3227
    ADAFRUIT
    WASHER FLAT 3/8 NYLON
3227 数据手册
Project Kit for Android Things™ PRODUCT ID: 3227 Description Welcome to the Internet of Things with Google! Whether you are a device creator prototyping a new design for production, or a hobbyist looking for an introduction to the new Android Things API, you've come to the right place. It's time to get your Android enabled hardware working with Google services. Android Things is an Android-based OS that supports new embedded single board computer like the Raspberry Pi 3 and introduces a new set of Hardware API for Android to access GPIO, SPI, I2C, PWM and UART peripherals. This kit will supply you with peripherals for your Intel Edison or Raspberry Pi 3, so you can get your feet wet with the new Android Things API and start exploring and developing on the platform. If you're planning on using this with the Pi 3, we recommend that you pick up the Raspberry Pi 3 Board Pack as well. This kit will allow you to run through official samples, "getting started" tutorials, and build your first Android Things projects. Kit includes: Assembled Adafruit BMP280 I2C or SPI Barometric Pressure & Altitude Sensor x 1 Assembled Quad Alphanumeric Display ‐ Yellow 0.54" Digits w/ I2C Backpack x 1 Piezo Buzzer ‐ PS1240 x 1 Micro servo x 1 Premium Male/Male Jumper Wires ‐ 20 x 3" (75mm) Premium Male/Male Jumper Wires ‐ 20 x 6" (150mm) Colorful Round Tactile Button Switch Assortment ‐ 15 pack Half‐size breadboard x 1 Through‐Hole Resistors ‐ 470 ohm 5% 1/4W ‐ Pack of 25 Through‐Hole Resistors ‐ 10K ohm 5% 1/4W ‐ Pack of 25 Diffused 10mm Red LED x 1 Diffused 10mm Green LED x 1 Diffused 10mm Blue LED x 1 Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3227”相匹配的价格&库存,您可以联系我们找货
