TW-DIY-5180
TW-DIY-5180
    TWIN
    KIT UHF REMOTE CONTROL 4CH RLLNG
TW-DIY-5180 数据手册
title Page 1 of 1 TW-DIY-5180 Rolling Code 4-Channel UHF Remote Control Kit - DIY This is one very clever remote control. With rolling code, it s close-toimpossible to electronically crack . With four channels, all either latching or momentary operation, it s extremely versatile. With a sensitive prebuilt receiver, it s long range. With up-to-16 keyring-size transmitters, it s go-anywhere. And the kit even includes the keyring! • Parts List : 4-Channel Code-Hopping Remote Control 1 TX-4312RSA 4-channel keyring rolling code transmitter assembly zoom photo 1 RX3302D A1.5 433MHz rolling code receiver module 1 PC board, coded K180, 86 x 78mm 4 miniature relays, SPDT, PCB mounting, 12V coils (Millionspot H5000xx) 1 ultramini pushbutton mounting, N-O contacts switch, PC 6 interlocking 2-way terminal blocks, PC mounting 2 14-pin DIL IC sockets (optional) 4 3-way header pin sets, PC mounting Red & black insulated hookup wire for power connection 1 200mm length insulated hookup wire for antenna (see text) Semiconductors 2 4013 dual D flipflops (IC1, IC2) 4 NPN general purpose (C8050 or similar) (Q1-Q4) transistors 1 7805 3-terminal regulator (REG1) 4 1A power diodes, 1N4004 or similar (D1 -D4) 4 red LEDS, 5mm (LED1-LED4) 1 green LED, 5mm (LED 5) Capacitors 2 100╡F, electrolytics 16VW PC mounting 7 0.1╡F polyester or ceramic (monolithic 5mm) Resistors 4 10MΩ 1 1MΩ 4 4.7kΩ 4 2.2kΩ 1 1kΩ http://twinind.com/catalog_detail.php?id=246 5/14/2012
TW-DIY-5180 价格&库存
很抱歉,暂时无法提供与“TW-DIY-5180”相匹配的价格&库存,您可以联系我们找货
