IL3085E
IL3085E
    NVECORP
    SOIC-16_10.3X7.5MM
    IL3085E
IL3085E 数据手册
IL3085 Low-Cost Isolated RS-485 Transceivers Features Functional Diagrams DE • • • • • • • • • • • • • 4 Mbps data rate Supports up to 32 nodes 3 V to 5 V power supplies 50 kV/μs typ.; 30 kV/μs min. common mode transient immunity Low quiescent supply current 600 VRMS working voltage per VDE V 0884-10 2500 VRMS isolation voltage per UL 1577 44000 year barrier life 7 kV bus ESD protection Low EMC footprint Thermal shutdown protection −40°C to +85°C temperature range Meets or exceeds ANSI RS-485 and ISO 8482:1987(E) • VDE V 0884-10 certified; UL 1577 recognized • QSOP, 0.15" SOIC, and 0.3" True 8™ mm 16-pin SOIC packages ISODE XDE D A B R RE ISOR IL3085-1 (QSOP) DE ISODE Applications XDE • • • • • D A B R Factory automation Industrial control networks Building environmental controls Equipment covered under IEC 61010-1 Edition 3 5 kVRMS rated IEC 60601-1 medical applications RE Description IL3085-3 (narrow-body) The IL3085 is a galvanically isolated, high-speed differential bus transceiver, designed for bidirectional data communication on balanced transmission lines. The device uses NVE’s patented* IsoLoop spintronic Giant Magnetoresistance (GMR) technology. DE ISODE A unique ceramic/polymer composite barrier provides excellent isolation and virtually unlimited barrier life. The wide-body version provides true 8 mm creepage. Narrow-body and QSOP packages offer unprecedented miniaturization. D A B R The IL3085 delivers at least 1.5 V into a 27 Ω load for excellent data integrity over long cable lengths. The device is compatible with 3.3 V input supplies, allowing interface to standard microcontrollers without additional level shifting. RE IL3085 (wide-body) VID (A-B) DE RE R D Mode ≥ 200 mV L L H X Receive ≤−200 mV L L L X Receive ≥ 1.5 V H L H H Drive ≤−1.5 V H L L L Drive X X H Z X Hi-Z R Open L L H X Receive Current limiting and thermal shutdown features protect against output short circuits and bus contention that may cause excessive power dissipation. Receiver inputs feature a “fail-safe if open” design, ensuring a logic high R-output if A/B are floating. IsoLoop® is a registered trademark of NVE Corporation. *U.S. Patent number 5,831,426; 6,300,617 and others. NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 REV. H (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Absolute Maximum Ratings(11) Parameter Storage Temperature Junction Temperature Ambient Operating Temperature Voltage Range at A or B Bus Pins Supply Voltage(1) Digital Input Voltage Digital Output Voltage ESD (all bus nodes) Symbol TS TJ TA VDD1, VDD2 Min. −55 −55 −40 −8 −0.5 −0.5 −0.5 7 Typ. Min. 3.0 4.5 −40 Typ. Max. 150 150 85 12.5 7 VDD + 0.5 VDD + 1 Units °C °C °C V V V V kV Test Conditions Max. 5.5 5.5 100 12 −7 Units Test Conditions VDD1 V 0.8 +12 / −7 60 V V mA 8 mA HBM Recommended Operating Conditions Parameter Junction Temperature Input Voltage at any Bus Terminal (separately or common mode) Symbol VDD1 VDD2 TJ VI VIC High-Level Digital Input Voltage VIH Low-Level Digital Input Voltage Differential Input Voltage(2) High-Level Output Current (Driver) High-Level Digital Output Current (Receiver) Low-Level Output Current (Driver) Low-Level Digital Output Current (Receiver) Ambient Operating Temperature Digital Input Signal Rise and Fall Times VIL VID IOH Supply Voltage 2.4 3.0 0 IOH V °C V IOL −60 mA IOL −8 mA TA tIR, tIF −40 85 °C DC Stable Symbol Min. 3.2 4.0 8.03 0.012 VDD1 = 3.3 V VDD1 = 5.0 V Insulation Specifications Parameter IL3085-1E Creepage Distance IL3085-3E (external) IL3085E Total Barrier Thickness (internal) Barrier Resistance Barrier Capacitance Leakage Current Comparative Tracking Index High Voltage Endurance AC (Maximum Barrier Voltage for Indefinite Life) DC Typ. VIO Units Test Conditions mm 8.3 0.013 >1014 7 0.2 Per IEC 60601 ≥175 1000 mm Ω pF μARMS V VRMS 1500 VDC RIO CIO CTI Max. Barrier Life 44000 500 V f = 1 MHz 240 VRMS, 60 Hz Per IEC 60112 At maximum operating temperature Years 100°C, 1000 VRMS, 60% CL activation energy Units Test Conditions Thermal Characteristics Parameter Symbol Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance