SS310B
SS310B
    PINGWEI(平伟)
    DO-214AA
    SS310B
SS310B 数据手册
SS310B 310B SS SS310B S . SCHOTTKY BARRIER RECTIFIERS 3 .0AMP .0AMPS B(DO-214A DO-214A A) SM SMB DO-214AA FEATURE .For surface mounted application .High current capability .Low forward voltage drop .Low power loss, high efficiency .High surge current capability .High temperature soldering guaranteed: 260℃/10 seconds at terminals. .083(2.11) .075(1.91) .155(3.94) .130(3.30) .185(4.70) .160(4.06) .012(0.305) .006(0.152) .103(2.60) .078(1.98) MECHANICAL DATA .060((1.52) .032(0.80) .Terminal: Solder plated .Case: Molded with UL-94 Class V-0 recognized Flame Retardant Epoxy .Polarity: color band denotes cathode .Packaging:12mm tape per EIA STD RS-481 .008(0.203) .002(0.051) .217(5.50) .193(4.9) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60Hz,resistive or inductive load. For capacitive load, derate current by 20% Type Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC blocking Voltage Maximum Average Forward Rectified Current at TL =90°C SYM BOL SS310B units VRRM VRMS VDC 100 V 70 V 100 V IF(AV) 3.0 A IFSM 80.0 A VF 0.85 V Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 3.0A DC Maximum DC Reverse Current @ TA =25°C at rated DC blocking voltage @ TA =100°C Typical Junction Capacitance (Note1) Typical Thermal Resistance (Note2) Storage Temperature Operating Junction Temperature 0.1 IR 10.0 CJ R(J A) (JA R(J C) (JC R(J L) (JL TSTG TJ 112 mA pF 55 15 °C /W 20 Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0Vdc 2. Measured on P.C.Board with 0.2×0.2”(5.0×5.0mm)Copper Pad Areas 1 -55 to +150 °C -55 to +150 °C SS310B RATING AND CHARACTERISTIC CURVES (SS310B SS310B)) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS INSTANEOUS FORWARD CURRENT,(A) AVERGE FORWARD RECTIFIED CURRENT,(A) 10 3.0 1.5 Single Phase Half Wave 60Hz Resistive or inductive Load 0 0 50 100 150 1 TJ=25℃ Pulse Width=300 μs 1% Duty Cycle .1 .01 200 .2 .6 .4 .8 1.0 INSTANEOUS FORWARD VOLTAGE,(V) LEAD TEMPERTURE,(℃) FIG.4-TYPICAL REVERSE CHARACTERISTICS FIG.3-MAXIMUN NON-REPETITIVE FORWARD SURGE CURRENT 120 8.3ms Single Half Sine-Wave (JEDEC Method) 90 INSTANEOUS REVERSE CURRENT,(mA) PEAK FORWARD SURGE CURRENT,(A) 10 60 30 0 1 10 1.0 TJ=25 ℃ .1 .01 100 0 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) NUMBER OF CYCLES AT 60Hz 2 140
SS310B 价格&库存
很抱歉,暂时无法提供与“SS310B”相匹配的价格&库存,您可以联系我们找货
