UMW
R
UMW LTV816
● 特点(Features):
1. 电流转换比(CTR: 最小. 50% 工作条件 IF=5mA, VCE=5V)
Current conversion ratio (Min 50% Working condition IF=5mA, VCE=5V)
2. 绝缘电压:(VISO=5,000Vrms) Insulation Voltage = 5,000Vrms,
3. 响应时间 (tr: TYP. 4μs;tf: TYP. 5μs)工作条件 VCE=2V, IC=2mA, RL=100 Ω)
Response Time (tr: TYP. 4μs;tf: TYP. 5μs)working condition VCE=10V, IC=2mA, RL=100 Ω)
● 说明 (Instructions)
1. 816 光耦合器的组成是:由一个 GaAs 的发射管和一个 NPN 的晶体管组成
816photocoupler consist of one piece of GaAs emitter and one piece of NPN transistor
2. 816 的引脚中心距是 2.54mm
Pin pitch of 816 is 2.54mm
3. UL Approved :UL1577,File No.E492440
● 应用范围 (Application Range)
1. 开关电源.Switching power supply
2. 电表.Ammeter
3. 电脑. Computer
4. 器具的应用, 测量机. Instrumental application, measurement machine
5. 贮存器, 复印机, 自动售货机. Imbursement equipments, duplicating machine, automat
6. 家用电器, 如风扇等. Family-use electric equipments, such as fans
7. 信号传输系统. Signal transforming systems
● 最大绝对额定值
(常温=25℃)
Max Absolute rated Value (Normal Temperature=25℃)
参数 Parameter
符号
Symbol
额定值 Rated Value
单位
Unit
IF
60
mA
IFP
1
A
VR
P
6
100
V
mW
VCEO
80
顺向电流 Forward Current
顺向电流峰
Peak forward current(1us pulse)
输入 Inout
逆向电压 Reverse Voltage
功消耗率 Consume Power
集极与射极电压
Collector and emitter Voltage
射极与集极电压
输出 Output Emitter and collector Voltage
集极电流 Collector Current
消耗功率 Consume Power
总功率消耗 Total Consume Power
*1 绝缘电压 Insulation Voltage
最大绝缘电压(绝缘油中) Max Insulation Voltage
VECO
6
IC
PC
Ptot
Viso
VIOTM
50
150
200
5,000
10,000
mA
mW
mW
Vrms
V
额定脉冲绝缘电压 Rated Impulse Insulation Voltage
VIORM
630
V
工作温度 Working Temperature
存贮温度 Deposit Temperature
*2 焊锡温度 Soldering Temperature
Topr
Tstg
Tsol
-55to + 110
-55 to + 125
260
V
*1. 交流测试, 时间 1 分钟,湿度. =40~60% AC Test, 1 minute, humidity = 40~60%
如下是绝缘测试的方法. Insulation test method as below:
(1) 将产品的两端短路。 Short circuit both terminals of photocoupler
(2) 测试绝缘电压时无电流通过。No Current when testing insulation voltage
(3) 测试时加正弦波形电压。Adding sine wave voltage when testing
*2. 锡焊时间为 10 秒 soldering time is 10 seconds
www.umw-ic.com
1
友台半导体有限公司
UMW
R
UMW LTV816
● 光电特性(常温=25℃) Opto-electronic Characteristics
符号
Symbol
条件 Condition
顺向电压 Forward Current
VF
IF=20mA
1.2
1.4
V
逆向电流 Reverse Voltage
IR
VR=4V
10
μA
Ct
V=0, f=1KHz
30
250
pF
ICEO
VCE=20V,
IF=0mA
100
nA
80
V
6
V
50
600
2.5
50
mA
0.1
0.2
V
1×1012
Ω
参数 Parameter
输入 Input
集极电容
Collector capacitance
集极至射极电流
Collector to emitter Current
输出 Output
集极 与射极 衰减电 压
Collector
and
Emitter
attenuation Voltage
BVCEO
射极与集极衰减电压
Emitter
and
Collector
attenuation Voltage
BVECO
*1 电流转换比
CTR
集极电流
IC
Collector Current
集极与射极饱和电压
Collector
and
Emitter
Saturation Voltage
VCE(sat)
IC=0.1mA
IF=0mA
IE=0.1mA
IF=0mA
IF=5mA
VCE=5V
IF=20mA
IC= 1mA
DC500V
最小 中.Mid 最 大 单位
Min
ium Max
Unit
传输特性 Transforming 绝缘阻抗
Characteristics
Insulation Impedance
Riso
电容量 capacotance
Cf
V=0, f=1MHz
0.6
1.0
pF
fc
VCE=5V,
IC=2mA
80
kHz
转换频率
Transforming Frequency
40~60%R.H.
