1163
    ADAFRUIT
    SMT ADAPTERS 3 PACK 32QFN/TQFP
1163 数据手册
Page 1 of 3 SMT Breakout PCB for 32-QFN or 32-TQFP - 3 Pack! PRODUCT ID: 1163 Page 2 of 3 DESCRIPTION - Beguiled by a fancy new chip that is only available in a QFP or QFN pinout? This breakout PCB set will make your life much much easier and get you prototyping faster than ever. One side has a 32-QFP pin out with traces going to two rows of 0.1" spaced holes, the other has 32-QFN. Solder your chip to either side and you're ready to rock on any solderless breadboard. Each item comes with three PCBs, each PCB is identical and can support either a 7mm square QFP or 5mm square QFN chip. Standard thickness PCBs, with 0.6" spacing between the two rows. The first run of these has a typo on the top right of the QFP where the pin # are off by one, we'll fix this in the next run of boards. - MAY WE ALSO SUGGEST... SMT Breakout PCB for 44-QFN or (/products/1162) SMT Breakout PCB for SOIC-28 or (/products/1208) Adafruit FPC Stick - 20 Pin (/products/1325) SMT Breakout PCB for SOIC-20 or (/products/1206) SMT Breakout PCB for SOIC-12 or (/products/1211) SMT Breakout PCB for SOIC-16 or (/products/1207) SMT Breakout PCB for 48-QFN or (/products/1377) SMT Breakout PCB Set For SOT-23, (/products/1230) Adafruit Multi-pitch FPC Adapter - (/products/1436) Page 3 of 3 SMT Breakout PCB for SOIC-14 or (/products/1210) SMT Breakout PCB for SOIC-8, (/products/1212) SMT Test Socket - TQFP-32 (/products/1240) + http://www.adafruit.com/product/1163 10/23/2014
很抱歉,暂时无法提供与“1163”相匹配的价格&库存,您可以联系我们找货
    • 1+52.01430
