PWDP13054
PWDP13054
    HAMMONDMANUFACTURING
    XFRMR DRAKE L4B-7SP
PWDP13054 数据手册
3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Quality Products. Service Excellence. Peter W Dahl Transformers PWDAHL Series Magnetics for Amateur Radio Products This listing of transformers and chokes is directly from the Peter W. Dahl files. They are arranged in alpha-numeric order beginning with AAA and ending with 999. These transformers are usually built to order one at a time.  Units we have already built are shown with Hammond part numbers.  If you do not see a part number listed remember that many of these designs are now decades old - a few may have been originally designed using "unobtainium". It is always best to confirm availability by phone or e-mail. Some Hipersil C-Core models (Style #8, #9 & #10) need to be quoted by our office (due to constant changes & high minimum charges imposed by current C-Core suppliers). We are constantly updating pricing as we quote and/or build units. Most "E-I" lamination units are normally shipped in our 6 week lead time. Stock units can usually be shipped next business day!   Description Hammond Style (see Part Number Core above) Primary 10 240VCT, 60Hz ADVANCED RADIO DEVICES 230A A-274 C- PLATE TRANSFORMER (2 EA 3CX800A7'S) Core ADVANCED RADIO DEVICES 230AX 50/60 HZ VERSION A-0480/ C- OF ARD 230A WITH TAPS CORE ADVANCED RADIO DEVICES 230C A-0518/ C- PLATE XFMR FOR 3 TUBE COMMERCIAL VERSION CORE ADVANCED RADIO DEVICES 230M 60 HZ VERSION OF 230AX WITH 1.4A RATING A-0480/ CCORE ALPHA A70V POWER TRANSFORMER A-0393/ C- FOR ALPHA VAPOR COOLED 3CV1500A7 LINEAR CORE ALPHA 76A POWER TRANSFORMER FOR ALPHA MODELS 76A, 76PA, 76CA & 78 PWDP13139 B-0393/ CCORE ALPHA 76A-1 POWER XFMR A-0393/ C- FILAMENT WINDING FOR 3CX800A7'S CORE 10 10 10 10 10 10 https://www.hammfg.com/electronics/transformers/classic/pwdahl Approx. Weight Secondary 1750 VRMS @ 1.1AMP CCS 200-220-234 VCT 1750 VRMS @ 1.1 AMP 50/60 HZ CCS 200-220-234 VCT 1750 VRMS @ 2.4 AMP 50/60 HZ CCS 200-220-234 VCT 60 HZ 1PH 750 VRMS @ 1.4 AMP CCS 115/230 VAC 60 HZ 1PH 120/240 VAC 60 HZ 1 PH 120/240 VAC 60 HZ 1 PH (lbs) 37 46 66 46 S1) 0-2000-3000 VAC @ 0.3A CCS S2) 5.0 VCT @ 30A CCS 23 S3) 0-22-44-66 VAC @ 1A CCS S1) 0-1200-1950 VAC @ 0.5A CCS S2) 40 VCT @ 0.5A CCS 23 S3) 25 VAC @ 1A CCS S4) 6.3 VAC @ 9.6A CCS S1) 0-1100-1750 VAC @ 0.5A CCS S2) 40 VCT @ 0.5A CCS 23 S3) 25 VAC @ 1A CCS S4) 13.5 VAC @ 3.0A CCS 1/31 3/1/22, 12:09 PM Description ALPHA 76A-2 POWER XFMR SPECIAL HEAVY DUTY 3CX800A7'S VERSION Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Hammond Part Number Core PWDP13047 B-0393/ CCORE Style (see above) 10 Primary 120/240 VAC 60 HZ 1 PH Secondary Approx. Weight (lbs) S1) 0-1200-1950 VAC @ 0.5A CCS S2) 40 VCT @ 0.5A CCS 23 S3) 25 VAC @ 1A CCS S4) 13.5 VAC @ 3.0A CCS S1) 0-1100-1750 VAC @ ALPHA 76PA 50 HZ SPECIAL PWR 115/230 VAC 50 HZ PRI & 20 VAC BUCK WIND A-0393/ CCORE 10 0-115 & 0-115 VAC 50 HZ 1 PH 0.5A CCS S2) 40 VCT @ 0.5A CCS 23 S3) 20 VAC @ 1A CCS S4) 6.3 VAC @ 9.6A CCS S1) 0-1800-2800 VAC @ ALPHA A77 POWER XFMR FOR ORIGINAL ETO PA-77 LINEAR AMPLIFIER PWDP13069 A-0393/ CCORE 10 120/240 VAC 60 HZ 1 PH 0.7A ICAS S2) 0-22-66 VAC @ 0.5A CCS 23 S3) 5.0 VAC @ 10A CCS S1) 0-1800-2800 VAC @ ALPHA A77S POWER TRANSFORMER INBOARD TRANSFORMER FOR 2 TUBE ALPHA 77 A-0525/ CPWDP13107 CORE 9 120/240 VAC 60 HZ 1PH 1.2A CCS S2) 5 VAC @ 20A CCS S3) 50 VAC @ 1.0A CCS 49 S4) 0-22-44 VAC @ 500MA CCS S1) 0-1800-2800 VAC @ 1.2A CCS ALPHA A77S POWER TRANSFORMER INBOARD TRANSFORMER FOR 2 TUBE ALPHA 77 PWDP13116 A-0525/ CCORE 9 220 VAC 50/60 HZ 1PH S2) 5 VAC @ 20A CCS S3) 50 VAC @ 1.0A CCS S4) 0-22-44 VAC @ 49 500MA CCS S1) 0-1800-3000 VAC @ 1.05A CCS ALPHA A77S-3 POWER TRANS SPECIAL WITH 3000 VAC SEC HI-TAP A-0525/ CCORE 9 120/240 VAC 60 HZ 1PH S2) 5 VAC @ 20A CCS S3) 50 VAC @ 1.0A CCS 49 S4) 0-22-44 VAC @ 500MA CCS S1) 0-2400-3400 VAC @ ALPHA A77S-4 POWER TRANS SPECIAL 3400/2400 SEC A-0525/ CVAC MODEL (NOTE: Installation requires modification to the PWDP13009 CORE power supply components 9 0.9A CCS 120/240 VAC 50/60 HZ S2) 5 VAC @ 20A CCS 1PH S3) 50 VAC @ 1.0A CCS 49 S4) 0-22-44 VAC @ 500MA CCS S1) 0-1100-1750 VAC @ 0.5A CCS ALPHA 78 50 HZ JAPAN A-0393/ C- SPECIAL FOR ALPHA 78 WITH 100/200V 50 HZ CORE 10 0-100 & 0-100 VAC 50 HZ 1 PH S2) 40 VCT @ 0.5A CCS S3) 5 VAC @ 1A CCS (FAN BUCKING 23 WINDING) S4) 6.3 VAC @ 9.6A CCS S1) 0-1100-1750 VAC @ ALPHA 78 50 HZ SPECIAL POWER SPECIAL FOR ALPHA 78 WITH 208/240V 50 HZ A-0393/ CCORE 10 0-120 & 0-88-120 VAC 50 HZ 1 PH 0.5A CCS S2) 40 VCT @ 0.5A CCS 23 S3) 25 VAC @ 1A CCS S4) 6.3 VAC @ 9.6A CCS ALPHA 87 POWER TRANSFORMER - REV K (NOT THE SAME AS THE ALPHA 87a) ALPHA POWER P/N TPX-X133 PWDP13140 A-0516/ CCORE 9 https://www.hammfg.com/electronics/transformers/classic/pwdahl 0-200-220-240 VAC 50/60 HZ 1 PH S1) 0-1280-1900 VAC @ 1.5A CCS S2) 7.8 VAC @ 4A CCS 33 S3) 14.45 VAC @ 3A CCS S4) 52 VCT @ 3.5A CCS 2/31 3/1/22, 12:09 PM Description Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Hammond Style (see Part Number Core above) Approx. Weight Primary Secondary (lbs) S1) 0-2050 VAC @ 1.5A CCS ALPHA POWER P/N TPX-X168 ALPHA 91b AND 99 POWER TRANSFORMER PWDP13049 A-0516/ CCORE 9 0-100-120 & 0-100-120 S2) 105 VAC @ 0.5A CCS VAC 50/60 HZ 1 PH S3) 310 VAC @ 0.5A CCS S4) 28 VCT @ 3.0A CCS 37 S5) 13.3 VAC @ 7.2A CCS MODIFIED AMERITRON AL-80A HD POWER SPECIAL HV MODEL FOR FWB&CAP (4000 VDC) PWDP13242 EI-175 X 4" S1) 2900 VAC @ 600 MA 4 240 VAC 60 HZ 1 PH A-0274/ CCORE 10 0-120 & 0-88-120 VAC 60 HZ 1PH 2570 VAC @ 800 MA ICAS 37 A-0274/ CCORE 10 0-120 & 0-100-120 VAC 2570 VAC @ 800 MA 60 HZ 1PH ICAS 37 AMP SUPPLY #LK-450 HV POWER HIGH VOLTAGE POWER TRANSFORMER A-0393/ CCORE 10 110/220 VAC 50 HZ 1 PH 2200 VAC @ 400 MA CCS 23 AMP SUPPLY #LK-450 LV POWER EI-150 X 110/220 VAC 50 HZ 1 LOW VOLTAGE POWER TRANSFORMER 1.5 S1) 5.5 VCT @ 15A CCS S2) 0-10-20 VAC @ 2A 8 NO 5V OR 13.8V WINDINGS AMERITRON P/N AR418-SP AL-1200 PLATE TRANSFORMER WITH 208V TAP AMERITRON P/N AR418-1D AL-1200 / AL-1500 / AL-82 PLATE TRANSFORMER AMP SUPPLY #LK-450 POWER PLATE & FIL XFMR FOR SINGLE 3-500Z PWDP13010 29G M6X PWDP13134 2.5" A-0393/ C- AMP SUPPLY #LK-500C CORE AMP SUPPLY #LK-500C-200 A-393 C- JAPANESE PRIMARY CORE FILAMENT TRANSFORMER FOR LK-500 AMP AMP SUPPLY #LK-500F-2 FIL & CONTROL FOR 2 EA 3-500Z TUBES PWDF13229 PWDP13232 AMP SUPPLY #LK-500F-3 EI-150 X 1.5 EI-150 X 1.5 EI-175 X 2 FIL & CONTROL FOR 3 EA 3-500Z TUBES AMP SUPPLY #LK-500F2-200 EI-150 X JAPANESE PRIMARY 1.5 AMP SUPPLY #LK-800EXT A-480 CCORE A-0518/ CCORE AMP SUPPLY #LK-800EXT H/L HD HIGHER VOLTAGE HIGHER CURRENT MODEL PWDP13128 AMP SUPPLY #LK-800EXT HI-LO A-0480/ C- EXTERNAL TRANSFORMER FOR LK-800 LINEAR CORE AMP SUPPLY #LK-800F EI-150 SQ FILAMENT TRANSFORMER FOR LK-800 LINEAR AMP SUPPLY #LK-800F-1 PWDP13080 AMP SUPPLY #LK-800F-1 (with C.T on 13.6 VAC winding) PWDP13093 AMP SUPPLY #LK-800F-100/200 JAPANESE PRIMARY VOLTAGES AMP SUPPLY #LK-800F/208 LK-800F WITH 208 VAC PRIMARY AMP SUPPLY #LK-800P 4 29GAM6 A-0393/ CCORE EI-150 X 1.5 EI-150 X 1.5 10 10 10 4 4 4 4 A-0393 / CCORE S2) 5.5 VCT @ 15A CCS S3) 11 VAC @ 2A CCS 117/234 VAC 60 HZ 1PH S1) 2135 VAC @ 500MA CCS S1) 2135 VAC @ 500MA 1PH CCS 100/200 VAC 60 HZ S1) 2135 VAC @ 500MA 1PH CCS 1PH 23 23 0S1) 5.5 VCT @ 30A CCS 8 115/230 VAC 60 Hz S1) 5.5 VCT @ 30A 1PH S2) 0-10-18 VAC @ 2A 115/230 VAC 60 HZ S1) 5.5 VCT @ 50A 1PH S2) 0-10-18 VAC @ 2A 100/200 VAC 60 HZ 23 S2) 12 VAC @ 1.5A CCS 117/234 VAC 60 HZ 115/230 VAC 60 HZ 17 8 14 S1) 5.5 VCT @ 30A CCS 234 VAC 60 Hz S1) 1800 VAC @ 1.5A CCS 46 10 234 VAC 60 HZ 1 PH S1) 0-1800-2500 VAC @ 1.5A CCS 66 10 234 VAC 60 HZ 1 PH 4 4 4 4 JAPANESE PRIMARY VOLTAGES ICAS PH 10 EI-150 SQ AMP SUPPLY #LK-800P-100/200 120/240 VAC 60 HZ 1 S2) 0-10-18 VAC @ 2A CCS 4 393/MA CCS 1PH EI-150 SQ A-0393/CA- PH 24 S1) 2080 VAC @ 0.4A EI-175 X AMP SUPPLY #LK-500B AMP SUPPLY #LK-500F-1 4 ICAS 10 10 https://www.hammfg.com/electronics/transformers/classic/pwdahl S1) 0-1800-2135 VAC @ 1.3A CCS 117/234 VAC 60 Hz S1) 13.6 VAC @ 9A 1PH S2) 12 VAC @ 2A 117/234 VAC 60 Hz S1) 13.6 VAC @ 9A 1PH S2) 0-10-18 VAC @ 2A 117/234 VAC 60 Hz 1PH C.T. S1) 13.6 VAC @ 9A S2) 12 VAC @ 2A S1) 13.6 VAC @ 9A S2) 12 VAC @ 2A 117/234 VAC 60 Hz S1) 1800 VAC @ 500 MA 1PH CCS 1PH 8 8 8 S2) 0-10-18 VAC @ 2A 1PH 100/200 VAC 60 Hz 46 S1) 13.6 VAC @ 9A - with 100/200 VAC 60 Hz 208 VAC 60 Hz 1PH 8 S1) 1800 VAC @ 500 MA 8 8 23 23 3/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond (see Part Number Core above) A-0480/ C- AMP SUPPLY P/N AL27-1.2 G CORE A-0480/ C- AMP SUPPLY P/N AL27-1.2 N CORE ARCOS P/N IVS-2700 A-480 C- POWER TRANSFORMER CORE ARRL-001 A-480 C- PLATE TRANSFORMER CORE ARRL-001-01 A-480 C- PLATE TRANSFORMER