K000005
K000005
    ARDUINO
    KIT TINKERKIT LAB
K000005 数据手册
Datasheet Arduino TinkerKit LAB K000005 The Scuola Lab is a complete pack of different TinkerKit Modules and Arduino accessories to kick-start your school's Lab. The Scuola Lab consists in 10 Sensor Shield V.2, 10 Arduino Uno Boards, every kind of sensors and actuators in different quantities, 2 Ethernet Shields, 10 Proto PCBs, 5 Kit Workshop Without Arduino and a copy of "Getting Started With Arduino" by Massimo Banzi. Kit Includes: Description Arduino Uno Board Proto PCB x 15mm Strip 6 and 8 ways x strip 40x1 Kit Workshop Base Level Without Arduino Board Ethernet Shield Getting Started With Arduino Sensor Shield V.2 Button Module LDR Module Tilt Module Therm Module Accelerometer Module Hall Sensor Rotary Potentiometer Module Linear Potentiometer Module Touch Sensor Module Joystick Module Relay Module Mosfet Module High Power Led Module 5mm Green Led Module 5mm Yellow Led Module 5mm Red Led Module 10mm Green Led Module 10mm Blue Led Module 10mm Yellow Led Module 10mm Red Led Module 20cm Cables 50cm Cables 100cm Cables USB Cables A/B Part Number A000046 A000024 A000040 A000026 A000028 A000056 A000035 T020010 T000180 T000090 T000090 T000200 T000020 T000070 T000140 T000150 T000220 T000030 T010010 T010020 T010112 T010113 T010114 T010116 T010115 T010117 T010118 T020060 T020070 T020080 Arduino TinkerKit LAB available at Mouser Electronics: Quantity 5 10 10 4 5 Datasheet 2 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 4 2 1 20 Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet Datasheet K000005 Datasheet Datasheet Datasheet Datasheet Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Arduino: K000005
K000005 价格&库存
很抱歉,暂时无法提供与“K000005”相匹配的价格&库存,您可以联系我们找货
