L01 Series 50 / 60 Hz PC Mount Toroidal Transformers
SCHEMATIC
6
1
PRI1
SEC1
2
3
5
8
PRI2
SEC2
Specifications valid for all types:
Input voltage
2x115V, 50/60Hz
0.5KVAC (prim-prim & sec-sec)
HV test
4KVAC (prim-sec)
Ambient Temperature T 70 ºF
Isolation class VDE* F 155 ºC
Safety Approval
VDE, UL, CE
*Refer to next page
7
4
D
E
1
2
3
4
A
8
7
6
5
C
B
*top view
DIMENSIONS – L01 SERIES
VA RATING
L
W
H
A
B
C
D
E
1.6
39.60
39.60
18.50
35.56
35.56
25.40
30.48
20.32
3.2
44.70
44.70
19.50
40.64
40.64
30.48
35.56
25.40
5
49.70
49.70
19.50
45.72
45.72
35.56
40.64
30.48
7
49.70
49.70
23.10
45.72
45.72
35.56
40.64
30.48
10
55.00
55.00
26.00
50.80
50.80
40.64
45.72
35.56
15
60.00
60.00
26.30
55.88
55.88
45.72
50.80
40.64
25
60.00
60.00
37.50
55.88
55.88
45.72
50.80
40.64
35
72.00
72.00
37.50
66.04
66.04
55.88
60.96
50.80
50
82.40
82.40
37.50
76.20
76.20
66.04
71.12
60.96
*in mm
Amgis LLC • 10899 Kinghurst St. Ste. 220 • Houston, Texas 77099
Phone: 832-775-1319 • Fax (832)775-1317
Technical: info@amgistoroids.com • Sales: sales@amgistoroids.com • www.amgistoroids.com
1.6 VA
3.2 VA
5 VA
7 VA
10 VA
15 VA
25 VA
35 VA
50 VA
Part Number
L01-6300
L01-6301
L01-6302
L01-6303
L01-6304
* L01-6305
2x
2x
2x
2x
2x
2x
Secondary
7V
114 mA
9V
89 mA
12V
67 mA
15V
53 mA
18V
44 mA
22V
36 mA
No load voltage
2 x 9V
2 x 11.6V
2 x 15.4V
2 x 19.3V
2 x 23.4V
2 x 28.2V
Resistance 20°C
2 x 8.80Ω
2 x 15.8Ω
2 x 26.9Ω
2 x 43.4Ω
2 x 65.9Ω
2 x 88.1Ω
Weight total = 80 g
Weight Cu = 20 g
Efficiency = 77%
External Fuse 32mA (stb) at 230V
Fixing = M4 threaded screw
Part Number
L01-6310
L01-6311
L01-6312
L01-6313
* L01-6314
* L01-6315
2x
2x
2x
2x
2x
2x
Secondary
7V
229 mA
9V
178 mA
12V
133 mA
15V
107 mA
18V
89 mA
22V
73 mA
No load voltage
2 x 10.2V
2 x 13.0V
2 x 17.3V
2 x 21.4V
2 x 25.7V
2 x 31.3V
Resistance 20°C
2 x 7.0Ω
2 x 11.3Ω
2 x 20.7Ω
2 x 28.9Ω
2 x 45.4Ω
2 x 62.2Ω
Weight total = 110 g
Weight Cu = 26 g
Efficiency = 70%
Part Number
L01-6320
L01-6321
L01-6322
L01-6323
* L01-6324
* L01-6325
2x
2x
2x
2x
2x
2x
Secondary
7V
357 mA
9V
278 mA
12V
208 mA
15V
167 mA
18V
139 mA
22V
114 mA
No load voltage
2 x 9.7V
2 x 12.4V
2 x 17.0V
2 x 21.3V
2 x 25.5V
2 x 30.5V
Resistance 20°C
2 x 4.0Ω
2 x 6.5Ω
2 x 12.3Ω
2 x 19.0Ω
2 x 28.8Ω
2 x 39.1Ω
Weight total = 144 g
Weight Cu = 33 g
Efficiency = 68%
External Fuse 50mA (stb) at 230V
Part Number
L01-6330
L01-6331
L01-6332
L01-6333
L01-6334
* L01-6335
2x
2x
2x
2x
2x
2x
