CR3111-3000
CR3111-3000
    CR(CR)
    CURRSENSEXFMR400AWIRELEAD
CR3111-3000 数据手册
Split Core Current Transformer CR3100 Series The CR3100 Series Split Core Current Transformer is designed to provide a low cost method to monitoring electrical current. A unique hinge and locking snap allows attachment without interrupting the current-carrying wire. High secondary turn will develop signals up to 10.0 VAC across a burden resistor. CR3110-3000 Current Transformers CR3109-1500 F Applications Portable Instruments Sub-Metering Monitor Motor Loads Features Small Size Low Cost High Secondary Turns Secure Locking Hinge CR3111-3000 CR3113-2000 Specifications Maximum Continuous Primary Current Insulation Voltage Storage Temp. Operating Temp. PART NUMBERS CR3109 CR3110 CR3111 CR3113 - 1500 3000 3000 2000 30 AMP 75 AMP 100 AMP 150 AMP 4 X Ir 3500 Vac/1min -45°C thru +85°C -40°C thru +65 °C Regulatory Agencies SPLIT CORE CURRENT TRANSFORMERS Part Number CR3109-1500 CR3110-3000 CR3111-3000 CR3113-2000 Imax 30 75 100 150 Vmax RMS 5 15 19 16 DCR Ω 187 440 390 58 Te (typ.) 1510 3100 3150 2125 Frequency 20 - 1 KHz 20 - 1 KHz 20 - 1 KHz 20 - 1 KHz CR3110-3000 ONLY Ir = Maximum Input Current to be linearly sensed Vmax = Maximum Voltage (Saturation) CT will develop Te = Effective turns ratio including losses (All Specifications tested at 60 Hz) I DCR R OUTLINE DRAWING A B D E VL = Vmax C - I x DCR Te V= V IxR Te For best linearity, choose R such that V < 0.8 VL F VL Part Number CR3109-1500 CR3110-3000 CR3111-3000 CR3113-2000 The Professional Energy Monitoring Company M N TI ISO 9001:2008 Quality Management System A B C D E F 0.76 (19.2) 1.00 (25.5) 1.24 (31.4) 2.68 (68.7) 0.19 (4.90) 0.40 (10.2) 0.62 (15.7) 0.98 (24.9) 1.24 (31.5) 1.57 (40.0) 1.77 (45.0) 2.56 (65.0) 6.10 (1.55) 5.91 (150) 6.10 (155) 118 (3000) 0.82 (20.8) 1.04 (26.5) 1.22 (31.0) 0.72 (18.4) 0.20 (5.08) 0.24 (6.10) 0.20 (5.08) 0.20 (5.08) I 3500 Scarlet Oak Blvd. St. Louis MO USA 63122 V: 636-343-8518 F: 636-343-5119 Web: http://www.crmagnetics.com 102 E-mail: sales@crmagnetics.com
CR3111-3000 价格&库存
很抱歉,暂时无法提供与“CR3111-3000”相匹配的价格&库存,您可以联系我们找货
