APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
OPERATING
HUMIDITY RANGE
VOLTAGE
Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
RATING
2
CURRENT
-40C TO + 85C(NOTE 1)
40% TO + 80%(NOTE 2)
250V AC/DC
AWG24 : 2.5A
AWG26 : 2.0A
AWG28 : 1.0A
STORAGE TEMPERATURE
RANGE
STORAGE
HUMIDITY RANGE
APPLICABLE CONNECTOR
-10C TO + 60C(NOTE 3)
40% TO + 70%(NOTE 3)
DF11-**DS-2C(##)
APPLICABLE CABLE
UL1061,1007 AWG24 TO 28
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT
AT
X
X
X
X
X
X
CONSTRUCTION
GENERAL EXAMINATION
VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ACCORDING TO DRAWING.
ELECTRIC CHARACTERISTICS
CONTACT RESISTANCE
100mA (DC OR 1000 Hz).
MECHANICAL CHARACTERISTICS
MECHANICAL OPERATION
30m MAX.
2
① CONTACT RESISTANCE:
30m MAX.
② NO DAMAGE, CRACK OR LOOSENESS OF
PARTS.
50 TIMES INSERTIONS AND EXTRACTIONS.
CONTACT INSERTION
AND EXTRACTION FORCE
□0.5±0.002 BY STEEL GAUGE.
INSERTION FORCE
EXTRACTION FORCE
X
VIBRATION
FREQUENCY 10 TO 55 Hz, SINGLE AMPLITUDE
0.75 mm, AT 2 h, FOR 3 DIRECTIONS.
① NO ELECTRICAL DISCONTINUITY OF 1s.
PARTS.
X
490 m/s2 DURATION OF PULSE 11 ms AT 3 TIMES FOR 3
DIRECTIONS.
PARTS.
X
SHOCK
ENVIRONMENTAL CHARACTERISTICS
4.4N MAX
0.3N MIN
2
RAPID CHANGE OF
TEMPERATURE
TEMPERATURE -55→ 5 TO 35→ 85→ 5 TO 35 C
TIME
30→10 TO 15→30→10 TO 15 min
UNDER 5 CYCLES.
30m MAX.
PARTS.
X
DAMP HEAT
(STEADY STATE)
EXPOSED AT 40 ± 2 C, 90 TO 95 , 96 h.
30m MAX.
PARTS.
X
REMARKS
NOTE 1:INCLUDING THE TEMPERATURE RISE BY CURRENT
NOTE 2:NO CONDENSING.
NOTE 3:APPLY TO THE CONDITION OF LONG TERM STORAGE FOR UNUSED PRODUCTS BEFORE MOUNTED ON PCB,
AFTER MOUNTED ON PCB, OPERATION TEMPERATURE AND HUMIDITY RANGE IS APPLIED FOR INTERIM
STORAGE DURING TRANSPORTATION.
2
COUNT
DESCRIPTION OF REVISIONS
DESIGNED
3
DIS-H-00004374
TS.MIYAKI
Unless otherwise specifid , refer to IEC 60512.
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
PART NO.
CODE NO.
DATE
SZ.ONO
20181102
APPROVED
KJ.KATAYOSE
20050105
CHECKED
TY.OMA
20050105
DESIGNED
IO.DENPOUYA
20050105
DRAWN
IO.DENPOUYA
20050105
DRAWING NO.
SPECIFICATION SHEET
CHECKED
ELC-080088-00-00
DF11-2428SCA
CL543-0551-3-00
2
1/1
很抱歉,暂时无法提供与“DF11-2428SCA”相匹配的价格&库存,您可以联系我们找货
