NA5W-K
NA5W-K
    TAKAMISAWA(高见泽)
    Through Hole
    NA5W-K
NA5W-K 数据手册
FTR-K1 SERIES MINIATURE RELAY 2 POLES - 1 to 2 A (For Signal Switching) NA Series n FEATURES Slim type relay for high density mounting Conforms to Telcordia specification and FCC Part 68 - Dielectric strength 1,500 VAC between coil and contacts - Surge strength 2,500 V between coil and contacts (at 2 × 10 s surge wave) l UL, CSA recognized l High sensitivity and low consumption power l High reliability - bifurcated contacts l DIL pitch terminals l Plastic sealed type l RoHS compliant. Please see page 8 for more information l l n PARTNUMBER INFORMATION [Example] (a) NA L (a) (b) Relay type (*) D 12 (c) (d) W - K (e) (f) NA : NA Series (b) Coil type Nil L (c) Number of coil Nil D : Standard type : Latching type (d) Coil rated voltage 12 : 1.5....48VDC Coil rating table at page 3 : Single winding type : Double winding type (e) Contact style W : Bifurcated type (f) Enclosure K : Plastic sealed Note: Actual marking omits the hyphen ( - ) of (*). 1 FTR-K1 SERIES NA SERIES n SPECIFICATION Item Contact Data Life Coil Data Timing Data Insulation Single winding latching type Double winding latching type NA - ( ) W - K NAL - ( ) W - K NAL-D ( ) W - K Configuration 2 form C (DPDT) Construction Bifurcated Material Gold overlay silver alloy (AgPd) Resistance (Initial) Max. 50 mΩ at 1 A, 6 VDC Contact rating (resistive) 0.5A, 125VAC or 1A, 30VDC Max. carrying current 2A Max. switching voltage 250VAC / 220VDC Max. switching power 62.5 AV / 30W Max. switching current 2A Min. switching load * 0.01 mA, 10 mVDC Capacitance Approx. 0.5 pF (open contacts, adjacent contacts) Approx. 1.0 pF (between coil and contacts) Mechanical Min. 100 x 106 operations Electrical Min. 200 x 103 operations (0.5A, 125VAC), Min. 500 x 103 operations (1A, 30VDC) Rated power 140 - 300 mW 100 - 150 mW 200 - 300 mW Operate power 80 - 70 mW 60 - 85 mW 115 - 170 mW Operating temperature range -40 °C to +85 °C (no frost) Operate (at nominal voltage) Max. 6 ms Max. 6 ms (set) Release (at nominal voltage) Max. 4 ms Max. 6 ms (reset) Resistance (Initial) Min. 1,000MOhm at 500VDC Dielectric strength Surge strength Vibration resistance Shock Weight Min. 10 x 106 operations Open contacts / 1,000VAC (50/60Hz) 1min adjacent contacts Contacts to coil Other Standard type 1,500VAC (50/60Hz) 1min. 1,000VAC (50/60Hz) 1min Open contacts / 1,500V / 10 x 700µs standard wave adjacent contacts 1,500V / 10 x 160µs standard wave Coil to contacts 2,500V / 2 x 10µs standard wave Misoperation 10 to 55Hz double amplitude 3.3mm Endurance 10 to 55Hz double amplitude 5.0mm Misoperation 500m/s² (11 ± 1ms) Endurance 1,000m/s² (6 ± 1ms) Approximately 1.5 g * Minimum switching loads mentioned above are reference values. Please perform the confirmation test with actual load before production since reference values may vary according to switching frequencies, environmental conditions and expected reliability levels. 2 NA SERIES FTR-K1 SERIES n COIL RATING Standard type Coil Code Rated Coil Voltage (VDC) Coil Resistance +/- 10% (Ohm) Must Operate Voltage (VDC) * Must ReleaseMax. Coil Voltage Voltage (VDC) (VDC) * 1.5 1.5 16.1 +1.13 +0.15 3.6 3 3 64.3 +2.25 +0.3 7.2 4.5 4.5 145 +3.38 +0.45 10.8 5 5 178 +3.75 +0.5 12.0 6 6 257 +4.5 +0.6 14.4 9 9 579 +6.75 +0.9 21.6 12 12 1,028 +9 +1.2 28.8 18 18 1,620 +13.5 +1.8 36.0 24 24 2,880 +18 +2.4 48.0 48 48 7,680 +36 +4.8 84.0 Rated Power (mW) 140 200 300 Single winding latching type Coil Code Rated Coil Voltage (VDC) Coil Resistance +/- 10% (Ohm) Set Voltage (VDC) * Reset Voltage (VDC) * 1.5 1.5 22.5 +1.13 -1.13 3 3 90 +2.25 -2.25 4.5 4.5 203 +3.38 -3.38 5 5 250 +3.75 -3.75 6 6 360 +4.5 -4.5 9 9 810 +6.75 -6.75 12 12 1,440 +9 -9 18 18 2,160 +13.5 -13.5 24 24 3,840 +18 -18 Rated Power (mW) 100 150 Note: All values in the table are valid for 20°C and zero contact current. * Specified operate values are valid for pulse wave voltage. 3 NA SERIES FTR-K1 SERIES n COIL RATING Double winding latching type Coil Code Rated Coil Voltage (VDC) Coil Resistance +/- 10% (Ohm) Set Voltage (VDC) * 1.5 1.5 P 11.25 +1.13 S 11.25 3 3 P 45 4.5 P 101 +2.25 +2.25 +3.38 S 101 5 5 P 125 +3.38 6 P 180 +3.75 +4.5 S 180 9 9 P 405 +4.5 +6.75 S 405 12 12 P 720 +6.75 +9 S 720 18 18 P 1,080 +9 +13.5 S 1,080 24 24 P 1,920 200 +3.75 S 125 6 Rated Power (mW) +1.13 S 45 4.5 Reset Voltage (VDC) * +13.5 300 +18 S 1,920 +18 Note: All values in the table are measured at 20°C and zero contact current. * Specified values are measured with pulse wave voltage P: Primary coil S: Secondary coil n SAFETY STANDARDS Type Compliance Contact rating UL UL 508, UL 1950 Flammability: UL 94-V0 (plastics) E 45026 0.5A, 125VAC (general