IP2110
IP2110
    INJOINIC(英集芯科技)
    SOT-23-5
    IP2110
IP2110 数据手册
IP2110 USB Dedicated Charging Port Controller 1. Features  2. Description Support Apple Devices charging: IP2110 is a low-cost dedicated charging Physical  Apple 2.4A: DP = 2.7V, DM = 2.7V  Apple 2.0A (circuit reverse DP, DM): DP = 2.0V, DM = 2.7V Apple 1.0A: DP = 2.0V, DM = 2.7V  SEL configure maximum current allotment       Apple 2.4A/2.0A/1.0A, Samsung 2.0A and BC1.2. An auto-detect feature monitors USB data line voltage,  pin Layer IC dedicated for USB ports, which supports and automatically provides the correct electrical signatures on the data lines to charge compliant devices. SEL pin used to configure the maximum Support Samsung 2.0A: DP = 1.2V, DM =1.2V allotment current. Support BC1.2: DP short to DM automatically Support auto-detect and auto-switching charging standards Very low power consumption IQ = 66uA(Typ.) Working voltage: 3V~5.5V Package: SOT23-5 3. Application  USB power output ports for AC adapters, Power Banka, Car chargers Battery chargers for smart phones, tablets, netbooks, digital cameras, and Bluetooth accessories  4. Typical Application Schematic VOUT (5V) (Regulator output voltage) VBUS1 VBUS 1uF IP2110 SEL DM DM DP DP GND GND USB Connector V1.0 SEL Current High 2.4A Float 1.0A GND Disable http://www.injoinic.com/ 1/6 Copyright © 2017, Injoinic Corp. IP2110 5. PIN Description Pin Name SEL 1 GND 2 VBUS 3 5 DM 4 DP IP2110 Pin No. Pin Description SEL 1 Configure the maximum Current allowed to apply for:  High: Apple 2.4A  Float: Apple 1.0A  GND: Disable (DP, DM do not work, in high-z state) GND 2 Ground VBUS 3 Power supply input, connect with 1uF capacitor to GND DP 4 Connect to USB DP data line DM 5 Connect to USB DM data line 6. IP Series Products List Power Bank IC LED charge Num Lighting Keys I2C DCP Type-C QC Certificate Package IP5303 1.0A 1.2A 1,2 √ √ - - - - eSOP8 IP5305 1.0A 1.2A 1,2,3,4 √ √ - - - - eSOP8 IP5306 2.4A 2.1A 1,2,3,4 √ √ - - - - eSOP8 IP5206 2A (Max) 1.5A 3,4,5 √ √ - - - - eSOP16 IP5108E 2.0A 1.0A 3,4,5 √ √ - - - - eSOP16 IP5108 2.0A 2.0A 3,4,5 √ √ √ - - - eSOP16 IP5207 1.2A 1.2A 3,4,5 √ √ - - - - QFN24 IP5207T 1.2A 1.2A 1,2,3,4 √ √ √ √ - - QFN24 IP5109 2.1A 2.1A 3,4,5 √ √ √ - - - QFN24 IP5209 2.4A 2.1A 3,4,5 √ √ √ √ - - QFN24 IP5219 2.4A 2.1A 1,2,3,4 √ √ √ √ √ - QFN24 IP5310 3.1A 3.0A 1,2,3,4 √ √ √ √ √ - QFN32 V1.0 http://www.injoinic.com/ 2/6 Compa tibility PIN2PIN Dis- Package PIN2PIN Charge Features PIN2PIN IC Part No. Charge /Discharge Copyright © 2017, Injoinic Corp. 15W 3.6A 2,3,4,5 √ √ √ √ - - QFN32 IP5318Q 18W 4.0A 2,3,4,5 √ √ √ √ - √ QFN40 IP5318 18W 4.0A 2,3,4,5 √ √ √ √ √ √ QFN40 IP5322 18W 4.0A 1,2,3,4 √ √ √ √ - √ QFN32 IP5328 18W 4.0A 1,2,3,4 √ √ √ √ √ √ QFN40 PIN IP5312 PIN2 IP2110 USB Charging Port Control IC Standards Supported IC Part No. Channel Num IP2110 BC1.2 QC3.0 MTK & & APPLE QC2.0 1 √ - - - - - - - - - - SOT23-5 IP2111 1 √ - - - - - - - - - - SOT23-6 IP2112 2 √ - - - - - - - - - - SOT23-6 IP2161 1 √ √ - - - √ - - - √ - SOT23-6 IP2163 1 √ √ √ - √ √ √ - √ √ - SOP8 IP2701 1 √ √ √ - √ √ - √ - - - SOP8 IP2703 1 √ √ √ - √ √ √ √ √ - - DFN10 IP2705 1 √ √ √ - √ √ √ √ √ - - DFN12 IP2707 2 √ √ √ - √ √ √ √ √ - - QFN16 IP2716 1 √ √ √ √ √ - 1.1 √ - √ √ QFN32 FCP SCP AFC SFCP PE+ QC Type-C NTC 2.0&1.1 Certi- PD3.0 Package ficate 7. Absolute Maximum Ratings Parameters Symbol Value Unit VBUS Input Voltage Range VBUS -0.3 ~ 7 V DP, DM Input Voltage Range VDP, VDM -0.3 ~ 11 V Junction Temperature Range TJ -40 ~ 150 ℃ Storage Temperature Range Tstg -60 ~ 150 ℃ Ambient Temperature Range TA -40 ~ 150 ℃ Human Body Model (HBM) ESD 4 KV *Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to Absolute Maximum Rated conditions for extended periods may affect device reliability. *Voltages are referenced to GND unless otherwise noted. 