Power Dissipation QSOP 0.15" SOIC 0.3" SOIC QSOP 0.15" SOIC 0.3" SOIC QSOP 0.15" SOIC 0.3" SOIC Min. Typ. 63 40 34 35 20 17 θJA θJT Max. °C/W °C/W 675 700 800 PD Soldered to doublesided board; free air mW 2 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Safety and Approvals VDE V 0884-10 (VDE V 0884-11 pending; Basic Isolation; VDE File Number 5016933-4880-0001) • Working Voltage (VIORM) 600 VRMS (848 VPK); basic insulation; pollution degree 2 • Isolation voltage (VISO) 2500 VRMS • Transient overvoltage (VIOTM) 4000 VPK • Surge rating 4000 V • Each part tested at 1590 VPK for 1 second, 5 pC partial discharge limit • Samples tested at 4000 VPK for 60 sec.; then 1358 VPK for 10 sec. with 5 pC partial discharge limit Safety-Limiting Values Safety rating ambient temperature Safety rating power (180°C) Supply current safety rating (total of supplies) Symbol TS PS IS Value 180 270 54 Units °C mW mA IEC 61010-1 (Edition 2; TUV Certificate Numbers N1502812; N1502812-101) Reinforced Insulation; Pollution Degree II; Material Group III Part No. Suffix -1 -3 None Package QSOP SOIC True 8™ Wide-body SOIC Working Voltage 150 VRMS 150 VRMS 300 VRMS UL 1577 (Component Recognition Program File Number E207481) Each part tested at 3000 VRMS (4240 VPK) for 1 second; each lot sample tested at 2500 VRMS (3530 VPK) for 1 minute Soldering Profile Per JEDEC J-STD-020C, MSL 1 3 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 IL3085-1 (QSOP Package) Pin Connections 1 VDD1 2 R 3 GND1 Input power supply ground return 4 RE Read data enable (if RE is high, R= high impedance) 5 DE 6 D 7, 8 NC No internal connection 9 A Non-inverting bus line 10 B Inverting bus line 11 12 Input power supply Output data from bus Drive enable Data input to bus VDD2X Output transceiver power supply (normally connected to pin 16) XDE Transceiver Device Enable input enables the transceiver from the bus side, or is connected to ISODE to enable the transceiver from the controller-side DE input. (this input should not be left unterminated) 13 ISOR Isolated R output (for testing; no connection should be made to this pin) 14 GND2 Output power supply ground return. 15 ISODE Isolated DE output (normally connected to pin 12) 16 VDD2I Output isolation power supply (normally connected to pin 11) VDD1 1 16 VDD2 R 2 15 ISODE GND1 3 14 GND2 RE 4 13 ISOR DE 5 12 XDE D 6 11 VDD2X NC 7 10 B NC 8 9 A IL3085-1 IL3085-3 (0.15" SOIC Package) Pin Connections 1 VDD1 Input power supply 2 GND1 Input power supply ground return 3 R 4 RE Read data enable (if RE is high, R= high impedance) 5 D Data input to bus 6 DE Drive enable 7, 8, 9 NC No internal connection Output data from bus VDD1 1 16 VDD2I GND1 2 15 GND2 R 3 14 ISODE RE 4 13 VDD2X D 5 12 B DE 6 11 A Transceiver Device Enable input enables the transceiver from the bus side, or is connected to ISODE to enable the transceiver from the controller-side DE input. (this input should not be left unterminated) 10 XDE 11 A Non-inverting bus line 12 B Inverting bus line NC 7 10 XDE 13 VDD2X Output transceiver power supply (normally connected to pin 16) NC 8 9 NC 14 ISODE Isolated DE output (normally connected to pin 10) 15 GND2 Output power supply ground return. 16 VDD2I Output isolation power supply (normally connected to pin 13) IL3085-3 4 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 IL3085 (0.3" SOIC Package) Pin Connections 1 VDD1 Input power supply 2 GND1 Input power supply ground return (pin 2 is internally connected to pin 8) 3 R 4 RE Read data enable (if RE is high, R= high impedance) 5 DE Drive enable 6 D 7 NC 8 GND1 Input power supply ground return (pin 8 is internally connected to pin 2) GND2 Output power supply ground return (pin 9 is internally connected to pin 15) 10 ISODE Isolated DE output for use in PROFIBUS applications where the state of the isolated drive enable node needs to be monitored. 11 NC No internal connection 12 A Non-inverting bus line 13 B Inverting bus line 14 NC 15 GND2 Output power supply ground return (pin 15 is internally connected to pin 9) 16 VDD2 Output power supply 9 Output data from bus Data input to bus No internal connection VDD1 1 16 VDD2 GND1 2 15 GND2 R 3 14 NC RE 4 13 B DE 5 12 A D 6 11 NC NC 7 10 ISODE GND1 8 9 GND2 IL3085 No internal connection 5 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Driver Section Electrical Specifications (Tmin to Tmax and VDD = 4.5 V to 5.5 V unless otherwise stated) Typ.