Page 01/02
Current Transformer
dϭϬϲϬ
Product Type
AMGIS Part Number
Customer Part Number
Place of Manufacture
SCHEMATIC:
(K)
(L)
(2)
(1)
ELECTRICAL SPECIFICATION:
Volt/Amp at rated Ip for different loads
Rated input current
= 60Amps
Primary to Secondary isolation
Operating Frequency
Turns Ratio
DC Resistance
Output Voltage
Io @ Vrms : 7.41V
Ratio Correction factor (RCF*)
100Ω
500Ω
2000Ω
5000Ω
= 2500VAC
= 50 / 60 Hz
0.10
0.44
0.66
0.76
= 1 : 1000
= 24.00 Ω
= 6.0V @ 60A / 100Ω, 0.3600W
= 1250µArms
= 1.001@10% (Multiply current reading by this factor to compensate for transformer losses)
MECHANICAL SPECIFICAITON :
38.10
1
10.16
3
2
Front View
Ø1
4. 6
Pin Side View
OUTPUT RESPONSE vs INPUT CURRENT @ RATED BURDEN :
38.10
(L)
(K)
1
3
3xØ1.0
5±1
Marking Area
2
16.50
33.00
All dimensions are in mm
Linear dimensional tolerance ±0.2mm
Note : Un-Used pin → #3
AMGIS, LLC * 10899 Kinghurst St. Ste. 220 Houston, TX 77099
Phone: 832-775-1319 * Fax: 281-933-9067* email: sales@amgistoroids.com
Toll Free: 877-762-6447 * www.amgistoroids.com
Page 02/02
TYPICAL EXCITATION CURVE :
RATIO ERROR (%) vs RATED BURDEN @ INPUT CURRENT :
TRAFO WEIGHT:
MARKING INFORMATION:
Approx. Weight = 0.0652 kg / pc
L01-6218
Ac yr / wk code
Dot mark for Start pin identification
-----------------Initial Issue----------------Changes
1
Issue
Rev
Balaji. R
Initial
18-Nov'2015
Date
很抱歉,暂时无法提供与“CT-1060”相匹配的价格&库存,您可以联系我们找货
