2mm Double-Row Connector (Product Compliant to UL/CSA Standard)
Feb.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DF11 Series
■Features
1. Space-saving on Board Realized
Double rows of 2mm pitch contact has been condensed
within the 5mm width.
The multiple number of signals can be secured in the same
space as the conventional 2mm single-row contact.
2. Broad Variation
The insulation displacement and crimping methods are
prepared for connection. Thus, board to cable, in-line,
board to board connectors are provided in order to widen a
board design variation.
In addition, "Gold" or "Tin" can be selected for the plating
according application, while the SMT products line up.
Rib to prevent
mis-insertion
3. Applicable Wire Covers Wide Range
Simple lock
Rib to prevent contact
mis-insertion as well as
disimilar contact mis-insertion
According to the double rows of 2mm pitch compact
design, the applicable wire can cover AWG22 to 30.
4. The ID Type Connector Achieves Connection
Work.
Using the full automatic insulation displacement machine,
the complicated multi-harness can be easily connected,
reducing the man-hour and eliminating the manual work
process.
5mm
4 wall box style
■Applications
Business equipments such as copy machine, printer and so on.
B220
DF11 Series●2mm Double-Row Connector (Product Compliant to UL/CSA Standard)
■Features of DF11 Insulation Displacement Machine
(Single Core Punching Full Automatic ID Machine AM700/DF11)
● 5 Major Features of ID Machine AM700/DF11
Data storage
1. Perform the multi-harness.
2. The setup time has been widely reduced. (10 minutes maximum)
Low cost
Multi-harness
Setup in 10 minutes
Half space
3. Space saving design.
(About half space compared with the conventional machine)
4. Minimize initial cost with low cost.
5. The harness data can be saved in the floppy disk and easily
changed.
■Points
Since the DF11 insulation displacemention allows double rows ID with a single part, the harness service is completed with
machine connection only.
■Product Specifications
Current rating
Rating
Crimping
Wire size
(Note 1)
Insulation Displacement Wire size
Voltage rating
Crimping
AWG #22 to #26 : 2A
Operating Temperature Range -30 to 85ç Note 2
AWG #28
: 1A
Operating Humidity Range
AWG #30
: 0.5A
AWG #26
: 1A
Storage Temperature Range -10 to 60ç Note 3
250V AC Insulation Displacement 100V AC Storage Humidity Range
Current rating
Rating
Wire size
Voltage rating
Item
: 2A
AWG #24 to #28
: 1A
AWG #30
: 0.5A
30V AC
Specification
Condition
1000M ohms min.
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
3. Contact Resistance
30m ohms max.
100mA
1. Insulation Resistance
4. Single Insertion/Extraction Force 0.3N (30gf) min., 4.4N(450gf) max.
5. Vibration
No electrical discontinuity of 1μs or more
6. Humidity (Steady state) Contact resistance: 30m ohms max. Insulation resistance: 500M ohms min.
7. Temperature Cycle
40 to 70%
■UL·CSA Safety Standard File No.
UL
:E52653
CSA
:LR95109
UL-CSA Safety Standard Approved Specification
AWG #22
40 to 80%
Contact resistance: 30m ohms max. Insulation resistance: 1000M ohmsmin.
8. Durability (Mating/un-mating) Contact resistance: 30m ohms max.
9. Resistance to Soldering heat No deformation of components affecting performance.
Measured by the square steel-made pin of 0.5±0.002mm
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
96 hours at temperature of 40ç and humidity of 90% to 95%
(-55ç: 30 minutes ➝ 5 to 35ç: 5 to 15 minutes
(-85ç: 30 minutes ➝ 5 to 35ç: 5 to 15 minutes) 5 cycles
Tin plated: 30 cycles
Gold plated:50 cycles
Flow:
Manual soldering:
260ç for 10 seconds
300ç for 2 seconds
Reflow:
Manual soldering:
At the recommended temperature profile 300ç for 3 seconds
Note 1: Current rating of header is 2A.
Note 2: Includes temperature rise caused by current flow.