WITH 110 VAC PRIMARY CORE ARRL-002 PLATE TRANSFORMER PWDP13253 ARRL-002-1 PLATE TRANSFORMER 10 10 Approx. Weight Primary Secondary 115/230 VAC 60 HZ S1) 2700 VAC @ 1.2A 1PH CCS 0-220-240 VAC 60 HZ S1) 2700 VAC @ 1.2A 1PH CCS (lbs) 46 46 S1) 0-1650-1790-1935 10 230 VAC 60 HZ 1 PH VAC @ 1.5A ICAS 46 S2) 13.5 VAC @ 3A CCS 10 0-220-240 VAC 60 HZ S1) 2650 VAC @ 1.5A 1PH ICAS S1) 0-2000-2300-2650 46 10 110 VAC 60 HZ 1PH A-480 CCORE 10 0-220-240 VAC 60 HZ 1PH 0-1770-2125-2500 VAC @ 46 1.5A ICAS A-0480/ CCORE 10 110/220 VAC 60 HZ 1PH S1) 0-1500-2000-2500 VAC @ 1.5A ICAS 46 VAC @ 1.5A ICAS 46 ARRL-002-2 PLATE TRANSFORMER PWDP13029 A-0480/ CCORE 10 110/220 VAC 60 HZ 1PH S1) 0-1500-2000-25002750 VAC @ 1.5A ICAS 46 ARRL-002-2 (MODIFIED) PLATE TRANSFORMER PWDP13146 A-0480/ CCORE 10 110/220/230/240 VAC 60 HZ 1PH S1) 0-1500-2000-25002750 VAC @ 1.5A ICAS 46 A-0480/ CCORE 10 100/200 VAC 50 HZ 1PH S1) 0-1770-2125-2500 VAC @ 1.5A ICAS 46 A-0480/ CCORE 10 235 VAC 60 HZ 1PH S1) 0-1900-2100-26002800 VAC @ 1.5A ICAS 46 15/230 VAC 60 HZ 1 S1) 90 VAC @ 60 MA CCS S2) 6.3 VAC @ 1A CCS 7 ARRL-002-200 PLATE XFMR WITH 100/200 VAC 50 HZ PRI ARRL-003 SPECIAL FOR WIRELESS INDUSTRY ASSN B&W PT2500A ER FILAMENT XFMR EXACT REPLACEMENT TRANSFORMER B&W PT2500A FILAMENT XFMR LARGER THAN ORIGINAL (EI-125 X 2" SN-2) PWDP13019 PWDF13103 EI-125 X 2" 29GAM6X EI-150 X 2 2 4 PH 115/230 VAC 60 HZ 1 PH PWDP13194 2.5" 29GM6X BTI LK-2000 PLATE/FILAMENT A-0480/ C- COMBINATION PLATE & FILAMENT TRANSFORMER CORE CENTRAL ELECTRONICS 100V PWR T-1 SUPPLIES +600, +340, -120 VOLTS DC 4 117 VAC 60 HZ 1 PH S2) 6.3 VAC @ 1.0A CCS 10 S3) 5.2 VCT @ 30A CCS CCS S2) 5.0 VAC @ 3A CCS 12 S3) 2.5 VCT @ 5A CCS 10 115/230 VAC 60 HZ 1 PH S1) 1250 VAC @ 1.5A CCS S2) 7.5 VCT @ 21A CCS 46 S1) 762-450-0-94-450-762 VAC @ 250MA CCS EI-175 X 2.5 29GA S1) 90 VAC @ 0.1A CCS S1) 1000 VCT @ 220 MA EI-150 X BC-610 LV FIL/BIAS XFMR T1 S3) 5.2 VCT @ 30A CCS 5 115 VAC 60 HZ 1 PH M6 S2) 5.0 VAC @ 3A CCS 17 S3) 12.6 VCT @ 7A CCS S4) 6.3 VAC @ 3.6A CCS S1) 240 VAC @ 0.015 A S2) 10 VCT @ 5 A CCS S3) 6.3 VAC @ 0.45 A CENTRAL ELECTRONICS 600L FILAMENT MULTIPLE FILAMENT, CHICAGO 25077 PWDF13181 EI 4 120 VAC 60 HZ 1 PH CCS 10 S4) 6.3 VAC @ 0.3 A CCS S5) 2.5 VCT @ 4 A CCS (2,500 VDC INSULATION) S6) 6.3 VCT @ 4 A CC CHOKE 10 HY @ 0.35A DC STYLE #4 VERT BRKT W\SCREW LUGS ON COIL CHOKE 10 HY @ 0.5A DC FOR 600 VDC @ 500 MA POWER SUPPLY EI-150 X 2 4 EI-175 X 2 4 CHOKE 10.0 HY @ 1.0A DC A-0274/ C- 3000 WVDC, 10 KVDC INSULATION CORE CHOKE 10.0 HY @ 1.3A DC A-0525/ C- 4000 WVDC 1 PH (10 KVDC TEST) CORE CHOKE 16.0 HY @ 0.25A DC A-0036/ C- 1 PH CHOKE FOR 1500 VDC SUPPLY, 5KV TEST CORE 10 HY @ 350 MA DC (650 WVDC) 10 HY @ 0.5A DC (600 WVDC) 10 14 10 10.0 HY @ 1.0A DC 37 9 10.0 HY @ 1.3A DC 49 10 16.0 HY @ 0.25A CCS 7 https://www.hammfg.com/electronics/transformers/classic/pwdahl 4/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Approx. Hammond (see Part Number Core above) Primary Weight Secondary (lbs) CHOKE 16.0 HY @ 0.4A DC 1500 WVDC, 5 KVDC TEST A-0016/ CCORE 10 16.0 HY @ 0.4A DC 17 CHOKE 8.0 HY @ 0.175A DC LV DC FILTER CHOKE, 3 KVDC TEST EI-100 X 1 1 8.0 HY @ 175 MA DC 2 CHOKE 8.0 HY @ 0.3A 2.5 KV TEST, 800 WVDC EI-125 X 2 2 8.0 HY @ 0.3A DC (800 WVDC) 7 CHOKE 8.0 HY @ 1.5A 10 KVDC INSULATION, 3000 WVDC A-0480/ CCORE 10 8.0 HY @ 1.5A DC (3000 WVDC) 46 EI 2 CHOKE 8.0 HY @ 1.5A 4000 WVDC PWDI13169 CHOKE 8.0 HY @ 2.0A A-540 C- 10 KVDC INSULATION, 5200 WVDC 1PH CORE CHOKE 9.0 HY @ 0.25A DC A-0036/ C- RESONATE WITH 0.2 MFD CAP @ 120 HZ CORE CHOKE 9.0 HY @ 0.65A DC A-0393/ C- 4000 WVDC RESONATE WITH 0.2 MF 10 KV CAP CORE CHOKE 9.0 HY @ 1.0A DC A-0274/ C- 4000 WVDC RESONATE WITH 0.2 MF 10 KV CAP CORE CHOKE 9.0 HY @ 1.0A DC HP A-0518/ C- SLIM & TALLER VERSION CORE CHOKE 9.0 HY @ 1.5A DC 5000 WVDC RESONATE WITH 0.2 MF 10 KV CAP A-0518/ CCORE 10 EI 4 CHOKE 60 HY @ 150 ma. DC MODULATION REACTOR (CHOKE) PWDI13132 2.5" 29GAM6 T1 MAIN POWER XFMR, P/N 601-016 PP 6B4G PLATES TO PP 810 GRIDS (T-404) 10 PWDM13041 EI-100 X 1 63 (4000 WVDC) 8.0 HY @ 2.0A DC 92 (5200 WVDC 1PH) 9.0 HY @ 0.25A DC 7 (1500 WVDC 1 PH) 9.0 HY @ 0.65ADC 10 (4000 WVDC 0.2 MF 23 CAP) 9.0 HY @ 1.0A DC 10 (4000 WVDC 0.2 MF 37 CAP) 9 9.0 HY @ 1.0A DC 38 (4500 WVDC) 9.0 HY @ 1.5A DC (5000 WVDC 0.2 MF 66 CAP) 60 HY @ 150 ma. DC 10 CCS (2 KVDC TEST) EI-175 X CLEGG APOLLO SIX T1 POWER COLLINS KW-1 AUDIO DRIVER 9 8.0 HY @ 1.5A DC S1) 1050 VAC @ 0.5A 6 5 117 VAC 60 HZ 1 PH ICAS 17 S2) 380 VCT @ 0.1A ICAS 375 VCT @ 0.1A CCS S1) 125 VAC @ 0.1A CCS (2225 OHMS G-G CT) (5000 OHMS P-P CT) S2) 125 VAC @ 0.1A CCS 2 (2225 OHMS G-G CT) COLLINS KW-1 BIAS T-401 -150 VOLT DC BIAS & FILAMENT TRANSFORMER PWDP13188 EI-112 X 1.125 S1) 300 VCT @ 30 MA 4 115 VAC 60 HZ 1 PH CCS 3 S2) 5 VAC @ 2A CCS S1) 400-80-0-80-400 VAC COLLINS KW-1 LV POWER T-402 EI-175 X 2" LV POWER (300 VDC @ 325 MA) & FIL WNDGS 29GAM6X COLLINS KW-1 MODULATION XFMR PP 810 MODULATORS TO PARALLEL 4-250A'S COLLINS KW-1 RECT FIL ER T-501 872A FIL XFMR (EXACT REPLACEMENT) PWDM13037 EI-175 EESTACK @ 325 MA CCS 5 10 EI-150 X 1.5 OHMS PP 5 115 VAC 60 HZ 1 PH 5 115 VAC 60 HZ 1 PH COLLINS KWS-1 HV CHOKE L-501 - Direct Replacement 8 HY @ 0.5A DC TUNED CHOKE REQUIRES THE 0.15 8 HY @ 0.5A DC TUNED CHOKE REQUIRES THE 0.15 MFD RESONATING CAP 14 1768 VAC @ 283 MA CCS (6250 OHMS RFPA) S1) 5.0 VCT @ 15A CCS (10 KVDC INS) S1) 5.0 VCT @ 15A CCS (10 KVDC INS) 35 6 8 8.0 HY @ 0.5A DC EI 2 MFD RESONATING CAP COLLINS KWS-1 HV CHOKE L-501 1800/2400 VCT18000/11600 29GRH T-501 872A FILAMENT TRANSFORMER S2) 5.0 VAC @ 6A CCS S3) 5.0 VAC @ 2A CCS S4) 6.3 VCT @ 7A CCS EI-150 X PWDF13255 1.25" COLLINS KW-1 RECT FILAMENT "EI" Lamination 115 VAC 60 HZ 1 PH A-0274/ CCORE (4000 WVDC, 55 OHMS DC) 20 8.0 HY @ 0.5A DC 9 https://www.hammfg.com/electronics/transformers/classic/pwdahl (4000 WVDC, 55 OHMS DC) 21 5/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond Part Number Core (see above) PWDF13061 EI-087 X 1 7 COLLINS KWS-1 HV FILAMENT REPLACEMENT 866A FIL XFMR (T-502) - BOBBIN WOUND - EPOXY FILLED BAYS COLLINS KWS-1 LV DC CHOKE EI-112 X +275 VDC FILTER CHOKES, L-502 & L-504 1.125 COLLINS KWS-1 LV POWER XFMR T-506 P/N 662-0146-00 ORIGINAL WAS STYLE #07 - CAN EI-150 X IS NO LONGER PWDP13171 2.5" Secondary 115/230 VAC 50/60 HZ S1) 2.5 VCT @ 10A CCS 1 PH (10 KVDC TEST) 4 HY @ 230MA DC Weight (lbs) 2 3 (+275 WVDC) VAC @ 0.255A CCS 5 120 VAC 60 HZ 1 PH 29GAM6 COLLINS KWS-1 PLATE XFMR P/N 662-0155-00, E-5017 P/N 662-0155-00, E-5017 Primary S1) 420-200-0-200-420 AVAILABLE COLLINS KWS-1 PLATE XFMR 5 Approx. A-0518/ CCORE 9 115/230 VAC 60 HZ 1 PH 4800 VCT @ 800 MA CCS 38 115/230 VAC 60 HZ 1 S1) 4800 VCT @ 800 MA PH CC EI-100 X P/N 662-0157-00 T504 - REPLACEMENT IS NOT POTTED PWDP13043 1.25 - SEE PDF DRAWING 29GAM6 COLLINS KWS-1 SCREEN FIL EI-112 X SCREEN SUPPLY FILAMENT XFMR (T-505) 1.125 13 S3) 12.6 VAC @ 0.3A CCS S4) 6.3 VAC @ 9.0A CCS PWDP13082 EI 29GAM6 9 COLLINS KWS-1 SCREEN S2) 5.0 VAC @ 4A CCS 5 120 VAC 60 HZ 5 115 VAC 60 HZ 1 PH S1) 980 VCT @ 0.050A CCS S1) 6.3 VAC @ 3.0A CCS S2) 5.0 VAC @ 2.0A CCS 39 6 3 S1) 325 VRMS @ 400 MA CCS COLLINS PM-2 POWER XFMR EI-137 X 2 P/N 662-0033-00, BALLASTRAN #BC-2950 4 115/230 VAC 60 HZ 1PH S2) 230 VRMS @ 150 MA CCS 8 S3) 110 VRMS @ 15 MA CCS S4) 6.3 VAC @ 6A CCS COLLINS 21E LV CHOKE L114 LV DC FILTER CHOKE, P/N 668-0072-00 COLLINS 30K MODULATION XFMR P/N 677-0316-00, 200W,+/- 2DB 100-5000HZ COLLINS 30K PLATE 4-125A RF PA & PP 75T MODULATORS PWDI13191 EI-175 X 3" 4 EI-150 X PWDM13203 2.5" 29GM6X PWDP13256 A-0480/ CCORE COLLINS 30K-1 FILAMENT T403 2 EA 75TH'S & 1 EA 4-125A (CASED UNIT) EI-l25 X 1.75 COLLINS 30K-1 HD PLATE HEAVY DUTY REPLACEMENT TRANSFORMER COLLINS 30K-5 HIPERSIL PLATE REPLACES P/N 662-0127-00 (SAME MTG) COLLINS 30L-1 7 PWDP13170 10 20 HY @ 0.35 A DC 2450 VCT @ 175 MA (32K OHMS) 19 S1) 1770 VAC @ .150ADC & .113AAC(16.7K OHM) 12 S2) 248 VAC @ .050ADC 115/230 VAC 60 HZ 2950-2365-0-2365-2950 1PH VAC @ 750MA CCS 46 0-105-110-115 VAC 60 5.0 VCT @ 20A CCS HZ 1 PH 6 EI-250 X 4" 4 29G M6X 115/230 VAC 60 HZ 1 PH 2950-2365-0-2365-2950 VAC @ 350 MA CCS 53 A-0480/ CCORE 115/230 VAC 60 HZ 1PH 2950-2365-0-2365-2950 VAC @ 0.4A CCS 46 EI-175 X 3" 29G M6X 7 10 2 S1) 650 VAC 0.7A CCS 115/230 VAC 50/60 HZ S2) 120 VAC @ 0.020A 1 PH CCS S3) 6.3 VCT @ 16A CCS 19 S1) 550 VAC 0.7A CCS COLLINS 30L-1-1 MODIFIED SEC 1 VOLTS & SEC 2 CURRENT EI-175 X 3" 2 29G M6X 115/230 VAC 50/60 HZ S2) 120 VAC @ 0.100A 1 PH CCS 19 S3) 6.3 VCT @ 16A CCS COLLINS 30S-1 ALC XFMR T-102 1:1 RATIO ALC TRANSFORMER COLLINS 30S-1 BIAS P/N 662-0353-00 COLLINS 30S-1 CHOKE REPLACEMENT FOR L-202 COLLINS 30S-1 ER RECT FIL T-202,P/N 662-0352-00 REPLACEMENT COLLINS 30S-1 FILAMENT--T101 LOW CAPACITY RF PA FILAMENT TRANSFORMER EE 24-25 