1833
    ADAFRUIT
    HEX STANDOFF 6-32 BRASS 7/8"
1833 数据手册
USB Micro-B Breakout Board PRODUCT ID: 1833 DESCRIPTION - Simple but effective - this breakout board has a USB Micro-B connector, with all 5 pins broken out. Great for pairing with a microcontroller with USB support, or adding USB 5V power to a project. We use a micro-AB connector with through-hole shielding pads for an excellent strong connection - it won't rip off by accident! Comes with one fully assembled and tested micro B breakout PCB and a small stick of 0.1" header so you can solder it on and plug into a breadboard. http://www.adafruit.com/products/1833 10/5/2015 Technical Details Dimensions: 10mm x 20mm x 4mm / 0.4" x 0.8" x 0.2" Height (w/ out micro USB connector): 1mm / 0.04" Weight: 0.64g
很抱歉,暂时无法提供与“1833”相匹配的价格&库存,您可以联系我们找货
    • 1+19.51059