Note 3: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 4: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
B221
■Material
Product Type
Part
MateriaI
Finish
Remarks
Crimping Socket
Insulator
Polyamide
Black
UL94V-0
Crimping Contact for Socket
ID Socket
Receptacle
Pin Header
SMT Header
In-line Plug
In-line Plug Crimping Contact
In-line Adaptor
Contact
Phosphor copper
Tin plated or gold plated
Insulator
Polyamide
Black
UL94V-0
Contact
Phosphor copper
Tin plated
Insulator
Polyamide
Black
UL94V-0
Contact
Phosphor copper
Insulator
Polyamide
Black
UL94V-0
Contact
Brass
Insulator
Polyamide
Beige
UL94V-0
Contact
Brass
Metal fittings
Brass
Tin plated
Insulator
Polyamide
Black
UL94V-0
Contact
Phosphor copper
Insulator
Polyamide
Black
UL94V-0
Contact
Brass
Tin plated
■Ordering Information
●Connector
DF11 - * DS - 2C
q
q Series Name
: DF11
w
e
r t
t Connection Form/Contact Style
w Number of Contacts : 4 to 32
C
e Connector Type
R26 : Insulation Displacemented socket for AWG26
: Crimping socket
DS : Double Row socket
DSA: Straight through hole
DP : Double Row pin header
DS : Right angle through hole
DEP : Double Row in-line plug
V
: Straight SMT
A
: Adaptor
r Contact Pitch
: 2mm
●Contact
DF11 - EP2428PCFA
q
q Contact Type
e
r
e Contact Type/Packaging Type
Blank : For socket
SCF
: Socket contact, Embossed tape
EP
SC
: Socket contact, Bag
PCF
: Plug contact, Embossed tape
PC
: Plug contact, Bag
: For in-line plug
w Applicable Wire Size
22
: AWG22
2428 : AWG24 to 28
30
B222
w
: AWG30
r Plating Type
Blank
: Tin plated
A
: Gold plated
■ID Socket
Note1: Port 1-piece indicates odd number row,
and port 2- pcs. indicate even number row.
Note2: Use the dip type header as follows.
· Straight angle type : DF11-*DP-2DSA ( 08 )
· Angle type: DF11-*DP-2DS(24)
Photo: Cable connection status
[Specific No.] –* *, (* *)
(05)
:Tin plated, 100 pcs. per bag
(25)
:Tin plated, Tube packaging
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
DF11- 4DS-2R26(**) 543-0652-0-**
4
6.0
2.0
Tube Packaging Quantity RoHS
188
DF11- 6DS-2R26(**) 543-0653-3-**
6
8.0
4.0
140
DF11- 8DS-2R26(**) 543-0654-6-**
8
10.0
6.0
112
DF11-10DS-2R26(**) 543-0655-9-**
10
12.0
8.0
94
DF11-12DS-2R26(**) 543-0656-1-**
12
14.0
10.0
80
DF11-14DS-2R26(**) 543-0657-4-**
14
16.0
12.0
70
DF11-16DS-2R26(**) 543-0658-7-**
16
18.0
14.0
62
DF11-18DS-2R26(**) 543-0659-0-**
18
20.0
16.0
56
DF11-20DS-2R26(**) 543-0660-9-**
18.0
50
DF11-22DS-2R26(**) 543-0661-1-**
22
24.0
20.0
46
DF11-24DS-2R26(**) 543-0662-4-**
24
26.0
22.0
42
DF11-26DS-2R26(**) 543-0663-7-**
26
28.0
24.0
40
DF11-28DS-2R26(**) 543-0664-0-**
28
30.0
26.0
36
DF11-30DS-2R26(**) 543-0665-2-**
30
32.0
28.0
34
DF11-32DS-2R26(**) 543-0666-5-**
32
34.0
30.0
32
YES
Note1: The specific No. (05) item is delivered per bag unit (100 pcs.). Please order products per bag unit.
Note2: To use the full automatic insulation displacement machine to punch the DF11 single contact, the (25) tube packaging specification
should be applied.
Note3: Please order the tube packaging products by multiplying the packaging quantity ( pcs.).