(5) Parameter Symbol Min. Max. Units Output voltage VO VDD V Differential Output Voltage(2) |VOD1| VDD V Differential Output Voltage(2, 6) VOD3 1.5 2.3 5 V Change in Magnitude of Differential Δ|VOD| ±0.01 ±0.2 V Output Voltage(7) Common Mode Output Voltage VOC 3 V Change in Magnitude of Common Δ|VOC| ±0.01 ±0.2 V Mode Output Voltage(7) 1 Output Current(4) IO mA −0.8 High Level Input Current IIH 10 μA Low Level Input Current IIL −10 μA Absolute |Short-circuit Output Current| IOS 250 mA VDD1 = 5 V 4 6 IDD1 Supply Current mA VDD1 = 3.3 V 3 4 IDD1 Test Conditions IO = 0 IO = 0 RL = 27 Ω, VDD = 4.5 V RL = 27 Ω or 50 Ω RL = 27 Ω or 50 Ω RL = 27 Ω or 50 Ω Output Disabled, VO = 12 VO = −7 VI = 3.5 V VI = 0.4 V −7 V < VO < 12 V No Load (Outputs Enabled) Notes (apply to both driver and receiver sections): 1. All voltages are with respect to network ground except differential I/O bus voltages. 2. Differential input/output voltage is measured at the noninverting terminal A with respect to the inverting terminal B. 3. Skew limit is the maximum propagation delay difference between any two devices at 25°C. 4. The power-off measurement in ANSI Standard EIA/TIA-422-B applies to disabled outputs only and is not applied to combined inputs and outputs. 5. All typical values are at VDD1,VDD2 = 5 V or VDD1= 3.3 V and TA = 25°C. 6. −7 V < VCM < 12 V; 4.5 V < VDD < 5.5 V. 7. Δ|VOD| and Δ|VOC| are the changes in magnitude of VOD and VOC, respectively, that occur when the input is changed from one logic state to the other. 8. This applies for both power on and power off, refer to ANSI standard RS-485 for exact condition. The EIA/TIA-422-B limit does not apply for a combined driver and receiver terminal. 9. Includes 10 ns read enable time. Maximum propagation delay is 25 ns after read assertion. 10. Pulse skew is defined as |tPLH – tPHL| of each channel. 11. Absolute Maximum specifications mean the device will not be damaged if operated under these conditions. It does not guarantee performance. 12. The relevant test and measurement methods are given in the Electromagnetic Compatibility section on p. 6. 13. External magnetic field immunity is improved by this factor if the field direction is “end-to-end” rather than to “pin-to-pin” (see diagram on p. 6). 6 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Receiver Section Electrical Specifications (Tmin to Tmax and VDD = 4.5 V to 5.5 V unless otherwise stated) Typ.(5) Parameter Symbol Min. Max. Units Positive-going Input Threshold 0.2 V VIT+ Voltage Negative-going Input Threshold −0.2 V VIT− Voltage Hysteresis Voltage (VIT+ − VIT−) VHYS 70 mV High Level Digital Output Voltage VOH Low Level Digital Output Voltage VOL 0.2 V High-impedance-state output current Line Input Current(8) IOZ II ±1 1 −0.8 Input Resistance RI μA mA mA kΩ Supply Current VDD – 0.2 VDD V 12 IDD2 5 16 mA Max. Units Mbps Test Conditions −7 V < VCM < 12 V −7 V < VCM < 12 V VCM = 0 V, T = 25°C VID = 200 mV IOH = −20 μA VID = −200 mV IOH = 20 μA VO = 0.4 to (VDD2−0.5) V VI = 12 V VI = −7 V No load; Outputs Enabled; VDD2X connected to VDD2I if applicable Switching Characteristics Parameter Data Rate Symbol Propagation Delay(2, 9) Pulse Skew(2, 10) Output Enable Time To High Level Output Enable Time To Low Level Output Disable Time From High Level Output Disable Time From Low Level Common Mode Transient Immunity (Output Logic High to Logic Low) Parameter Data Rate tPD 48 150 ns tSK(P) 6 15 ns tPZH tPZL tPHZ tPLZ 33 33 33 33 50 50 50 50 ns ns ns ns |CMH|,|CML| Symbol Propagation Delay(2, 9) Pulse Skew(2, 10) Output Enable Time To High Level Output Enable Time To Low Level Output Disable Time From High Level Output Disable Time From Low Level Common Mode Transient Immunity (Output Logic High to Logic Low) VDD1 = 5 V, VDD2 = 5 V Typ.(5) Min. 4 30 50 kV/μs VDD1 = 3.3 V, VDD2 = 5 V Typ.