MVK50VC100M10*10_10TP
    SAMYOUNG(韩国三莹)
    SMD_D10X10MM
MVK50VC100M10*10_10TP 数据手册
삼영내지42-54 02.13 페이지45 2012.10.10 6:33 PM mac2 EAGLERIP/F9000-1130-175-CMYK SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS BDS(MVK) Series 쪾105℃ 1,000~2,000Hrs assured. Solventproof 쪾Vertical SMD type. 쪾Wide Temperature range. 쪾For CD/DVD-ROM, Navigation, LCD MT/TV 쪾RoHS compliant. MV 쪾Halogen-free capacitors are also available. WV 쬩 63V DC BDS (MVK) Wide Temp. SPECIFICATIONS Item Rated Voltage Range Operating Temperature Range Capacitance Tolerance Characteristics 6.3 ~ 450 V DC -40 ~ +105 20%(M) 6.3~100 0.01CV ( ) or 3 , whichever is greater. (at 20 , 2 minutes) ± Rated Voltage(V ) ㎂ ㎂ Max. Leakage current(㎂) ℃ Where, C:Nominal capacitance(㎌), DC Leakage Current Dissipation Factor Rated voltage(VDC) δ Tan (Max.) Temperature Characteristics (Max. Impedance ratio) 6.3 0.30 0.40 Ø4~Ø6.3 Ø8~Ø18 Rated voltage(VDC) Z(-25 )/Z(+20 ) Z(-40 )/Z(+20 ) 6.3 4 10 ℃ ℃ ㎂ V:Rated voltage(VDC) 10 0.24 0.30 16 0.20 0.26 25 0.16 0.16 35 0.14 0.14 10 3 8 16 2 6 25 2 4 35 2 3 50~100 160~250 400~450 0.12 0.12 0.15 0.20 (at 20 , at 120Hz) ℃ 50~100 160~250 400~450 3 3 6 4 6 10 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20 after the rated voltage is applied with the following conditions. ℃ ℃ ℃ ØØ ØØ ℃ Ø Ø ℃ 쬩쬩 ±± 쬩쬩쬩 BDS(MVK) Ø Ø ØØ δ ØØ ℃ ℃ 4~ 6.3:105 , 1,000 hours, 8~ 18:105 , 2,000 hours. Capacitance change 4~ 6.3 30% of the initial value 8~ 18 20% of the initial value Tan 4~ 6.3 300% of the initial specified value 8~ 18 200% of the initial specified value Leakage current The initial specified value Load Life ℃ (at 20 , 120Hz) 160~450 0.04CV+100( ) (at 20 , 1 minute) ℃ The following specifications shall be satisfied when the capacitors are restored to 20 after exposing them for the specified time at 105 without voltage applied. The rated voltage shall be applied to the capacitors for a minimum of 30 minutes, at least 24 hours and not more than 48 hours before the measurements. 4~ 6.3:105 , 500 hours, 8~ 18:105 , 1,000 hours. Capacitance change 4~ 6.3 25% of the initial value 8~ 18 20% of the initial value Tan 200% of the initial specified value Leakage current The initial specified value 쬩쬩 ±± 쬩쬩 Ø Ø ℃ Series Ø Ø ℃ ØØ ØØ δ Shelf Life ℃ Satisfied characteristics KS C IEC 60384-4 Others PART NUMBERING SYSTEM BDS 50 VC R47 M D55 TP With tape Capacitance Case code 0.1 F ± Capacitance tolerance( 20%) Nominal capacitance code Lead type Rated voltage in volts Series name μ 0.47μF 1.0μF 4.7μF 10μF 100μF Code R1 R47 1 4R7 10 