Arduino Starter kit FRENCH
FRENCH EDITION - FRENCH LANGUAGE
This kit walks you through the basics in a hands-on way, with creative projects you build by
learning, thanks to a selection of the most common and useful electronic components with a
selection of 15 projects that start from a low complexity, in order to let you learn the basic of
electronic, to a major one, using components that let you control the physical world throw
different kind of sensor.
Once you have mastered this knowledges, you will have a palette of software and circuits that
you can use to create something beautiful, and make someone smile with what you invent, that
is the reason why you will find more components than the required from the projects of the
book. Then build it, hack it and share it. Because arduino is you!
The kit includes:
1
1
1
1
1
1
70
2
6
3
10
1
1
1
1
1
8
8
8
3
1
1
1
1
2
5
2
5
3
5
5
3
1
5
5
10
5
5
Arduino Projects Book (170 pages) - French
Arduino UNO board rev.3
USB cable
Breadboard
Easy-to-assemble wooden base
9v battery snap
Solid core jumper wires
Stranded jumper wires
Photoresistor
Potentiometer 10kilohm
Pushbuttons
Temperatursensor
Tilt sensor
LCD alphanumeric (16x2 characters)
LED (bright white)
LED (RGB)
LEDs (red)
LEDs (green)
LEDs (yellow)
LEDs (blue)
Small DC motor 6/9V
Small servo motor
Piezo capsule
H-bridge motor driver
Optocouplers
Transistor
Mosfet transistors
Capacitors 100nF
Capacitors 100uF
100pF capacitor
Diodes
Trasparent gels (red, green, blue)
Male pins strip (40x1)
Resistors 220 ohm
Resistors 560 ohm
Resistors 1 kilohm
Resistors 4.7 kilohm
Resistors 10 kilohm
Resistors 1 megohm
Resistors 10 megohm
Model: K020007
Shipping Weight: 0.9667Kg
Origin: Italy
http://www.arduinosrl.it/catalog/index.php?main_page=product_info&products_id=423 3/27/2017
很抱歉,暂时无法提供与“K020007”相匹配的价格&库存,您可以联系我们找货
