Anodized Aluminum Metal Chasis for a Mini
Robot Rover
PRODUCT ID: 2943
DESCRIPTION
OK the name is a little...utilitarian? But this Anodized Aluminum Metal Chasis for a
Mini Robot Rover does exactly what it says. You can build a very sturdy (and quite
handsome!) little robot rover with this metal frame.
It's made of aluminum so it's light and strong.
The anodizing is quite lovely to boot
Can be used to build a 2-wheel or 4-wheel robot
Tons of mounting holes & slots!
Easy to modify because you can drill and cut aluminum
Wont crack or break if it falls down the stairs (it happens)
Remember, this is just the metal frame chassis! Motors, wheels, motor driver,
microcontroller, etc are not included! It's specifically designed to use either our
Micro Continuous Rotation Servo or DC Motor in Micro Servo Body. You'll need to
grab either 2 or 4 of those. You will also want 2 or 4 wheels, they snap onto the
motors so you can scoot around. If you have a two-wheel'er, also grab a supporting
swivel wheel. Finally, you can add a cute little topper if you like. Then, any
microcontroller and motor/servo driver can be used to build up your robot.
https://www.adafruit.com/products/2943
1/15/2016
Technical Details
Dimensions: 156mm x 74mm x 25mm / 6.1" x 2.9" x 0.98"
Weight: 47.3g
很抱歉,暂时无法提供与“2943”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+112.702671+13.62135