RL=100Ω, -3dB
上升时间 Risetime
tr
VCE=10V,
IC=2mA
4
18
μs
下降时间 Descend Time
tf
RL=100Ω
3
18
μs
电流转换比 Current Conversion Ratio = IC / IF × 100%
www.umw-ic.com
2
友台半导体有限公司
UMW
R
UMW LTV816
● 电流转换比的等级分类 Grades of Current conversion ratio
等级标示
Grade Sign
最 小 .Min (% )
最 大 .Max (% )
50
80
130
200
300
50
100
160
260
400
600
600
L
A
B
C
D
L or A or B or C or D
说 明 : 工作条件: IF=5mA, VCE=5V, Ta=25℃.
Note: Working condition: IF=5mA, VCE=5V, Ta=25℃.
www.umw-ic.com
3
友台半导体有限公司
UMW
R
UMW LTV816
816
● 外形尺寸 Outer Dimension
●注解: Note
*1. 公司英文名. Company name
*2. BIN 级. Bin
*3. 生产周期. Production period
www.umw-ic.com
4
友台半导体有限公司
UMW
R
UMW LTV816
● 焊接温度曲线图 (Temperature Profile Of Soldering)
1.红外回流焊(jedec-std-020c 兼容)(IR
Reflow soldering (JEDEC-STD-020C compliant))
注意:一次焊接回流建议在温度和时间配置文件如下所示的条件下。不要焊接超过三次。
配置项
条件
预热(Preheat)
-最低温度(TSmin )
150˚C
-最高温度(TSmax )
200˚C
-时间(最小到最大(TS)
90±30 sec
焊接区(Soldering zone)
www.umw-ic.com
-温度(TL)
217˚C
-时间(tL)
60 sec
峰值温度(Peak Temperature)
260˚C
爬升率(Ramp-up rate)
3˚C / sec max.
下降率(3˚C / sec max.)
3~6˚C / sec
5
友台半导体有限公司
UMW
R
UMW LTV816
2.超声波焊接(jedec22a111 兼容)(Wave soldering (JEDEC22A111 compliant)
建议在温度条件下一次性焊接。
3.
温度(Temperature)
260+0/-5˚C
时间(Time)
预热温度(Preheat temperature)
10 sec
5 to 140˚C
预热时间(Preheat time)
30 to 80 sec
电烙铁手工焊接(Hand soldering by soldering iron)
允许单铅焊接在每一个过程中,建议一次性焊接。
www.umw-ic.com
温度(Temperature)
380+0/-5˚C
时间(Time)
3 sec max
6
友台半导体有限公司
UMW
R
UMW LTV816
● 特性曲线 Characteristics Curve
www.umw-ic.com
7
友台半导体有限公司
UMW
R
UMW LTV816
OR-FOR-070
www.umw-ic.com
7
友台半导体有限公司
很抱歉,暂时无法提供与“LTV816D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.41007
- 100+0.31638
- 300+0.26953
- 1000+0.23440
- 5000+0.19634
- 10000+0.18229