■Applicable Cable
Part Number
Applicable Cable
Jacket Diameter
DF11-*DS-2R26
UL1061 AWG26 (7/0.16)
Ø0.9 to 1.05mm
■DF11-*DS-2R Insulation Displacement Machine
Type
Part Number
Punching full automatic ID
machine DF11 single contact
AM700/DF11
Desktop ID Machine
SA700/DF11
CL903-0013-5
Connection Type
■Effective harness form
1. DF11-both ended, one ended
2. DF11-DF11, separation
3. DF11-DF3, separation
■Effective harness length
100 to 2,000mm
■Continuity Inspection Mechanism Equipped
■Used for DF11 only, No restricted condition
Remarks
The connector is applicable to
(25) tube packaging.
Desktop machine for small lot
B223
■Crimping Socket
Blank :100 pcs. per pack
Photo: Contact insertion status
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
Part Number
CL No.
Number of Contacts
A
B
DF11- 4DS-2C(**)
543-0568-6-**
4
6.0
DF11- 6DS-2C(**)
543-0502-8-**
6
8.0
2.0
DF11-20DS-2C(**)
543-0509-7-**
18.0
4.0
DF11-22DS-2C(**)
543-0510-6-**
22
24.0
20.0
DF11- 8DS-2C(**)
543-0503-0-**
8
DF11-10DS-2C(**)
543-0504-3-**
10
10.0
6.0
DF11-24DS-2C(**)
543-0511-9-**
24
26.0
22.0
12.0
8.0
DF11-26DS-2C(**)
543-0512-1-**
26
28.0
24.0
DF11-12DS-2C(**)
543-0505-6-**
DF11-14DS-2C(**)
543-0506-9-**
12
14.0
10.0
DF11-28DS-2C(**)
543-0513-4-**
28
30.0
26.0
14
16.0
12.0
DF11-30DS-2C(**)
543-0514-7-**
30
32.0
28.0
DF11-16DS-2C(**)
543-0507-1-**
16
18.0
14.0
DF11-32DS-2C(**)
543-0515-0-**
32
34.0
30.0
RoHS
YES
RoHS
YES
18
20.0 16.0
DF11-18DS-2C(**) 543-0508-4-**
Note: Delivered per bag unit (100 pcs.). Please order products bag pack unit.
■Receptacle (DIP)
(05) :Tin plated 100 pcs. per pack
(06) :Gold plated 100 pcs. per pack
●Board Through-hole Diameter: Ø0.8++0.1
●Kink Prefixed Effective Diameter: Ø0.8++0.05
Unit: mm
Part Number
B224
CL No.
Number of Contacts
A
B
RoHS
Part Number
CL No.
Number of Contacts
A
B
DF11- 6DS-2DSA(**) 543-0553-9-**
6
8.0
4.0
DF11-20DS-2DSA(**) 543-0560-4-**
18.0
DF11- 8DS-2DSA(**) 543-0554-1-**
8
10.0
6.0
DF11-22DS-2DSA(**) 543-0561-7-**
22
24.0
20.0
DF11-10DS-2DSA(**) 543-0555-4-**
10
12.0
8.0
DF11-24DS-2DSA(**) 543-0562-0-**
24
26.0
22.0
DF11-12DS-2DSA(**) 543-0556-7-**
12
14.0
10.0
DF11-26DS-2DSA(**) 543-0563-2-**
26
28.0
24.0
DF11-14DS-2DSA(**) 543-0557-0-**
14
16.0
12.0
DF11-28DS-2DSA(**) 543-0564-5-**
28
30.0
26.0
DF11-16DS-2DSA(**) 543-0558-2-**
16
18.0
14.0
DF11-30DS-2DSA(**) 543-0565-8-**
30
32.0
28.0
18
20.0 16.0
DF11-18DS-2DSA(**) 543-0559-5-**
DF11-32DS-2DSA(**) 543-0566-0-**
Note: Delivered per bag unit (100 pcs.). Please order products per bag unit.
32
34.0
30.0
YES
RoHS
YES
■Receptacle (SMT)
(22) :Tin plated embossed tape packaging
(with vacuum pick-up cap)
(52) :Gold plated embossed tape packaging
Unit: mm
Part Number
CL No.
