BOS501
BOS501
    BOPLAENCLOSURES
    BOS501
BOS501 数据手册
BOS Detailed product information can be found on www.bopla.de - 8 sizes - Various designs - Enclosure with display cut-out or continuous membrane keypad area - Various battery compartments - With matching desktop and charging station, depending on model Colour: Depending on the model: black, similar to RAL 9005, or agate grey, similar to RAL 7038; special colours on request Protection class: Depending on the model: IP 40 / IP 65/DIN EN 60529 Enclosure material: ABS, seal made of CR; for details see Technical Information 148 Hand-held enclosure series for a range of uses in a classic design BOS hand-held enclosures in various designs with different equipment features. BOS 4..: With continuous membrane keypad area - with tip-up clip or belt clip BOS 4..ASC BOS 5.., BOS 7.., BOS 8..: Available with a membrane keypad and/or different display types. BOS 6..: With display screen, continuous keypad surface or integrated loudspeaker grille. BOS 9..: With large display and slimline grip area – Versions with a battery compartment are also available. A carrying strap or a tip-up foot is available for enclosure BOS 9.. . Some BOS 7.. series enclosures also have a slide switch (see table on the following page). Data transfer can be achieved with the table stand for BOS 9.. (available as an accessory). 149 Display opening Battery comp. for Ingress protect. Slide switch Panoramic display scr. Display screen UDS application BOS 400 – 9V block IP 40 – – – – BOS 400 ASC – 9V block IP 40 – – – – BOS 401 – - IP 40 – – – – BOS 401 ASC – - IP 40 – – – – BOS 500 x 9V block IP 40 – x – x BOS 501 x 9V block IP 40 – – x x BOS 502 – 9V block IP 40 – – – x BOS 503 – 9V block IP 40 – – – x BOS 600 x 9V block IP 40 – – x – BOS 601 – 9V block IP 40 – – – – BOS 602 – 3 mignons IP 40 – – – – BOS 700 x 9V block IP 40 – – x x BOS 701 x 9V block IP 40 – – x x BOS 704 x 9V block IP 40 x – x x BOS 705 x 9V block IP 40 x – x x BOS 750 x 9V block IP 40 – x – x BOS 751 x 9V block IP 40 – – x x BOS 752 – 9V block IP 40 – – – x BOS 753 x - IP 40 – x – x BOS 754 x - IP 40 – – x x BOS 755 – - IP 40 – – – x BOS 756 x 9V block IP 40 x x – x BOS 757 x 9V block IP 40 x – x x BOS 758 – 9V block IP 40 x – – x BOS 759 x - IP 40 x x – x BOS 760 x - IP 40 x – x x BOS 761 – - IP 40 x – – x BOS 800 x 4 mignons IP 40 – x – x BOS 801 x 4 mignons IP 40 – – x x BOS 802 – 4 mignons IP 40 – – – x BOS 803 x - IP 40 – x – x BOS 804 x - IP 40 – – x x BOS 805 – - IP 40 – – – x BOS 807 – 4 mignons IP 40 – – – x BOS 808 – - IP 40 – – – x BOS 900 x - IP 65 – – x x BOS 901 x - IP 65 – – x – BOS 902 x 4 mignons IP 65 – – x – BOS 903 x 2 x 9V block IP 65 – – x – BOS 910 x - IP 65 – – x x BOS 911 x - IP 65 – – x – BOS 912 x 4 mignons IP 65 – – x – BOS 913 x 2 x 9V block IP 65 – – x – 150 BOS 400 / 400 ASC / 401 / 401 ASC | Enclosures BOS 400/400 ASC with compartment for 9V block battery Model Order no. A B C Colour BOS 400 34400000 100 65 24 Black BOS 400 ASC 34400500 100 65 24 Black Scope of delivery: Lid, base, battery compartment lid, battery compartment side, screws For BOS 400 ASC, plus integrated clip bearing and bow Note: As an option, 2 micro batteries can be inserted in the enclosure by using battery holder BH 2 MC (order no.: 34165572). Wall fitting for ASC types: see general accessories. BOS 401/401 ASC Model Order no. A B C Colour BOS 401 34401000 100 65 24 Black BOS 401 ASC 34401500 100 65 24 Black Scope of delivery: Lid, base, screws For BOS 400 ASC, plus integrated clip bearing and bow Note: As an option, 2 micro batteries can be inserted in the enclosure by using battery holder BH 2 MC (order no.: 34165572). Wall fitting for ASC types: see general accessories. 