3118
    ADAFRUIT
    WASHER FLAT #4 NYLON
3118 数据手册
HDMI Plug to Terminal Block Breakout PRODUCT ID: 3118 Description Make your own custom HDMI cable or HDMI interface with ease, using this HDMI Terminal Block Breakout. You get a nice solid PCB with an HDMI plug and two strips of terminal blocks that you can use with stranded or solid core wire to quickly assemble your own wiring jigs. If you just need a plain HDMI cable, we have plenty and it's less expensive to just buy a standard cable than DIY it. So, we recommend this adapter when you have some unusual setup or wiring needs like splicing off the I2C or power pins. Comes with one fully assembled breakout and a clip-on housing Technical Details Product Dimensions: 50.6mm x 25.0mm x 16.5mm / 2.0" x 1.0" x 0.6" Product Weight: 15.4g/0.5oz Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3118”相匹配的价格&库存,您可以联系我们找货
