PS10U100S
PS10U100S
    PINGWEI(平伟)
    PS10U100S
PS10U100S 数据手册
PS10U100S&PS10U100FS PS10U100S&PS10U100FS 10.0AMPS. SCHOTTKY BARRIER RECTIFIERS FEATURE .High current capability .Ultra low forward voltage drop .Low power loss, high efficiency .High surge capability .High temperature soldering guaranteed 260°C /10seconds, 0.25"(6.35mm)from case. TO-220AB PS10U100S ITO-220AB PS10U100FS MECHANICAL DATA .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Mounting position: any Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% MAXIMUM RATINGS (TC=25℃ unless otherwise noted) Parameter Symbol PS10U100S&PS10U100FS Units Maximum Recurrent Peak Reverse Voltage VRRM VRMS VDC 100 V 70 V 100 V Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current at TC =100°C Per Leg Total device Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Operation Junction Temperature and Storage Temperature A 10.0 IFSM 120.0 A CJ TJ, TSTG 460 pF -55 to +150 °C Per Leg Typical Junction Capacitance (Note 1) 5.0 IF(AV) Maximum Mounting torque, M3 or 6-32 srew 1.1N•m (10 lbf•in) ELECTRICAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Maximum Forward Voltage (Per Leg) Symbol at 5A DC VF at 10.0A DC Maximum DC Reverse Current at rated DC blocking voltage @TA =25°C IR @TA =100°C Typ Max 0.54 ---- 0.65 0.70 ---- 0.10 ---- 10.0 Units V mA THERMAL CHARACTERISTICS (TC=25℃ unless otherwise noted) Parameter Symbol PS10U100S PS10U100FS Units Typical Thermal Resistance (Note 2) R(JC) 2.0 3.0 °C /W Notes: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Thermal Resistance from Junction to Case 1 PS10U100S&PS10U100FS RATINGANDCHARACTERISTIC CURVES FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10.0 INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 100 5.0 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 10 1 .1 200 TJ=25℃ Pulse Width=300μs 1% Duty Cycle CASE TEMPERTURE,(℃) 0.5 .3 .1 0.7 0.9 INSTANEOUS FORWARD VOLTAGE,(V) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 160 8.3ms Single Half Sine-Wave (JEDEC Method) 120 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 10 80 40 0 1.0 TJ=25℃ 0.1 .01 1 10 100 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz 2 140 PS10U100S&PS10U100FS PACKAGE OUTLINE DIMENSIONS TO-220AB L I Dim A C B H G C D A E F PIN 1 2 G 3 H I D J E K J F L P TO-220AB Min Max .573(14.55) .603(15.32) ―― .412(10.5) .103(2.62) .113(2.87) .140(3.56) .160(4.06) .510(13.0) .560(14.3) .027(0.68) .037(0.94) .148(3.74) .154(3.91) .230(5.84) .270(6.86) .175(4.44) .185(4.86) .100(2.54) .110(2.79) .014(0.35) .025(0.64) .045(1.14) .055(1.40) .095(2.41) .105(2.67) Dimensions in inches and (millimeters) ITO-220AB B L G I C H A PIN 1 2 D 3 E J F P ITO-220AB Min Max A .571(14.5) .610(15.5) B .383(9.72) .406(10.3) C .110(2.80) .126(3.20) D .133(3.38) .162(4.10) E .512(13.0) .551(14.0) F .028(0.70) .035(0.90) G .114(2.90) .138(3.50) H .268(6.80) .291(7.40) I .162(4.10) .185(4.70) J .102(2.60) .110(2.80) K .018(0.45) .026(0.65) L .097(2.46) .113(2.86) P .890(2.25) .113(2.85) Dim K Dimensions in inches and (millimeters) 3
PS10U100S 价格&库存
很抱歉,暂时无法提供与“PS10U100S”相匹配的价格&库存,您可以联系我们找货