Number of Contacts
A
DF11CZ- 4DS-2V(**)
CL543-2063-0-**
4
2.0
8.5
8.7
DF11CZ- 6DS-2V(**)
CL543-2064-3-**
6
4.0
10.5
10.7
DF11CZ- 8DS-2V(**)
CL543-2065-6-**
8
6.0
12.5
12.7
DF11CZ-10DS-2V(**)
CL543-2066-9-**
10
8.0
14.5
14.7
DF11CZ-18DS-2V(**)
CL543-2070-6-**
18
16.0
22.5
22.7
DF11CZ-20DS-2V(**)
CL543-2071-9-**
24.5
24.7
DF11CZ-22DS-2V(**)
CL543-2072-1-**
22
20.0
26.5
26.7
DF11CZ-26DS-2V(**)
CL543-2074-7-**
26
24.0
30.5
30.7
DF11CZ-30DS-2V(**)
CL543-2076-2-**
30
28.0
34.5
34.7
B
C
RoHS
YES
40
38.0 44.5 44.7
DF11CZ-40DS-2V(**) CL543-0584-2-**
Note1: Tape and reel packaging(500 pieces/reel). Order by number of reels.
Note2: The 40 contacts connector is marchandized only in combination with the SMT product.
Note3: Embossed packaging products have the reel wrapped in polyethylene and include a desiccant.
BPCB mounting pattern
Note:If the pattern is included in the shaded area and
not treated with resist, it could touch the
connector contact .
B225
■Straight Pin Header
(01)
: Gold plated
(08)
: Tin plated
(24)
: Tin plated tube package product
Unit: mm
Part Number
CL No.
Number of
Contacts
Tube Package
RoHS
Quantity
Part Number
CL No.
Number of
B
6.0
2.0
81pcs.
DF11-20DP-2DSA(**) 543-0525-3-**
18.0 22pcs.
Contacts
A
B
Tube Package
RoHS
Quantity
A
DF11- 4DP-2DSA(**) 543-0517-5-**
4
DF11- 6DP-2DSA(**) 543-0518-8-**
6
8.0
4.0
61
DF11-22DP-2DSA(**) 543-0526-6-**
22
24.0
20.0 20
DF11- 8DP-2DSA(**) 543-0519-0-**
8
10.0
6.0
49
DF11-24DP-2DSA(**) 543-0527-9-**
24
26.0
22.0 18
DF11-10DP-2DSA(**) 543-0520-0-**
10
12.0
8.0
40
DF11-26DP-2DSA(**) 543-0528-1-**
26
28.0
24.0 17
DF11-12DP-2DSA(**) 543-0521-2-**
12
14.0
10.0 34
DF11-28DP-2DSA(**) 543-0529-4-**
28
30.0
26.0 16
DF11-14DP-2DSA(**) 543-0522-5-**
14
16.0
12.0 30
DF11-30DP-2DSA(**) 543-0530-3-**
30
32.0
28.0 15
DF11-16DP-2DSA(**) 543-0523-8-**
16
18.0
14.0 27
DF11-32DP-2DSA(**) 543-0531-6-**
32
34.0
30.0 14
YES
YES
18
20.0 16.0 24
DF11-18DP-2DSA(**) 543-0524-0-**
Note1: Specific No. (01) and (08) items are delivered per bag unit (100 pcs.). Please order products per bagunit.
Note2: Please order the tube packaging products, by mutiplying a tube quantity( pcs.).
■Right Angle Pin Header
(24)
: Tin plated tube packaging product
(52)
: Gold plated tube packaging product
Unit: mm
Part Number
CL No.
Number of
Contacts
DF11- 4DP-2DS(**) 543-0533-1-**
4
Tube Package
RoHS
Quantity
Part Number
B
6.0
2.0
81pcs.
DF11-20DP-2DS(**) 543-0541-0-**
18.0 22pcs.
