r
to
uc
nd
www.jsmsemi.com
第7/12页
LM2575S-3.3 P+
CR
MI
JS
O
mi
Se
co
r
to
uc
nd
www.jsmsemi.com
第8/12页
LM2575S-3.3 P+
Typical Characteristics - LM2576
CR
MI
JS
O
mi
Se
co
r
to
uc
nd
www.jsmsemi.com
第9/12页
LM2575S-3.3 P+
Typical Characteristics - LM2576 (Cont.)
CR
MI
JS
O
mi
Se
co
r
to
uc
nd
www.jsmsemi.com
第10/12页
LM2575S-3.3 P+
CR
MI
JS
O
mi
Se
co
r
to
uc
nd
www.jsmsemi.com
第11/12页
LM2575S-3.3 P+
JS
MI
Outline Drawing - TO-220-5
Outline Drawing - TO-263-5
CR
O
mi
Se
co
r
to
uc
nd
Minimum Land Pattern - TO-263-5
www.jsmsemi.com
第12/12页
很抱歉,暂时无法提供与“LM2575S-3.3 P+”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.59000
- 10+3.81240
- 50+3.16440
- 100+2.77560
- 500+2.53800
- 1000+2.41920