(5) Min. 4 tPD 48 150 ns tSK(P) 6 20 ns tPZH tPZL 33 33 50 50 ns ns Test Conditions RL = 54 Ω, CL = 50 pF VO = −1.5 to 1.5 V, CL = 15 pF VO = −1.5 to 1.5 V, CL = 15 pF CL = 15 pF CL = 15 pF tPHZ 33 50 ns CL = 15 pF tPLZ 33 50 ns CL = 15 pF VCM = 1500 VDC tTRANSIENT = 25 ns |CMH|,|CML| 30 Max. Units Mbps Test Conditions RL = 54 Ω, CL = 50 pF VO = −1.5 to 1.5 V, CL = 15 pF VO = −1.5 to 1.5 V, CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF CL = 15 pF VCM = 1500 VDC tTRANSIENT = 25 ns 50 kV/μs 7 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Magnetic Field Immunity(12) Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(13) HPF HPM HOSC KX Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(13) HPF HPM HOSC KX VDD1 = 5 V, VDD2 = 5 V 3500 4500 4500 2.5 VDD1 = 3.3 V, VDD2 = 5 V 1500 2000 2000 2.5 A/m A/m A/m 50Hz/60Hz tp = 8µs 0.1Hz – 1MHz A/m A/m A/m 50Hz/60Hz tp = 8µs 0.1Hz – 1MHz 8 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Electrostatic Discharge Sensitivity This product has been tested for electrostatic sensitivity to the limits stated in the specifications. However, NVE recommends that all integrated circuits be handled with appropriate care to avoid damage. Damage caused by inappropriate handling or storage could range from performance degradation to complete failure. Pinout Differences Between Packages QSOP and narrow-body version (IL3085-1E and IL3085-3E) are designed for application flexibility and minimum board area in dense PCAs. The wide-body version (IL3085E) has redundant ground pins for layout flexibility. QSOP and narrow-body versions provide separate isolated DE output (ISODE) and Transceiver Device Enable (XDE) input. ISODE follows the Device Enable input (DE). XDE can be used to enable and disable the transceiver from the bus side, or connected to ISODE to enable and disable the transceiver from the DE controller-side input. The QSOP and narrow-body versions also provide separate bus-side power supply pins— VDD2X for the transceiver module and VDD2I for the isolation module. These should be externally connected for normal operation, but can be used separately for testing or troubleshooting. The QSOP version also has an “ISOR” output that is isolated with respect to the controller-side “R.” This pin is used for testing and normally not connected, but could be used for a bus-side data output under special circumstances. The wide-body version has internal connections between the isolated DE output and the Transceiver Device Enable input, and well as between the two VDD2 bus-side power supply pins. The two internally-connected GND pins for each supply side provide layout flexibility. The ISODE output can be used in PROFIBUS applications where the state of the isolated drive enable node needs to be monitored, or for testing or troubleshooting. Dynamic Power Consumption IsoLoop Isolators have low power consumption because data is transmitted across the isolation barrier only on edge transitions. Power consumption therefore varies with the data rate. Typical dynamic supply currents are as follows: Data Rate (Mbps) 1 4 IDD1 150 μA 600 μA IDD2 150 μA 600 μA Table 2. Typical Dynamic Supply Currents. Power Supply Decoupling Both VDD1 and VDD2 must be bypassed with 47 nF ceramic capacitors. These should be placed as close as possible to VDD pins for proper operation. Additionally, VDD2 should be bypassed with a 10 µF tantalum capacitor. Maintaining Creepage Creepage distances are often critical in isolated circuits. In addition to meeting JEDEC standards, NVE isolator packages have unique creepage specifications. Standard pad libraries often extend under the package, compromising creepage and clearance. Similarly, ground planes, if used, should be spaced to avoid compromising clearance. Package drawings and recommended pad layouts are included in this datasheet. DC Correctness The IL3085 incorporates a patented refresh circuit to maintain the correct output state with respect to data input. At power up, the bus outputs will follow the Function Table shown on Page 1. The DE input should be held low during power-up to eliminate false drive data pulses from the bus. An external power supply monitor to minimize glitches