PWDA13244 1 SQ STACK 3.5 HY @ 700 OHMS 115 VAC 50/60 HZ 1 S1) 125 VCT @ 0.1A CCS PH S2) 12.6 VAC @ 0.8A CCS PWDP13042 EI-087 X 1 1 EI-175 X 3 5 8.0 HY @ 0.5A DC (10 KVDC INS) 5 15 VAC 60 HZ 1 PH S1) 2.5 VCT @ 10A CCS (10 KVDC INSULATION) 3 4 105 VAC 60 HZ 1 PH 6.0 VAC @ 12.5A LOW CAPACITY 8 EI-100 X PWDP13018 1.25 29GAM6 EI-150 X 1.5 https://www.hammfg.com/electronics/transformers/classic/pwdahl 2 19 6/31 3/1/22, 12:09 PM Description Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Hammond Style (see Part Number Core above) COLLINS 30S-1 FILTER CHOKE A-0016/CA- HEAVY DUTY HIPERSIL DC CHOKE - L202 16 COLLINS 30S-1 FILTER CHOKE-1 A-0016/ C- FOR 50 HZ WITH 0.15 MFD CAP (L202) CORE Approx. Weight Primary Secondary (lbs) 8.33 HY @ .5A CCS 10 (3000 WVDC 1PH FWCT) 17 16.7 HY @ .5A CCS 10 (3000 WVDC 1PH FWCT) 17 S1) 6320 VCT @ 350MA COLLINS 30S-1 PLATE XFMR STANDARD REPLACEMENT TRANSFORMER EI-300 X PWDP13017 3.375 4 115/230 VAC 60 HZ 1PH HI-LO TAPS CCS (HI Primary Tap) S2) 245 VAC @ 350MA 67 CCS (HI Primary Tap) COLLINS 30S-1 RECT FILAMENT T-202, P/N 662-0352-00 EI-100 X 1 5 115 VAC 60 HZ 1 PH COLLINS 30S-1 SCREEN CHOKE L-201, P/N 668-0356-00, STD SCREEN CHOKE EI-150 X 1.5 5 3.5 HY @ 500 MA DC (300 WVDC SUPPLY) EI-175 X 1.75 4 115 VAC 60 HZ 1PH HI-LO TAPS COLLINS 30S-1 SCREEN POWER 350/250 VAC @ 400 MA CCS PWDP13149 COLLINS 30S-1-J PLATE XFMR JAPANESE 100/200 VAC EI-300 X 50 HZ PRIMARY 3.375 4 2.5 VCT @ 10A CCS (10 KVDC INSULATION) 8 S1) 350 VAC @ 400 MA CCS S1) 6320 VCT @ 350MA 100/200 VAC 50/60 HZ CCS 1PH HI-LO TAPS 2 S2) 245 VAC @ 350MA CCS 12 67 S1) 6320 VCT @ 350MA COLLINS 30S-1-50 PLATE XFMR 50 HZ VERSION OF 30S-1 PLATE XFMR EI-300 X PWDP13124 3.375 4 115/230 VAC 50/60 HZ CCS 1PH HI-LO TAPS S2) 245 VAC @ 350MA 67 CCS COLLINS 30S-1M-J PLATE XFMR EI-300 X SPECIAL 100/200 VAC 50/60 HZ PRIMARY 3.375 COLLINS 30S-1M-50 PLATE XFMR 50 HZ VERSION OF 30S-1M PLATE XFMR EI-137 X 1.375 4 4 100/200 VAC 50 HZ 1PH HI-LO TAPS 220 VAC 60 HZ 1 PH S1) 6320 VCT @ 350MA CCS S2) 365 VAC @ 350MA CCS S1) 120 VAC @ 500 MA CCS 67 6 S1) 1360 VCT @ 60 MA CCS S2) 600/150 VCT @ 70 COLLINS 310B POWER XFMR EI-150 X 2 BIAS/LV/HV/FILS FOR COLLINS 310B EXCITER 6 115 VAC 60 HZ 1 PH MA CCS S3) 5.0 VAC @ 3A CCS 10 S4) 5.0 VAC @ 3A CCS S5) 6.3 VAC @ 4A CCS COLLINS 32V-1/2/3 LV POWER LV POWER XFMR FOR 32V-1, 32V-2 OR 32V-3 PWDP13005 EI-150 X 1.5 S1) 850 VCT @ 175 MA CCS 4 115 VAC 60 HZ 1 PH S2) 5.0 VAC @ 4A CCS S3) 5.0 VAC @ 4A CCS 4 115 VAC 50/60 HZ 1 PH W/VCTAP 4 115/230 VAC 45/70 HZ CCS (FWCT) 1 PH S2) 5.0 VAC @ 2A CCS 8 S4) 6.3 VAC @ 9A CCS COLLINS 32V3 HV POWER TRANSFORMER T302, P/N 662-0014-00 EI-162 X 2 S1) 1370 VCT @ 500 MA CCS 15 S1) 700 VCT @ 200 MA COLLINS 51J4 POWER ALSO USED IN COLLINS R-388 (51J-3) RECEIVER EI-150 X PWDP13063 1.5 COLLINS 516F-1 POWER XFMR P/N 662-0252-00 MODEL 164 EI-150 X PWDP13075 1.5 8 S3) 6.3 VAC @ 7A CCS COLLINS 516F-2 CHOKE (L1/L2) 8 HY @ 175MA DC 200 OHMS P/N 668-0300-00 COLLINS 516F-2 CHOKE (L3) 1.0 HY @ 180MA DC FILTER CHOKE PWDI13251 COLLINS 516F-2HD POWER P/N 662-0434-00 ADVERTISED UNIT - OLDER VERSION (120 VAC ONLY) PWDP13199 S1) 920-0-920 VAC @ 250MA ICAS 5 115 VAC 60 HZ 1PH EI-100 X 1 6 8 HY @ 175MA DC 2 EI-075 X 1 3 1.0 HY @ 180 MA DC 1 EI-175 X 3" 29G M6X 8 S1) 1000-425-123-0-4251000 VAC @ 250MA CCS 2 120 VAC 60 HZ 1 PH S2) 6.3 VAC @ 11A CCS S3) 5.0 VAC @ 3A CCS 19 S4) 5.0 VAC @ 3A CCS https://www.hammfg.com/electronics/transformers/classic/pwdahl 7/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Description Hammond Part Number Core Style (see above) Primary Secondary Approx. Weight (lbs) S1) 1000-425-123-0-425COLLINS 516F-2HD POWER G P/N 662-0249-010 120/240 PRIMARY - NEWER VERSION COLLINS 516F-2HD-100 POWER 100 VAC 60 HZ ONLY PRIMARY PWDP13200 PWDP13201 EI-175 X 3" 29 GA M6 EI-175 X 3" 29GA M6 2 120/240 VAC 50/60 HZ 1 PH 1000 VAC @ 250MA CCS S2) 6.3 VAC @ 11A CCS 19 S3) 5.0 VAC @ 3A CCS S4) 5.0 VAC @ 3A CCS S1) 1000-425-123-0-4251000 VAC @ 250MA CCS 2 100 VAC 60 HZ 1 PH S2) 6.3 VAC @ 11A CCS S3) 5.0 VAC @ 3A CCS 19 S4) 5.0 VAC @ 3A CCS COLLINS 62S-1 POWER XFMR T3, P/N 662-0035-00, STANCOR P/N 30064 EI-125 X 2" 6 29GM6RH COLLINS 75A-1, 75A-2, 75A-3, 75A-4 (L29) FILTER CHOKE (#1) P/N 668-0020-00 S1) 315 VAC @ 125 MA CCS 115 VAC 60 HZ 1 PH S2) 90 VAC @ 100 MA 7 CCS S3) 6.3 VAC @ 6.5A CCS 3 HENRY 120 MA DC PWDI13161 EI 3 CHOKE (#2) P/N 668-0019-00 PWDI13158 EI 3 COLLINS 75A-2/3 POWER P/N 662-0017-00 WITH ADDED 234V EI-125 X PWDP13233 1.75 COLLINS 75A-1, 75A-2, 75A-3, 75A-4 (L30) FILTER 600V WORKING VOLTAGE 2 5 HENRY 80 MA DC 600V WORKING VOLTAGE 2 S1) 700 VCT @ 150 MA 5 117/234 VAC 50/60 HZ CCS 6 1 PH S2) 5.0 VAC @ 2.0A CCS S3) 6.3 VAC @ 6.0A CCS COLLINS 75A-4 NB POWER XFMR P/N 662-0431-00 EI-087 X .875 5 117 VAC 60 HZ 1 PH S1) 135 VAC @ 0.1A CCS 2 S2) 6.3 VAC @ 3A CCS S1) 350-160-0-350 VAC @ COLLINS 75A-4 POWER P/N 662-0145-00 COLLINS 75S-1, 75S-3, 75S-3A POWER XFMR P/N 662-0301-00, T-4 (75S-1), T-8 (75S-3, 75S-3A) EI-125 X PWDP13053 1.75 PWDP13115 COLLINS 75S-3B AUDIO OUTPUT P/N 667-0302-00 COLLINS 75S-3B, 75S-3C POWER XFMR MAIN POWER XFMR (T-8) P/N 662-0250-010 HEAVY DUTY REPLACEMENT POWER TRANSFORMER 1.5 4 EI-050 X .5 1 117 VAC 60 HZ 1 PH PWDP13090 EI-112 X 1.5 5 EI-ll2 X 1.5 5 150 MA CCS 6 S2) 5.0 VAC @ 2.0A CCS S3) 6.3 VAC @ 6.0A CCS 117 VAC 50/60 HZ 1 S1) 220 VCT @ 0.1A CCS PH S2) 6.3 VAC @ 6.0A CCS 70 VAC 100-3000 HZ 2500 OHMS (PLATEB+) COLLINS 75S-3B-100 POWER 100 VAC 60 HZ PRIMARY ONLY COMMANDER HF-2500 POWER XFMR EI-112 X 5 115/230 VAC 60 HZ 1PH 100 VAC 60 HZ 1PH 4 S1) 0-2.8-31.3 VAC, 4/500 OHMS @ 1.9 WATTS S1) 290 VCT @ 125MA CCS 4 S2) 6.3 VAC @ 5.5A CCS S1) 290 VCT @ 125MA CCS 4 S2) 6.3 VAC @ 5.5A CCS PWDP13011 EI-250 X 4" 29G M6X COMMANDER HF-2500-50S XFMR EI-250 X 4" 50 HZ VERSION 29G M6X 2 230 VCT 60 HZ 1 PH S1) 900 VRMS @ 2.0A ICAS 53 S2) 6.3 VRMS @ 1A CCS 2 230 VCT 50 HZ 1 PH S1) 900 VRMS @ 2.0A ICAS 53 S2) 6.3 VRMS @ 1A CCS 2 117/234 VAC 60 HZ 1PH S1) 0-640-1010 VAC @ DENTRON CLIPPERTON-L POWER TRANSFORMER EI-162 X PWDP13002 3.5 600 MA CCS S2) 12 VAC @ 2A CCS 24 S3) 6.3 VAC @ 16A CCS DENTRON CLIPPERTON-L (Late Production) POWER TRANSFORMER MODIFIED (Filament winding EI-162 X includes C.T.) PWDP13123 3.5 We believe this power transformer was also used in the later CLIPPERTON QRO 2 https://www.hammfg.com/electronics/transformers/classic/pwdahl 117/234 VAC 60 HZ 1PH S1) 0-640-1010 VAC @ 600 MA CCS S2) 12 VAC @ 2A CCS S3) 6.3 VAC C.T. @ 16A CCS 24 8/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond Part Number Core (see above) Approx. Primary Secondary Weight (lbs) S1) 0-640-1010 VAC @ DENTRON CLIPPERTON-L F CLIPPERTON-L POWER XFMR WITH 110/220 PRI DENTRON CLIPPERTON-L-50 50 HZ VERSION EI-162 X 3.5 2 110/220 VAC 60 HZ 1PH 2 117/234 VAC 50 HZ 1PH DENTRON CLIPPERTON-LX A-516 C- OUTBOARD POWER TRANSFORMER CORE EI-162 X 3.5" DENTRON DTR-1200L POWER XFMR REPLACEMENT TRANSFORMER A-0480/ C- OUTBOARD POWER XFMR FOR DTR-2000L CORE DENTRON GLA-1000B EI-175 X 2 600 MA CCS S2) 12 VAC @ 2A CCS 24 S3) 6.3 VAC @ 16A CCS 10 2 29GM6X DENTRON DTR-2000L-X1 24 S1) 0-640-1010 VAC @ EI-162 X PWDP13001 3.5 29G M6X 600 MA CCS S2) 12 VAC @ 2A CCS S3) 6.3 VAC @ 16A CCS 10 2 117/234 VAC 60 HZ 1PH 117/234 VAC 60 HZ 1 PH 115/230 VAC 60 HZ 1 PH 115/230 VAC 60 HZ 1PH S1) 0-640-1060 VAC @ 3.0A CCS S2) 12 VAC @ 2A CCS S3) 6.3 VAC @ 16A CCS 58 S1) 775 VAC @ 0.8A CCS S2) 10 VAC @ 1.0A CCS 24 S3) 6.3 VCT @ 8A CCS S1) 0-900-1200 VAC @ 2.0A CCS S2) 5.0 VAC @ 11A CCS S3) 12 VAC @ 1.5A CCS 46 S1) 800 VAC @ 0.3A CCS S2) 6.3 VAC @ 6A CCS S3) 12 VAC @ 1A CCS 14 S1) 0-600-800 VAC @ DENTRON MLA-2500B POWER TRANSFORMER PWDP13102 EI-162 X 3" 29GAM6X 2 115/230 VAC 50/60 HZ 1 PH 0.9A CCS S2) 12.6 VAC @ 4.0A CCS 21 S3) 6.3 VAC @ 8A CCS S4) 120 VAC @ 0.1A CCS DENTRON MLA-2500B-1 MODIFIED MLA-2500B TRANSFORMER PWDP13249 EI-162 X 3" 29G M6X 2 115/230 VAC 60 HZ 1 PH S1) 800 VAC @ 0.9A CCS S2) 12.6 VCT @ 4.0A CCS S3) 6.0 VAC @ 9A CCS S4) 120 VAC @ 0.1A CCS 21 S1) 985 VAC @ 1.0A ICAS DENTRON 160-10L POWER EXACT REPLACEMENT FOR 160-10L AMPLIFIER EI-162 X 3" PWDP13048 4 29GAM6X DRAKE AC-4 POWER XFMR EI-150 X 3" DRAKE AC-4 POWER SUPPLY USED WITH "4" LINES (T- PWDP13137 2 29GAM6X 4, T-4X AND TR-4) 115/230 VAC 60 HZ 1 PH 120/240 VAC 50/60 HZ 1 PH OR 0.65A CCS 21 S2) 9.5 VAC @ 1.0A CCS S3) 6.3 VCT @ 16A CCS S1) 265 VAC @ 750 MA CCS S2) 90 VAC @ 350 MA CCS S3) 95 VAC @ 100 MA 14 CCS S4) 12.6 VAC @ 5.5A CCS DRAKE L4B FILAMENT PWDF13238 EI-137 X 2 6 DRAKE L4B-6 DIRECT REPLACEMENT WITH 6 TERMINAL PRI PWDP13241 EI-212 X 3 2 EI-212 X 3 2 PWDP13087 EI-212 X 3 PWDP13054 EI-212 X 3 DRAKE L4B-6-1 DIRECT REPLACEMENT WITH 6 TERM 50 HZ PRI DRAKE L4B-7 and L7 PS DIRECT REPLACEMENT WITH 7 TERMINAL PRI DRAKE L4B-7-1 DIRECT REPL WITH 100/200 