1518
    ADAFRUIT
    FIXED IND 100UH 750MA 1.2 OHM
1518 数据手册
Page 1 of 2 PROTOTYPING / BREADBOARDS Adafruit Flex Perma-Proto - Half-sized Breadboard Flex-PCB PRODUCT ID: 1518 Page 2 of 2 DESCRIPTION - Make your next project super-flexy with a prototyping board that can twist and bend. We took our lovely classic perma-proto design and had it made from incredibly thin polyamide film. It's extremely bendable, and you can cut it easily with scissors. It has a bend radius of 1cm or better (you can also crease it but that might break a trace if you crease a trace) and you can solder any components to the pads. Sensors? Wearables? Tubular-tronics? We have no idea what people are going to use it for but we know it is going to be awesome. The flex PCB is really floppy, so you may need to support it if you solder electronic components on, it won't stay 'straight' on its own unless given some sort of physical support. Comes as a single flex PCB per order. http://www.adafruit.com/products/1518 7/21/2015
很抱歉,暂时无法提供与“1518”相匹配的价格&库存,您可以联系我们找货
    • 250+65.60953
