Standalone AVR ISP Programmer Shield Kit
- includes blank chip!
PRODUCT ID: 462
Description
This shield kit pack will allow you to turn any Arduino into an AVR chip burner! It is specifically designed
for people who want to program Atmega328P's to turn them into Arduino bootloader chips using an AVRISP sketch, but it can also be used to make a 'standalone' AVR ISP programmer - so that you can program
blank chips without a computer! We use this set up in the shop to program chips for our kits. We even
include a blank ATmega328P DIP chip so you can get to programming immediately!
If you want to program Arduino bootloaders onto chips, using the IDE, check out our simple tutorial which
shows how to solder up the kit and the sketch for bootloading
If you want to create a stand-alone AVR ISP programmer, we have a tutorial for that as well Note that this
is a little more challenging to set up than the first tutorial above, because you'll need to paste in the HEX
file, and set up the standalone programmer for your specific code. It's best used by advanced
microcontroller geeks who are comfortable with looking up fuse settings!
Comes with:
o
o
o
o
Adafruit Proto Shield for Arduino Kit
28 pin, 0.3" ZIF socket
Piezo beeper
Blank ATmega328P chip - ready for you to mess around with, program, and reprogram!
You'll also need some solid core wire for the connections, soldering tools and basic hand tools. An Arduino
is not included, you'll need one to plug the shield into, and a USB cable to program it as well.
Technical Details
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“462”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+198.302561+23.95715
