10/3/22, 1:35 AM
Low Voltage/Filament - Economical Single Primary - 0.63 VA to 288 VA (166 Series) - Hammond Mfg.
Quality Products. Service Excellence.
VA 166 Series
Open Style, Chassis Mount - 115 V Primary
Features
Economical single primary 115 VAC, 60 Hz. (or 117 50/60 Hz. see table) - (If you require
117/234 or 50/60 Hz. operation or dual secondaries check out our versatile 266 Series.
Most secondaries are center tapped (C.T.), VAC (RMS) - see table for details.
Open style, channel bracket, two hole chassis mount.
Minimum 6" long leads.
Dual bobbin design - no electrostatic shield required.
We use Class B insulation (130 degrees, C) for extra protection - UL listed as a Class A
(105 degree, C) design
Hi-Pot test of 2,000V RMS.
UL listed.
CSA certified.
https://www.hammfg.com/electronics/transformers/power/166
1/5
10/3/22, 1:35 AM
Primary
Secondary (R.M.S.)
Overall Dimensions
Mounting
Part No.
VA
(VAC)
VAC
Amps
A
B
C
D
166S2
25
115V 60 Hz.
2.5 C.T.
10
3.69
2.00
2.31
3.13
E
0.19
Dimensions
Ref
C
166F2
0.63
115V 60 Hz.
2.5 C.T.
0.25
2.06
1.25
1.19
1.75
0.19
C
166G2
1.25
115V 60 Hz.
2.5 C.T.
0.5
2.06
1.25
1.19
1.75
0.19
C
166J2
2.5
115V 60 Hz.
2.5 C.T.
1
2.06
1.38
1.19
1.75
0.19
C
166K2
3.75
115V 60 Hz.
2.5 C.T.
1.5
2.38
1.38
1.38
2.00
0.19
C
166L2
6.25
115V 60 Hz.
2.5 C.T.
2.5
2.81
1.50
1.69
2.38
0.19
C
166M2
7.5
115V 60 Hz.
2.5 C.T.
3
2.81
1.50
1.69
2.38
0.19
C
166Q2
15
115V 60 Hz.
2.5 C.T.
6
3.25
1.63
2.00
2.81
0.19
C
166R5
40
115V 60 Hz.
5 C.T.
8
3.69
2.00
2.31
3.13
0.19
C
166S5
50
115V 60 Hz.
5 C.T.
10
3.69
2.13
2.31
3.13
0.19
C
166U5
75
115V 60 Hz.
5 C.T.
15
4.03
2.25
2.63
3.56
0.19
C
166RS
40
115V 60 Hz.
5 C.T.
8
4.50
2.50
3.00
4.00
0.20
C
166V5
100
115V 60 Hz.
5 C.T.
2.50
3.00
4.00
0.20
C
166F5
1.25
115V 60 Hz.
5 C.T.
0.25
2.06
1.25
1.19
1.75
0.19
C
166G5
2.5
115V 60 Hz.
5 C.T.
0.5
2.06
1.38
1.19
1.75
0.19
C
166J5
5
115V 60 Hz.
5 C.T.
1
2.38
1.50
1.38
2.00
0.19
C
166L5
10
115V 60 Hz.
5 C.T.
2
2.81
1.63
1.69
2.38
0.19
C
166MS
15
115V 60 Hz.
5 C.T.
3
3.25
1.75
2.00
2.81
0.19
C
166M6
18.9
117V 50/60 Hz.
6.3 C.T.
3
3.25
2.00
2.00
2.81
0.19
C
166Q6
37.8
115V 60 Hz.
6.3 C.T.
6
3.69
2.00
2.31
3.13
0.19
C
166S6
63
115V 60 Hz.
6.3 C.T.
10
4.03
2.25
2.63
3.56
0.19
C
2/5
10/3/22, 1:35 AM
Primary
Secondary (R.M.S.)
Overall Dimensions
Mounting
Part No.
VA
(VAC)
VAC
Amps
A
B
C
D
E
Dimensions
166E6
0.95
115V 60 Hz.
6.3 C.T.
0.15
2.06
1.25
1.19
1.75
0.19
Ref
C
166F6
1.89
115V 60 Hz.