100 45 삼영내지42-54 02.13 2012.9.14 10:28 PM 페이지46 mac2 EAGLERIP/F9000-1130-175-CMYK SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS DIMENSIONS OF BDS(MVK) Series(Type:VC) DIMENSIONS Unit(mm) MARKING ●Vibration Resistance ± × × × Note 1 : L 0.5 for 8 6.3(H63) ~ 18 21.5(M22) Note 2 : 4 5.2(D55), 5 5.2(E55) is excluded symbol mark Note 3 : 6.3WV is marked by 6V : Dummy terminals Recommended Solder land on PC board : Solder land on PC board Case code D55 E55 F55 F60 F80 H63 H10 J10 K14 L17 L22 M17 M22 ØD 4 5 6.3 6.3 6.3 8 8 10 12.5 16 16 18 18 L 5.2 5.2 5.2 5.7 7.7 6.3 10 10 13.5 16.5 21.5 16.5 21.5 × A 4.3 5.3 6.6 6.6 6.6 8.3 8.3 10.3 13.0 17.0 17.0 19.0 19.0 B 4.3 5.3 6.6 6.6 6.6 8.3 8.3 10.3 13.0 17.0 17.0 19.0 19.0 C 5.1 5.9 7.2 7.2 7.2 9.0 9.0 11.0 13.7 18.0 18.0 20.0 20.0 W 0.5-0.8 0.5-0.8 0.5-0.8 0.5-0.8 0.5-0.8 0.5-0.8 0.7-1.1 0.7-1.1 1.0-1.3 1.0-1.3 1.0-1.3 1.0-1.3 1.0-1.3 P 1.0 1.4 1.9 1.9 1.9 2.3 3.1 4.5 4.2 6.5 6.5 6.5 6.5 a 1.0 1.4 1.9 1.9 1.9 2.3 3.1 4.5 4.0 6.0 6.0 6.0 6.0 b 2.6 3.0 3.5 3.5 3.5 4.5 4.2 4.4 5.7 6.9 6.9 7.9 7.9 ●Vibration Resistance c 1.6 1.6 1.6 1.6 1.6 1.6 2.2 2.2 2.5 2.5 2.5 2.5 2.5 a b c 3.1 4.2 3.5 4.5 4.4 3.5 3.4 6.3 9.3 4.7 7.8 9.6 4.7 8.8 9.6 ▲ RATINGS OF BDS(MVK) Series μF VDC 10 16 25 6.3 0.1 0.22 0.33 0.47 1 2.2 3.3 4.7 D55 16 E55 25 10 D55 21 E55 30 E55 30 F55 40 22 E55 34 E55 34 F55 45 F55 45 33 E55 36 F55 48 F55 48 F60 H63 52 80 47 56 F60 H63 90 F60 H10 110 180 F80 H63 135 100 F55 F60 H63 150 F80 H63 150 F80 H10 150 275 H10 275 220 450 J10 450 J10 450 330 F80 H10 127 290 J10 J10 460 J10 460 J10 460 J10 460 470 J10 520 J10 540 K14 550 K14 550 1,000 J10 550 K14 620 1,500 K14 680 L17 850 M17 1,000 M22 1,300 2,200 M17 1,000 M17 1,100 M17 1,200 3,300 L22 1,200 M22 1,350 4,700 6,800 M22 1,350 μF V DC 3.3 4.7 10 22 33 47 68 100 200 160 J10 K14 K14 L17 M17 L22 45 85 95 260 320 380 K14 K14 L17 M17 M22 250 80 85 220 270 330 K14 L17 L17 M17 M22 65 100 180 230 280 ℃ K14 L17 L17 M22 50 D55 E55 F55 H63 H63 H10 J10 K14 K14 L17 15 25 40 80 140 250 375 480 520 750 M22 1,450 400 Rated Ripple Current(mArms/105 , 120Hz) Case code 46 35 450 30 60 85 130 K14 L17 L17 M22 40 60 85 130 D55 D55 D55 D55 D55 D55 D55 E55 F55 H63 H10 H10 J10 K14 K14 L17 M22 63 1.3 2.6 3.2 3.8 5.6 10 14 19 29 70 140 170 310 420 500 700 1,200 D55 D55 D55 D55 D55 D55 E55 E55 F60 H10 H10 H10 K14 K14 L17 M17 100 1.3 3.0 4.0 5.0 8.0 12 17 20 32 80 145 180 380 470 700 900 H63 H10 J10 K14 K14 M17 M22 48 90 150 250 380 750 980
MVK50VC100M10*10_10TP 价格&库存
很抱歉,暂时无法提供与“MVK50VC100M10*10_10TP”相匹配的价格&库存,您可以联系我们找货