Contacts
A
B
Tube Package
RoHS
Quantity
A
DF11- 6DP-2DS(**) 543-0534-4-**
6
8.0
4.0
61
DF11-22DP-2DS(**) 543-0542-2-**
22
24.0
20.0 20
DF11- 8DP-2DS(**) 543-0535-7-**
8
10.0
6.0
48
DF11-24DP-2DS(**) 543-0543-5-**
24
26.0
22.0 18
DF11-10DP-2DS(**) 543-0536-0-**
10
12.0
8.0
40
DF11-26DP-2DS(**) 543-0544-8-**
26
28.0
24.0 17
DF11-12DP-2DS(**) 543-0537-2-**
12
14.0
10.0 34
DF11-28DP-2DS(**) 543-0545-0-**
28
30.0
26.0 16
DF11-14DP-2DS(**) 543-0538-5-**
14
16.0
12.0 30
DF11-30DP-2DS(**) 543-0546-3-**
30
32.0
28.0 15
DF11-16DP-2DS(**) 543-0539-8-**
16
18.0
14.0 27
DF11-32DP-2DS(**) 543-0547-6-**
32
34.0
30.0 14
YES
18
20.0 16.0 24
DF11-18DP-2DS(**) 543-0540-7-**
Note1: Please order the tube packaging product by mutiplying a tube quantity( pcs.).
B226
CL No.
Number of
YES
■Straight Pin Header (SMT)
2
No.1
1.5
B
(27) :Tin plated embossed tape packaging
(57) :Gold plated embossed tape packaging
1.5
A
Ø0
.5
No.2
2
6.2
0.65
1.5
A
P=2
2.25
7.2
1.5
Unit: mm
Tin plated
Gold plated
Part Number
CL Numer
Part Number
CL Numer
Number of contacts
A
B
C
DF11CZ- 4DP-2V(27)
0543-2047-4-27
DF11C- 4DP-2V(57)
0543-0682-1-57
4
2.0
8.5
8.7
DF11CZ- 6DP-2V(27)
0543-2048-7-27
DF11C- 6DP-2V(57)
0543-0683-4-57
6
4.0
10.5
10.7
DF11CZ- 8DP-2V(27)
0543-2049-0-27
DF11C- 8DP-2V(57)
0543-0684-7-57
8
6.0
12.5
12.7
DF11CZ-10DP-2V(27)
0543-2050-9-27
DF11C-10DP-2V(57)
0543-0685-0-57
10
8.0
14.5
14.7
DF11CZ-12DP-2V(27)
0543-2051-1-27
DF11C-12DP-2V(57)
0543-0686-2-57
12
10.0
16.5
16.7
DF11CZ-14DP-2V(27)
0543-2052-4-27
DF11C-14DP-2V(57)
0543-0687-5-57
14
12.0
18.5
18.7
DF11CZ-16DP-2V(27)
0543-2053-7-27
DF11C-16DP-2V(57)
0543-0688-8-57
16
14.0
20.5
20.7
DF11CZ-18DP-2V(27)
0543-2054-0-27
DF11C-18DP-2V(57)
0543-0689-0-57
18
16.0
22.5
22.7
DF11CZ-20DP-2V(27)
0543-2055-2-27
DF11C-20DP-2V(57)
0543-0690-0-57
24.5
24.7
DF11CZ-22DP-2V(27)
0543-2056-5-27
DF11C-22DP-2V(57)
0543-0691-2-57
22
20.0
26.5
26.7
DF11CZ-24DP-2V(27)
0543-2057-8-27
DF11C-24DP-2V(57)
0543-0692-5-57
24
22.0
28.5
28.7
DF11CZ-26DP-2V(27)
0543-2058-0-27
DF11C-26DP-2V(57)
0543-0693-8-57
26
24.0
30.5
30.7
DF11CZ-28DP-2V(27)
0543-2059-3-27
DF11C-28DP-2V(57)
0543-0694-0-57
28
26.0
32.5
32.7
DF11CZ-30DP-2V(27)
0543-2060-2-27
DF11C-30DP-2V(57)
0543-0695-3-57
30
28.0
34.5
34.7
DF11CZ-32DP-2V(27)
0543-2061-5-27
DF11C-32DP-2V(57)
0543-0696-6-57
32
30.0
36.5
36.7
0543-0697-9-57
40
38.0
DF11CZ-40DP-2V(27)
0543-2062-8-27
DF11C-40DP-2V(57)
Note2: The 40 contacts connector is merchandized in combination with the SMT product.
