1N4148
SMALL SIGNAL SWITCHING DIODE
DO-34(GLASS)
DO-35(GLASS)
FEATURES
1.0 2(26.0)
MIN.
0.079(2.0)
MAX
1.0 2(26.0)
MIN.
0.079(2.0)
MAX
0.106 (2.9)
MAX
Silicon epitaxial planar diode
Switching diodes
500mw power dissipation
High temperature soldering guaranteed
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
0.165 (4.2)
MAX
MECHANICAL DATA
1.0 2(26.0)
MIN.
0.017(0.42)
TYP
1.0 2(26.0)
MIN.
0.018(0.45)
TYP
Case: DO-34\DO-35 glass sealed envelope.
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.003 ounce, 0.09 grams(DO-34)
0.005 ounce, 0.14 grams(DO-35)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length at TA=25 C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 10mA
Maximum DC reverse current
TA=25 C VR=75V
at rated DC blocking voltage
TA=100 C VR=20V
Maximum reverse recovery time
(NOTE 1)
Typical junction capacitance (NOTE 2)
1N4148
UNITS
100
75
VOLTS
VOLTS
I(AV)
150
mAmps
IFSM
500
mAmps
VF
1.0
Volts
IR
5.0
50
µA
trr
4.0
ns
4.0
-65 to +200
pF
C
SYMBOLS
VRRM
VRMS
CJ
Operating junction and storage temperature range
TJ,TSTG
NOTES:
1.Test condition:IF=10mA,IR=10mA,Irr=1mA,VR=6V,RL=100Ω.
2.Measured at 1.0 MHz and applied reverse voltage of 4.0 volts
198
STAR SEA
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
P,POWER DISSIPATION,MILLIWATTS
RATINGS AND CHARACTERISTIC CURVES 1N4148
FIG. 1-ADMISSIBLE POWER DISSIPATION
VERSUS AMBIENT TEMPERATURE
800
700
600
500
400
300
200
100
200 C
AMBIENT TEMPERATURE, C
FIG. 2-REVERSE CURRENT VERSUS CONTINUOUS
REVERSE VOLTAGE (TYPICAL VALUES)
1
0.1
0.01
TJ=25 C
0.001
0.0001
40
60
80
100
120
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 4-RELATIVE CAPACTANCE VERSUS
REVERSE VOLTAGE
INSTANTANEOUS FORWARD
CURRENT,MILLIAMPERES
FIG. 3-FORWARD CHARACTERISTICS
Ctot(vR)
RELATIVE CAPACTANCE
Ctot(0v)
16
14
12
10
8
6
4
2
2V
1.2
1.0
0.8
0.6
0.4
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
5
10V
REVERSE VOLTAGE,VOLTS.
FIG. 5-MAXIMUM PERMISSIBLE NON-REPETITIVE PEAK FORWARD CURRENT AS A FUNCTION OF PULSE DURATION
10
2
IFSM
(A)
10
1
10
-1
1
10
10
2
Based on square wave currents.
199
10
3
tp(*s)
10
4
Tj=25* prior to surge.
STAR SEA
很抱歉,暂时无法提供与“1N4148”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.09198
- 500+0.07497
- 1500+0.06552
- 5000+0.05702
- 25000+0.05210
- 50000+0.04946
