165X5
165X5
    HAMMONDMANUFACTURING
    XFRMR LAMINATED 150VA CHAS MOUNT
165X5 数据手册
10/3/22, 1:35 AM Low Voltage, Filament High Current, Chassis Mount - 125 VA to 440 VA (165 Series) - Hammond Mfg. Quality Products. Service Excellence. Low Voltage, Filament High Current, Chassis Mount - 125 VA to 440 VA 165 Series 115 V Primary Features 115 VAC - 60 Hz. single primary All secondaries are center tapped (C.T.) Open style, 4 hole frame chassis mount. Minimum 6" long leads or copper tabs with holes. Dual bobbin design - no electrostatic shield required. Class B insulation (130 degrees, C). Hi-Pot test of 2,000V RMS. UL listed (# E207860) Type 3AH CSA certified (# LR209651).   Secondary (R.M.S.) Dimensions Part No. VA VAC Amps A B C D E F Mounting Slot 165Z3 150 3.0 C.T. 50 3.75 3.13 3.13 3.13 2.75 3.50 0.22 x 0.56 165X5 150 5.0 C.T. 30 3.75 2.63 3.13 3.13 2.50 3.25 0.22 x 0.56 165V7 157.5 7.5 C.T. 21 3.75 2.63 3.13 3.13 2.50 3.25 0.22 x 0.56 165V10 200 10.0 C.T. 20 3.75 3.13 3.13 3.13 2.75 3.50 0.22 x 0.56 165U11 165 11.0 C.T. 15 3.75 2.63 3.13 3.13 2.50 3.25 0.22 x 0.56 165S12 126 12.6 C.T. 10 3.00 3.25 2.56 2.50 3.25 4.00 0.22 x 0.56 https://www.hammfg.com/electronics/transformers/power/165 1/2 10/3/22, 1:35 AM Low Voltage, Filament High Current, Chassis Mount - 125 VA to 440 VA (165 Series) - Hammond Mfg. Secondary (R.M.S.) Dimensions Part No. VA VAC Amps A B C D E F 165V12 252 12.6 C.T. 20 3.75 3.63 3.13 3.13 3.25 4.00 0.22 Mounting Slot x 0.56 165S18 180 18.0 C.T. 10 3.75 3.13 3.13 3.13 2.75 3.50 0.22 x 0.56 165U18 270 18.0 C.T. 15 4.50 3.88 3.75 3.75 2.75 3.50 0.28 x 0.56 165V18 360 18.0 C.T. 20 4.50 4.38 3.75 3.75 3.25 4.00 0.28 x 0.56 165T22 264 22.0 C.T. 12 4.50 3.88 3.75 3.75 2.75 3.50 0.28 x 0.56 165V22 440 22.0 C.T. 20 4.50 4.38 3.75 3.75 3.75 4.50 0.28 x 0.56 165P25 125 25.0 C.T. 5 3.00 3.25 2.56 2.50 3.25 4.00 0.22 x 0.56 165S25 250 25.0 C.T. 10 3.75 3.63 3.13 3.13 3.25 4.00 0.22 x 0.56 165P30 150 30.0 C.T. 5 3.00 3.25 2.56 2.50 3.25 4.00 0.22 x 0.56 165S30 300 30.0 C.T. 10 4.50 3.88 3.75 3.75 2.75 3.50 0.28 x 0.56 165P60 300 60.0 C.T. 5 4.50 3.88 3.75 3.75 2.75 3.50 0.28 x 0.56 165N80 320 80.0 C.T. 4 4.50 4.38 3.75 3.75 3.25 4.00 0.28 x 0.56 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/power/165 2/2
165X5 价格&库存
很抱歉,暂时无法提供与“165X5”相匹配的价格&库存,您可以联系我们找货
