Adafruit LED Sequins - Royal Blue - Pack of 5
PRODUCT ID: 1757
Description
Sew a little sparkle into your wearable project with an Adafruit LED Sequin. These are the kid-sister to
our popular Flora NeoPixel, they only show a single color and they don't have digital control, but that
makes them smaller easier to use for many projects.
Simply connect 3 to 6VDC to the + pin and ground to the - pin, and the LED on the board will light up. You
can make the LEDs fade and twinkle by using the PWM (a.k.a. analogWrite) functionality of your Gemma
or Flora, or just connect directly to a digital I/O pin of a microcontroller to turn on and off. Or even skip
the micro altogether, and power directly from a LiPoly or coin battery.
This order comes with 5 Royal Blue "1206 size" LEDs, matched with a 100 ohm resistor. When powered
from 3.3V they draw about 5mA so you can put up to 4 or 5 in parallel on a single microcontroller pin.
We also have these sequins in warm white, emerald green, ruby red, and rose pink.
Technical Details
4mm x 9mm / .16" x .35"
2mm thick
Holes are 7mm / .28" apart
Datasheet for blue 1206 LED
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1757”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+34.497611+4.27942