use) 2A, 30VDC (resistive) 0.3A, 110VDC (resistive) CSA C22.2 No. 14, No. 950 LR 35579 Complies to IEC60950-1; FCC part 68: Telcordia (Relay is only marked with UL and CSA logo) 4 FTR-K1 SERIES NA SERIES n CHARACTERISTIC DATA 5 FTR-K1 SERIES NA SERIES n REFERENCE DATA 6 FTR-K1 SERIES NA SERIES n DIMENSIONS l Dimensions l Schematics (BOTTOM VIEW) l PC board mounting hole layout (BOTTOM VIEW) NA, NAL (Standard type, Single winding latching type) NAL-D (Double winding latching type) Unit: mm 7 FTR-K1 SERIES NA SERIES RoHS Compliance and Lead Free Information 1. General Information All signal and power relays produced by Fujitsu Components are compliant with RoHS directive 2002/95EC including amendments. l Cadmium as used in electrical contacts is exempted from the RoHS directives on October 21st, 2005. (Amendment to Directive 2002/95/EC) l All of our signal and power relays are lead-free. Please refer to Lead-Free Status Info for older date codes at: http://www.fujitsu.com/us/downloads/MICRO/fcai/relays/lead-free-letter.pdf l Lead free solder plating on relay terminals is Sn-3.0Ag-0.5Cu, unless otherwise specified. This material has been verified to be compatible with PbSn assembly process. l 2. Recommended Lead Free Solder Profile l Recommended solder Sn-3.0Ag-0.5Cu. Flow Solder condition: Pre-heating: Soldering: maximum 120˚C dip within 5 sec. at 260˚C solder bath Solder by Soldering Iron: Soldering Iron Temperature: maximum 360˚C Duration: maximum 3 sec. We highly recommend that you confirm your actual solder conditions 3. Moisture Sensitivity l Moisture Sensitivity Level standard is not applicable to electromechanical relays, unless otherwise indicated. 4. Tin Whiskers l Dipped SnAgCu solder is known as presenting a low risk to tin whisker development. No considerable length whisker was found by our in house test. 8 FTR-K1 SERIES NA SERIES Fujitsu Components International Headquarter Offices Japan Fujitsu Component Limited Gotanda-Chuo Building 3-5, Higashigotanda 2-chome, Shinagawa-ku Tokyo 141, Japan Tel: (81-3) 5449-7010 Fax: (81-3) 5449-2626 Email: promothq@ft.ed.fujitsu.com Web: www.fcl.fujitsu.com Europe Fujitsu Components Europe B.V. Diamantlaan 25 2132 WV Hoofddorp Netherlands Tel: (31-23) 5560910 Fax: (31-23) 5560950 Email: info@fceu.fujitsu.com Web: emea.fujitsu.com/components/ North and South America Fujitsu Components America, Inc. 250 E. Caribbean Drive Sunnyvale, CA 94089 U.S.A. Tel: (1-408) 745-4900 Fax: (1-408) 745-4970 Email: components@us.fujitsu.com Web: http://us.fujitsu.com/components Asia Pacific Fujitsu Components Asia Ltd. 102E Pasir Panjang Road #01-01 Citilink Warehouse Complex Singapore 118529 Tel: (65) 6375-8560 Fax: (65) 6273-3021 Email: fcal@fcal.fujitsu.com Web: http://www.fujitsu.com/sg/services/micro/components/ ©2011 Fujitsu Components Europe B.V. All rights reserved. All trademarks or registered trademarks are the property of their respective owners. The contents, data and information in this datasheet are provided by Fujitsu Component Ltd. as a service only to its user and only for general information purposes. The use of the contents, data and information provided in this datasheet is at the users’ own risk. Fujitsu has assembled this datasheet with care and will endeavor to keep the contents, data and information correct, accurate, comprehensive, complete and up to date. Fujitsu Components Europe B.V. and affiliated companies do however not accept any responsibility or liability on their behalf, nor on behalf of its employees, for any loss or damage, direct, indirect or consequential, with respect to this datasheet, its contents, data, and information and related graphics and the correctness, reliability, accuracy, comprehensiveness, usefulness, availability and completeness thereof. Nor do Fujitsu Components Europe B.V. and affiliated companies accept on their behalf, nor on behalf of its employees, any responsibility or liability for any representation or warrant of any kind, express or implied, including warranties of any kind for merchantability or fitness for particular use, with respect to these datasheets, its contents, data, information and related graphics and the correctness, reliability, accuracy, comprehensiveness, usefulness, availability and completeness thereof. Rev. March 02, 2011 9 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Fujitsu: NAL-D5W-K NAL-D1.5W-K NA-6W-K NAL-24W-K NAL-12W-K NA-4.5W-K NA-24W-K NA-12W-K NA-5W-K NAL-D12W-K NA-9W-K NAL-1.5W-K NAL-D4.5W-K NAL-D24W-K NA-48W-K NAL-D18W-K NAL-4.5W-K NAL9W-K NA-1.5W-K NAL-5W-K NAL-18W-K NAL-D6W-K NAL-6W-K NA-18W-K NAL-D9W-K NAL-3W-K NAL-D3WK
NA5W-K 价格&库存
很抱歉,暂时无法提供与“NA5W-K”相匹配的价格&库存,您可以联系我们找货