24 (C) 100 (A) 83 65 65 (B) 50 18,8 For accessories, please see the end of the chapter Z-2803235 151 BOS 500 / 501 / 502 / 503 | Enclosures BOS 500 with panoramic display screen and compartment for 9V block battery Model Order no. A B C Colour BOS 500 34500000 120 60 25 Black BOS 500 34500003 120 60 25 Agate grey Scope of delivery: Lid, base, front panel, battery compartment lid, screw, panoramic display screen BOS 501 with display screen and compartment for 9V block battery Model Order no. A B C Colour BOS 501 34501000 120 60 25 Black BOS 501 34501002 120 60 25 Agate grey Scope of delivery: Lid, base, front panel, battery compartment lid, screw, display screen BOS 502 without display cut-out, with compartment for 9V block battery Model Order no. A B C Colour BOS 502 34502000 120 60 25 Black BOS 502 34502002 120 60 25 Agate grey Scope of delivery: Lid, base, front panel, battery compartment lid, screws BOS 503 with continuous membrane keypad area and compartment for 9V block battery Model Order no. A B C Colour BOS 503 34503000 120 60 25 Black BOS 503 34503001 120 60 25 Agate grey Scope of delivery: Lid, base, front panel, battery compartment lid, screws 60 (B) 78,8 120 (A) 53 47,6 152 25 (C) * = Available on request 19,5 Z-2803236 BOS 600 / 601 / 602 | Enclosures BOS 600 with display screen and compartment for 9V block battery Model Order no. A B C Colour BOS 600 34600000 172 77 25 Black Scope of delivery: Lid, base, 2 front panels, screws, battery compartment lid, display screen BOS 601 with continuous membrane keypad area and compartment for 9V block battery Model Order no. A B C Colour BOS 601 34601000 172 77 25 Black Scope of delivery: Lid, base, 2 front panels, screws, battery compartment lid BOS 602 with loudspeaker grille and compartment for 3x 1.5 V mignon batteries Model Order no. A B C Colour BOS 602 34602000 172 77 25 Black Scope of delivery: Lid, base, 2 plastic front panels, screws 25 (C) 166 172 (A) 112 93 77 (B) 52 17,5 For accessories, please see the end of the chapter Z-2803237 153 BOS 700 / 701 / 704 / 705 | Enclosures BOS 700/701 with display opening and compartment for 9V block battery Model Order no. A B C Colour Note BOS 700 34700000 150 80 30 Black Display opening: 23 x 58 mm BOS 701 34701000 150 80 30 Black Display opening: 18 x 48 mm Scope of delivery: Lid, base, front panel, battery compartment lid, screws, threaded inserts Please order display screen separately. BOS 704/705 with display opening, side-fitted slide for switch and compartment for 9V block battery Model Order no. A B C Colour Note BOS 704 34704000* 150 80 30 Black Display opening: 23 x 58 mm BOS 705 34705000 150 80 30 Black Display opening: 18 x 48 mm Scope of delivery: Lid, base, front panel, battery compartment lid, screws, threaded inserts Please order display screen separately. 30 (C) 150 (A) 60 110,7 80 (B) 65 154 * = Available on request 23,6 Z-2803238 BOS 750 - BOS 761 | Enclosures BOS 750 with panoramic display screen and compartment for 9V block battery Model Order no. A B C Colour BOS 750 34750000 157 84 30 Black BOS 750 34750001 157 84 30 Agate grey Scope of delivery: Lid, base, front panel, battery compartment lid, screws, panoramic display screen BOS 751 with display screen and compartment for 9V block battery Model Order no. A B C Colour BOS 751 34751000 157 84 30 Black BOS 751 34751001 157 84 30 Agate grey Scope of delivery: Lid, base, front panel, battery compartment lid, screws, display screen, slide BOS 752 with continuous membrane keypad area and compartment for 9V block battery Model Order no. A B C Colour BOS 752 34752000 157 84 30 Black BOS 752 34752001 157 84 30 Agate grey Scope of delivery: Lid, base, front panel, battery compartment lid, screws BOS 753 with panoramic display screen Model Order no. A B C Colour BOS 753 34753000 157 84 30 Black Scope of delivery: Lid, base, front panel, screws, panoramic display screen BOS 754 with display screen Model Order no. A B C Colour BOS 754 34754000 157 84 30 Black BOS 754 34754001 157 84 30 Agate grey Scope of delivery: Lid, base, front panel, screws, display screen BOS 755 with continuous membrane keypad area Model Order