50-1101D
50-1101D
    PULSAR
    PAPER TONER TRANSFER, 3500 SHEET
50-1101D 数据手册
Toner Transfer Paper The “Toner Transfer Paper” (or TTP) is a replenishment item used with both the “PCB Fab-In-A-Box” kit for making circuit boards, and the “DecalPro” kit to create professional dry-transfer graphics for enclosures, faceplates... basically any surface, flat or curved. Toner images print perfectly to the transfer paper because the printer sees this as regular soft paper (vs plastic sheet from other processes). On one side of the paper is a barrier coating (Dextrin) that prevents the toner from fusing into the fibers of the paper. Printed Circuit Board Fabrication: The circuit image is laid face-down over the copper-clad surface and subjected to high heat and pressure (using either a calibrated houshold iron or the highly recommended “laminator” (see right-panel >) upon which, the toner image will re-fuse to the copper’s surface. The board and paper combination are then submerged in a tray of water where the Dextrin coating dissolves in 1 minute, releasing the image. ALL “PulsarProFX” PRODUCTS: KITS: - PCB “Fab-In-A-Box” 50-1003 - PCB “Fab-In-A-Box” (MINI kit) 50-1006 - Combo (PCB + DecalPro) 50-1004 - DecalPRO (10min Graphics) 50-1001 LAMINATOR: - Applicator (12” 120 vac) 50-1301C SUPPLIES: - PAPER: Toner Transfer Paper 50-1101 - FOIL: GreenTRF (Etching) 50-1225 - FOIL: WhiteTRF (Silkscreen) 50-1226 - FOILS: “DecalPro” 50-1201 ~ 50-1299 - CARRIER BOARD: “DecalPro” 50-1503 COPPER CLAD: 8” x 10” - 2pk Rigid .032” Single Sided 50-1501 - 2pk Rigid .032” Double Sided 50-1502 - 2pk Flex .005” Single Sided 50-1504 - 2pk Flex .005” Double Sided 50-1505 COPPER CLAD: 6” x 8” - 4pk Rigid .032” Single Sided 50-1507 Rinse the board under tap water, dry and apply the sealing “GreenTRF” foil the same way as before to SEAL the toner image to prevent pitting from etchant getting through the granular toner image. This special foil goes hand-in-hand with the transfer paper. More info is available on our website at “PCBfx.com”. - 4pk Rigid .032” Double Sided 50-1508 - 4pk Sampler (Mixed)... 50-1506 (.005” SS+DS and .032” SS+DS) Dry-Transfer Graphics: The DecalPro process is a stand-alone technique to create an image that is simply rubbeddown over the intended target location with no clear carrier around the image, unlike that of old-fashioned water-slide graphics. More info is available on our website at “DecalProFX.com”. Regarding the recommended ‘laminator’: Although the “direct-etch” (PCB) method for applying an etching mask to copper can be done reliably after doing a simple calibration of a houshold iron, the suggested laminator does make it much easier and faster to use. The DecalPro process on the other hand does REQUIRE the use of the laminator. For more information about our techniques we invite you to visit our website at PulsarProFX.com or call us at (850) 926-2009, 9am-5pm MST
50-1101D 价格&库存
很抱歉,暂时无法提供与“50-1101D”相匹配的价格&库存,您可以联系我们找货