caused by slow power-up and power-down transients is not required. Electromagnetic Compatibility The IL3085 is fully compliant with generic EMC standards EN50081, EN50082-1 and the umbrella line-voltage standard for Information Technology Equipment (ITE) EN61000. The IsoLoop Isolator’s Wheatstone bridge configuration and differential magnetic field signaling ensure excellent EMC performance against all relevant standards. NVE conducted compliance tests in the categories below: EN50081-1 Residential, Commercial & Light Industrial Methods EN55022, EN55014 EN50082-2: Industrial Environment Methods EN61000-4-2 (ESD), EN61000-4-3 (Electromagnetic Field Immunity), EN61000-4-4 (Electrical Transient Immunity), EN61000-4-6 (RFI Immunity), EN61000-4-8 (Power Frequency Magnetic Field Immunity) ENV50204 Radiated Field from Digital Telephones (Immunity Test) Immunity to external magnetic fields is even higher if the field direction is “end-to-end” (rather than to “pin-to-pin”) as shown above. 9 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Application Information Figures 1a, 1b, and 1c show typical connections to a bus and microcontroller for the three package versions. The schematics include typical termination and fail-safe resistors, and power supply decoupling capacitors: VDD2 = 5 V VDD1 = 3.3 V + C DD2B C DD2 C DD1 47nF DE 5 D 6 R 2 RE 4 IL3085-1 47nF 11 16 10µF 15 ISODE 12 XDE R FS-EXT 560R A 9 10 ISOR 13 3 GND1 14 Isolation Boundary Microcontroller 1 RT 120R B R FS-EXT 560R GND2 Figure 1a. Typical QSOP transceiver connections. VDD2 = 5 V VDD1 = 3.3 V + C DD2B C DD2 C DD1 47nF 1 47nF 13 16 10µF 14 ISODE 6 10 D 5 R 3 RE 4 XDE R FS-EXT 560R A 11 12 RT 120R B 2 GND1 R FS-EXT 560R 15 Isolation Boundary Microcontroller DE IL3085-3 GND2 Figure 1b. Typical narrow-body connections. VDD2 = 5 V VDD1 = 3.3 V C DD2 C DD1 47nF 1 5 + C DD2B 47nF 16 10µF 10 ISODE D 6 R 3 RE 4 R FS-EXT 560R 12 13 2 or 8 GND1 A RT 120R B Isolation Boundary Microcontroller DE IL3085 9 or 15 R FS-EXT 560R GND2 Figure 1c. Typical wide-body connections. 10 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Receiver Features The receiver output “R” has tri-state capability via the active low RE input. Driver Features The RS-485 driver has a differential output and delivers at least 2.1 V across a 54 Ω load. Drivers feature low propagation delay skew to maximize bit width and minimize EMI. Drivers have tri-state capability via the active-high DE input. Receiver Data Rate, Cables and Terminations The IL3085 is intended for networks up to 4,000 feet (1,200 m), but the maximum data rate decreases as cable length increases. Twisted pair cable should be used in all networks since they tend to pick up noise and other electromagnetically induced voltages as common mode signals, which are effectively rejected by the differential receiver. Fail-Safe Operation “Fail-safe operation” is defined here as the forcing of a logic high state on the “R” output in response to an open-circuit condition between the “A” and “B” lines of the bus, or when no drivers are active on the bus. Proper biasing can ensure fail-safe operation, that is a known state when there are no active drivers on the bus. IL3000-Series Isolated Transceivers include internal pull-up and pull-down resistors of approximately 30 kΩ in the receiver section (RFS-INT; see figure below). These internal resistors are designed to ensure failsafe operation but only if there are no termination resistors. The entire VDD will appear between inputs “A” and “B” if there is no loading and no termination resistors, and there will be more than the required 200 mV with up to four RS-485 worstcase Unit Loads of 12 kΩ. Many designs operating below 1 Mbps or less than 1,000 feet are unterminated. Termination resistors may not be necessary for very low data rates and very short cable runs because reflections have time to settle before data sampling, which occurs at the middle of the bit interval. In busses with low-impedance termination resistors however, the differential voltage across the conductor pair will be close to zero with no active drivers. In this case the state of the bus is indeterminate, and