44.5
44.7
RoHS
YES
Note2
not treated with resist, it could contact to the
connector contact .
B227
■In-line Plug
BIn-line Plug Panel Cutouts
Note1: Please use the non-radius side for the panel hooking area.
Note2: Applicable panel thicknessing is 1.6 to 1.0mm (A slight deviation will occur for the thickness except for 1.6 and 1.2mm.)
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
C
D
E
F
DF11- 4DEP-2C
543-0619-5
4
11.0
9.2
6.0
2.0
9.4
6.3
DF11- 6DEP-2C
543-0620-4
6
13.0
11.2
8.0
4.0
11.4
8.3
DF11- 8DEP-2C
543-0621-7
8
15.0
13.2
10.0
6.0
13.4
10.3
DF11-10DEP-2C
543-0622-0
10
17.0
15.2
12.0
8.0
15.4
12.3
DF11-12DEP-2C
543-0623-2
12
19.0
17.2
14.0
10.0
17.4
14.3
DF11-14DEP-2C
543-0624-5
14
21.0
19.2
16.0
12.0
19.4
16.3
DF11-16DEP-2C
543-0625-8
16
23.0
21.2
18.0
14.0
21.4
18.3
DF11-18DEP-2C
543-0626-0
18
25.0
23.2
20.0
16.0
23.4
20.3
DF11-20DEP-2C
543-0627-3
25.2
22.0
18.0
25.4
22.3
DF11-22DEP-2C
543-0628-6
22
29.0
27.2
24.0
20.0
27.4
24.3
DF11-24DEP-2C
543-0629-9
24
31.0
29.2
26.0
22.0
29.4
26.3
DF11-26DEP-2C
543-0630-8
26
33.0
31.2
28.0
24.0
31.4
28.3
DF11-28DEP-2C
543-0631-0
28
35.0
33.2
30.0
26.0
33.4
30.3
DF11-30DEP-2C
543-0632-3
30
37.0
35.2
32.0
28.0
35.4
32.3
DF11-32DEP-2C
543-0633-6
32
39.0
37.2
34.0
30.0
37.4
34.3
Note1: Delivered per bag unit (100 pcs.). Please order products per bag unit.
B228
RoHS
YES
■In-line Adaptor
BIn-line Adaptor Panel Cutouts
Note1: Please use the non-radius surface in the panel hooking area.
Note2: Applicable panel thickness is 1.6 to 1.0mm (A slight backlash will occur in the thickness other than 1.6 and 1.2mm.)
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
C
D
E
F
DF11- 4DEP-2A
543-0698-1
4
11.0
9.2
6.0
2.0
9.4
6.3
DF11- 6DEP-2A
543-0699-4
6
13.0
11.2
8.0
4.0
11.4
8.3
DF11- 8DEP-2A
543-0700-1
8
15.0
13.2
10.0
6.0
13.4
10.3
DF11-10DEP-2A
543-0701-4
10
17.0
15.2
12.0
8.0
15.4
12.3
DF11-12DEP-2A
543-0702-7
12
19.0
17.2
14.0
10.0
17.4
14.3
DF11-14DEP-2A
543-0703-0
14
21.0
19.2
16.0
12.0
19.4
16.3
DF11-16DEP-2A
543-0704-2
16
23.0
21.2
18.0
14.0
21.4
18.3
DF11-18DEP-2A
543-0705-5
18
25.0
23.2
20.0
16.0
23.4
20.3
DF11-20DEP-2A
543-0706-8
25.2
22.0
18.0
25.4
22.3
DF11-22DEP-2A
543-0707-0
22
29.0
27.2
24.0
20.0
27.4
24.3
DF11-24DEP-2A
543-0708-3
24
31.0
29.2
26.0
22.0
29.4
26.3
DF11-26DEP-2A
543-0709-6
26
33.0
31.2
28.0
24.0
31.4
28.3
DF11-28DEP-2A
543-0710-5
28
35.0
33.2
30.0
26.0
33.4
30.3
DF11-30DEP-2A
543-0711-8
30
37.0
35.2
32.0
28.0
35.4
32.3
DF11-32DEP-2A
543-0712-0
32
39.0
37.2
34.0
30.0
37.4
34.3
RoHS
YES
B229
■Crimping Contact for Socket
Type
Part Number
CL No.
