3345
    ADAFRUIT
    METROSTARTERPACK
3345 数据手册
Adafruit Metro Starter Pack PRODUCT ID: 3345 Description Heard about Arduino compatibles but not sure how to start? The Adafruit Metro is a ATmega328 based  development board that we use a lot for our own products. Since it is shaped the same, and code/shield‐ compatible with the Arduino UNO R3 design, our Adafruit Metro is easy to use and hacker friendly and this  is the perfect beginner kit for learning how to use the Adafruit Metro! If you want this pack with an official Arduino UNO, check out the Starter Pack for Arduino!  This bundle is designed to get you started quickly and easily on your path of learning electronics. Once  you've received your starter pack you can follow the introductory tutorials here on my site, designed for  everyone, even people with little or no electronics and programming experience. The starter pack has  everything you need (except tools) for most of the lessons.  Just sub in the Adafruit Metro for the Arduino  UNO R3 and you'll be all set! It includes: Adafruit Metro 328 w/ Headers ‐ The Adafruit Metro ‐ assembled and ready to go, including 4 rubber feet MicroUSB Cable ‐ Perfect for connecting your Metro to a computer Protoshield Kit ‐ Get hacking with the best prototyping shield out there! Tiny Breadboard ‐ Fits on top of the protoshield, easy to use 9V DC regulated wall adapter ‐ You can power your Metro from any wall socket. This switching regulator is  efficient and small and works with US (110V) and European (220V) power. 9V Battery case with switch and a 2.1mm plug‐ so you can power your Metro using a 9V battery. This case  is much sturdier than just a battery clip and it has an on/off switch too! Note that this comes unassembled Tutorial starter pack parts ‐ Includes a 10K potentiometer, 1K potentiometer, 2 small pushbuttons, 5 red  diffused bright LEDs, one each of red, green and blue ultra‐bright LED, 5 100 ohm resistors, 5 1K resistors, 5  10K resistors, and a CdS photocell sensor. Also includes 65 flexible breadboard wires in 8 colors, perfect for use with the solderless breadboard. Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3345”相匹配的价格&库存,您可以联系我们找货