6.3 C.T.
0.3
2.06
1.38
1.19
1.75
0.19
C
166G6
3.78
115V 60 Hz.
6.3 C.T.
0.6
2.38
1.38
1.38
2.00
0.19
C
166G6B
3.78
117V 50/60 Hz.
6.3 C.T.
0.6
2.38
1.38
1.38
2.00
0.19
C
166J6
6.3
115V 60 Hz.
6.3 C.T.
1
2.81
1.50
1.69
2.38
0.19
C
166K6
7.56
115V 60 Hz.
6.3 C.T.
1.2
2.81
1.50
1.69
2.38
0.19
C
166K6B
7.56
117V 50/60 Hz.
6.3 C.T.
1.2
2.81
1.50
1.69
2.38
0.19
C
166L6
12.6
115V 60 Hz.
6.3 C.T.
2
2.81
1.63
1.69
2.38
0.19
C
166N6
25.2
115V 60 Hz.
6.3 C.T.
4
3.25
1.75
2.00
2.81
0.19
C
166G7
4.9
115V 60 Hz.
7 C.T.
0.7
2.38
1.50
1.38
2.00
0.19
C
166U7
112.5
115V 60 Hz.
7.5 C.T.
15
4.50
2.50
3.00
4.00
0.20
C
166G8
4
115V 60 Hz.
8 C.T.
0.5
2.38
1.38
1.38
2.00
0.19
C
166N8
34
115V 60 Hz.
8.5 C.T.
4
3.25
2.00
2.00
2.81
0.19
C
166J8
8.5
115V 60 Hz.
8.5 C.T.
1
2.81
1.50
1.69
2.38
0.19
C
166L8
17
115V 60 Hz.
8.5 C.T.
2
3.25
1.63
2.00
2.81
0.19
C
166M8
25.5
115V 60 Hz.
8.5 C.T.
3
3.25
1.75
2.00
2.81
0.19
C
166G9
4.5
115V 60 Hz.
9 C.T.
0.5
2.38
1.38
1.38
2.00
0.19
C
166M10
30
115V 60 Hz.
10 C.T.
3
3.25
2.00
2.00
2.81
0.19
C
166N10
40
115V 60 Hz.
10 C.T.
4
3.69
2.00
2.31
3.13
0.19
C
166P10
50
115V 60 Hz.
10 C.T.
5
3.69
2.13
2.31
3.13
0.19
C
166R10
80
115V 60 Hz.
10 C.T.
8
4.03
2.50
2.63
3.56
0.19
C
166S10
100
115V 60 Hz.
10 C.T.
10
4.50
2.50
3.00
4.00
0.20
C
166F10
3
115V 60 Hz.
10 C.T.
0.3
2.06
1.38
1.19
1.75
0.19
C
166G10
5
115V 60 Hz.
10 C.T.
0.5
2.38
1.50
1.38
2.00
0.19
C
166J10
10
115V 60 Hz.
10 C.T.
1
2.81
1.63
1.69
2.38
0.19
C
166L10
115V 60 Hz.
10 C.T.
2
3.25
1.75
2.00
2.81
0.19
C
166P11
55
115V 60 Hz.
11 C.T.
5
3.69
2.13
2.31
3.13
0.19
C
166S11
110
115V 60 Hz.
11 C.T.
10
4.50
2.50
3.00
4.00
0.20
C
166C12
0.63
115V 60 Hz.
6.3/12.6 C.T.
.1/.05
2.06
1.25
1.19
1.75
0.19
C
166N12B
48
117V 50/60 Hz.
12 C.T.
4
3.69
2.00
2.31
3.13
0.19
C
166E12
1.8
115V 60 Hz.
12 C.T.
0.15
2.06
1.38
1.19
1.75
0.19
C
166F12B
3.6
115V 60 Hz.
12 C.T.
0.3
2.38
1.38
1.38
2.00
0.19
C
166F12C
4.2
115V 60 Hz.
12 C.T.
0.35
2.38
1.38
1.38
2.00
0.19
C
166F12D
4.2
117V 50/60 Hz.