Quantity
Finish RoHS
DF11-22SCF
543-0601-0
Reel contact
10000 pcs.
per reel
DF11-22SC
543-0602-2
Bulk contact
100 pcs.
per bag
DF11-2428SCF
543-0500-2
Reel contact
10000 pcs.
per reel
DF11-2428SC
543-0501-5
Bulk contact
100 pcs.
per bag
Tin plated
DF11A-2428SCF
543-0634-9
Reel contact
10000 pcs.
per reel
DF11A-2428SC
543-0635-1
Bulk contact
100 pcs.
per bag
DF11-30SCF
543-0605-0
Reel contact
10000 pcs.
per reel
YES
DF11-30SC
543-0606-3
Bulk contact
100 pcs.
per bag
543-0603-5-04 Reel contact
DF11-22SCFA(04)
10000 pcs.
per reel
DF11-22SCA
543-0604-8
Bulk contact
100 pcs.
per bag
DF11-2428SCFA(04) 543-0550-0-04 Reel contact
10000 pcs.
per reel
Gold plated
DF11-2428SCA
543-0551-3
Bulk contact
100 pcs.
per bag
DF11-30SCFA(04)
543-0607-6-04 Reel contact
10000 pcs.
per reel
DF11-30SCA
543-0608-9
Bulk contact
100 pcs.
per bag
Note1: DF11A-2428SCF/SC is of tin plated low insertion/extraction type.
●Applicable Wire (Tin Plated Annealed
Copper Wire)
●Recommended Wire
UL1061, UL1007 (Note 2.)
●Strip Length
Conductor Size (Wire Structure)
Jacket Diameter
Ø1.2 to Ø1.45mm
AWG 22 (17pcs./0.16mm)
1.7 to 2.3mm
AWG 24 (11pcs./0.16mm)
Ø0.9 to Ø1.45mm
AWG 26 (7pcs./0.16mm)
AWG 28 (7pcs./0.127mm)
Ø0.75 to Ø1.2mm
AWG 30 (7pcs./0.1mm)
Note1: If other wires are used than the applicable wire, consult the HRS sales department.
Note2: DF11-22SCF/SC/SCFA/SCA is for UL1061.
■Crimping Contact for In-line Plug
Part Number
DF11EP2428PCF
DF11EP2428PC
DF11EP2428PCFA
DF11-EP2428PCA
CL No.
543-0615-4
543-0616-7
543-0617-0
543-0618-2
Type
Reel contact
Bulk contact
Reel contact
Bulk contact
Quantity
Finish
RoHS
10000 pcs. per reel
Tin plated
100 pcs.
per bag
YES
10000 pcs. per reel
Gold plated
100 pcs.
per bag
Copper Wire)
●Recommended Wire
UL1061, UL1007
●Strip Length
Conductor Size (Contact Wire Structure) Jacket Diameter
1.9 to 2.3mm
Ø0.9 to Ø1.45mm
BApplicable Crimping Tool
Type
CL No.
Applicable Contact
901-4529-7 DF11A-22SCF/SCFA(04)
DF11A-2428SCF/SCFA(04)
AP105-DF11-2428S
901-4511-1
DF11A-2428SCF
Applicator
AP105-DF11-30S
901-4532-1 DF11A-30SCF/SCFA(04)
AP105-DF11-EP2428P 901-4528-4 DF11A-EP2428PCF/PCFA
Press Unit
CM-105
901-0005-4 –––––––––––––––––––
DF11-TA22HC
550-0228-6 DF11A-22SC/SCA
DF11A-2428SC/SCA
DF11-TA2428HC
550-0197-4
DF11A-2428SC
Hand Crimping Tool
DF11-TA30HC
550-0230-8 DF11A-30SC/SCA
DF11EP-TA2428HC
550-0227-3 DF11A-EP2428PC/PCA
DF11A-****SCF
Extraction Tool
DF-C-PO(B)
550-0179-2
DF11A-EP****PCF
Note: If any trouble has occurred due to tools other than the designated tool, Hirose bears
no respoisibility for any trouble.
