方
合
盟
※ Application
合
泰
Thin type of on-board power supply module for
合
泰
盟
方
(C)3.5±0.5
(E)0~0.15
泰
盟
方
合
4,1
方
盟
泰
合
④ Inductance Value:2R2=2.2µH;
方
⑤ The Material Code;
方
⑥ Material Type;
盟
泰
合
19
S 1
⑤ ⑥
盟
方
盟
泰
④
泰
2R2
合
方
泰
合
1040
③
方
盟
the diagram above applies
to values 0.56uH and below
合
泰
合
②
③ Dimensions(unit:mm):10.0x10.0x4.0;
泰
12,2
Suggested pad layout
Dimensions are in mm
盟
泰
MC F
4,1
盟
above
The rated current as listed is either the saturation current or the
heating current depending on which value is lower.
12,2
方
盟
方
should be verified in the end application.
合
(B)10.0±0.3
5,4
component.PWB trace size and thickness, airflow and other
(D)4.0Max
合
泰
(F)2.0±0.5
125℃ under the worst case operating conditions.Circuit design,
cooling provision all affect the part temperature.Part temperature
(C)3.0±0.5
盟
泰
合
合
(E)0~0.15
泰
合
方
盟
方
方
盟
泰
(F)2.0±0.5
5,4
The part temperature (ambient + temp rise ) should not exceed
①
(A)11.15±0.35
盟
(B)10.0±0.3
(D)4.0Max
合
合
泰
泰
盟
盟
方
方
(A)11.15±0.35
方
※ Dimensions in inches (unit:mm)
Operat between temperature range -55℃ to +125℃
合
合
Voltage regulator VRM for server
泰
盟
泰
DC/DC converters for laptop motherboards/CPU
Isat :DC current (A) that will cause L0 to drop approximately 20%
※ Regulation of Part number
方
盟
方
方
方
100% lead (Pb) free meet RoHS standards
Idc: DC current (A) that will cause an approximate △T of 40℃
Low loss and low resistance
Test Condition:100KHz,1.0Vrms
② Mold Categories:F;
Low profile:Thickness max.4.0mm
All test data is reference to 25℃ ambient.
① Molding Choke;
合
泰
盟
合
High performance (Isat) realizde by metal dust core.
Capable of corresponding high frequency (3MHz)
盟
合
泰
泰
盟
泰
合
方
盟
方
※Note:
方
※ Features
方
泰
盟
方
盟
方
方
盟
www.sz-hotland.com
MCW-1040-XXX-S1 Series
很抱歉,暂时无法提供与“MCF-1040-6R8-S1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.63286
- 10+1.31534
- 30+1.17926