the idle bus will be susceptible to noise. For example, with 120 Ω termination resistors (RT) on each end of the cable, and four Unit Loads (12 kΩ each), without external fail-safe biasing resistors the internal pull-up and pulldown resistors will produce a voltage between inputs “A” and “B” of only about 5 mV. This is not nearly enough to ensure a known state. External fail-safe biasing resistors (RFS-EXT) at one end of the bus can ensure fail-safe operation with a terminated bus. Resistors should be selected so that under worst-case power supply and resistor tolerances there is at least 200 mV across the conductor pair with no active drivers to meet the input sensitivity specification of the RS-485 standard. Using the same value for pull-up and pull-down biasing resistors maintains balance for positive- and negative going transitions. Lower-value resistors increase inactive noise immunity at the expense of quiescent power consumption. Note that each Unit Load on the bus adds a worst-case loading of 12 kΩ across the conductor pair, and 32 Unit Loads add 375 Ω worst-case loading. The more loads on the bus, the lower the required values of the biasing resistors. In the example with two 120 Ω termination resistors and four Unit Loads, 560 Ω external biasing resistors provide more than 200 mV between “A” and “B” with adequate margin for power supply variations and resistor tolerances. This ensures a known state when there are no active drivers. Other illustrative examples are shown in the following table: 11 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Fail-Safe Biasing 5V 30K RFS-INT RT RT None 120 Ω 120 Ω 120 Ω B RFS-EXT 30K RFS-INT GND RFS-EXT Internal Only Internal Only 560 Ω 510 Ω A RT R RFS-EXT VDD Loading Four unit loads (12 kΩ ea.) Four unit loads (12 kΩ ea.) Four unit loads (12 kΩ ea.) 32 unit loads (12 kΩ ea.) Nominal VA-B Fail-Safe Operation? (inactive) 238 mV Yes 5 mV No 254 mV Yes 247 mV Yes 12 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Package Drawings Ultraminiature 16-pin QSOP Package (-1 suffix) Dimensions in inches (mm); scale = approx. 5X 0.188 (4.77) 0.197 (5.00) 0.020 (0.50) 0.029 (0.75) 0.050 (1.27) 0.056 (1.42) 0.060 (1.52) 0.069 (1.75) 0.150 (3.8) 0.157 (4.0) 0.228 (5.8) 0.244 (6.2) 0.004 (0.10) 0.010 (0.25) 0.025 (0.635) NOM NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0.007 (0.20) 0.010 (0.25) 0.013 (0.3) 0.020 (0.5) 0.15" 16-pin SOIC Package (-3 suffix) Dimensions in inches (mm); scale = approx. 5X 0.013 (0.3) 0.020 (0.5) NOM 0.007 (0.2) 0.013 (0.3) 0.386 (9.8) 0.394 (10.0) Pin 1 identified by either an indent or a marked dot 0.016 (0.4) 0.050 (1.3) 0.055 (1.40) 0.062 (1.58) 0.054 (1.4) 0.072 (1.8) 0.150 (3.81) 0.157 (3.99) 0.049 (1.24) 0.051 (1.30) 0.228 (5.8) 0.244 (6.2) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0.004 (0.1) 0.012 (0.3) 13 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 0.3" 16-pin SOIC Package (no suffix) Dimensions in inches (mm); scale = approx. 5X 0.033 (0.85)* 0.043 (1.10) 0.260 (6.60)* 0.280 (7.11) 0.013 (0.3) 0.020 (0.5) 0.007 (0.2) 0.013 (0.3) 0.397 (10.08) 0.413 (10.49) 0.017 (0.43)* 0.022 (0.56) 0.016 (0.4) 0.050 (1.3) 0.007 (0.18)* 0.010 (0.25) 0.092 (2.34) 0.105 (2.67) Pin 1 identified by either an indent or a marked dot 0.08 (2.0) 0.10 (2.5) 0.292 (7.42)* 0.299 (7.59) 0.049 (1.24) 0.051 (1.30) 0.394 (10.00) 0.419 (10.64) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate *Specified for True 8™ package to guarantee 8 mm creepage per IEC 60601. 0.004 (0.1) 0.012 (0.3) 14 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Recommended Pad Layouts 4 mm x 5 mm 16-pin QSOP Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.160 (4.05) 0.025 (0.635) 0.012 (0.30) 16 PLCS 0.275 (6.99) 0.15" 16-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.160 (4.06) 0.050 (1.27) 0.020 (0.51) 16 PLCS 0.275 (6.99) 15 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 0.3" 16-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.317 (8.05) 0.050 (1.27) 0.020 (0.51) 16 PLCS 0.449 (11.40) 16 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Ordering Information and Valid Part Numbers IL 30 85 -3 E TR13 Valid