8. Recommended Operating Conditions Parameter Symbol Min. Input Voltage VBUS Ambient Temperature TA Typ. Max. Unit 3 5.5 V -40 85 ℃ *Devices’ performance cannot be guaranteed when working beyond those Recommended Operating Conditions. V1.0 http://www.injoinic.com/ 3/6 Copyright © 2017, Injoinic Corp. IP2110 9. Electrical Characteristics Unless otherwise specified, TA=25℃, 4.5V ≤ VBUS ≤ 5.5V Parameter Symbol Test Conditions Min. Typ. Max. Unit Quiescent Current IQ No load, VBUS=5V 50 66 100 uA Startup Time Ts 8 10 12 ms DP Voltage VDP DM Voltage VDM SEL= VSELH 2.7 V SEL=Float 2.0 V SEL= VSELH 2.7 V SEL=Float 2.7 V SEL Input High Voltage Range VSELH 3 5 5.5 V SEL Default Output Voltage VSELO 1.35 1.5 1.65 V 10. Function Description Charging Standards IP2110 is a low-cost dedicated charging Physical Layer IC dedicated for charging applications where charging standards required to be negotiated between USB ports. IP2110 is needed at the host-side, when the attached portable client-side device negotiate the power allotment from the power source host-side. An auto-detect feature monitors USB data line voltage, and automatically provides the correct electrical signatures on the data lines to charge compliant devices. SEL pin used to configure the maximum allotment current. IP2110 supports Apple 2.4A/2.0A/1.0A, Samsung 2.0A and BC1.2. IP2110 is not in control of the charging power loop, the actual charging loop and charging current is determined by the host-side power source and the client-side USB port device. SEL SEL line is used to configure the maximum current allotment for Apple, when SEL line is pull up to high-voltage of VSELH, the maximum current allotment is 2.4A; when SEL line is floating, the maximum current allotment is 1.0A. Reverse the DP, DM on PCB board, the maximum current allotment is 2.0A. when the SEL line is pull down to GND, IP2110 will not respond to any charging requirements, DP, DM are in high-z state. V1.0 http://www.injoinic.com/ SEL1 Voltage High (VSELH) 2.4A Float 1.0A GND Disable 4/6 Copyright © 2017, Injoinic Corp. IP2110 11. Package SYMBOL MILLIMETER MIN NOM A 2.82 3.02 A1 0.90 1.00 A2 0.35 0.45 B 1.52 1.72 B1 2.80 3.00 B2 0.119 0.135 C 1.05 1.15 C1 0.03 0.13. C2 0.60 0.70 D 0.03 0.13 D1 0.40 0.50 D2 D3 0.254TYP 0.60 0.70 θ 9 º TYP4 θ1 10 º TYP4 θ2 0º 8º θ3 6 º TYP R V1.0 MAX 0.2TYP R1 0.08 TYP R2 0.08TYP http://www.injoinic.com/ 5/6 Copyright © 2017, Injoinic Corp. IP2110 12. IMPORTANT NOTICE INJOINIC TECHNOLOGY and its subsidiaries reserve the right to make corrections, enhancements, improvements and other changes to its semiconductor products and services. Buyers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. All semiconductor products (also referred to herein as “components”) are sold subject to INJOINIC TECHNOLOGY's terms and conditions of sale supplied at the time of order acknowledgment. INJOINIC TECHNOLOGY assumes no liability for applications assistance or the design of Buyers' products. Buyers are responsible for their products and applications using INJOINIC TECHNOLOGY's components. To minimize the risks associated with Buyers' products and applications, Buyers should provide adequate design and operating safeguards. Buyer acknowledges and agrees that it is solely responsible for compliance with all legal, regulatory and safety-related requirements concerning its products, and any use of INJOINIC TECHNOLOGY's components in its applications, notwithstanding any applications-related information or support that may be provided by INJOINIC TECHNOLOGY. Buyer represents and agrees that it has all the necessary expertise to create and implement safeguards which anticipate dangerous consequences of failures, monitor failures and their consequences, lessen the likelihood of failures that might cause harm and take appropriate remedial actions. Buyer will fully indemnify INJOINIC TECHNOLOGY and its representatives against any damages arising out of the use of any INJOINIC TECHNOLOGY's components in safety-critical applications. Reproduction of significant portions of INJOINIC TECHNOLOGY's information in INJOINIC TECHNOLOGY's data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. INJOINIC TECHNOLOGY is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. INJOINIC TECHNOLOGY will update this document from time to time. The actual parameters of the product may vary due to different models or other items. This document voids all express and any implied warranties. Resale of INJOINIC TECHNOLOGY's components or services with statements different from or beyond the parameters stated by INJOINIC TECHNOLOGY for that component or service voids all express and any implied warranties for the associated INJOINIC TECHNOLOGY's component or service and is an unfair and deceptive business practice. INJOINIC TECHNOLOGY is not responsible or liable for any such statements. V1.0 http://www.injoinic.com/ 6/6 Copyright © 2017, Injoinic Corp.
IP2110 价格&库存
很抱歉,暂时无法提供与“IP2110”相匹配的价格&库存,您可以联系我们找货
IP2110
    • 10+0.45088
    • 100+0.37312
    • 300+0.33424
