SparkFun Stepoko Motion Control Add-On
Kit
T OL-1 3757 ROHS
images are CC BY-NC-SA 3.0
Description: Need a bit more than just a SparkFun Stepoko controller? The Stepoko
Motion Control Add-On Kit provides you with everything you need to get your CNC
moving, powered, and controlled. This add-on will allow you to convert a simple
mechanical kit into a full CNC machine! Inside each kit you will find our SparkFun
Stepoko board, four NEMA23 stepper motors, an enclosure milled to hold the
Stepoko, a 24V/5A power supply, a toggle switch, and 6ft A-B USB cable. Just add
your own rig (like the Shapeoko 3) and you are ready to get started.
The included SparkFun Stepoko is an Arduino compatible, 3-axis control solution with
pre-installed grbl software and is able to connect to your computer to accept stepper
motor commands. Additionally, the four stepper motors found in this kit are ideal for
CNC projects by offering 125 oz.in of torque, 200 steps/rev, and adhere to a NEMA23
form factor.
Note: This kit does NOT come with a power cable to connect the power supply to
your specific wall outlet. This way you will be able to use your own cable that fits your
country’s national standard.
Includes:
1x SparkFun Stepoko
4x Stepper Motor - 125 oz.in (200 steps/rev)
1x Power Supply - 24V 5A
1x USB Cable A to B - 6 Foot
1x Toggle Switch
1x Big Red Box Enclosure (Milled)
https://www.sparkfun.com/products/13757
11/24/2015
很抱歉,暂时无法提供与“TOL-13757”相匹配的价格&库存,您可以联系我们找货