Part Numbers IL3085E IL3085E TR13 IL3085-3E IL3085-3E TR7 IL3085-3E TR13 IL3085-1E IL3085-1E TR7 IL3085-1E TR13 Bulk Packaging Blank = Tube TR7 = 7'' Tape and Reel TR13 = 13'' Tape and Reel Package E = RoHS Compliant Package Type Blank = 0.3'' SOIC -3 = 0.15'' SOIC -1 = 0.15'' QSOP Channel Configuration 85 = RS-485 Base Part Number 30 = Digital-In, 4 Mbps Transceiver Product Family IL = Isolators RoHS COMPLIANT 17 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Revision History ISB-DS-001-IL3085-H December 2017 Change ISB-DS-001-IL3085-G Change • • ISB-DS-001-IL3085-F ISB-DS-001-IL3085-D ISB-DS-001-IL3085-C ISB-DS-001-IL3085-B ISB-DS-001-IL3085-A December 2012 Updated from IEC 60747-5-5 (VDE 0884) certification to VDE V 0884-10. Change • ISB-DS-001-IL3085-E Improved thermal specifications based on new test data (p. 2). Increased IL3085-1E (QSOP) creepage specification from 2.75 mm to 3.2 mm (p. 2). Change • Added QSOP version (-1 suffix). • Revised and added details to thermal characteristic specifications (p. 2). • Added VDE 0884 Safety-Limiting Values (p. 3). Change • IEC 60747-5-5 (VDE 0884) certification. • Upgraded from MSL 2 to MSL 1. Change • Increased transient immunity specifications based on additional data. • Noted UL 1577 recognition, IEC 61010-1 approval, and VDE 0884 pending. • Added transient immunity specifications. • Added high voltage endurance specification. • Increased magnetic immunity specifications. • Updated package outline drawings and added recommended solder pad dimensions. Change • Added thermal characteristics (p. 2). • Finalized maximum data rate (4 Mbps). • Cosmetic changes. Change • Initial Release. 18 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 Datasheet Limitations The information and data provided in datasheets shall define the specification of the product as agreed between NVE and its customer, unless NVE and customer have explicitly agreed otherwise in writing. All specifications are based on NVE test protocols. In no event however, shall an agreement be valid in which the NVE product is deemed to offer functions and qualities beyond those described in the datasheet. Limited Warranty and Liability Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Right to Make Changes NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions at any time and without notice. This document supersedes and replaces all information supplied prior to its publication. Use in Life-Critical or Safety-Critical Applications Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless against all claims and damages. Applications Applications described in this datasheet are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customers. NVE accepts no liability in this respect. Limiting Values Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the recommended operating conditions of the datasheet is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and Conditions of Sale In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NVE hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NVE products by customer. No Offer to Sell or License Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export Control This document as well as the items described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Automotive Qualified Products Unless the datasheet expressly states that a specific NVE product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NVE accepts no liability for inclusion or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NVE’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NVE’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NVE for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NVE’s standard warranty and NVE’s product specifications. 19 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation IL3085 An ISO 9001 Certified Company NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 www.nve.com e-mail: iso-info@nve.com ©NVE Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. ISB-DS-001-IL3085-H December 2017 20 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation ©NVE Corporation
IL3085E 价格&库存
很抱歉,暂时无法提供与“IL3085E”相匹配的价格&库存,您可以联系我们找货
