PLA/PHA bambooFill for 3D Printers 1.75mm Diameter - 600g
PRODUCT ID: 2475
Description
Having a 3D printer without filament is sort of like having a regular printer without paper or ink. And
while a lot of printers come with some filament there's a good chance you've been printing up a storm and
need something new. That's why we've started carrying a complete line of 3D printing filament in a variety
of colors!
This PLA/PHA bambooFill blend 1.75mm 600g spool from colorFabb is a great material for 3D printers.
This amazing one of a kind filament will allow you to print with actual recycled bamboo at home! Your
prints will look absolutely amazing and your 3d printer cave will smell like a woodshop!
Tips: Start out with a bit rougher layers, 0.2 – 0.27mm (for 0.4mm nozzle) this will ensure that you’re
printing with a decent amount of material flow. This is important because it will make sure the material
isn’t spending too much time in the hot-zone of the 3D printer, which will degrade the polymer.
This filament has been tested successfully on a wide variety of printers, working well on both heated and
non-heated build platforms. For those users printing on a cold build platform colorFabb advises applying
blue painter's tape to the build area. For heated build platforms colorFabb used a temperature of 55-60°C
which will keep the print sticking to the platform. It can be printed straight on glass or with a bit of
gluestick applied to it. They've also printed it succesfully on kapton tape with the same temperature
settings. Testing showed reliable results using the all metal hot-ends, such as the E3D and the Makerbot
Replicator 2 hotend. Hotends which use a teflon isolator coupler can generate adhesion to the bamboo
filament possibly leading to clogs and is there for not recommended for novice users yet.
Technical Details
Please note: PLA/PHA filament cannot be used with New Matter MOD-t 3D printers.
o
o
o
o
o
Advised 3D printing temperature: 195-220°C
Advised 3D print speed: 40 - 100 mm/s
Advised Heated bed (if you have one, not strictly necessary): 50-60° C
Diameter Tolerance: ± 0.05mm
Glass Transition Temperature: 55°C
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2475”相匹配的价格&库存,您可以联系我们找货
