Perma-Proto Mint Tin Size Breadboard PCB
PRODUCT ID: 723
Description
Making a project that will fit into a "Altoids" Mint Tin? Put down that PCB shear and pick up a PermaProto in the new exciting minty shape!
Customers have asked us to carry basic perf-board, but we never liked the look of most basic perf:
its always crummy quality, with pads that flake off and no labeling. Then we thought about how
people actually prototype - usually starting with a solderless breadboard and then transferring the
parts to a more permanent PCB. That's when we realized what people would really like is a proto
board that makes it easy!
This proto‐board is the PCB you always wish you had, but never realized it! We took the basic layout of a
half‐sized breadboard, extended it to the size of a mint tin and turned that into a beautiful PCB. The top
side has a white silkscreen, and the same markings you're familiar with, to make transferring components
easy. The bottom has 30 rows of 5‐hole pad design that matches a classic breadboard, with 4 power bus
lines on the sides, and no mask so you can easily cut traces when necessary. There are another 80 holes for
general wiring on the edges. We used 1.2mm diameter drill holes so even parts with big leads will fit. All
holes are thru‐plated for strength ‐ these wont peel off with rework. The finish is a gold plate ‐ you won't
get oxidation like with bare copper perf! There are also four big mounting holes so you can attach the PCB
to the tin. A perfect match for a Altoids‐sized mint tin
Comes one per package. Once you use a Perma-Proto board, you'll never go back!
Technical Details
30 rows of double 5-hole rows + 80 individual holes
4 power rails with positive/negative markings
3.6" x 2.24" (92mm x 57mm), 0.063" thick FR4
1.2mm / 0.047" drill holes
Four 3.0mm mounting holes, 3" x 1.65" square
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“723”相匹配的价格&库存,您可以联系我们找货