VAC 50 HZ 7 TP DRAKE L4B 3CX1200A7 X 2 FIL - NOTE: REQUIRES EXTENSIVE POWER SUPPLY AND RF AMP MODS FIL XFMR FOR 2 EA 3CX1200A7'S IN L4B HZ 1 PH S2) 22 VAC @ 1A CCS 120/240 VAC 60 HZ 1PH HI-LO TAPS S1) 1065/780 VAC @ 0.81A CCS 120/240 VAC 50/60 HZ S1) 780/1065 VAC @ 8 29 29 1PH HI-LO TAPS 0.68A CCS 2 120/240 VAC 60 HZ 1PH HI-LO TAPS S1) 1065/780 VAC @ 0.81A CCS 29 2 120/240 VAC 60 HZ 1PH HI-LO TAPS S1) 1170/878 VAC @ 0.81A CCS 29 EI-212 X 3" 2 29GM6X 100/200 VAC 50 HZ 1PH HI-LO TAPS S1) 1065/780 VAC @ 0.81A CCS 29 DRAKE L4B-7-SP and L7 PS 1170 VAC SECONDARY WITH 7 TERMINAL PRI - NOTE: REQUIRES POWER SUPPLY AND RF AMP MODS 0-115/0-62-115 VAC 60 S1) 5.0 VCT @ 30A CCS EI-150 X PWDF13243 2.5" 29GM6X 4 https://www.hammfg.com/electronics/transformers/classic/pwdahl 0-120/0-62-120 VAC 60 S1) 7.5 VCT @ 42A CCS HZ 1 PH S2) 22 VAC @ 1A CCS 12 9/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond Part Number Core (see above) DRAKE R-4, R-4A, R-4B POWER XFMR T15 POWER XFMR FOR DRAKE R-4, R-4A AND R-4B EI-100 X PWDP13202 1.5" 5 RECEIVER ONLY DRAKE R-4C POWER XFMR T14 POWER XFMR FOR DRAKE R-4C RECEIVER ONLY DRAKE 1A POWER TRANSFORMER FOR R.L. DRAKE MODEL 1A RECEIVER DRAKE 2-C POWER TRANSFORMER EXACT REPLACEMENT 29GM6X EI-100 X PWDP13178 1.5" 29GM6X Primary PWDP13219 EI-100 X 1" 29GAM6X EI-100 X 1 L16 EICO 720 POWER XFMR EI-150 X 2" 90 WATT CW TRANSMITTER POWER TRANSFORMER 29GAM6X ELDICO MODEL 1000 FIL/BIAS EI-l25 X W/O 866A FIL WINDING (NEED SS 866A'S) 1.25 PWDI13257 C-CORE Secondary S1) 260 VCT @ 0.15A 120/240 VAC 50/60 HZ CCS 1 PH S2) 12.6 VCT @ 2A CCS S1) 250 VCT @ 0.13A 20/240 VAC 50/60 HZ 1 CCS PH EI-100 X PWDP13210 1.25 29GM6X EICO 720 DC CHOKE ENERGY-ONIX CHOKE P/N 376-056 5 Approx. S2) 26 VCT @ 0.65A CCS S3) 6.3 VAC @ 2A CCS Weight (lbs) 3 3 S1) 525 VCT @ 50 MA 2 5 1 6 5 115 VAC 60 HZ 1 PH 115/230 VAC 60 HZ 1 PH CCS S2) 12.6 VAC @ 2A CCS S1) 208 VCT @ .075A CCS S2) 22.8 VCT @ 0.4A CCS S3) 13.3 VCT @ 0.8A CCS 8.0 HY @ 150 MA DC PH 115 VAC 60 HZ 1 PH S1) 1400 VCT @ 170 MA CCS S2) 5 VAC @ 2A CCS S3) 6.3 VAC @ 3A CCS S1) 6.3 VAC @ 6.5A CCS S2) 250 VCT @ 0.1A CCS PR) 2.0 HY @ 1.7A DC (6400 WVDC 1 PH) 10 2 2 (600 WVDC) PR) 117 VAC 60 HZ 1 3 10 4 37 S1) 860 VAC @ 250 MA GALAXY V POWER TRANSFORMER EI-175 X 2 2 117 VAC 60 HZ CCS S2) 285 VAC @ 175 MA CCS S3) 80 VAC @ 50 MA CCS S4) 24 VCT @ 500 MA 14 CCS S5) 12.6 VAC @ 6A CCS 40 HENRY 600 MA DC GATES BC-1 MODULATION REACTOR PWDI13065 GATES/HARRIS CHOKE 476-0420-000 PWDI13211 GLOBE CHAMPION LV POWER T1 LV, BIAS, FIL VOLTS FOR MODELS 300 & 350 GLOBE CHAMPION 175 POWER T3 THORDARSON P/N T-21P93 C-CORE EI-150 X 2.5" 29GM6X EI-162 X 1.625 GLOBE KING 500A LV POWER THORDARSON T-21P89 EI-125 X 2 GLOBE KING 500A/B MOD XFMR PP 811A'S TO SINGLE 4-250A/4-400A RF PA GLOBE KING 500B PLATE 1800 VDC @ 400 MA CCS FWB CHOKE INPUT 60 S1) 900 VCT @ 250 MA CCS S2) 110 VAC @ 0.1A CCS EI-150 X PWDP13217 2.5" 29GAM6 PP 809 MODULATORS TO PARALLEL 9909 RF PA 1000 VDC FOR 811A'S & 400 VDC FOR 6L6G 10KV WORKING VOLTAGE 5H 2 2.5A, 5600 VDC GLOBE CHAMPION 300 MOD XFMR GLOBE KING 500A MOD POWER 10 5 PR) 115 VAC 60 HZ 1 PH S3) 12.6 VCT @ 3A CCS 12 S4) 5 VAC @ 3A CCS S5) 6.3 VCT @ 6A CCS & 6.3 VAC @ 6A CCS S6) 2.5 VCT @ 10A CCS 5 4 117 VAC 60 HZ 1 PH S1) 2150/1000 VCT @ 95/125 MA CCS FWCT 11,000 OHMS P-P (PP 2830 OHMS (920 VDC @ 12 13 809'S) (1280 VCT) 325 MA, 650 VRMS) 5 115 VAC 60 HZ 1 PH 1160 VCT @ 150 MA CCS 7 PWDP13052 EI-162 X 2 2 117 VAC 60 HZ 1 PH EI-150 X PWDM13086 3.5" 5 1465 VCT @ 0.246A 1275 VAC @ 0.283A CCS 16 CCS (7400 OHMS P-P) (1800 VDC @ .4A) 5 115 VAC 60 HZ 1 PH 29GM6X PWDP13074 EI-175 X 5 https://www.hammfg.com/electronics/transformers/classic/pwdahl 1160-350-0-350-1160 VAC @ 450 MA ICAS S1) 4000 VCT @ 400 MA ICAS (FWCT) 15 31 10/31 3/1/22, 12:09 PM Description GLOBE KING 500B PLATE (MODIFIED) 1800 VDC @ 400 MA CCS FWB CHOKE INPUT Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Hammond Style (see Part Number Core above) Primary 5 120/240 VAC 60 HZ 1 PH 10 115 VAC 60 HZ 1 PH 1 25 HY @ 0.050A DC (400 WVDC) PWDP13108 EI-175 X 5 GLOBE KING 500B-X PLATE A-0274/ C- HEAVY DUTY EXTERNAL PLATE TRANSFORMER CORE GLOBE KING 500C SCREEN CHOKE CH1 SCREEN SUPPLY DC FILTER CHOKE EI-075 X .75 Approx. Weight Secondary (lbs) 31 S1) 4400/4000 VCT @ 400 MA CCS (FWCT) 37 1 S1) 1200 VCT @ 0.2A GLOBE SCOUT 65A POWER XFMR WRL MODEL 65A GLOBE SCOUT TRANSMITTER EI-150 X 2" PWDP13162 5 29G M6X GONSET G-50 POWER XFMR 6 METER COMMUNICATOR EI-137 X 2" PWDP13028 5 29GAM6X 115 VAC 60 HZ 1 PH 115 VAC 60 HZ 1 PH CCS (500 VDC FWCT) 10 S2) 6.3 VAC @ 3.5A CCS S3) 5 VAC @ 3A CCS S1) 770 VCT @ 250 MA CCS S2) 5.0 VAC @ 3A CCS 8 S3) 6.3 VAC @ 9A CCS GONSET G-76 POWER XFMR T-1, MAIN POWER TRANSFORMER EI-175 X PWDP13247 2.5" 29GM6X 6 115 VAC 60 HZ 1 PH S1) 1300/540 VCT @ 0.3A CCS S2) 5.0 VAC @ 4A CCS S3) 12.6 VAC @ 5A CCS 17 S1) 720-260-0-130-260GONSET GSB-100 POWER ADVERTISED UNIT PWDP13106 EI-150 X 2 4 117 VAC 60 HZ 1 PH 720 VAC @ 150 MA CCS S2) 5.0 VAC @ 3A CCS 10 S3) 5.0 VAC @ 3A CCS S4) 6.3 VAC @ 10A CCS GONSET GSB-101 ALT PLATE C ALT XFMR ON EI-175 LAMS WITH 117 VAC PRI EI-175 X 5" 4 29G M6X GONSET GSB-101 ALT PLATE J EI-175 X 5" ALT XFMR ON EI-175 LAMS WITH 220 VAC PRI 29G M6X GONSET GSB-101 ER PLATE C EXACT REPLACEMENT UNIT WITH 117 VAC PRI GONSET GSB-101 ER PLATE J EXACT REPLACEMENT UNIT WITH 220 VAC PRI EI-162 X PWDP13101 3.5" S1) 3600 VCT @ 500 MA CCS S1) 3600 VCT @ 500 MA 31 4 220 VAC 60 HZ 1 PH 4 117 VAC 60 HZ 1 PH 3600 VCT @ 500 MA CCS 24 4 220 VAC 60 HZ 1 PH S1) 3600 VCT @ 500 MA CCS 5 25 HY @ 75 MA TO 5 HY @ 450 MA DC 10 10 117 VAC 60 HZ 1 PH 3600 VCT @ 600 MA CCS 30 4 120/240 VAC 60 HZ 1PH 2500 VAC @ 1.0A ICAS (0.3A CCS) 120/240 VAC 60 HZ 1 S1) 1705 VAC @ 500 MA PH CCS CCS 31 29GM6X EI-162 X 3.5" 29GM6X GONSET GSB-101 FILTER CHOKE EXACT REPLACEMENT EI-150 X 2 GONSET GSB-101 PLATE A-0203/ C- HEAVY DUTY HIPERSIL REPLACEMENT XFMR CORE GONSET GSB-201 MK IV POWER EI-175 X 5 29G M-6 GONSET GSB-201 POWER EI-175 X 5" ADVERTISED UNIT 29G M6X HALLICRAFTERS FPM-300-MKII EI-150 X POWER TRANSFORMER 2.5 HALLICRAFTERS FPM-300-MKII POWER TRANSFORMER 117 VAC 60 HZ 1 PH EI-150 X 2.5 4 6 6 120/240 VAC 60 HZ 1 PH PR) PRI "1" 117/234 PRI "2" 18.7 VCT S1) 1705 VAC @ 500 MA CCS S2) 6.3 VAC @ 20A CCS S1) 215 VAC @ 250MA S2) 320 VAC @ 250MA S3) 12 VAC @ 1A 24 31 31 31 12 S4) 6.3-0-103 VAC @ 4A0-100MA S1) 490-360-0-75-360-490 HALLICRAFTERS HT-30 POWER POWER XFMR FOR HT-30 MARK I EXCITER HALLICRAFTERS HT-32 DC CHOKE L-25, P/N 056-300259 EI-150 X 2.5" 6 117 VAC 60 HZ 1 PH 29GAM6 EI-087 X 1 VAC @ 0.25A CCS S2) 5 VAC @ 3A CCS 12 S3) 5 VAC @ 3A CCS S4) 6.3 VAC @ 6A CCS 1 https://www.hammfg.com/electronics/transformers/classic/pwdahl 9.0 HY @ 135 MA DC 2 11/31 3/1/22, 12:09 PM Description HALLICRAFTERS HT-32 MARK I T4 MAIN POWER TRANSFORMER Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Hammond Style (see Part Number Core above) PWDP13141 EI-175 X 3 6 Approx. Weight Primary Secondary 117 VAC 60 HZ S1) 880-270-90-0-270-880 VAC @ 300MA CCS S2) 6.3 VAC @ 11A CCS 19 (lbs) S3) 5.0 VAC @ 3A CCS S4) 5.0 VAC @ 3A CCS S1) 880-270-140-0-270- HALLICRAFTERS HT-32A POWER MAIN POWER TRANSFORMER T4 PWDP13245 EI-175 X 3 29G M-6 880 VAC @ 300MA CCS =6 17 VAC 60 HZ S2) 6.3 VAC @ 11A CCS S3) 5.0 VAC @ 3A CCS 19 S4) 5.0 VAC @ 3A CCS S1) 880-270-140-0-270880 VAC @ 300MA CCS HALLICRAFTERS HT-32B POWER MAIN POWER TRANSFORMER T103 EI-175 X 3 HALLICRAFTERS HT-33 SPECIAL EI-212 X 4 HALLICRAFTERS HT-33A PLATE EI-212 X REPLACEMENT (2700 VDC FOR PL-172) 4.625 6 0-75-117 VAC 60 HZ S2) 6.3 VAC @ 11A CCS 19 S3) 5.0 VAC @ 3A CCS S4) 5.0 VAC @ 3A CCS 4 120 VAC 60 HZ 1PH 4 120 VAC 60 HZ 1 PH S1) 4500 VCT @ 500MA CCS S1) 6000 VCT @ 0.350A CCS (FWCT LC RECT) 38 43 S1) 350 VCT @ 100MA HALLICRAFTERS HT-33A/B FIL EI-137 X HT-33A OR HT-33B FILAMENT TRANSFORMER 1.375 HALLICRAFTERS HT-33A/B FIL HT-33A OR HT-33B FILAMENT TRANSFORMER MODIFIED FOR SOLID STATE PWDF13180 EI-137 X 1.375 CCS 5 120 VAC 60 HZ 1 PH S3) 2.5 VAC @ 10A CCS (10 KVDC INS) S1) 350 VCT @ 100MA 5 120 VAC 60 HZ 1 PH REPLACEMENT (2700 VDC FOR PL-172) PWDP13071 EI-212 X 4.625 CCS 17 S2) 6.0 VAC @ 7.8A CCS RECTIFIERS (2.5 VAC WINDING ELIMINATED) HALLICRAFTERS HT-33B PLATE S2) 6.0 VAC @ 7.8A CCS 6 4 120 VAC 60 HZ 1 PH 6000 VCT @ 0.350A CCS (FWCT LC RECT) 43 S1) 880-270-140-0-270880 VAC @ 300MA CCS HALLICRAFTERS HT-37 POWER MAIN POWER TRANSFORMER - SAME AS HT-32 MARK 1 PWDP13141 EI-175 X 3 6 0-75-117 VAC 60 HZ (ABOVE) S2) 6.3 VAC @ 11A CCS 19 S3) 5.0 VAC @ 3A CCS S4) 5.0 VAC @ 3A CCS HALLICRAFTERS HT-41 PLATE EI-212 X 4 1800 VDC @ 400 MA CCS FROM FWCT RECT A-516 C- HALLICRAFTERS HT-45 BRIDGE CORE 2 9 117 VAC 60 HZ 1 PH S1) 4200 VCT @ 400MA CCS (FWCT) 115/230 VAC 60 HZ S1) 3500 VRMS @ 0.5A 1PH CCS 38 