Adafruit 50 pin 0.5mm pitch FPC Adapter ID: 1492
DESCRIPTION
Page 1 of 2
Page 2 of 2
Connect to those pesky 0.5mm pitch connectors that you may run across with an
FPC stick. We designed this for use in house, to quickly connect to 50pin 0.5mm
pitch flex cables we need to test. But we also thought it might be useful for our
customers. There's a 50-pin long connector on top, and we have one very long
'mechanical' pad. Since the pad extends along the entire length you can use any
size 0.5mm pitch connector you wish, we seem to bump into 40 and 50 pin the
most. Each pad is broken out to a 25-pin long 0.1"x0.1" spaced header. One side is
doubled on the opposite side to make it bread-board friendly. It can accommodate
most ZIF and snap connectors and will make prototyping much easier on you!
Each order comes with a single PCB stick, no header or other connectors included.
http://www.adafruit.com/products/1492
2/23/2015
很抱歉,暂时无法提供与“1492”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.317861+4.03849
