Adafruit Multi-pitch FPC Adapter - 40 Pin 0.5/0.6/0.7/0.8/1.0mm ID: 1436
DESCRIPTION
Page 1 of 2
Page 2 of 2
You will roll lucky 7's and connect to nearly any kind of FPC/flex cable with
Ladyada's Super Lucky 40-pin FPC to breadboard adapter plate. You get 40 pads of
0.5mm, 0.6mm, 0.7mm, 0.8mm or 1.0mm. It may even work for some 2.0mm
pitch connectors. We designed this for use in house, to quickly connect to FPCs we
need to test. But we also thought it might be useful for our customers. Each pad is
broken out to both a 2x20 0.1" spaced header as well as two strips of 20-pin long
0.1" spaced header 2.1" inches apart. It can accommodate most ZIF and snap
connectors or just solder the FPC directly on. This adapter will make prototyping
much easier on you!
Each order comes with a single-sided PCB plate no header or other connectors
included.
http://www.adafruit.com/products/1436
2/23/2015
很抱歉,暂时无法提供与“1436”相匹配的价格&库存,您可以联系我们找货
