10/6/22, 9:06 AM
Low Voltage PCB Mount - Epoxy Cast - 1 VA to 40 VA (226-227-228 Series) - Hammond Mfg.
Quality Products. Service Excellence.
Low Voltage PCB Mount - Epoxy Cast - 1 VA to 40 VA 226-227-228 Series
Features
Primary 115 VAC, 60 or 400Hz. models, 3 case sizes
Epoxy cast to withstand shock and severe environments
Two coil design provides balanced windings and low magnetic radiation - no electrostatic
shield required.
228 series include four, 6-32 X .38 machine screw inserts for less strain on p.c. board
connections.
https://www.hammfg.com/electronics/transformers/power/226-227-228
1/2
10/6/22, 9:06 AM
226 Series:
Size Freq.
Part No. (VA) (Hz)
Secondary (RMS)
Temp. Rise
High
Pin
Regulation Max Diameter
Weight
Series
Parallel
(C)
226D
1
60
20V C.T. @ 50ma
10V @ 100ma
25
19.7
0.8
0.04
0.22
lbs.
226F
1
60
30V C.T. @ 34ma
15V @ 67ma
25
21.7
0.8
0.04
0.22
226H
1
60
40V C.T. @ 25ma
20V @ 50ma
25
18.9
0.8
0.04
0.22
226N
20V C.T. @ 1A
10V @ 2A
35
7.2
0.8
0.04
0.22
226P
26V C.T. @ 770ma
13V @ 1.54A
35
7.6
0.8
0.04
0.22
226R
30V C.T. @ 670ma
15V @ 1.33A
35
7.5
0.8
0.04
0.22
226T
40V C.T. @ 500ma
20V @ 1A
35
7.2
0.8
0.04
0.22
Temp. Rise
High
Pin
Weight
227 Series:
Size Freq.
Part No. (VA) (Hz)
Secondary (RMS)
Series
Parallel
(C)
lbs.
227D
5
60
20V C.T. @ 250ma 10V @ 500ma
25
20.07
1.05
0.05
0.38
227F
5
60
30V C.T. @ 170ma 15V @ 340ma
25
24
1.05
0.05
0.38
227H
5
60
40V C.T. @ 125ma 20V @ 250ma
25
26
1.05
0.05
0.38
227N
40
400
20V C.T. @ 2A
10V @ 4A
45
6
1.05
0.05
0.38
227P
40
400
26V C.T. @ 1.54A
13V @ 3.08A
45
5.7
1.05
0.05
0.38
227R
40
400
30V C.T. @ 1.33A
15V @ 2.66A
45
6
1.05
0.05
0.38
227T
40
400
40V C.T. @ 1A
20V @ 2A
45
5.7
1.05
0.05
0.38
High
Pin
Weight
228 Series:
Size Freq.
Part No. (VA) (Hz)
Secondary (RMS)
Temp. Rise
Series
Parallel
(C)
10V @ 1A
1.22
0.50
0.91
lbs.
228D
10
60
20V C.T. @ 500ma
228F
10
60
30V C.T. @ 340ma 15V @ 670ma
1.22
0.50
0.91
228H
10
60
40V C.T. @ 250ma 20V @ 500ma
1.22
0.50
0.91
Data subject to change without notice
© 2022. Hammond Manufacturing Ltd. All rights reserved.
2/2
很抱歉,暂时无法提供与“228H”相匹配的价格&库存,您可以联系我们找货