33 HALLICRAFTERS HT-45 PLATE TO PRODUCE 2700 VDC @ 400 MA CCS A-516 CCORE 9 120/240 VAC 60 HZ 1 PH S1) 6000 VCT @ 400 MA CCS (FWCT) 33 HALLICRAFTERS P-20A PLATE EI-212 X 3.5 5 115 VAC 60 HZ STATIC SHIELD- 3300 VCT @ 350MA DC 34 HALLICRAFTERS P-20A POWER EI-150 X 2 2 HALLICRAFTERS P-26 POWER EI-175 X 2 5 110/220 VAC 50/60 HZ 46 VCT @ 8A CCS 10% W/+OR-10% BUCK 117 VAC 60 HZ BUCK-BOOST 860-230-0-130-230-860 @ 300MA 10 14 S1) 630 VCT @ 450 MA HALLICRAFTERS PS-150-120 POWER TRANSFORMER FOR HT-44 POWER SUPPLY CCS PWDP13092 EI-175 X 2 6 117 VAC 60 HZ 1 PH S2) 120 VAC @ 20 MA 14 CCS S3) 12.6 VAC @ 4.5A CCS S1) 600 VCT @ 0.6A CCS HALLICRAFTERS PS-500A-AC POWER TRANSFORMER, T201 EI-175 X 2.5 6 117/234 VAC 60 HZ 1 PH S2) 135 VAC @ 0.05A CCS 17 S3) 12.6 VAC @ 5.0A CCS HALLICRAFTERS SR-2000 PLATE TRANSFORMER (PLATE & SCREEN) VOLTAGES PWDP13022 EI-175 X 4" 29G M6 2 117/234 VAC HI-LO S1) 1080 VRMS @ 0.91 AMPS CCS TAPS 60 HZ 1PH S2) 450 VRMS @ 0.070 25 AMPS CCS https://www.hammfg.com/electronics/transformers/classic/pwdahl 12/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond Part Number Core HALLICRAFTERS SR-2000 SCREEN SCREEN CHOKE L301 EI-75 SQ. 1.25" 29GM6 POWER XFMR FOR SX-117 RECEIVER AUDIO OUTPUT PWDA13083 REPLACES P/N P26305-1, 115 VAC PRI ONLY HAMMARLUND HQ-180A POWER (FOR OVERSEAS) REPLACES P/N P26305-1 15 HY @ 100MA 5 120 VAC 60 HZ 1 PH .75 1 9K OHMS P-P 6 117 VAC 60 HZ 1 PH Weight (lbs) 1 S1) 360 VCT @ 0.1A CCS S2) 6.3 VAC @ 6A CCS 100/500/5000 OHMS 3 1 S2) 5.0 VAC @ 3.0A CCS 10 S3) 6.3 VAC @ 8.0A CCS S1) 500 VCT @ 90 MA EI-112 X 1.5 T-9 HAMMARLUND HQ-180A POWER EI-075 X EI-150 X 2 HAMMARLUND HQ-100C POWER T13 MAIN POWER TRANSFORMER 1 Secondary S1) 520 VCT @ 0.3A CCS HALLICRAFTERS SX-62A POWER T30, MAIN POWER TRANSFORMER HAMMARLUND HQ-145A POWER Primary EI-100 X HALLICRAFTERS SX-117 POWER HALLICRAFTERS SX-28 AUDIO Approx. (see above) 6 117 VAC 60 HZ 1 PH 29M6RH EI-112 X PWDP13094 1.5 6 29GM6RH PWDP13021 EI-125 X 1.75 EI-125 X PWDP13165 1.75 6 115/230 VAC 60 HZ 1 S1) 360 VCT @ 0.1A CCS PH S2) 6.3 VAC @ 6A CCS 115 VAC 60 HZ 1 PH S1) 420 VCT @ 200 MA CCS 6 220 VAC 50/60 HZ 1 PH EI-150 X 2.5" 29GM6R MAIN POWER XFMR, P/N 26726-1 (6DQ5 PA) S2) 5.0 VAC @ 2A CCS S3) 6.3 VAC @ 3A CCS 4 4 6 S2) 6.3 VAC @ 6A CCS 29GAM6 HAMMARLUND HX-50 POWER CCS 6 117 VAC 60 HZ 1 PH S1) 420 VCT @ 200 MA CCS 6 S2) 6.3 VAC @ 6A CCS S1) 700-425-20-0-425-700 VAC @ 200MA CCS S2) 5.0 VAC @ 3A CCS 12 S3) 6.3 VAC @ 10A CCS S1) 900-320-110-0-320- HAMMARLUND HX-500 POWER T16 MAIN POWER XFMR, P/N K42351-1 900 VAC @ 175MA CCS PWDP13096 EI-150 X 3 6 117 VAC 60 HZ 1 PH 5 120/240 VAC 60 HZ 1 PH S2) 12.6 VAC @ 1.2A CCS 14 (5 KV TEST) S3) 6.3 VAC @ 10A CCS HAMMARLUND HXL-1 PLATE "EI" REPLACEMENT TRANSFORMER PWDP13153 EI 29M6 HAMMARLUND HXL-1 PLATE A-393 C- HIPERSIL REPLACEMENT TRANSFORMER CORE HEATH AT-1 POWER XFMR P/N 54-21 EI-125 X PWDP13114 1.25" 10 115/230 VAC 60 HZ 1 PH EI-100 X 1.25 HEATH CHIPPEWA PLATE XFMR REPLACES BASLER ELECTRIC P/N BE-7129 A-0516/ CCORE HEATH DX-100 DRIVER EI-050 X AUDIO DRIVER, P/N 51-23 .625 900 VAC @ 1.0A CCS 23 S1) 860 VCT @ 0.1A CCS 5 115 VAC 60 HZ 1 PH 5 117 VAC 60 HZ 29GM6 HEATH BR-2 S1) 900 VAC @ 1.0A CCS 30 (FWCT) S2) 5.0 VAC @ 3A CCS S3) 6.3 VAC @ 2A CCS S1) 440 VCT @ 75MA S2) 5 VAC @ 2A 4 3 S3) 12.6 VAC @ 0.6A 9 3 115/230 VAC 60 HZ 1 PH 2500 OHMS @ 20 MA DC S1) 7000 VCT @ 0.5A ICAS (FWCT) 33 S1) 2000 OHMS C.T. S1) 317-60-0-60-317 VAC @ 250 MA CCS HEATH DX-100 LOW VOLTAGE HEATH P/N 54-31 EI-150 X 2 4 117 VAC 60 HZ S2) 5 VAC @ 4A (3 KV INSULATION) 10 S3) 5 VAC @ 2A S4) 12.6 VCT @ 4A HEATH DX-100 MOD DX-100 MODULATION TRANSFORMER PWDM13136 EI-112 X 1.5 HEATH DX-100 PLATE EI-150 X HEATH P/N 54-30 POTTED TYPE 2.5 5 7 https://www.hammfg.com/electronics/transformers/classic/pwdahl 8000 OHMS PP C.T. 845 VCT 117 VAC 60 HZ 1 PH 500/2800 O @ 250MA(88W) 500 VAC @ 4 .176A 1830 VCT @ 400 MA ICAS 12 13/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Hammond Style (see Description Part Number Core above) HEATH DX-100 PLATE OF OPEN FRAME VERSION EI-175 X 2" PWDP13234 4 29GM6X HEATH DX-20 POWER MAIN POWER TRANSFORMER FOR HEATH DX-20 EI-125 X PWDP13109 1.75 Approx. Weight Primary Secondary (lbs) 117 VAC 60 HZ 1 PH 1830 VCT @ 400 MA ICAS 14 S1) 1200 VCT @ 120 MA 5 117 VAC 60 HZ 1 PH CCS S2) 6.3 VAC @ 2A CCS 6 S3) 5.0 VAC @ 3A CCS HEATH DX-35/40 POWER TRANSFORMER S1) 750-0-750 VAC @ 150 MA ICAS (FWCT) EI-125 X PWDP13105 1.75 5 117 VAC 60 HZ 1 PH 29GAM6 S2) 6.3 VAC @ 3.25A CCS 6 S3) 5.0 VAC @ 3A CCS S4) 6.3 VAC @ 0.65A CCS S1) 260 VAC @ 500MA HEATH DX-60 POWER EI-137 X 2" STYLE #6 HALFSHELL TYPE XFMR 29G M6RH HEATH HA-10 WARRIOR PLATE EI-175 X 4" TO PRODUCE 1500 VDC @ 0.5A CCS FWCT 29GM6RTM HEATH HA-14-X EI-162 X 3" HEAVY DUTY OUTBOARD POWER TRANSFORMER 29G M6X 6 115/230 VAC 60 HZ 1PH CCS S2) 110 VAC @ 30MA 8 CCS S3) 6.3 VAC @ 2A CCS HEATH HL-2200 FILAMENT XFMR REPLACEMENT TRANSFORMER (SAME AS SB-220 / SB- PWDF13057 221) EI-137 X 1.375 6 2 5 HEATH HL-2200 POWER XFMR SAME EXACT REPLACEMENT FOR SB-220 / SB-221 / HL- PWDP13034 EI 2 2200 HEATH HL-2200 PLATE EXTRA HD REPLACEMENT WITH 7 MIL C-CORE (SAME AS SB-220 / SB-221 / HL-2200) REQUIRES MODIFICATION TO CHASSIS B-0393/ PWDP13026 (SIDE 10 MOUNT) 115/230 VAC 60 HZ 1 S1) 3400 VCT @ 0.5A PH CCS (FWCT) 24 VCT 250 HZ (PP S1) 0-2400-2800 VAC @ TRANSISTOR 0.5A CCS DRIVEN) S2) 120 VAC @ 0.1A CCS 120/240 VAC 50/60 HZ S1) 5.0 VCT @ 30A CCS 1 PH S2) 90 VAC @ 0.1A CCS 117/234 VAC 60 HZ HI- 860/1171 VAC @ 0.7A LO TAPS CCS 117/234 VAC 60 HZ HI- S1) 860/1171 VAC @ 1.3A LO TAPS CCS 25 21 6 23 23 S1) 282 VAC @ 0.25A HEATH HP-23A/B POWER XFMR FOR HP-23A OR HP-23B POWER SUPPLY EI-137 X PWDP13135 2.5" 6 29GM6X 120/240 VAC 60 HZ 1 PH CCS S2) 0-95-125 VAC @ 0.1A 10 CCS S3) 12.6 VCT @ 6A CCS S1) 550 VAC @ 50 MA CCS S2) 200 VAC @ 100 MA HEATH IO-102 SCOPE XFMR EI-137 X 2" HEATH P/N 54-258 29GAM6X 5 120/240 VAC 50/60 HZ 1 PH CCS S3) 26 VAC @ 250 MA 8 CCS S4) 7.88 VAC @ 1A CCS ???? S5) 0.35 VAC @ 1A CCS S1) 0-325-650-11751175.625 @ HEATH I0-10 SCOPE POWER EI-l25 X P/N 54-105-24 1.75 2 115/230 VAC 50/60 HZ 60MA,5MA,0.3A S2) 120 VAC @ 60MA S3) 6.3 VAC @ 0.6A 6 S4) 6.3 VCT @ 3.6A S1) 120 VAC @ 50MA (PURPLE) S2) 180 VAC @ 300MA HEATH OP-1 SCOPE EI-125 X 2.625 5 117 VAC 60 HZ (RED) S3) 6.6 VCT @ 3A 9 (GREEN) S4) 6.6 VAC @ 2A (BLUE) S5) 0-1840-1841.35 (IMA) (@0.2A) (YELLOW) https://www.hammfg.com/electronics/transformers/classic/pwdahl 14/31 3/1/22, 12:09 PM Description Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Hammond Style (see Part Number Core above) Approx. Weight Primary Secondary (lbs) S1) 1200 VAC @ .005A CCS S2) 0.625 VAC @ 0.3A HEATH P/N 54-130 HO-13 & HO-10 MONITOR SCOPE POWER XFMR EI-100 X PWDP13126 1.5 5 117 VAC 60 HZ 1 PH CCS (5 KVDC INS) S3) 220 VAC @ .050A 3 CCS S4) 6.3 VAC @ 0.6A CCS S5) 6.3 VAC @ 3.6A CCS S1) 125 VCT @ 6A CCS EI-162 X HEATH P/N 54-884 3.5" 29G STEREO POWER AMPLIFIER POWER TRANSFORMER 5 120 VAC 60 HZ 1 PH M6 (+ & - 91 VDC) S2) 54 VCT @ 0.5A CCS (+15,-15,+12,+35 VDC) 24 S3) 6 VAC @ 0.5A CCS (METER LIGHTS) HEATH PS-23 DC CHOKE (L1) EI-100 X 1 6 HY @ 175 MA DC (350/275 VDC) 1 6 HY @ 175 MA DC 2 (350 WVDC) HEATH RX-1 - MOHAWK PLATE SUGGESTED HAMMOND REPLACEMENT PART NUMBER 272JX REQUIRES PLATE DROPPING RESISTOR (1K OHM, 20 272JX WATT) SEE ARTICLE BY JOHN TREICHLER (KJ6SAV) IN ELECTRIC RADIO (AUGUST 2017) ISSUE FOR DETAILS HEATH SB-1000 POWER XFMR HEATH P/N 54-1061 EI-175 X PWDP13073 3.5" 29G 4 M6 HEATH SB-200 T-1 MAIN POWER TRANSFORMER - SB-200 / SB-221 S1) 1100 VAC @ 0.5A PWDP13227 60 HZ ONLY EI-175 X 3" 29G M-6 2 120/240 VAC 60 HZ 1 CCS PH S2) 5.2 VCT @ 15A CCS S3) 10.5 VAC @ 0.5A CCS 120/240 VAC 60 HZ 1 S1) 800 VAC @ 500MA CCS PH S2) 6.3 VCT @ 8A CCS 22 19 S3) 120 VAC @ 0.1A CCS S1) 900 VAC @ 500 MA HEATH SB-200-1 HIGHER VOLTAGE MODEL PWDP13142 EI-175 X 3 2 110/220 VAC 60 HZ 1 CCS PH S2) 6.3 VCT @ 8A CCS 19 S3) 120 VAC @ 0.1A CCS HEATH SB-220 - FILAMENT XFMR 50 HZ EI-137 X REPLACEMENT TRANSFORMER 1.375 HEATH SB-220 / SB-221 - FILAMENT XFMR REPLACEMENT TRANSFORMER HEATH SB-220 POWER XFMR EXACT REPLACEMENT FOR SB-220 / SB-221 / HL-2200 HEATH SB-220-3-7 EXTRA HD REPLACEMENT FOR SB-220 / SB-221 / HL2200 REQUIRES CHASSIS MODIFICATION TO INSTALL PWDF13057 EI-137 X 1.375 PWDP13034 EI 5 5 S1) 5.0 VCT @ 30A CCS PH S2) 90 VAC @ 0.1A CCS 120/240 VAC 50/60 HZ S1) 5.0 VCT @ 30A CCS 1 PH S2) 90 VAC @ 0.1A CCS 6 6 2 117/234 VAC 60 HZ HI- S1) 860/1171 VAC @ 0.7A 23 LO TAPS CCS 10 117/234 VAC 60 HZ HI- S1) 860/1171 VAC @ 1.3A 23 LO TAPS CCS B-0393/ PWDP13026 (SIDE 120/240 VAC 50 HZ 1 MOUNT) HEATH SB-220-X 2-3 TUBE OUTBOARD - POWER TRANSFORMER A-0480/ CCORE 10 117/234 VAC 60 HZ WITH HI-LO TAPS S1) 925/1175 VAC @ 2.13A CCS HEATH SB-220-X2 OUTBOARD - POWER TRANSFORMER (4-6 