793
    ADAFRUIT
    ROUND SPACER #10 NYLON 5/8"
793 数据手册
PROTOTYPING / WIRING Premium Female/Female Jumper Wires - 40 x 12" (300mm) PRODUCT ID: 793 DESCRIPTION - Handy for making wire harnesses or jumpering between headers on PCB's. These premium jumper wires are 12" (300mm) long and come in a 'strip' of 40 (4 pieces of each of ten rainbow colors). They have 0.1" female header contacts on either end and fit cleanly next to each other on standard-pitch 0.1" (2.54mm) header. The best part is they come in a 40-pin ribbon cable. You can always pull the ribbon wires off to make individual jumpers, or keep them together to make neatly organized wire harnesses. We have these in three handy lengths: 3"/75mm, 6"/160mm and 12"/300mm. If you want the male/male type, we have those too! For best results, when plugging these in a line, have the sides with the 'silver latch bit' sticking out since that side is a tiny bit wider than 0.1" http://www.adafruit.com/products/793 7/16/2015
很抱歉,暂时无法提供与“793”相匹配的价格&库存,您可以联系我们找货
    • 1+69.60370
