K000003
K000003
    ARDUINO
    KIT TINKERKIT PRO
K000003 数据手册
Datasheet Arduino TinkerKit Pro K000003 The Pro Kit is a pack of different TinkerKit Modules, aimed to start designing interactive environments / prototype interfaces without using the breadboard or the soldering iron. The Pro Kit consists in 2 Sensor Shield V.2, 13 different Sensors and 12 Actuators, cables, and more. Kit Includes: Description Sensor Shield V.2 Button Module LDR Module Tilt Module Therm Module Accelerometer Module Hall Sensor Rotary Potentiometer Module Linear Potentiometer Module Touch Sensor Module Joystick Module Relay Module Mosfet Module High Power Led Module 5mm Blue Led Module 5mm Green Led Module 5mm Yellow Led Module 5mm Red Led Module 10mm Green Led Module 10mm Blue Led Module 10mm Yellow Led Module 10mm Red Led Module 20cm Cables 50cm Cables 100cm Cables Part Number T020010 T000180 T000090 T000190 T000200 T000020 T000070 T000140 T000150 T000220 T000030 T010010 T010020 T010111 T010112 T010113 T010114 T010116 T010115 T010117 T010118 T020060 T020070 T020080 Arduino TinkerKit Pro available at Mouser Electronics: Quantity 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 4 2 1 K000003 Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet
K000003 价格&库存
很抱歉,暂时无法提供与“K000003”相匹配的价格&库存,您可以联系我们找货
