Mini Solderless Breadboard - 4x4 Points
PRODUCT ID: 2463
Description
Add a micro-slice standard solderless breadboard to your Perma-Proto or other perf-board. This 4x4 point
solder-less breadboard is a good way to add some solderless prototyping space if you just need to have a
couple points.
Comes with one 18mm x 13mm x 10mm piece of solder-less breadboard. There are four white posts on the
bottom for PCB positioning, but you can cut them off with diagonal cutters if you dont want them.
Technical Details
o
o
o
4 rows of 4 holes
Breadboard: 18mm x 13mm x 10mm /
Weight: 2g
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2463”相匹配的价格&库存,您可以联系我们找货
