50-1226
    PULSAR
    FILM WHITE TRF 8"X 15'
50-1226 数据手册
Toner Reactive Foils - DecalPro - KITS: “TRF Sampler” (#1299) All 20 Toner Reactive Foils (Metallic, Pigment and Special Effect) used to colorize black toner images, including 2 special effect foils for full color images. - PCB “Fab-In-A-Box” Toner Reactive Foil Set w/Carrier & Cover CONTENTS: • Qty: 20 TRF Foils • Size: 8” wide x 36” long • Carrier Board & Tape • 1/2mil Mylar Cover Sheet • Tack Rag • Metallic Foils: “TRF Flat-Paks” (#1202~1238) Individual foil shades. Flat-Paks are a continuous 15’ length by 8” wide. (Mylar Carrier, below-right, is used for all dry-transfers created.) ALL “PulsarProFX” PRODUCTS: 1: 2: 3: 4: 5: 6: 7: 8: 9: 10: 11: 12: 13: Red Copper Gold Gold (Satin) Green Green (Satin) Aqua Blue (Cobalt) Blue (Royal) Purple Fuchsia Silver Silver (Satin) • Pigment Foils: 14: 15: 16: White Gray Black #1227 #1228 #1230 • Special Effect Foils: 17: 18: 19: 20: Clear Coat Iridescent Holographic Silver Holographic Gold • Carrier Board “cover sheet” 21: #1202 #1204 #1206 #1208 #1210 #1212 #1214 #1216 #1218 #1220 #1221 #1222 #1224 Mylar Carrier foil #1232 #1234 #1236 #1238 #1201 Note: There are 2 silver-looking foils and they are used differently! “Foil 12” (SILVER #1222) is put on top of black toner images, but “Foil 18” (IRIDESCENT #1234) is put under color toner images the same way you would use “Foil 14” (WHITE #1226) as a color toner reflector. Also, “Foil 17” (CLEAR COAT #1232) is a sealant used over color toner and looks just like “Foil 21” (Mylar Carrier #1201). UNPACK & HANG: It is easiest to unwrap and hang the foils vertically on a wall for easy access to the foil you need. Carefully unravel the entire set of foils & set the loose fiberglass Carrier Board aside. Lay this cover sheet over the chipboard stapled to the end of the foils and using a push-pin or tape, mount the foils to a wall with the RED foil to the front. CARRIER BOARD SETUP: Cut off 12” of the clear Mylar foil “cover sheet” (last foil in the stack). Lay the foil over the 11” long Carrier Board - flush to the bottom of the board then wrap the remaining 1” around the top of the board. Center and secure this end with the blue tape. Do not use any other additional cover or “carrier” over this board. The 1/2mil Mylar film allows max heat & pressure to reach the foil to bond to the toner image. 50-1003 - PCB “Fab-In-A-Box” (MINI kit) 50-1006 - Combo (PCB + DecalPro) 50-1004 - DecalPRO (10min Graphics) 50-1001 LAMINATOR: - Applicator (12” 120 vac) 50-1301C SUPPLIES: CLEANING: Using the yellow “Tack Rag”, always wipe down the toner print and the back of the cut-to-size color foil before laying over the toner image. If micro dust particles land over a spec of toner it will raise the foil over it preventing the foil from fusing to the toner. This can be the cause of a little “pits” of black toner showing through the foil color after it has been transferred. - PAPER: Toner Transfer Paper 50-1101 TRANSFERRING FOILS: Flip the Mylar Carrier foil back, lay the printed image face-up over the board and place the cut-to-size foil (color-side up) centered over the print and covering the print’s borders! Lay the Mylar smoothly back down and insert the wraped-around end of the board into the laminator. When the board is grabbed by the rollers, spread your fingers out over the Mylar film applying drag so the foil doesn’t wrinkle. Always make two passes through the laminator. Upon the second exit from the laminator, lift the Mylar Carrier and remove the foil/print off the board. Now peel the color foil back 180º over itself and discard. Voila! - FOIL: GreenTRF (Etching) 50-1225 - FOIL: WhiteTRF (Silkscreen) 50-1226 - FOILS: “DecalPro” 50-1201 ~ 50-1299 - CARRIER BOARD: “DecalPro” 50-1503 COPPER CLAD: 8” x 10” - 2pk Rigid .032” Single Sided 50-1501 - 2pk Rigid .032” Double Sided 50-1502 - 2pk Flex .005” Single Sided 50-1504 - 2pk Flex .005” Double Sided 50-1505 COPPER CLAD: 6” x 8” - 4pk Rigid .032” Single Sided 50-1507 #50-1202 #50-1204 #50-1206 #50-1208 #50-1210 - 4pk Rigid .032” Double Sided 50-1508 - 4pk Sampler (Mixed)... 50-1506 (.005” SS+DS and .032” SS+DS) #50-1212 #50-1221 #50-1214 #50-1222 #50-1216 #50-1218 #50-1220 PIGMENT White PIGMENT Gray #50-1224 #50-1227 #50-1228 #50-1234 #50-1236 #50-1238 SPECIAL OverCoat #50-1230 #50-1232 Shown with Carrier Board supporting printed page ovelaid with foil, passing through the laminator. For more information about our techniques we invite you to visit our website at PulsarProFX.com or call us at (850) 926-2009, 9am-5pm MST
50-1226 价格&库存
很抱歉,暂时无法提供与“50-1226”相匹配的价格&库存,您可以联系我们找货