12
0.35
2.38
1.38
1.38
2.00
0.19
C
166GD12
8.4
117V 50/60 Hz.
12
0.7
2.81
1.63
1.69
2.38
0.19
C
166JA12
12
115V 60 Hz.
12 C.T.
1
2.81
1.63
1.69
2.38
0.19
C
166K12
14.4
115V 60 Hz.
12 C.T.
1.2
3.25
1.63
2.00
2.81
0.19
C
166JB12
14.4
117V 50/60 Hz.
12
1.2
3.25
1.75
2.00
2.81
0.19
C
166LA12
24
115V 60 Hz.
12 C.T.
2
3.25
1.75
2.00
2.81
0.19
C
166K12B
18.9
117V 50/60 Hz.
12.6 C.T.
1.5
3.25
2.00
2.00
2.81
0.19
C
166L12B
25.2
117V 50/60 Hz.
12.6 C.T.
2
3.25
2.00
2.00
2.81
0.19
C
166L12
31.5
115V 60 Hz.
12.6 C.T.
2.5
3.25
2.00
2.00
2.81
0.19
C
166M12
37.8
117V 50/60 Hz.
12.6 C.T.
3
3.69
2.13
2.31
3.13
0.19
C
166N12
50.4
115V 60 Hz.
12.6 C.T.
4
3.69
2.13
2.31
3.13
0.19
C
166Q12
75.6
115V 60 Hz.
12.6 C.T.
6
4.03
2.25
2.63
3.56
0.19
C
166R12
100.8
115V 60 Hz.
12.6 C.T.
8
4.50
2.50
3.00
4.00
0.20
C
166F12
3.78
115V 60 Hz.
12.6 C.T.
0.3
2.38
1.38
1.38
2.00
0.19
C
166G12
6.3
115V 60 Hz.
12.6 C.T.
0.5
2.81
1.50
1.69
2.38
0.19
C
166J12
12.6
115V 60 Hz.
12.6 C.T.
1
2.81
1.63
1.69
2.38
0.19
C
166J12B
12.6
117V 50/60 Hz.
12.6 C.T.
1
3.25
1.75
2.00
2.81
0.19
C
166L14
28
115V 60 Hz.
14 C.T.
2
3.25
2.00
2.00
2.81
0.19
C
166Q14
84
115V 60 Hz.
14 C.T.
6
4.03
2.50
2.63
3.56
0.19
C
166F14
3.5
115V 50/60 Hz.
14 C.T.
0.25
2.38
1.35
1.43
2.00
0.19
C
166E14
2.1
115V 60 Hz.
14 C.T.
0.15
2.06
1.38
1.19
1.75
0.19
C
166G14
7
115V 60 Hz.
14 C.T.
0.5
2.81
1.50
1.69
2.38
0.19
C
3/5
10/3/22, 1:35 AM
Primary
Secondary (R.M.S.)
Overall Dimensions
Mounting
Part No.
VA
(VAC)
VAC
Amps
A
B
C
D
E
Dimensions
166J14
14
115V 60 Hz.
14 C.T.
1
2.81
1.63
1.69
2.38
0.19
Ref
C
166L16
35.2
115V 60 Hz.
16 C.T.
2.2
3.25
2.00
2.00
2.81
0.19
C
166M16
48
115V 60 Hz.
16 C.T.
3
3.69
2.13
2.31
3.13
0.19
C
166F16
4
115V 60 Hz.
16 C.T.
0.25
2.38
1.38
1.38
2.00
0.19
C
166G16
8
115V 60 Hz.
16 C.T.
0.5
2.81
1.50
1.69
2.38
0.19
C
166J16
16
115V 60 Hz.
16 C.T.
1
3.25
1.63
2.00
2.81
0.19
C
166B18
0.54
115V 60 Hz.
9/18 C.T.
.06/.03
2.06
1.25
1.19
1.75
0.19
C
166J18
18
115V 50/60 Hz.
18 C.T.
1
3.25
2.00
2.00
2.81
0.19
C
166L18
36
115V 50/60 Hz.
18 C.T.
2
3.69
2.13
2.31
3.13
0.19
C
166M18
54
115V 60 Hz.
