SHENZHEN FAST SENSOR CO., LTD
PCB/SMD Mount Reed Switch/Sensor
Product Name
Normally Open Reed Sensor
Item No.
FRS-16A45H
Advantages:
1. Easy installation, operate in magnetic field.
2. Passive switch, no need outer power
3. Cut through any non-iron materials.
Item Numbers
FRS-16A45H☜
Built-in reed switch
MKA-14103
Switch Form
Form A-SPST
Operate Range (AT)
8-35
Operate Time (ms)
1.0
Resonant Frequency (Hz)
4000
Switched Power (max.)
10
Switched Vdc/Vac (max,)
100
Switched Current (max.)
0.5
Carry Current (max.)
1.0
Breakdown Voltage (min.)
220
Contact Resist. (max.)
100
Contact Capacit. (max.)
0.7
Insulation Resist. (min.)
108
Mould Case
Black Epoxy Resin
Sealed technique
Black Epoxy Resin
Work Temperature
-40~+125
Installation
2 leads, Plug-in
很抱歉,暂时无法提供与“FRS-16A45H1015”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.28320
- 10+2.76480
- 30+2.51640
- 100+2.28960
- 500+2.13840
- 1000+2.10600
