Preliminary Datasheet
LPW5206
USB Power Loading Switch
General Description
Features
The LPW5206 is an integrated power switch for
160mΩ Low RDS(ON), High-side N-MOSFET
self-powered and bus-powered Universal Series Bus
Guaranteed 600mA Continuous Current
(USB) applications. A built-in charge pump is used to
2.5V to 6V Input Voltage
Low Quiescent Current:16μA
Soft Start Function
quiescent current (16μA) and small package (SOT23-5)
Built-In Short-Circuit Protection
is particularly suitable in battery-powered portable
Built-In Thermal Protection
equipment.
RoHS Compliant and 100% Lead(Pb)-Free
drive the N-Channel MOSFET that is free of parasitic
body diode to eliminate any reversed current flow
across the switch when it is powered off. Its low
Several protection functions include soft start to limit
inrush current during plug-in, current limiting at 600mA
to meet USB power requirement, and thermal
Typical Application Circuit
shutdown to protect damage under over current
conditions.
VIN
LPW5206
5
Cin
10uF
Order Information
LPW5206 □ □
4
VIN
EN
VOUT
VOUT
GND
NC
1
3
Cout
10uF
2
F: Pb-Free
Package Type
B5: SOT23-5
Marking Information
Device
Marking
Package
LPW5206B5F
LPS
SOT23-5
Applications
4WYWX
Y: Year code. W: Weeks code. X: Series number code.
Power Switch
USB Device
Battery Charger Circuits
LPW5206-09
Shipping
Feb.-2014
Email: marketing@lowpowersemi.com
www.lowpowersemi.com
Page 1 of 4
LPW5206
Functional Pin Description
Package Type
Pin Configurations
Top View
VOUT
1
GND
2
NC
3
5
VIN
4
EN
SOT23-5
Pin Description
Pin
Name
Description
1
VOUT
Output to system pin.
2
GND
Ground.
3
NC
No connector.
4
EN
Device Enable (active High).
5
VIN
Input pin.
Function Block Diagram
LPW5206-09
Feb.-2014
Page 2 of 4
LPW5206
Absolute Maximum Ratings Note 1
Input Voltage to GND --------------------------------------------------------------------------------------------------- 6.5V
Output Voltage to GND ------------------------------------------------------------------------------------------------ 6.5V
Other pin to GND ---------------------------------------------------------------------------------------------------------- 6V
Maximum Junction Temperature --------------------------------------------------------------------------------- 150°C
Operating Ambient Temperature Range (TA) -------------------------------------------------------- -40℃ to 85°C
Maximum Soldering Temperature (at leads, 10 sec) -------------------------------------------------------
Note 1.
260°C
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress
ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational
sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect
device reliability.
Thermal Information
Maximum Power Dissipation (PD) -------------------------------------------------------------------------------- 0.45W
Thermal Resistance (θJA) ---------------------------------------------------------------------------------------- 250℃/W
ESD Susceptibility
HBM(Human Body Mode) --------------------------------------------------------------------------------------------- 2KV
MM(Machine Mode) --------------------------------------------------------------------------------------------------- 200V
Electrical Characteristics
(Over recommended operating conditions unless specified otherwise) VIN=5.0V, EN=High, TA=25℃ )
Symbol
Parameter
VIN
Input Voltage
IOUT
Output Current Limited
600
mA
RDS(ON)
Output N-MOSFET RDS(ON)
160
mΩ
IQ
Quiescent Current
VIN=3V
ISHDN
Shutdown Current
VEN=GND
VEN(L)
Enable Threshold Low
VEN(H)
Enable Threshold High
IEN
Input High Current
LPW5206-09
Feb.-2014
Condition
Min
Typ
2.5
16
1.4
VIN=VEN=5.0V
Max
Units
6
V
28
µA
1
µA
0.4
V
V
5
µA
Page 3 of 4
LPW5206
Packaging Information
SOT23-5
LPW5206-09
Feb.-2014
Page 4 of 4
很抱歉,暂时无法提供与“LPW5206B5F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.70363
- 50+0.56631
- 150+0.49766
- 500+0.44617
- 3000+0.40497
