TS02N
2-Channel Self Calibration Capacitive Touch Sensor
SPECIFICATION
VER. 1.6
JUN. 2018
ADSemiconductor Confidential
General
Feature
The TS02N is 2-Channel capacitive sensor with auto
sensitivity calibration. And the supply voltage range
is from 2.5 to 5.5V.
2-Channel capacitive touch sensor with self
Low power consumption
Sync function for parallel operation
Adjustable internal clock frequency with external
resister
Open-drain digital output
Embedded noise elimination circuit
Embedded Internal power reset circuit
RoHS compliant 8SOP package
2.5V to 5.5V operation
Typical current consumption 28 uA (@3.3V,
R_BIAS 510K Ohm)
Typical current consumption 56 uA (@5.0V,
R_BIAS 510K Ohm)
The result of touch sensing can be checked by
parallel output port(OUT1 and OUT2).
Over two TS02N can work on the one application at
the same time thanks to SYNC function.
Block Diagram
Application
Home appliance
Membrane switch replacement
Human interface for toys & interactive games
Sealed control panels, keypads
Ordering Information
Part No.
TS02N
Package
8 SOP
ADSemiconductor®
TS02N(2-CH Sensitivity Calibration Capacitive Touch Sensor)
Revision History
Rev.
1.0
1.1
1.2
1.3
1.4
1.5
1.6
Description of change
First creation
Spec. supplementation
Mechanical drawing modification
Additional mechanical drawing modification
Current consumption modification
Marking name modification
Add an overview
Revise the Operating Temperature : -20 ~ 75℃ -> -40 ~ 85℃
Date
Originator
06. 07. 26.
06. 09. 29.
07. 03. 04.
07. 04. 06.
17. 06. 16.
17. 09. 15.
KD PARK
KD PARK
KD PARK
KD PARK
CH LEE
CH LEE
18. 06. 21.
KD PARK
AD Semiconductor Confidential
3 / 19
ADSemiconductor®
Content
General ..................................................................................................................2
Revision History .............................................................................................3
1 Pin Configuration............................................................................................5
1.1
2
2.1
3
4
R_BIAS implementation .................................................................................... 10
CS implementation ............................................................................................. 11
SYNC implementation........................................................................................ 12
OUTPUT implementation .................................................................................. 12
Recommended Application ..........................................................................13
7.1
7.2
8
ESD Characteristics .............................................................................................. 8
Latch-up Characteristics ....................................................................................... 8
Electrical Characteristics ................................................................................9
Implementation of TS02N ............................................................................10
6.1
6.2
6.3
6.4
7
Pin Map – 8 SOP .................................................................................................. 7
Absolute Maximum Rating ............................................................................8
ESD & Latch-up Characteristics ....................................................................8
4.1
4.2
5
6
8 SOP .................................................................................................................... 5
Pin Description ...............................................................................................6
Example – Power Line Split Strategy PCB Layout ............................................ 14
Example – PCB Layout (2 Channel Touch button with LED Display) ............. 15
PACKAGE DESCRIPTION ........................................................................16
8.1
8.2
Mechanical Drawing - GREATEK ..................................................................... 16
Marking Description ........................................................................................... 18
4 / 19
ADSemiconductor®
1
1.1
Pin Configuration
8 SOP
TS02N 8SOP (Drawings not to scale)
5 / 19
ADSemiconductor®
2 Pin Description
VDD, GND
Supply voltage and ground pin.
CS1, CS2
Capacitive sensor input pins.
R_BIAS
Internal bias adjust input. Normally 510K-ohm resistor is connected between this port and ground.
SYNC
The IC operation signal output and peripheral IC operation signal input.
OUT1, OUT2
Parallel output ports of CS1 and CS2 respectively. The structure of these parallel output ports is open drain
NMOS for active low output level operation.
6 / 19
ADSemiconductor®
Pin Map – 8 SOP
2.1
PIN Number
Name
I/O
1
SYNC
Analog Input
2
3
4
5
6
R_BIAS
GND
CS1
CS2
VDD
Analog Input
Ground
Analog Input
Analog Input
Power
7
OUT2
Digital Output
8
OUT1
Digital Output
Description
Self sense operation signal output
Peripheral sense operation signal input
Supply ground
Sense channel 1
Sense channel 2
Power (2.5V ~ 5.0V)
Ch2 touch detect output
Open drain output (Active Low)
Ch1 touch detect output
Protection
VDD/GND
VDD/GND
VDD
VDD/GND
VDD/GND
GND
VDD/GND
VDD/GND
7 / 19
ADSemiconductor®
3
Supply voltage
5.5 V
Maximum voltage on any pin
VDD+0.3 V
Maximum current on any PAD
100mA
Continuous power Dissipation
800mW
Storage Temperature
-50 ~ 150℃
-40 ~ 85℃
Junction Temperature
150℃
Note Unless otherwise noted, all above are operated in normal temperature
4
4.1
4.2
ESD Characteristics
Mode
Polarity
H.B.M
Pos / Neg
M.M
Pos / Neg
C.D.M
Pos / Neg
Max
3500V
6250V
8000V
700V
700V
700V
800V
Reference
VDD
VSS
P to P
VDD
VSS
P to P
DIRECT
Polarity
Positive
Negative
Positive
Max
200mA
-200mA
8.0V
Test Step
Mode
I Test
V supply over 5.0V
25mA
1.0V
8 / 19
ADSemiconductor®
5
▪ VDD=3.3V, RB =510k, (Unless otherwise noted), TA = 25℃
Characteristics
Symbol
Operating supply voltage
VDD
Current consumption
IDD
Output maximum sink
current
Sense input
capacitance range
Note1
Sense input
resistance range
Minimum detectable
capacitance difference
Min
Typ
Max
Units
2.5
3.3
5.5
V
VDD= 3.3V RB=510k
28
52
VDD= 5.0V RB=510k
56
105
TA = 25℃
4.0
CS1
CS2
10
100
RS
200
1000
Ω
CS = 10pF
0.2
ΔC > 0.2pF
12
ΔC < 0.2pF
30M
VDD = 3.3V RB = 510k
100
VDD = 5.0V RB = 510k
80
VDD = 3.3V
200
510
820
VDD = 5.0V
330
620
1200
IOUT
ΔC
Output impedance
(open drain)
Zo
Self calibration time after
power on
TCAL
Recommended bias
resistance range
RB
Note2
Test Condition
Ω
ms
kΩ
Maximum bias capacitance
CB_MAX
820
1000
pF
Recommended sync
resistance range
RSYNC
1
2
MΩ
Note 1:
The sensitivity can be increased with lower CS value.
The recommended value of CS is 10pF when using 3T PC(Poly Carbonate) cover and 10 ㎜ x 7 ㎜
touch pattern.
Note 2: The lower RB is recommended in noisy condition.
9 / 19
ADSemiconductor®
6
6.1
VDD
CB
RB
R_BIAS
很抱歉,暂时无法提供与“TS02NT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.63520
- 10+2.17080
- 30+1.97640