18 C.T.
3
3.69
2.13
2.31
3.13
0.19
C
166N18
72
115V 60 Hz.
18 C.T.
4
4.03
2.25
2.63
3.56
0.19
C
166P18
90
115V 60 Hz.
18 C.T.
5
4.03
2.50
2.63
3.56
0.19
C
166E18
5.4
115V 60 Hz.
18 C.T.
0.3
2.38
1.50
1.38
2.00
0.19
C
166K18
27
115V 60 Hz.
18 C.T.
1.5
3.25
1.75
2.00
2.81
0.19
C
166L20
40
115V 60 Hz.
20 C.T.
2
3.69
1.88
2.31
3.13
0.19
C
166D20
2
115V 60 Hz.
20 C.T.
0.1
2.06
1.38
1.19
1.75
0.19
C
166E20
3
115V 60 Hz.
20 C.T.
0.15
2.06
1.38
1.19
1.75
0.19
C
166F20
6
115V 60 Hz.
20 C.T.
0.3
2.38
1.50
1.38
2.00
0.19
C
166G20
10
115V 60 Hz.
20 C.T.
0.5
2.81
1.63
1.69
2.38
0.19
C
166J20
115V 60 Hz.
20 C.T.
1
3.25
1.75
2.00
2.81
0.19
C
166L22
44
115V 60 Hz.
22 C.T.
2
3.69
2.13
2.31
3.13
0.19
C
166A24
0.63
115V 60 Hz.
12.6/25.2 C.T.
.05/.025
2.06
1.25
1.19
1.75
0.19
C
166T24
288
117V 50/60 Hz.
24 C.T.
12
3.75
3.60
4.63
3.00
166J24
24
117V 50/60 Hz.
24
1
3.25
2.00
2.00
2.81
0.19
C
3.00
0.20
0.38
B
166L24
48
115V 60 Hz.
24 C.T.
2
3.69
2.13
2.31
3.13
0.19
C
166M24
72
115V 60 Hz.
24 C.T.
3
4.03
2.25
2.63
3.56
0.19
C
166N24
96
115V 60 Hz.
24 C.T.
4
4.50
2.50
3.00
4.00
0.20
C
166C24
2.04
115V 60 Hz.
24 C.T.
0.085
2.06
1.38
1.19
1.75
0.19
C
166EA24
4.8
115V 60 Hz.
24 C.T.
0.2
2.38
1.50
1.38
2.00
0.19
C
166FB24
9.6
117V 50/60 Hz.
24 C.T.
0.4
2.81
1.63
1.69
2.38
0.19
C
166GD24B
16.8
117V 50/60 Hz.
24 C.T.
0.7
3.25
1.75
2.00
2.81
0.19
C
166JB24
24
115V 60 Hz.
24 C.T.
1
3.25
1.75
2.00
2.81
0.19
C
166J25B
25
117V 50/60 Hz.
25 C.T.
1
3.25
2.00
2.00
2.81
0.19
C
166K25
37.5
115V 60 Hz.
25 C.T.
1.5
3.69
1.88
2.31
3.13
0.19
C
166L25
50
115V 60 Hz.
25 C.T.
2
3.69
2.13
2.31
3.13
0.19
C
166M25
75
115V 60 Hz.
25 C.T.
3
4.03
2.25
2.63
3.56
0.19
C
166D25
2.5
115V 60 Hz.
25 C.T.
0.1
2.06
1.38
1.19
1.75
0.19
C
166E25
3.75
115V 60 Hz.
25 C.T.
0.15
2.38
1.38
1.38
2.00
0.19
C
166F25
7.5
115V 60 Hz.
25 C.T.
0.3
2.81
1.50
1.69
2.38
0.19
C
166G25
12.5
115V 60 Hz.
25 C.T.
0.5
2.81
1.63
1.69
2.38
0.19
C
166J25C
25
117V 50/60 Hz.
25
1
3.25
2.00
2.00
2.38
0.19
C
166J25
25
115V 60 Hz.
25 C.T.
1
3.25
1.75
2.00
2.81
0.19
C
166L25B
50.4
115V 50/60 Hz.