Secondary
7V
500 mA
9V
389 mA
12V
292 mA
15V
233 mA
18V
194 mA
22V
159 mA
No load voltage
2 x 9.5V
2 x 12.2V
2 x 16.2V
2 x 20.3V
2 x 24.3V
2 x 29.7V
Resistance 20°C
2 x 2.5Ω
2 x 4.1Ω
2 x 7.7Ω
2 x 12.0Ω
2 x 17.9Ω
2 x 24.4Ω
Weight total = 174 g
Weight Cu = 36 g
Efficiency = 74%
External Fuse 63mA (stb) at 230V
Part Number
L01-6340
L01-6341
L01-6342
L01-6343
L01-6344
* L01-6345
2x
2x
2x
2x
2x
2x
Secondary
7V
714 mA
9V
556 mA
12V
417 mA
15V
333 mA
18V
278 mA
22V
227 mA
No load voltage
2 x 8.3V
2 x 10.8V
2 x 14.4V
2 x 18.0V
2 x 21.7V
2 x 26.3V
Resistance 20°C
2 x 1.0Ω
2 x 1.7Ω
2 x 3.2Ω
2 x 5.0Ω
2 x 7.5Ω
2 x 10.3Ω
Weight total = 252 g
Weight Cu = 45 g
Efficiency = 82%
External Fuse 80mA (stb) at 230V
Part Number
L01-6350
L01-6351
L01-6352
L01-6353
L01-6354
* L01-6355
2x
2x
2x
2x
2x
2x
Secondary
7V
1071 mA
9V
833 mA
12V
625 mA
15V
500 mA
18V
417 mA
22V
341 mA
No load voltage
2 x 8.9V
2 x 11.1V
2 x 14.8V
2 x 18.5V
2 x 22.2V
2 x 27.2V
Resistance 20°C
2 x 0.85Ω
2 x 1.3Ω
2 x 2.3Ω
2 x 3.1Ω
2 x 5.3Ω
2 x 7.4Ω
Weight total = 304 g
Weight Cu = 57 g
Efficiency = 80%
External Fuse 100mA (stb) at 230V
Part Number
L01-6360
L01-6361
L01-6362
L01-6363
L01-6364
* L01-6365
2x
2x
2x
2x
2x
2x
Secondary
7V
1785 mA
9V
1377 mA
12V 1041 mA
15V
832 mA
18V
694 mA
22V
568 mA
No load voltage
2 x 8.3V
2 x 10.7V
2 x 14.3V
2 x 17.8V
2 x 21.4V
2 x 26.2V
Resistance 20°C
2 x 0.4Ω
2 x 0.7Ω
2 x 1.3Ω
2 x 2.0Ω
2 x 2.7Ω
2 x 4.1Ω
Weight total = 435 g
Weight Cu = 85 g
Efficiency = 83%
External Fuse 160mA (stb) at 230V
Part Number
L01-6370
L01-6371
L01-6372
L01-6373
L01-6374
* L01-6375
2x
2x
2x
2x
2x
2x
Secondary
7V
2500 mA
9V
1944 mA
12V 1458 mA
15V 1167 mA
18V
972 mA
22V
795 mA
No load voltage
2 x 8.2V
2 x 10.6V
2 x 14.0V
2 x 17.6V
2 x 20.9V
2 x 25.7V
Resistance 20°C
2 x 0.19Ω
2 x 0.32Ω
2 x 0.53Ω
2 x 0.84Ω
2 x 1.10Ω
2 x 1.34Ω
Weight total = 590 g
Weight Cu = 187 g
Efficiency = 82%
External Fuse 200mA (stb) at 230V
Fixing = M5 threaded screw
Part Number
L01-6380
L01-6381
L01-6382
L01-6383
L01-6384
* L01-6385
2x
2x
2x
2x
2x
2x
Secondary
7V
3571 mA
9V
2777 mA
12V 2083 mA
15V 1666 mA
18V 1389 mA
22V 1136 mA
No load voltage
2 x 8.1V
2 x 10.4V
2 x 13.9V
2 x 17.3V
2 x 20.8V
2 x 25.4V
Resistance 20°C
2 x 0.13Ω
2 x 0.20Ω
2 x 0.34Ω
2 x 0.54Ω
2 x 0.82Ω
2 x 1.25Ω
Weight total = 800 g
Weight Cu = 209 g
Efficiency = 85%
External Fuse 315mA (stb) at 230V
* Not Applicable for VDE
很抱歉,暂时无法提供与“L01-6332”相匹配的价格&库存,您可以联系我们找货