no. A B C Colour BOS 755 34755000 157 84 30 Black BOS 755 34755001 157 84 30 Agate grey Scope of delivery: Lid, base, front panel, screws BOS 756 with panoramic display screen, side-fitted slide for switch and compartment for 9V block battery Model Order no. A B C Colour BOS 756 34756000 157 84 30 Black Scope of delivery: Lid, base, front panel, battery compartment lid, screws, panoramic display screen, slide For accessories, please see the end of the chapter 155 BOS 750 - BOS 761 | Enclosures BOS 757 with display screen, side-fitted slide for switch and compartment for 9V block battery Model Order no. A B C Colour BOS 757 34757000 157 84 30 Black Scope of delivery: Lid, base, front panel, battery compartment lid, screws, display screen, slide BOS 758 with continuous membrane keypad area and side-fitted slide for switch and compartment for 9V block battery Model Order no. A B C Colour BOS 758 34758000 157 84 30 Black Scope of delivery: Lid, base, front panel, battery compartment lid, screws, slide BOS 759 with panoramic display screen and side-fitted slide for switch Model Order no. A B C Colour BOS 759 34759000 157 84 30 Black Scope of delivery: Lid, base, front panel, battery compartment lid, screws, panoramic display screen, slide BOS 760 with display screen, side-fitted slide for switch Model Order no. A B C Colour BOS 760 34760000 157 84 30 Black Scope of delivery: Lid, base, front panel, battery compartment lid, screws, display screen, slide BOS 761 with continuous membrane keypad area and side-fitted slide for switch Model Order no. A B C Colour BOS 761 34761000 157 84 30 Black Scope of delivery: Lid, base, front panel, battery compartment lid, screws, slide 84 (B) 110,8 157 (A) 86 70 156 30 (C) * = Available on request 24 Z-2803239 BOS 800 - BOS 808 | Enclosures BOS 800 with panoramic display screen and compartment for 4 x 1.5 mignon batteries Model Order no. A B C Colour BOS 800 34800000 196 100 40 Black BOS 800 34800001 196 100 40 Agate grey Scope of delivery: Lid, base, front panel, screws, battery compartment lid, contacts, panoramic display screen BOS 801 with display screen and compartment for 4 x 1.5 mignon batteries Model Order no. A B C Colour BOS 801 34801000 196 100 40 Black BOS 801 34801001* 196 100 40 Agate grey Scope of delivery: Lid, base, front panel, screws, battery compartment lid, contacts, display screen BOS 802 without display cut-out, with compartment for 4 x 1.5 V mignon batteries Model Order no. A B C Colour BOS 802 34802000 196 100 40 Black BOS 802 34802001* 196 100 40 Agate grey Scope of delivery: Lid, base, front panel, screws, battery compartment lid, contacts BOS 803 with panoramic display screen Model Order no. A B C Colour BOS 803 34803000 196 100 40 Black BOS 803 34803001* 196 100 40 Agate grey Scope of delivery: Lid, base, front panel, screws, panoramic display screen BOS 804 with display screen Model Order no. A B C Colour BOS 804 34804000 196 100 40 Black BOS 804 34804001 196 100 40 Agate grey Scope of delivery: Lid, base, front panel, screws, display screen BOS 805, without display cut-out Model Order no. A B C Colour BOS 805 34805000 196 100 40 Black BOS 805 34805001* 196 100 40 Agate grey Scope of delivery: Lid, base, front panel, screws BOS 807 with continuous membrane keypad area and compartment for 4 x 1.5 V mignon batteries Model Order no. A B C Colour BOS 807 34807000 196 100 40 Black BOS 807 34807001 196 100 40 Agate grey Scope of delivery: Lid, base, front panel, screws, battery compartment lid, contacts For accessories, please see the end of the chapter 157 BOS 800 - BOS 808 | Enclosures BOS 808 with continuous membrane keypad area Model Order no. A B C Colour BOS 808 34808000 196 100 40 Black BOS 808 34808001 196 100 40 Agate grey Scope of delivery: Lid, base, front panel, screws, battery compartment lid, contacts 40 (C) 187,1 196 (A) 92,5 121,25 100 (B) 80 158 * = Available on request 34 Z-2803240 BOS 900 - BOS 903 | Enclosures BOS 900 Model Order no. A B C Colour BOS 900 34900009 211 100 26 Black BOS 900 34900000 211 100 26 Agate grey Scope of delivery: Lid with seal, base, screws, display screen (enclosed unfitted) Note: Fitting of display screen on request BOS 901 with carrying strap and tip-up foot Model Order no. A B C Colour BOS 901 34901009* 211 100 26 Black BOS 901 34901000 211 100 26 Agate grey Scope of delivery: Lid with seal, base, carrying strap, tip-up foot, screws, display screen (enclosed unfitted) Note: Fitting of display screen on request BOS 902 with carrying strap and compartment for 4 x 1.5 V mignon batteries Model Order no. A B C Colour BOS 902 34902009 211 100 26 Black BOS 902 34902000 211 100 26 Agate grey Scope of delivery: Lid with seal, base with battery compartment including contacts, carrying strap, screws, display screen (enclosed unfitted) Note: Fitting of display screen on request BOS 903 with carrying strap and compartment for 2 x 9V block batteries Model Order no. A B C Colour BOS 903 34903009* 211 100 26 Black BOS 903 34903000 211 100 26 Agate grey Scope of delivery: Lid with seal, base with battery compartment, carrying strap, screws, display screen (enclosed unfitted) Note: Fitting of display screen on request 26 (C) 131,5 202,4 211 (A) 100 (B) 75 81 20,5 For accessories, please see the end of the chapter Z-2803241 159 BOS 910 - BOS 913 | Enclosures BOS 910 Model Order no. A B C Colour BOS 910 34910009 224 106 40 Black BOS 910 34910002 224 106 40 Agate grey Scope of delivery: Lid with seal, base, screws, display screen (enclosed unfitted) Note: Fitting of display screen on request BOS 911 with tip-up foot Model Order no. A B C Colour BOS 911 34911009 224 106 40 Black BOS 911 34911000 224 106 40 Agate grey Scope of delivery: Lid with seal, base, self-tapping screws, tip-up foot, display screen Note: Fitting of display screen on request BOS 912 with compartment for 4 x 1.5 V mignon batteries Model Order no. A B C Colour BOS 912 34912009 224 106 40 Black BOS 912 34912000 224 106 40 Agate grey Scope of delivery: Lid with seal, base with battery compartment including contacts, screws, display screen (enclosed unfitted) Note: Fitting of display screen on request BOS 913 with compartment for 2 x 9V block batteries Model Order no. A B C Colour BOS 913 34913000 224 106 40 Agate grey BOS 913 34913009* 224 106 40 Black Scope of delivery: Lid with seal, base with battery compartment, screws, display screen (enclosed unfitted) Note: Fitting of display screen on request 106 (B) 131,5 215,4 224 (A) 40 (C) 75 81,8 160 * = Available on request 34 Z-2803242 BOS 500 – 913 | Accessories Front panels BOS 500-503, ABS Model Order no. Frontplatte IR 34955006 Frontplatte Alu 34055000 Scope of delivery: 1 front panel Note: IR = Infrared-permissive Note For BOS 500/501/502/503 For BOS 500/501/502/503 Display screens BOS 700-705, polycarbonate Model Order no. Displayscheibe 26000800 Scope of delivery: 1 display screen Note For BOS 700/701/704/705 Intermediate frame BOS 900-903 Model Order no. Colour Note ZR 900 34900909 Black For BOS 900/901/902/903 ZR 900 34900900 Agate grey For BOS 900/901/902/903 Scope of delivery: Intermediate frame, mounted seal, 6 screws Table stand BOS 900-903 / BOS 910-913 Model Order no. STD 900 34900029* STD 900 34900002 Scope of delivery: Lid, base, screws Colour Note Black For BOS 900/901/902/903/910/911/912/913 Agate grey For BOS 900/901/902/903/910/911/912/913 Display adapter BOS 910-913 Model Order no. ADS 910-I 34913001* ADS 910-II 34913002* ADS 910-III 34913003* Scope of delivery: 2 plastic parts, 4 screws Model ADS 910-I ADS 910-II ADS 910-III Type Adapter for graphic-type displays, 128 x 64 dots Adapter for graphic-type displays, 128 x 64 dots Adapter for graphic-type displays, 16 characters, 4 lines Display fitting dimensions 77 x 60 68 x 64,92 82 x 55 161 Powered by TCPDF (www.tcpdf.org)
BOS501 价格&库存
很抱歉,暂时无法提供与“BOS501”相匹配的价格&库存,您可以联系我们找货