25.2 C.T.
2
4.03
2.25
2.63
3.56
0.19
C
166J28
28
115V 60 Hz.
28 C.T.
1
3.25
2.00
2.00
2.81
0.19
C
166L28
56
115V 60 Hz.
28 C.T.
2
3.69
2.13
2.31
3.13
0.19
C
166F28
7
115V 60 Hz.
28 C.T.
0.25
2.81
1.50
1.69
2.38
0.19
C
166G28
14
115V 60 Hz.
28 C.T.
0.5
2.81
1.63
1.69
2.38
0.19
C
166E30
4.5
115V 60 Hz.
30 C.T.
0.15
2.38
1.38
1.38
2.00
0.19
C
166F30
7.5
115V 60 Hz.
30 C.T.
0.25
2.81
1.50
1.69
2.38
0.19
C
166G30
15
115V 60 Hz.
30 C.T.
0.5
3.25
1.63
2.00
2.81
0.19
C
166J33
33
115V 60 Hz.
33 C.T.
1
3.25
2.00
2.00
2.81
0.19
C
166K35
52.5
115V 60 Hz.
35 C.T.
1.5
3.69
2.13
2.31
3.13
0.19
C
166J36
36
115V 60 Hz.
36 C.T.
1
3.69
1.88
2.31
3.13
0.19
C
166E36
5.4
115V 60 Hz.
36 C.T.
0.15
2.38
1.50
1.38
2.00
0.19
C
166F36
10.8
115V 60 Hz.
36 C.T.
0.3
2.81
1.63
1.69
2.38
0.19
C
4/5
10/3/22, 1:35 AM
Primary
Secondary (R.M.S.)
Overall Dimensions
Mounting
Part No.
VA
(VAC)
VAC
Amps
A
B
C
D
E
Dimensions
166F36A
10.8
117V 50/60 Hz.
36 C.T.
0.3
2.81
1.63
1.69
2.38
0.19
C
166G36
18
115V 60 Hz.
36 C.T.
0.5
3.25
1.63
2.00
2.81
0.19
C
166L42
84
115V 60 Hz.
42 C.T.
2
4.03
2.50
2.63
3.56
0.19
C
166J44
44
115V 60 Hz.
44 C.T.
1
3.69
2.00
2.31
3.13
0.19
C
166E44
6.6
115V 60 Hz.
44 C.T.
0.15
2.81
1.50
1.69
2.38
0.19
C
C
166F44
11
115V 60 Hz.
44 C.T.
0.25
2.81
1.63
1.69
2.38
0.19
166G44
22
115V 60 Hz.
44 C.T.
0.5
3.25
1.75
2.00
2.81
0.19
166M48
144
117V 50/60 Hz.
48 C.T.
3
3.44
2.98
4.13
2.75
2.38
0.20
Ref
C
0.38
B
166J50
50
115V 60 Hz.
50 C.T.
1
3.69
2.13
2.31
3.13
0.19
C
166L50
100
115V 60 Hz.
50 C.T.
2
4.50
2.50
3.00
4.00
0.20
C
166C50
3.75
115V 60 Hz.
50 C.T.
0.075
2.38
1.38
1.38
2.00
0.19
C
166F50
15
115V 60 Hz.
50 C.T.
0.3
3.25
1.63
2.00
2.81
0.19
C
166G50
25
115V 60 Hz.
50 C.T.
0.5
3.25
1.75
2.00
2.81
0.19
C
166G60
30
115V 60 Hz.
60 C.T.
0.5
3.25
2.00
2.00
2.81
166M72
216
117V 50/60 Hz.
72 C.T.
3
3.75
3.56
4.50
3.00
0.19
166G80
40
115V 60 Hz.
80 C.T.
0.5
3.69
1.88
2.31
3.13
0.19
C
166G100
50
115V 60 Hz.
100 C.T.
0.5
3.69
2.13
2.31
3.13
0.19
C
166F120
36
115V 60 Hz.
120 C.T.
0.3
3.69
1.88
2.31
3.13
0.19
C
3.00
0.20
C
0.38
B
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
5/5
很抱歉,暂时无法提供与“166J2”相匹配的价格&库存,您可以联系我们找货
