LOW PROFILE MINIATURE TRANSFORMERS
Electrical Specification @20°C
Amgis
P/N
XF-10200
XF-10201
XF-10202
1.6 VA
XF-10203
XF-10204
XF-10205
Rated Secondary
Voltage/Current
2 x 7V
114 mA
2 x 9V
89 mA
2 x 12V
67 mA
2 x 15V
53 mA
2 x 18V
44 mA
2 x 22V
36 mA
No load
voltage
(Uo)
2 x 8.94V
2 x 11.63V
2 x 15.43V
2 x 19.30V
2 x 23.41V
2 x 28.19V
XF-10206
XF-10207
XF-10208
3.2 VA
XF-10209
XF-10210
XF-10211
2x
2x
2x
2x
2x
2x
7V
9V
12V
15V
18V
22V
229
178
133
107
89
73
mA
mA
mA
mA
mA
mA
2x
2x
2x
2x
2x
2x
10.20V
13.00V
17.30V
1.5(mA)
21.40V
25.70V
31.30V
XF-10212
XF-10213
XF-10214
5.0 VA
XF-10215
XF-10216
XF-10217
2x
2x
2x
2x
2x
2x
7V
9V
12V
15V
18V
22V
357
278
208
167
139
114
mA
mA
mA
mA
mA
mA
2x
2x
2x
2x
2x
2x
9.92V
12.72V
17.11V
2.0(mA)
21.37V
25.49V
31.19V
XF-10218
XF-10219
XF-10220
7.0 VA
XF-10221
XF-10222
XF-10223
2x
2x
2x
2x
2x
2x
7V
9V
12V
15V
18V
22V
500
389
292
233
194
159
mA
mA
mA
mA
mA
mA
2x
2x
2x
2x
2x
2x
9.09V
11.71V
15.75V
3.0(mA)
19.61V
23.72V
28.52V
XF-10224
XF-10225
XF-10226
10.0 VA
XF-10227
XF-10228
XF-10229
2x
2x
2x
2x
2x
2x
7V
9V
12V
15V
18V
22V
714
556
417
333
278
227
mA
mA
mA
mA
mA
mA
2x
2x
2x
2x
2x
2x
8.30V
10.80V
14.40V
3.0(mA)
18.00V
21.70V
26.30V
XF-10230
XF-10231
XF-10232
15.0 VA
XF-10233
XF-10234
XF-10235
2x
2x
2x
2x
2x
2x
7V
9V
12V
15V
18V
22V
1071
833
625
500
417
341
mA
mA
mA
mA
mA
mA
2x
2x
2x
2x
2x
2x
8.90V
11.10V
14.80V
4.0(mA)
18.50V
22.20V
27.20V
XF-10236
XF-10237
XF-10238
25.0 VA
XF-10239
XF-10240
XF-10241
2x
2x
2x
2x
2x
2x
7V
9V
12V
15V
18V
22V
1786
1389
1042
833
694
568
mA
mA
mA
mA
mA
mA
2x
2x
2x
2x
2x
2x
8.30V
10.70V
14.24V
5.0(mA)
17.80V
21.40V
26.20V
XF-10242
XF-10243
XF-10244
35.0 VA
XF-10245
XF-10246
XF-10247
2x
2x
2x
2x
2x
2x
7V
9V
12V
15V
18V
22V
2500
1944
1458
1167
972
795
mA
mA
mA
mA
mA
mA
2x
2x
2x
2x
2x
2x
8.24V
10.60V
14.00V
7.0(mA) 17.7
17.60V
20.90V
25.70V
XF-10248
XF-10249
XF-10250
50.0 VA
XF-10251
XF-10252
XF-10253
2x
2x
2x
2x
2x
2x
7V
9V
12V
15V
18V
22V
3571
2778
2083
1667
1389
1136
mA
mA
mA
mA
mA
mA
2x
2x
2x
2x
2x
2x
8.10V
10.40V
13.80V
8.0(mA) 15.5
17.30V
20.70V
25.40V
Rating
All dimensions are in mm
Data subject to change without prior notice
No
Load
Reg.
current
1.0(mA)
29
41
45
34
Temp
rise
in °C
10
25
24
27
ƞ in %
77
70
70
74
82
81
Wt.
in g
Coil size
OD x ID x H
71
37.5
x
7.0
x
17.0
89
42.0
x
7.0
x
17.5
115
47.0
x
6.0
x
18.0
145
47.0
x
6.8
x
21.5
216
53.5
x
6.8
x
23.5
262
57.5
x
7.0
x
24.0
SCHEMATIC:
* Primaries & Secondaries are intended for both
series and parallel connections
FINISHED ASSEMBLY:
ADDITIONAL FEATURES:
-Primary intended to use in 115V or 230V @ 50/60Hz
-UL recognition for class A insulation
-UL recognized to UL5085-1 and UL5085-2, UL file
E310463
-C-UL recognized to CSA C22.2 no 66. UL file E310403
19
28
31
30
84
85
86
388
58.0
x
13.8
x
34.5
453
72.0
x
17.0
x
33.5
670
78.0
x
22.5
x
35.0
-Design construction meet UL 1950, VDE 0805, IEC 950,
eeeeeeeeeeeEe
EN60950
-Hipot testing between Pri to Sec 4000V (VDE0550)
-Maximum ambient temperature +60°C
-Center hole Potted for M4 bolt
很抱歉,暂时无法提供与“XF-10229”相匹配的价格&库存,您可以联系我们找货