B230
Part Number
AP105-DF11-22S
BApplication Pattern
DF11-πDS-2R**(05)
DF11-πDS-2R**(05)
DF11#Z-πDP-2V
DF11-πDS-2R**(05)
DF11-πDS-2R**(05)
DF11#Z-πDP-2V
DF11-πDS-2DSA(05)
DF11#Z-*DS-2V
DF11-πDS-2DSA(05)
DF11#Z-πDP-2V
DF11Z-πDS-2V
DF11-πDS-2DSA(05)
DF11Z-πDS-2V
B231
BEmbossed Carrier tape Dimensions
E-E
●Header (SMT)
.5
2±0.15
16±0.1
4±0.1
1.75±0.1
Ø1
9.4±0.3
E
7.8±0.3
0.4±0.1
(8)
2±0.5
A±0.3
.8
(Ø80)
Ø370±2
Ø21±0
A
A
B±0.1
Ø1.5 Lead hole depth
1.7 +0.15
R0
.7
5
D+20
(D+6)MAX
E
Unreeling direction
1.5 +0.1
Unit: mm
A
24.0
32.0
44.0
56.0
72.0
04~80
10~12
14~22
24~32
004000
2 ±0.1
16±0.1
4 ±0.1
1
0.
+ 0
.5
E
( 5.5 )
A
A
C±0.1
Contact NO.1
Reel Dimensions
E-E
2±0.5
.8
Ø21±0
Ø370±2
( Ø80 )
●Receptacle (SMT)
D
24.4
32.4
44.4
56.4
72.4
Ø1
DF11C-**DP-2V(57)
C
11.5
14.2
20.2
26.2
34.2
B±0.1
A±0.3
DF11CZ-**DP-2V(27)
B
----------------28.4
40.4
52.4
68.4
0.2
Number of Contacts
3±
Size
1.75±0.1
Product Type
Ø1
( 5.8)
Ø1
3±
0.2
C±0.1
Reel Dimensions
.75
R0
( 5)
D+20
1.7 +0.15
(D+6) MAX
0.4±0.1
E
Unreeling direction
1.5 +0.1
6.6±0.3
8.4±0.3
Unit: mm
Product Type
Size
DF11CZ-**DS-2V
B232
Number of Contacts
04~80
10~12
14~18
002000
002200
24~32
004000
A
24.0
32.0
44.0
56.0
44.0
56.0
72.0
B
40.4
52.4
40.4
52.4
68.4
C
11.5
14.2
20.2
26.2
20.2
26.2
34.2
D
24.4
32.4
44.4
56.4
44.4
56.4
72.4
BPrecautions
1. Recommended Temperature Profile (SMT)
Temperature (ç)
10s max
250
230
200
180±10
60s max
150
100 to 120s
100
Powered by TCPDF (www.tcpdf.org)
Time (S)
Note1: UP to 2 cycles of Reflow soldering are possible under the same conditions, provided that
there is a return to normal temperature between the first and second cycle
Note2: The temperature profile indicates the board surface temperature at the point of contacts
with the connector terminals.
Note3: This reflow profile is for the connectors packaged in embossed tape(reel), with desiccant in
the package.
Temperature (ç)
10s max
240
230
200
165±5
60s max
150
90 to 120s
100
Time (S)
Note4: Reflow temperature for SMT connectors in another package is 240ç, 10 sec.max.
2. Recommended Manual Soldering Condition (SMT) Soldering iron temperature: 290±10ç, Soldering time: Within 2 seconds
3. Recommended Screen Thickness (SMT) 0.15 to 0.2mm
4. Board Warp age (SMT)
5. Recommended Soldering Condition(Through hole)
Based on the both connector edges, 0.03mm max. is allowed in the connector center area.
Flow: 250ç for 10 seconds
Manual soldering: 290ç for 2 seconds
6. Cleaning Condition
Refer to the "Nylon Connector Use Hand book".
7. Connection Condition
B233
