TW-DIY-5134
TW-DIY-5134
    TWIN
    KIT LCD INTRO W/16X2 LCD
TW-DIY-5134 数据手册
title Page 1 of 1 TW-DIY-5134 The aim of this kit is to show how to use a 16x2 alphanumeric Liquid Crystal Display (LCD) with a PC. First we show how to connect it to the parallel port and echo and handle keyboard input. Then we show how to use the LCD to display temperature from a DS1620 Digital Thermometer/Thermostat chip and set the HI & LO triggerpoints in it. All C source code is provided. Introduction to LCD's Kit - DIY Learn how to connect a 2x16 LCD to a PC parallel port. First this kit will show you how to write keystrokes from the PC keyboard to display on the LCD. It will show you how to process this data (rotate the string left and right.) All the code is provided. Second, there is an on-board DS1620 to measure temperature. The temperature is displayed in F or C. Just press a button to display either. With the DS1620 you may set breakpoints to turn a thermostat on/off. We provide all the code to do this. Once the DS1620 is programmed it may be removed and placed in another device for temperature control. Many web references are provided. • PARTS LIST - KIT 134 Resistors (0.25W carbon) zoom photo 10K......................R1-4 ........................ 4 10K trimpot...........VR1.......................... 1 Capacitors 100nF monobloc .........C3...................... 1 10uF electrolytic...C2....................... 1 25V 100uF electrolytic..C1...................... 1 16V Semiconductors 1N4004........................D2..................... 1 1N4148........................D1..................... 1 78L05..........................IC2 1 ................... +5V regulator, TO-92 package DS1620 ......................IC1 ....................1 Digital Thermometer and Thermostat Liquid Crystal Display..LCD 16 x 2, no b/l .. 1 Miscellaneous 2.5mm jack ...............X2.................. 1 DC PCB mounting D25 connector..................X1.................. 1 PCB mounting, right-angle, male 5pin SIL header...............X3................. 1 8-pin IC socket .........for IC1................. 1 14-pin SIL LCD................. 1 socket 14-pin SIL LCD................ 1 header... ......for ...for Screw, 2.6mm x 18mm long2 Nut, 2.6mm . 6 PCB, K134...................................................... 1 http://twinind.com/catalog_detail.php?id=242 5/14/2012
TW-DIY-5134 价格&库存
很抱歉,暂时无法提供与“TW-DIY-5134”相匹配的价格&库存,您可以联系我们找货