3-500Z) A-518 CCORE 10 117/234 VAC 60 HZ WITH HI-LO TAPS S1) 925/1175 VAC @ 3.5A 66 CCS 117/234 VAC 60 HZ S1) 0-1850-2400 VAC @ WITH HI-LO TAPS 1.75A CCS HEATH SB-220-X2B OUTBOARD - USE WITH FULL WAVE BRIDGE RECTIFIER HEATH SB-220-X2BS OUTBOARD - X2 FOR BRIDGE RECT WITH HI/LO SEC TAPS A-518 CCORE A-0518/ CCORE HEATH SB-221-X A-0480/ C- 2-3 TUBE OUTBOARD - POWER TRANSFORMER CORE 10 10 10 https://www.hammfg.com/electronics/transformers/classic/pwdahl 230 VAC 60 HZ 1PH 0-1850-2400 VAC @ 2.0A CCS 117/234 VAC 60 HZ S1) 925/1175 VAC @ WITH HI-LO TAPS 2.13A CCS 46 66 66 46 15/31 3/1/22, 12:09 PM Description Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Hammond Style (see Part Number Core above) Approx. Weight Primary Secondary (lbs) S1) 800 VAC @ 0.4A CCS HEATH SB-230 POWER PLATE, BIAS, & FIL POWER FOR 8873 PWDP13015 EI-150 X 3 5 120/240 VAC 60 HZ S2) 95 VAC @ 0.045A 1PH CCS 14 S3) 6.3 VAC @ 3.5A CCS S1) 600 VAC @ 0.020A CCS HEATH SB-610 SCOPE XFMR P/N 54-168, T-601 MONTIOR SCOPE POWER PWDP13070 EI-100 X 1.5 5 120 VAC 60 HZ 1 PH S2) 215 VAC @ 0.050A CCS 3 S3) 6.3 VAC @ 1.5A CCS (5 KVDC TEST) S4) 6.3 VAC @ 2.5A CCS S1) 600 VAC @ 0.020A EI-100 X 1.5" HEATH SB-614 SCOPE XFMR P/N 54-182, STATION MONTIOR SCOPE POWER CCS S2) 210 VAC @ 0.050A 5 120 VAC 60 HZ 1 PH 29GM6X CCS S3) 6.3 VAC @ 0.6A CCS (5 KVDC TEST) 3 S4) 6.3 VAC @ 0.6A CCS (16 VDC @ 55 MA) S1) 600 VAC @ 0.020A CCS HEATH SB-614/620 SCOPE XFMR P/N 54-182, STATION MONTIOR SCOPE POWER S2) 210 VAC @ 0.050A EI-100 X PWDP13099 1.5" 5 120 VAC 60 HZ 1 PH 29GM6X CCS 3 S3) 6.3 VAC @ 0.6A CCS (5 KVDC TEST) S4) 6.3 VAC @ 0.6A CCS (16 VDC @ 55 MA) S1) 0-390-780 @ 80MA HEATH SCOPE EI-ll2 X 1.5 P/N 54-25 5 117 VAC 60 HZ S2) 780-1440 @ 3MA S3) 1440-1440.625 @ 600MA 4 S4) 6.3 VAC @ 3.5A S5) 6.3 VAC @ 0.6A S1) 300-120-0-120-300 HEATH TX-1 LV POWER APACHE EI-150 X (54-65) 2.5 4 117 VAC 60 HZ VAC 175MA S2) 5.0 VAC @ 4A S3) 6.3 VAC @ 3.5A 12 S4) 6.3 VAC @ 9.0A S5) 5.0 VAC @ 2.0A S1) 1600 VCT @ 150 MA HEATH VHF-1 SENECA POWER EI-150 X 2" P/N 54-73 29GM6X CCS S2) 800 VCT @ 100 MA 5 117 VAC 60 HZ 1 PH CCS 10 S3) 5.0 VAC @ 2A CCS S4) 5.0 VAC @ 2A CCS S5) 6.3 VAC @ 8A CCS HEATH W4-AM POWER XFMR P/N 54-29, OPTION - Electrically similar substitute - our stock Hammond P/N 374X HEATH W5M POWER P/N 54-32 OPTION - Electrically similar substitute - our stock 374X 379X Hammond P/N 379X HENRY TEMPO 2000 EI-175 X 4" 2 29GAM6X 120/240 VAC 60 HZ 1 PH HI/LO TAPS 980/760 VAC @ 1.0A ICAS 25 S1) 330 VAC @ 0.5A CCS HENRY TEMPO 2020 T101 ON SCHEMATIC A-0036/ CCORE 10 0-100-110-117/0-100110-117 VAC 60 HZ S2) 0-80-250 VAC @ 100 MA CCS S3) 0-10-20-23 VAC @ 6A 7 (13.8 VDC PRI) S4) 4.5 VCT @ 250 MA CCS (BASE FEEDBACK) https://www.hammfg.com/electronics/transformers/classic/pwdahl 16/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond (see Part Number Core above) Approx. Weight Primary Secondary (lbs) S1) 330 VAC @ 0.5A CCS S2) 0-80-250 VAC @ 100 HENRY TEMPO 2020 (C) A-36 C- T101 ON SCHEMATIC -- 117 VAC PRI ONLY CORE 10 117 VAC 60 HZ 1PH MA CCS S3) 0-10-20-23 VAC @ 6A 7 (13.8 VDC PRI) S4) 4.5 VCT @ 250 MA CCS (BASE FEEDBACK) S1) 2250 VAC @ 200 MA HENRY 1KD-5 POWER XFMR T1, P/N ECA-1111, DIRECT REPLACEMENT PWDP13033 EI-175 X 3" 29G M6X 4 115/230 VAC 50/60 HZ CCS 1PH 19 S2) 5.0 VCT @ 15A CCS HENRY 1KD-5X A-480 C- OUTBOARD POWER TRANSFORMER CORE HENRY 2K CHOKE RESONATES WITH 0.1 MFD 7500 VDC CAP EI-175 X 4" 4 29G M6X 17.6 HY @ 500 MA CCS (700 MA ICAS) EI-250 X 115/230 VAC 60 HZ HENRY 2K CLASSIC HENRY 2K CLASSIC DC CHOKE L101 HEAVY DUTY REPLACEMENT FOR ECA 5023 PWDP13016 3.125 10 4 EI-162 X PWDI13024 HENRY 2K FILAMENT BIAS 4 120/240 VAC 60 HZ 5 120/240 VAC 60 HZ 1PH PWDP13221 EI-212 X 4 4 A-0518/ CCORE 9 HENRY 2K-2 POWER REPLACEMENT POWER TRANSFORMER PWDP13215 EI HENRY 2K-2 POWER HIPERSIL CORE TYPE REPLACEMENT XFMR PWDP13222 4 A-0480/ CCORE 9 HENRY 2K-3 DC FILTER CHOKE EI-19 X 2 4 HENRY 2K-3/4 ER PLATE EI-250 X REPLACEMENT POWER TRANSFORMER 3.125 HENRY 2K-4 CHOKE EI-175 X 4 EXACT REPLACEMENT (USE WITH 0.1 MFD CAP) 29G M6X HENRY 2K-4-XM SPECIAL OUTBOARD POWER TRANSFORMER A-516 CCORE HENRY 2K-4-1 A-518 C- SPECIAL OUTBOARD POWER TRANSFORMER CORE 4 4 10 10 S1) 2250 VAC @ 0.7A CCS S2) 5.0 VCT @ 15A CCS S1) 0-2700-3600 VAC @ 0.5A S2) 10 VCT @ 15A PH 120/240 VAC 60 HZ 1 PH 120/240 VAC 60 HZ 1 PH 120/240 VAC 60 HZ 1 PH S1) 5.5 VCT @ 30A S2) 90 VAC @ 0.1A S1) 6000 VCT @ 0.5A CCS (FWCT) 62 S1) 3500 VAC @ 0.8A CCS 38 S2) 10.2 VCT @ 15A CCS S1) 3500 VAC @ 0.4A ICAS S2) 10.2 VCT @ 15A CCS S1) 3500 VAC @ 0.4A ICAS 26 S2) 10.2 VCT @ 15A CCS 22 TO 10 HY @ 0.7A DC PH 10 2400 VRMS @ 0.45A CCS 38 17.6 HY @ 0.050A DC 115/230 VAC 60 HZ 1 42 18 MFD 7.5 KVDC CAP) 115/230 VAC 60 HZ 1 46 25 8 HY @ 0.8A DC (0.1 EI-150 X 2 LONGER AVAILABLE HENRY 2K-2 MODIFIED 1PH 4 PWDP13155 EI HENRY 2K ULTRA 1PH 2.5" 29GM6X HENRY 2K PLATE TRANSFORMER ORIGINAL LAMINATION SIZE AND STEEL CASE IS NO 115/230 VAC 50/60 HZ S1) 3500 VAC @ 0.4A CCS 42 S2) 10.2 VCT @ 15A CCS 10.0 HY @ 500 MA 25 CCS (700 MA ICAS) 120/240 VAC S1) 3500 VAC @ 1A CCS 58 S2) 10.2 VCT @ 30A 120/240 VAC 60 HZ S1) 4500 VAC @ 800MA 1PH S2) 10.2 VCT @ 15A HENRY 2KD-2 POWER XFMR T1, P/N 70398, DIRECT REPLACEMENT PWDP13218 EI-212 X 3" 4 29G M6X 115/230 VAC 60 HZ 1PH HENRY 2KD-5 POWER XFMR T1, P/N FDN-7497, DIRECT REPLACEMENT EI-212 X 3" PWDP13121 4 29G M6X 115/230 VAC 60 HZ 1PH 66 S1) 2800 VAC @ 400 MA CCS 29 S2) 10.0 VCT @ 15A CCS S1) 0-1780-2250 VAC @ 400 MA CCS 29 S2) 10.0 VCT @ 15A CCS HENRY 3K ER PLATE EXACT REPLACEMENT, TRIAD P/N 70400 EI-250 X 5" 4 29GM6XRH https://www.hammfg.com/electronics/transformers/classic/pwdahl 230 VAC 60 HZ HI-LO TAP S1) 3800/2800 VAC @ 600MA CCS 65 17/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Approx. Hammond (see Part Number Core above) Primary 9 10 HY @ 700 MA DC A-0518/ CCORE 9 230 VAC 60 HZ HI-LO TAP S1) 4000/3000 VAC @ 600MA CCS 38 HENRY 3K-A-M HEAVY DUTY PLATE TRANSFORMER A-516 CCORE 10 230 VAC 60 HZ 1 PH HI-LO TAPS 4000/3000 VAC @ 1.0A CCS 58 HENRY 3K-A-MC PLATE A-0518/ C- SPECIAL HENRY 3K-A PLATE WITH SEC TAPS CORE 9 230 VAC 60 HZ 1 PH HENRY 3K-CLASSIC X PLATE A-0525/ C- PLATE XFMR FOR EXPORT MODEL CORE HENRY 3K-CLASSIC X-1 PLATE A-0525/ C- PLATE XFMR FOR EXPORT MODEL W/HI/LO PRI CORE HENRY 3002A-M PLATE HEAVY DUTY PLATE TRANSFORMER A-0516/ CCORE 10 HENRY 4K ULTRA CHOKE EI-212 X 4 4 Description HENRY 3K-A DC FILTER CHOKE A-0203/ C- RESONATES WITH 0.1 MFD 7500V CAPACITOR CORE HENRY 3K-A PLATE HIPERSIL REPLACEMENT FOR HENRY 3K-A HENRY 4K ULTRA DC CHOKE RESONANT CHOKE - REQUIRES 0.2 MFD 10 KVDC CAP PWDP13084 PWDI13097 A-0518/ CCORE 10 10 9 HENRY 4K ULTRA PLATE REPLACEMENT XFMR WITH 20% PRI CUTBACK TAP PWDP13147 EI 4 FOR MODERN PRI VOLTAGES HENRY 4K-2 DC FILTER CHOKE EI-175 X 4" REPLACES TRIAD P/N 16113 29GA M6X HENRY 4K-2 SCREEN/BIAS XFMR EI-137 X 1.75 HENRY 8K ULTRA XHD DC CHOKE A-0525/ C- EXTRA HEAVY DUTY DC FILTER CHOKE CORE HUNTER 2000A A-0459/ C- POWER TRANSFORMER CORE Weight Secondary 17 0-2800-3500-4000 VAC @ 0.6A CCS 0-200-210-220-230 S1) 0-3000-4000 VAC @ VAC 60 HZ 1 PH 1.5A ICAS 230 VAC 60 HZ HI LO- 4000/3000 VAC @ 1.5A TAP (lbs) ICAS 38 86 86 0-220-230-240 VAC 60 0-3000-4400 VAC @ 1.0A 58 HZ 1 PH CCS 4 HY @ 1.5A CCS OR 38 2.0A ICAS 9.0 HY @ 1.0A DC 38 (4500 WVDC) 0-244-294 VAC 60 HZ 1 0-3500-4200 VAC @ 1.0A PH ICAS 102 8.8 HY @ 0.7A DC 2 (RESONATE WITH 0.2 25 MF) S1) 0-500-700-900 VAC @ 5 230 VAC 60 HZ 1 PH 0.1A CCS 7 S2) 175 VAC @ 0.1A CCS 9 9 8.0 HY @ 1.5A CCS 49 120/240 VAC 60 HZ 1 S1) 0-450-700-900 VAC @ 1.0A CCS PH S2) 6.3 VCT @ 16A CCS 23 S3) 6.3 VAC @ 1A CCS S1) 0-800-860-920 VAC @ HUNTER 2000B A-0459/ C- POWER TRANSFORMER CORE HUNTER 2000C EI-225S X POWER TRANSFORMER 3" 9 6 120/240 VAC 60 HZ 1 1.0A CCS PH S2) 6.3 VCT @ 16A CCS S3) 6.3 VAC @ 1A CCS 117/234 VAC 60 HZ 1PH 23 S1) 900 VAC @ 1.0A CCS S2) 7.0 VAC @ 1.0A CCS 35 S3) 6.0 VCT @ 25A CCS S1) 0-265-530 VAC @ 0.25A CCS S2) 0-130-260 VAC @ HY-GAIN 3750 POWER XFMR EI-150 X 2 STYLE NO. 5 HORIZONTAL ENDBELL TYPE 29 M6 5 0-100-110-120/0-100110-120 VAC 60HZ 0.1A CCS S3) 80 VAC @ 0.1A CCS S4) 0-7-14 VAC @ 3.5A 10 CCS S5) 6.3 VAC @ 4.5A CCS S6) 12.6 VAC @ 0.7A CCS S1) 1060 VCT @ 150 MA JOHNSON ADVENTURER POWER VIKING ADVENTURER POWER TRANSFORMER EI-l25 X PWDP13068 1.75 4 115 VAC 60 HZ 1 PH CCS S2) 6.3 VAC @ 2A CCS 6 S3) 5.0 VAC @ 3A CCS JOHNSON CHALLENGER POWER EFJ P/N 22.1501, T1 MAIN POWER XFMR PWDP13206 EI-150 X 2 4 115 VAC 60 HZ 1 PH S1) 1300 VCT @ 275 MA CCS (FWCT) S2) 6.3 VAC @ 5A CCS 10 S3) 5.0 VAC @ 3A CCS https://www.hammfg.com/electronics/transformers/classic/pwdahl 18/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond (see Part Number Core above) Approx. Weight Primary Secondary (lbs) S1) 300 VCT @ 150 MA JOHNSON DESK KW BIAS T-200 (WILL FIT, BUT NEED