112040000
    SEEED(矽递科技)
    XADOW STORAGE
112040000 数据手册
      Xadow - Storage SKU 112040000    DISCONTINUED  This item is no longer available.    Description  Most AVRs have a small EEPROM which can be used to save variables, configuration setting etc. Like Chip Atmega32u4 Xadow Main Board used has 1K Bytes Internal EEPROM. If you want more storage for your Xadow project, this module is designed for you! This module supplies two extra 32K byte for your project. The Xadow Storage can be powered by 3.3V. And it is compatible with Xadow system.    Note: This module is not compatible with any other Xadow version 2 or RePhone modules.    SPECIFICATION     Work Voltage: 3.3V   Control Mode: I²C   EEPROM: AT24C256C   I²C Address are convertible    Xadow is a though small but perfectly formed Arduino(TM) compatible board series containing several modules. It's a kit extremely suitable for space-sensitive projects such as wearable devices & arts designs, which have higher request on size, weight and flexible cascade connection.  You can find more modules here.    DOCUMENTS  Please visit our wiki page for more info about this product. It will be appreciated if you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum.  Technical Details  Dimensions 0mm x 0mm x 0mm  Weight  G.W 9g      Battery  Exclude  ECCN/HTS  ECCN Not Available  HSCODE  8471709000                                                            https://www.seeedstudio.com/Xadow‐Storage‐p‐1625.html/12‐10‐18
112040000 价格&库存
很抱歉,暂时无法提供与“112040000”相匹配的价格&库存,您可以联系我们找货
