ACFE4A2G900E
ACFE4A2G900E
    AMOTECH(阿莫泰克)
    SMD
    ACFE4A2G900E
ACFE4A2G900E 数据手册
DATA SHEET Part No. COMMON MODE ESD FILTER ACFE4A2G900E CUSTOMER : 승인번호 ISSUE DATA SHEET Product Name : COMMON MODE ESD FILTER Part No : ACFE4A2G900E Revision Date : 2016/12/08 Customer Code : We have approved the attached specification. CUSTOMER AMOTECH Written by Checked by Approved by R & D part QM part Sales part Signature Signature Address : AMOTECH. CO. LTD., 17-2 ,JAMWON-DONG, SEOCHO-GU, SEOUL,KOREA Contact Rev. 04 : TEL) 82-2-544-1351, FAX) 82-2-517-7183 AMOTECH Co., Ltd. Page. 1 1. DATA SHEET Part No. COMMON MODE ESD FILTER ACFE4A2G900E Parts description 1.1. Overview ACF series is multi-layer chip Common Mode Filter for high speed differential transmission line. This product shows excellent noise reduction without signal loss by high coupled Inductor pair. 1.2. Features - Excellent noise reduction without signal loss - Built-in two ESD suppression devices each line - Low profile (T = 0.47 mm) - Ceramic multilayer type SMD component - RoHS compliance 1.3. Applications - High speed differential transmission lines at electronic devices (ex. MIPI, USB2.0, etc.) - LCD/PDP TV, DSC, DVC, DVD player, notebook, PC, portable audio player, mobile phones, etc. 2. Model and Lot Number description 2.1. Model 2.2. Lot Number ACF E 4A 2 G 900 E E 08 Y 900 12A 01 A (1) (2) (3) (4) (5) (6) (7) (1) (2) (3) (4) (5) (6) (7) Rev. 04 (1) Series name (1) Material code (2) Function : “E” - ESD suppression devices (2) Chip size. : “08” - 0.85 X 0.65, (3) Chip size : “4A” - 0.87 X 0.67 (3) Thickness : “Y” - 0.4, 0.45mm (4) Number of Lines : “2” - 2 lines (4) Common Mode Impedance : “900” - 90Ω (5) Characteristics : “G” - for Gbps (5) Date : “12A” - 2012. January (6) Impedance : “900” - 90Ω (6) Produced No. (7) Internal code (7) Produced code AMOTECH Co., Ltd. Page. 2 DATA SHEET Part No. COMMON MODE ESD FILTER ACFE4A2G900E 3. Style and Dimension 3.1. Appearance and dimension • Top view • Side view` GL GW Item Size (mm) L 0.87 ± 0.05 L W 0.67 ± 0.05 P T 0.47 ± 0.05 SL 0.15 ± 0.05 SW 0.20 ± 0.05 GL 0.15 ± 0.05 GW 0.20 ± 0.05 P 0.40 ± 0.05 No. Pin Description ①/④ In/ Out line (Data) ②/③ In/ Out line (Data) ⑤, ⑥ Ground (Common) W T SL SW 3.2. Equivalent circuit & Pin description ※ No Polarity & Directionality 4. Structure and materials External Electrode Internal Electrode Item Body 1 Body 2 Body1 Ni-Zn Ferrite Body2 Glass + Alumina Internal electrode Ag External electrode Ag – Ni– Sn Plate layer Rev. 04 AMOTECH Co., Ltd. Material Ni ≥ 1 ㎛, Sn ≥ 2 ㎛ Page. 3 DATA SHEET Part No. COMMON MODE ESD FILTER ACFE4A2G900E 5. Specifications 5.1. Electrical characteristics Common Mode DC Capacitance Parameter Impedance Resistance @ 1MHz @ 100 MHz Rated Voltage Rated Current Insulation Resistance Leakage Current @ 5Vdc Symbol ZCM RDC CP VDC IDC IR IL Units Ω Ω pF V (DC) mA (DC) MΩ μA Value 90 ± 30% 1.0 ~ 5.0 Max. 1.7 5 100 Min. 10 Max. 1.0 5.2. Frequency characteristics Impedance vs. Frequency characteristics Insertion Loss vs. Frequency characteristics 0 1k -5 Insertion Loss (dB) Impedance [ohm] Common Impedance Differential Impedance 100 -10 -15 -20 10 -25 Common mode (Scc21) Differential mode (Sdd21) 1 1M -30 10M 100M 1M 1G 10M 100M 1G 10G Frequency (Hz) Frequency [Hz] 5.3. Temperature range 1) Operating Temperature range : -40 ~ +85℃ 2) Storage Temperature range : -40 ~ +85℃ 5.4. Measurement method When measuring and supplying the voltage, the following terminal is applied. parameter Common Mode Impedance DC Resistance Capacitance Insulation Resistance Leakage Current Equipment Agilent E4991A Impedance Analyzer Agilent 4338B Milliohm Meter Agilent 4288A capacitance meter KEITHLEY 2400 KEITHLEY 2400 Terminal to be Tested Rev. 04 RDC AMOTECH Co., Ltd. CP IR IL Page. 4 DATA SHEET Part No. COMMON MODE ESD FILTER ACFE4A2G900E 6. Soldering (Reflow soldering) 6.1. Soldering condition - Lead Free Solder paste : Sn / Ag / Cu : 96.5 / 3.0 / 0.5 Follow the recommended soldering conditions to avoid degradation of performance . - This product is designed for reflow soldering only. Do not use flow soldering. - Use non-activated flux. (Max. Cl content less than 0.2%) - Reflow cycle times should be done less than 3 times. A 1.17 B 0.86 S4 C 0.42 S3 6.2. PCB pattern design condition (recommended) D 0.40 E 0.61 S1 SM Unit :mm S5 S2 G2 D Solder Mask 0.05 0.14 G1 0.08 S2 0.06 G2 0.06 S3 0.03 G3 0.03 S4 0.22 G4 0.25 S5 0.20 G5 0.20 G5 G1 B E C S1 SM G3 G4 SM Copper pattern A 7. Caution 1) Storage environment : -5~40℃ temperature, 20~70% humidity (MSL Level 1) 2) Do not use in high temperature/high humidity and a corrosive atmosphere like sulfide, chloride gas which could damage the solderability. 3) Do not expose to mechanical shock to avoid crack. 4) Use chips within 6 months. If over 6 months, check solderability before use. Rev. 04 AMOTECH Co., Ltd. Page. 5 DATA SHEET Part No. COMMON MODE ESD FILTER ACFE4A2G900E 8. Packaging specification 8.1 Carrier tape Specification 8.1.1. Size T1 ΦF D C W E L T2 A B L W A B C D E ΦF T1 T2 Tolerance ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 ±0.10 +0.10 ±0.10 Max. Spec (mm) 0.77 0.97 2.00 4.00 3.50 1.75 8.00 1.55 0.60 0.10 8.1.2. Chip Locations Empty Section (45 pitch Min.) Packed part END Empty Section (45 pitch Min.) Unsealed section (45 pitch Min.) Start 8.1.3. Material 1) Pater carrier tape : Laminated virgin pulp 2) Top tape : Polyester film 3) Bottom tape : Adhesive coated paper Rev. 04 AMOTECH Co., Ltd. Page. 6 DATA SHEET Part No. COMMON MODE ESD FILTER ACFE4A2G900E 8.2. Reel Specification 8.2.1. Size WIDTH HOLE DIA CORE DIA Item DIA WIDTH CORE DIA HOLE Size (mm) 178.0±0.5 9.0±0.5 60.0±1.0 13.2±0.3 8.2.2. Label adherence and winding direction Product label Behind side Press type Top tape Front side Press type Bottom tape End tape (Polypropylene) Checked label < Front side > < Behind side > 8.2.3. Material 1) Carrier Tape : PET / PC / PS 2) Plastic reel : GPS(General Purpose Styrene) Rev. 04 AMOTECH Co., Ltd. Page. 7 DATA SHEET Part No. COMMON MODE ESD FILTER ACFE4A2G900E 8.3 Box packaging Specification Box Small Medium Size (mm) 183 (W) x 185 (D) x 70 (T) Quantity Large 200 (W) x 375 (D) x 205 (T) 375 (W) x 390 (D) x 205 (T) 5 reel 5 small boxes 10 Medium boxes = 10,000 ea/reel × 5 = 10,000 ea/reel X 25 = 10,000 ea/reel X 50 = 50,000 ea = 250,000 ea = 500,000 ea Detail 8.4. Label Specification Size : Reel & Small boxes : 80 X 40 (mm) Medium & Large boxes : 100 X 100 (mm) Rev. 04 AMOTECH Co., Ltd. Page. 8
ACFE4A2G900E 价格&库存
很抱歉,暂时无法提供与“ACFE4A2G900E”相匹配的价格&库存,您可以联系我们找货
ACFE4A2G900E
    • 10+0.10661
    • 100+0.05812
    • 300+0.02582
    • 1000+0.02340
    • 5000+0.02145
    • 10000+0.02047
    库存:728
    ACFE4A2G900E
      • 1+0.32090
      库存:100