NEW MTG HOLES) PWDP13058 EI-125 X 2 JOHNSON DESK KW FILTER CHOKE A-0393/ C- HV FILTER CHOKE, L300 CORE JOHNSON DESK KW MOD PP 810 MODULATORS TO PARALLEL 4-250A'S PWDM13037 EI-175 EESTACK JOHNSON DESK KW MOD FILAMENT EI-137 X FILAMENT XFMR FOR PP 810 MODULATORS 1.375 JOHNSON DESK KW PLATE EI-287 X 5" P/N P-2126 STACK JOHNSON DESK KW PLATE (HR) HIPERSIL REPLACEMENT TRANSFORMER PWDP13051 JOHNSON DESK KW RECT FIL 872A RECTIFIER FILAMENT XFMR, T-301 JOHNSON DESK KW SCREEN T-201, EFJ P/N 22.1069 JOHNSON INVADER 2000 L301 DC FILTER CHOKE, 4-10 HY @ 500 MA DC PWDP13192 PWDI13231 5 10 115 VAC 60 HZ 1 PH 1800/2400 VCT, 18000/11600 OHMS PP 5 115 VAC 60 HZ 1 PH 10.0 VCT @ 10A CCS 115/230 VAC 60 HZ 1 2900-2325-0-2325-2900 PH VAC @ 600 MA CCS (6250 OHMS RFPA) 35 6 100 A-0480/ CCORE 10 115/230 VAC 60 HZ 1 PH 2900-2325-0-2325-2900 VAC @ 600 MA CCS 46 EI-150 X 2 4 115 VAC 60 HZ 1 PH S1) 5.0 VCT @ 20A CCS (10 KVDC INSULATION) 10 115 VAC 60 HZ 1 PH 1350 VCT @ 125MA OR (HI-LO TAPS) 1060 VCT @ 130MA EI-125 X 1.25 EI-175 X 2 5 5 10 HY @ 90 MA TO 4 .875 JOHNSON INVADER 2000 PLATE MAIN PLATE TRANSFORMER EI-225 X 3" 6 29G M6X 117/234 VAC 60 HZ 1 PH JOHNSON INVADER 2000 SCREEN EI-l25 X 2" 0-105-117 VAC 60 HZ 1 T-303, SNC P/N P4215, EFJ P/N 22-1643 29G M6X 1 4 EI-100 X 1 4 EI-175 X 2 4 5 HY @ 100 MA DC 2 (600 WVDC) PH 115 VAC 60 HZ 1 PH 4 14 HY @ 500 MA DC EI-87 X JOHNSON THUNDERBOLT DC CHOKE L101 HIGH VOLTAGE DC FILTER CHOKE 1768 VAC @ 283 MA CCS 8 5 7 23 (2500 WVDC 1 PH) DC SCREEN CHOKE, 5 HY @ 100 MA DC 866A HIGH VOLTAGE FILAMENT TRANSFORMER S2) 5.0 VAC @ 3A CCS S3) 5.0 VAC @ 3A CCS 6.0 HY @ 800MA DC JOHNSON INVADER 2000 L302 JOHNSON INVADER 2000 T302 CCS 5000 VCT @ 400 MA ICAS 33 S1) 1060 VCT @ 130 MA CCS S2) 5.3 VAC @ 2A CCS S1) 2.5 VAC @ 10A CCS (5 KVDC TEST) 7 2 25 HY @ 80 MA TO 5 PWDI13205 HY @ 500 MA 2200 14 VDC S1) 5.0 VAC @ 15A CCS (4-400A FILAMENT) JOHNSON THUNDERBOLT FILAMENT T-102, SNC P/N P3389, EFJ P/N 22.789-1 EI-150 X 1.5 2 115 VAC 60 HZ 1 PH S2) 5.0 VAC @ 15A CCS (4-400A FILAMENT) 8 S3) 2.5 VAC @ 10A CCS (866A FILAMENTS) S1) 783-219-0-219-783 JOHNSON THUNDERBOLT LV T-103 SCREEN & BIAS TRANSFORMER, P/N 22.1421 PWDP13250 EI-l25 X 1.75 4 JOHNSON THUNDERBOLT PLATE DIRECT REPLACEMENT - PLATE TRANS (SAME AS T302 - JOHNSON 500 PLATE) PWDP13046 EI JOHNSON VALIANT DRIVER XFMR EI-062 X P/N 22.1286, T4 .75 5 0-110-120 VAC 60 HZ 1 VAC @ 0.1A CCS PH 115/230 VAC 60 HZ 1 PH 230 OHMS DC (12AU7 1 AUDIO DRIVER PLATE) S2) 5.0 VAC @ 3.0A CCS S3) 6.3 VAC @ 1.6A CCS 6 4800 VCT @ 500 MA CCS 33 800 OHMS CT (PP 6146 MODULATOR GRIDS) 1 S1) 310-215-0-215-310 VAC @ 250 MA CCS JOHNSON VALIANT LOW VOLTAGE EI-150 X 2 POWER TRANSFORMER, (T-2) SNC P/N 3068 5 117 VAC 60 HZ S2) 6.3 VAC @ 12A CCS 10 S3) 2.5 VAC @ 10A CCS S4) 5.0 VAC @ 2A CCS JOHNSON VALIANT LV CHOKE EI-100 X 1 5V4 +300 VDC FILTER CHOKE, L-44 JOHNSON VALIANT MOD XFMR EFJ P/N 22.1285, SNC P/N P2998 PWDM13044 EI-125 X 1.5 3 5 https://www.hammfg.com/electronics/transformers/classic/pwdahl 10 HY @ 100 MA DC 2 (300 WVDC) 840 VCT @ 0.212A S1) 450 VCT @ 0.300A CCS (7300 OHMS P-P) CCS (2100 OHMS RF PA) 5 19/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description (see Part Number Core above) Primary 5 120 VAC 60 HZ 1 PH 3.5" FOR JOHNSON VALIANT TRANSMITTER HV DC FILTER CHOKE JOHNSON VIKING COURIER PLATE TO DELIVER 1500 VDC @ 335 MA JOHNSON VIKING II AUDIO DR SNC P/N 1503 EFJ P/N 22.753 Weight EI-150 X JOHNSON VALIANT PLATE JOHNSON VIKING COURIER CHOKE Approx. Hammond 29GM6X PWDI13055 PWDP13056 EI-137 X 2" 29G M6X EI-175 X 3" 5 Secondary S1) 1520 VCT @ 400MA CCS PR) 10 HY @ 0.35A (lbs) 16 8 CCS (1500 WVDC) S1) 3600 VCT @ 237 MA 5 115 VAC 60 HZ 1 PH PWDA13076 EI-62 SQ. 3 100 VAC @ .030A CCS S1) 84 VCT @ .036A CCS 1 (SINGLE 6AU6 PLATE) (PP 807 GRIDS) EI-62 SQ. 3 100 VAC @ .030A CCS 84 VCT @ .036A CCS (PP 1 (SINGLE 6AU6 PLATE) 807 GRIDS) EI-150 X 2 5 115 VAC 60 HZ 1 PH JOHNSON VIKING II AUDIO DR-1 SNC P/N 1503 EFJ P/N 22.753 * NO AIR GAP JOHNSON VIKING II HV XFMR SNC P/N #1781, EFJ P/N 23.1002-1 29GAM6X CCS 865-0-865 VAC @ 250MA CCS 19 10 S1) 298-70-0-70-298 VAC JOHNSON VIKING II LV POWER T-2, P/N 22.752, P/N P1893 @ 250MA CCS PWDP13225 EI-125 X 2 5 115 VAC 60 HZ 1 PH S2) 6.3 VAC @ 7A CCS S3) 5 VAC @ 2A CCS EI-112 X PWDM13220 1.875 5 795 VCT @ 100 MA PP S1) 500 VAC @ 250 MA 807 @ 7000 OHMS P-P DC (RP = 2800 OHMS) PWDI13014 1 7 S4) 5 VAC @ 2A CCS JOHNSON VIKING II MOD XFMR T4, SNC P/N P1992 PP 807'S TO PAR 6146 JOHNSON VIKING RANGER CHOKE P/N 22.749, SNC P/N P1501, LV DC CHOKE JOHNSON VIKING RANGER AUDIO DR SNC P/N 1503 EFJ P/N 22.753 EI-087 X 1 PWDA13076 EI-62 SQ 3 15.0 HY @ 95 MA DC 2 (DCR = 290 OHMS) 100 VAC @ .030A CCS 5 S1) 84 VCT @ .036A CCS (PP 1614 / 6L6 GRIDS) 1 S1) 19.8 VAC @ 0.050A JOHNSON VIKING RANGER II MOD SNC P/N P2429, T2, PP 7027A'S, 32 WATTS PWDM13007 EI-087 X 1 1 10600 OHM PP, 695 CCS (4% FEEDBACK) VCT @ .072A CCS S2) 495 VCT @ .065A AC & .130A DC 2 S1) 670-420-140-0-140JOHNSON VIKING RANGER PLATE SNC P/N 2793, EFJ P/N 22.985 EI-150 X PWDP13183 2.5 5 117 VAC 60 HZ 2 10 HY @ 200MA DC (350 WVDC) 420-670 VAC @ 0.260A S2) 6.3 VAC @ 10A CCS 12 S3) 5.0 VAC @ 3A CCS JOHNSON VIKING 500 L302 10 HY @ 200MA, P/N 22.1264 JOHNSON VIKING 500 L303 EFJ P/N 22.1265 25HY@.08A TO 5 HY @ 0.5A JOHNSON VIKING 500 MOD VIKING 500 MODULATION TRANSFORMER JOHNSON VIKING 500 PLATE DIRECT REPLACEMENT - PLATE TRANS (T-302) PWDI13131 PWDI13036 EI-112 X 1.5 EI-175 X 2" 29GAM6X 5 PWDM13062 EI-212 X 3 4 PWDP13046 EI CORE 5 4 25 HY @ 80 MA TO 5 14 HY @ 0.5A * 2200 VDC S1) 8000 OHMS 23000 OHMS P-P 2400 (2000VDC @ VCT (200-3500 HZ) 250MA)1414VAC 250W 115/230 VAC 60 HZ 1 PH 29 4800 VCT @ 500 MA CCS 33 S1) 960 VCT @ 200MA CCS JOHNSON VIKING 500 T-301 LV POWER TRANSFORMER, P/N 22.1266 PWDP13025 EI-175 X 1.75 5 115 VAC 60 HZ 1 PH S2) 560 VCT @ 100MA CCS S3) 6.4 VCT @ 9A CCS 12 S4) 2.5 VCT @ 10A CCS (10 KVDC INSULATION) S5) 5.0 VCT @ 3A CCS JOHNSON VIKING 500 T102 AUDIO DRIVER 4W 6B4 TO PP 6146'S JOHNSON 6N2 T-BOLT FILAMENT FILAMENT TRANSFORMER, T-102 JOHNSON 6N2 T-BOLT PLATE T101 PLATE TRANSFORMER EI-75 X 1 1 EI-125 X 1.75 5 EI-212 X 4 2 LOUDENBOOMER MK 2 A-0393/ C- PLATE TRANSFORMER CORE 76 VAC @ .050A (170 76 VCT @ .050A (180 OHMS DC) OHMS DC) 1 S1) 2.5 VAC @ 10A CCS 115 VAC 60 HZ 1 PH S2) 6.0 VAC @ 6A CCS 6 S3) 115 VAC @ 0.1A CCS 10 https://www.hammfg.com/electronics/transformers/classic/pwdahl 115/230 VAC 60 HZ 1 S1) 4800 VCT @ 0.5A PH CCS 115/230 VAC 60 Hz S1) 6570 VCT @ 300 MA CCS FWCT CHK INPUT 38 23 20/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond (see Part Number Core above) Approx. Weight Primary Secondary (lbs) S1) 0-1600-2000 VAC @ MCABEE A-518-10 MULTI-SEC-#1 A-0518/ C- PLATE/SCREEN/BIAS/FILAMENT TRANSFORMER CORE 10 0-220-240 VAC 60 HZ 1 PH 2.0A CCS S2) 6.0 VAC @ 21A CCS (8 EA 4CX250R'S) 66 S3) 280 VCT @ 0.25A CCS S4) 90 VAC @ 0.1A CCS MFJ P/N 406-1418-X SPECIAL HEAVY DUTY MODEL FOR AL-1500 A-0480/ CCORE MFJ P/N 406-1418-1DX A-0516/ C- EXTRA HEAVY DUTY AL-1500 TRANSFORMER CORE MFJ P/N 406-1418-1DX-J A-0516/ C- EXTRA HD AL-1500 XFMR, 100/200 VAC PRI CORE MFJ P/N 406-1418-1J "J" IS JAPANESE VERSION FOR AL-1200 A-274/C C10 CORE MOD TRANSFORMER 1200 WATT A-550/C C- PP 304TL'S @ 12,000 OHMS P-P CORE MOD TRANSFORMER 30 WATT EI-175 X 1.75 29G SINGLE 807 @ 450 VDC @ 150MA DC THRU SEC 10 10 10 9 4 M6 MOD TRANSFORMER 300 WATT A-0518/ C- PP 4CX150A'S @ 17600 OHMS P-P CORE MOD TRANSFORMER 500 WATT PP 813'S TO SINGLE 813 @ 2000 VDC @ .25A A-0525/ CCORE 0-220-240 VAC 60 HZ 1PH 0-120 & 0-100-120 VAC 60 HZ 1PH 100/200 VAC 50/60 HZ 1PH S1) 2570 VAC @ 1.0A CCS 46 2800 VAC @ 1.5A ICAS 58 2800 VAC @ 1.5A ICAS 58 100/200 VAC 50/60 HZ 2570 VAC @ 800MA ICAS 37 2872 VCT @ 0.34A 1768 VAC @ 0.39A CCS CCS (12,000 OHMS P(2500 VDC @ .55A) P) 16.4 VAC @ 2.0A CCS S1) 318 VAC @ 0.106A (8 OHMS) CCS (3000 OHMS) 137 12 9 2100 VCT @ 0.17A 1414 VAC @ 0.18A CCS CCS (17,600 OHMS P(2000 VDC @ .25A) P) 38 9 1768 VCT @ 0.2A CCS 1414 VAC @ 0.25A DC (PP 813'S 16K PP) (2000 VDC @ 0.25A) 49 S1) 550 VCT @ 200 MA NATIONAL HRO-60 POWER (R) NOT EXACT REPLACEMENT BUT WILL FIT IN PWDP13224 EI-150 X 2 5 115/230 VAC 60 HZ 1 PH CCS S2) 5.0 VAC @ 3A CCS 10 S3) 0-6.3-13.3 VAC @ 6A CCS NATIONAL NC-183 POWER PWDP13122 EI NATIONAL NCL-2000 FIL/BIAS EI-087 X T2 (FILAMENT & BIAS), P/N C51440 2.250 6 115/230 VAC 60 HZ 1 8 PH S1) 130 VCT @ 50 MA 5 115 VAC 60 HZ 1 PH CCS 2 S2) 13.5 VAC @ 3A CCS S1) 1080 VRMS @ 0.91 NATIONAL NCL-2000 POWER TRANSFORMER (PLATE & SCREEN) VOLTAGES PWDP13091 EI-175 X 4 2 117/234 VAC HI-LO AMPS CCS TAPS 60 HZ 1PH S2) 450 VRMS @ 0.070 25 AMPS CCS S1) 1100 VAC @ 0.36A NATIONAL NCX-1000 POWER PLATE, DRIVER PLATE & SCREEN VOLTAGES PWDP13003 EI-175 X 2.5 2 117/234 VAC 60 HZ 1 PH CCS 17 S2) 0-240-480 VAC @ 0.20A CCS S1) 310 VRMS @ 1.0 AMP PALOMAR 300A POWER PWDP13148 EI-150 X 2 1/2" 5 117 VAC 60 HZ 1 PH CCS S2) 14 VRMS @ 8 AMPS CCS PITTENGER JP1815 A-480 C- FOR AMP IN AUG 84 ISSUE OF HAM RADIO CORE PITTENGER P/N FT-800A7 DUAL 3CX800A7 FILAMENT TRANSFORMER PITTENGER P/N JP3315 PLATE FOR J. PITTENGER 8877 AMP IN SEPT 86 QST PITTENGER P/N PT-2475 FOR K8RA AMPS DESCRIBED IN ARRL HANDBOOK PWDP13166 PWDP13239 10 240 VAC 60 HZ 1 PH 1800 VRMS @ 1.5A CCS 46 EI-100 X 1 1 120 VAC 60 HZ 1 PH 13.5 VAC @ 3.0A CCS 2 A-0518/ CCORE 10 230 VAC 60 HZ 1 PH 0-2300-2600-3300 VAC @ 66 1.5A CCS 117/234 VAC 60 HZ 1 0-1770-2125-2475 VAC @ PH 1.5A CCS 117/234 VAC 60 HZ 1 0-1414-1770-2125-2475 PH VAC @ 1.5A CCS A-0518/ CCORE PITTENGER P/N PT-2475-01 A-0518/ C- ADDITIONAL SEC TAP @ 1414 VAC CORE 10 10 https://www.hammfg.com/electronics/transformers/classic/pwdahl 66 66 21/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond Part Number Core PITTENGER P/N PT-2475-1 A-0516/ C- 1.35 AMP CCS VERSION OF PT-2475 CORE PRIME INST P/N AL1800T A-393 C- PLATE TRANSFORMER CORE PRIME INST P/N AL2080 A-274 CCORE PRIME INST P/N AL2080A A-393 CCORE PRIME INST P/N AL2400 A-0393/ C- PLATE TRANSFORMER CORE (see above) 10 10 10 10 10 Approx. Primary Secondary 117/234 VAC 60 HZ 1 0-1770-2125-2475 VAC @ PH 1.35A CCS 117/234 VAC 60 HZ 0-1200-1650-1800 VAC @ 1PH 500 MA CCS 120/240 VAC 60 HZ Weight (lbs) 58 23 2080 VAC @ 0.8A ICAS 37 120/240 VAC 60 HZ 1PH 2080 VAC @ 0.5A CCS 23 117/234 VAC 60 HZ S1) 0-1700-2400 VAC @ 1PH 500 MA CCS 1PH 23 S1) 970 VAC @ 700 MA PRIME INST P/N AL8A PRIME INST P/N AL84T PRIME INST P/N AL88T EI-162 X 3.5 A-0016/ CCORE A-0393/ CCORE 4 10 10 117/234 VAC 60 HZ 1 CCS PH S2) 5.0 VCT @ 15A CCS S3) 12 VAC @ 2A CCS 117/234 VAC 60 HZ 1 PH 24 S1) 0-600-850 VAC @ 1.0A ICAS S2) 6.0 VAC @ 8A CCS 117/234 VAC 60 HZ S1) 0-1700-2400 VAC @ 0.5A 1PH S2) 10 VAC @ 2.0A 17 23 S3) 5 VAC @ 10A PRIME INST P/N AR-418 A-0274/ CCORE PRIME INST P/N AR-418-M PLATE TRANSFORMER A-274 CCORE PRIME INST P/N AR418-1J A-274/C C- "J" IS JAPANESE VERSION CORE SIGNAL ONE CX7A A-0371/ CCORE SIGNAL ONE 1030 A-0371/ C- MILSPEC 1030 TRANSCEIVER POWER XFMR CORE 10 120/240 VAC 50/60 HZ 1 PH 10 0-220-240 VAC 50/60 HZ 1 PH 10 100/200 VAC 50/60 HZ 9 117/234 VAC 60 HZ 1 PH 9 120/240 VAC 60 HZ 1 PH S1) 2570 VAC @ 800MA 37 S1) 2872 VAC @ 800 MA ICAS 37 S1) 2570 VAC @ 800MA ICAS 37 S1) 230 VAC @ 0.1A CCS S2) 43 VCT @ 1.0A CCS 8 S3) 575 VAC @ 0.2A CCS S1) 22.0 VAC @ 20 AMPS 8 S1) 650 VCT @ 300 MA STANCOR P-8339 EI-150 X 2.5 CCS 5 117 VAC 60 HZ 1 PH S2) 5.0 VAC @ 3A CCS S3) 12.6 VCT @ 5.25A 12 CCS STANCOR P-8339-1 EI-150 X 2.5 5 117 VAC 60 HZ 1 PH S1) 600 VCT @ 300 MA CCS S2) 12.6 VCT @ 5.25A 12 CCS STANCOR P/N P-8031 A-518/C C- HIPERSIL VERSION OF STANCOR P/N P-8031 CORE STANCOR P/N PC-8417 30 VA LV RECTIFIER POWER TRANSFORMER EI-100 X 1 10 5 115/230 VAC 60 HZ 1 S1) 2075-1775-0-1775- PH 2075 VAC @ 0.5A CCS S1) 440 VCT @ 0.050A 0-110-115 VAC 60 HZ 1 CCS PH S2) 6.3 VAC @ 0.6A CCS 66 2 S3) 25.2 VAC @ 0.5A CCS SVETLANA 4CX800A FIL XFMR EI-150 X FIL & BIAS XFMR FOR 2 TUBES 1.5 SVETLANA 4CX800A FIL, BIAS, SCREEN XFMR FIL & BIAS XFMR FOR 2 TUBES WITH HIGHER SCREEN PWDP13193 VOLTAGE EI-150 X 1.5 SVETLANA 4CX800A PLATE XFMR A-0274/ C- 2500 VDC @ 1.0A ICAS FROM FWC CAP INPUT CORE 4 0-115-120-125 VAC 60 S1) 12.6 VAC @ 8A CCS HZ 1 PH S2) 150 VAC @ 0.1A CCS 8 S1) 12.6 VAC @ 8A CCS S2) 70 VAC @ 150 MA 4 10 https://www.hammfg.com/electronics/transformers/classic/pwdahl 0-115-120-125 VAC 60 CCS HZ 1 PH S3) 250 VAC @ 0.25A CCS 0-230-240-250 VAC 60 S1) 1770 VAC @ 1.5A HZ 1 PH ICAS 8 37 22/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond Part Number Core (see above) SWAN MARK I POWER POWER TRANSFORMER FOR SWAN MARK I LINEAR EI-162 X 3" PWDP13012 6 29GAM6X Approx. Primary Secondary Weight (lbs) S1) 0-568-1065 VAC @ 120/240 VAC 60 HZ 1 PH 0.5A CCS 21 S2) 10.0 VCT @ 15A CCS S3) 12 VAC @ 1A CCS S1) 0-500-1000 VAC @ A-480 C- SWAN MARK VI OUTBOARD POWER CORE 10 120/240 VAC 60 HZ 2.0A CCS 1PH S2) 10.0 VCT @ 15A CCS 46 S3) 12.0 VAC @ 2A CCS S1) 588/1123 VAC @ 1.2A SWAN MK II 3 TUBE OUTBOARD A-274 C- MUST RUN FILAMENTS IN SERIES CORE SWAN MK-I-X A-480 C- OUTBOARD POWER TRANSFORMER CORE SWAN MK-I-X2 A-0518/ C- HEAVY DUTY OUTBOARD POWER TRANSFORMER CORE 10 117/234 VAC 60 HZ CCS S2) 15 VCT @ 15A CCS S3) 12.6 VAC @ 2A CCS 37 S1) 0-568-1065 VAC @ 10 117/234 VAC 60 HZ 1 1.5A CCS PH S2) 10.0 VCT @ 30A CCS S3) 12 VAC @ 1A CCS 46 S1) 0-568-1065 VAC @ 10 117/234 VAC 60 HZ 1 3.0A CCS PH S2) 10.0 VCT @ 30A CCS 66 S3) 12 VAC @ 1A CCS SWAN 117-B/C FILTER CHOKE P/N 274-001, 3946524 (2 EA SWAN 400 PS) EI-62 X .75 1 3.5 HY @ 80 MA DC (+275 VDC SUPPLY) 1 S1) 0-320-640 VAC @ 360 MA CCS SWAN 117-B/C POWER EI-150 X 2 FOR SWAN 400 AC POWER SUPPLY 6 117 VAC 60 HZ 1 PH S2) 90 VAC @ 140 MA CCS 10 S3) 12.6 VAC @ 3.69A CCS S1) 0-9.6-14.4-19.2 VAC @ 6A CCS (DC PRI) S2) 427 VAC @ 300 MA SWAN 117-XC POWER FOR SWAN 350 AC POWER SUPPLY PWDP13023 EI-150 X 2 4 117 VAC 60 HZ 1 PH CCS (AC PRIMARY) S3) 230 VAC @ 300 MA CCS 10 S4) 90 VAC @ 140 MA CCS S1) 0-9.6-14.4-19.2 VAC @ 6A CCS (DC PRI) S2) 427 VAC @ 300 MA SWAN 230-XC POWER FOR SWAN 350 AC POWER SUPPLY EI-150 X 2" PWDP13027 4 29G M-6 117/234 VAC 50/60 HZ CCS 1 PH (AC PRIMARY) S3) 230 VAC @ 300 MA 10 CCS S4) 90 VAC @ 140 MA CCS TEN-TEC 422 & 422B - HV TRANSFORMER FOR TEN-TEC MODEL 422 CENTURION LINEAR AMPLIFIER Page 3-1 of the Ten-Tec Centurion Manual (Section 3-1.4) is incorrect. PWDP13045 B-0393/ CCORE 10 115/230 VAC 60 HZ 1 P 2225 VAC @ 0.5A CCS 23 The stock unit was not a 2.5KVA unit nor did it weigh 35 lbs (it weighs 23 lbs.) Special thanks to Steve - KD8ZBG for reporting this. S1) 1270 VAC @ 1.0A CCS TEN-TEC 425 TITAN POWER XFMR T1, MAIN POWER TRANSFORMER PWDP13039 A-0480/ CCORE 10 120/240 VAC 50/60 HZ S2) 570 VAC @ 1.0A CCS 1 PH S3) 13.5 VAC @ 6A CCS 46 S4) 20 VAC @ 6A CCS S5) 20 VAC @ 2A CCS https://www.hammfg.com/electronics/transformers/classic/pwdahl 23/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description THOMAS LV POWER #01 LOW VOLTAGE POWER TRANSFORMER THORDARSON P/N T-11M77 125-300 WATT MULTI-MATCH MODULATION XFMR Hammond (see Part Number Core above) EI-150 X 1.5 4 EI 5 Approx. Weight Primary 120/240 VAC 60 HZ 1 PH 2.5" 5 S2) 60 VAC @ 0.3A CCS SINGLE 813 @ 2000 VDC @ 225 MA DC 29GM6X 8 S3) 6.3 VCT @ 10A CCS VDC 117 VAC 60 HZ 1 PH (lbs) S1) 290 VCT @ 0.3A CCS PP 811A'S @ 1000 EI-150 X THORDARSON P/N T-21P93 Secondary S1) 2150/1000 VCT @ 95/125 MA CCS FWCT 26 12 S1) 12.6 VCT @ 10.8A TIBBETTS LV POWER #01 (3) 4CX800A FIL/BIAS/SCREEN XFMR CCS EI-150 X 1.5" 4 29GAM6 120/240 VAC 60 HZ 1 S2) 270 VCT @ .025A PH CCS S3) 570 VCT @ .080A 8 CCS S1) 850 VAC @ 0.5A CCS TOKYO HY POWER LABS HL-1K EI-175 X 3" T1, (NEED MTG BRKTS FROM OLD XFMR) 29G M6X 2 0-100-110-117/0-100- S2) 280 VAC @ 0.1A CCS 110-117 VAC 60 HZ S3) 100 VAC @ 0.1A CCS 19 S4) 12 VAC @ 3A CCS TRANSWORLD P/N 410012 T9, T10, T11 OR T12 IN TRANSWORLD SS AMP TRIAD P-11A WILL YIELD 600 VDC @ 250 MA FROM FWCT TRIAD P-216AL PLATE TRANSFORMER (WITHOUT END COVERS) TRIAD P-217AL PLATE TRANSFORMER EI-125 X PWDP13167 1.25" 2 120 VAC 60 HZ 1 PH EI-150 X 2 5 115 VAC 60 Hz EI-212 X 3 4 EI-175 X PWDP13040 2.5" EI-175 X POWER TRANSFORMER 1.75 POWER TRANSFORMER 5 29GAM6 TRIAD P-3A TRIAD P-9A 15.1 VAC @ 8A CCS 4 29GM6 5 S1) 1455 VCT @ 250 MA CCS 115/230 VAC 60 HZ S1) 2430 VCT @ 500 MA 1PH CCS (FWCT) 115/230 VAC 50/60 HZ 2880 VCT @ 0.25A DC 1 PH (FWCT) 115 VAC 60 HZ 1 PH S1) 600/300 VCT @ 0.3A CCS 10 29 17 12 S2) 5.0 VAC @ 4A CCS S1) 1236 VCT @ 500 MA EI-175 X 3" 5 115 VAC 60 HZ 1 PH CCS (FWCT) 19 S2) 5 VAC @ 6A CCS TRIAD P/N 70581 EI-250 X HENRY 2K-4 REPLACEMENT POWER TRANSFORMER 3.125 4 115/230 VAC 60 HZ 1 PH S1) 3500 VAC @ 0.4A CCS 42 S2) 10.2 VCT @ 15A CCS S1) 700 VCT @ 125 MA TRIAD R-14A POWER XFMR PLATE & FILAMENT TRANSFORMER EI-l25 X 1.5 5 115 VAC 60 HZ 1 PH CCS S2) 5.0 VAC @ 3A CCS 5 S3) 6.3 VCT @ 4.5A CCS S1) 800 VCT @ 70 MA DC CCS TRIAD R-83A EI-ll2 X O-12 OSCILLOSCOPE POWER TRANSFORMER 1.875 S2) 650 VAC @ 3 MA DC 5 115 VAC 60 HZ 1 PH CCS 5 S3) 1.25 VAC @ 0.3A CCS S4) 6.3 VCT @ 3.5A CCS S5) 6.3 VAC @ 0.6A CCS UTC CVM-2 60W MULTI-MATCH MOD XFMR IN RC-150 CASE EI 5 18K-2K OHMS P-P S1) 30K-200 OHMS RF PA CENTER TAPPED (60 WATTS AUDIO OUT) 11 S1) 1240 VAC @ 0.4A VECTRONICS HF600-QSK POWER SINGLE 3-500Z IN GROUNDED GRID CCS EI-200RX 2" 4 29GAM6X 0-120 & 0-80-100-120 VAC 60 HZ 1 PH S2) 21 VAC @ 0.2A CCS 18 S3) 5.8 VCT @ 15A CCS VR GLOBE KING 500 MOD XFMR PP 811A'S TO SINGLE 4-250A/4-400A RF PA EI-150 X 3.5" 5 29GM6X https://www.hammfg.com/electronics/transformers/classic/pwdahl 1465 VCT @ 0.246A S1) 1275 VAC @ 0.283A CCS (7400 OHMS P-P) CCS (1800 VDC @ .4A) 16 24/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond (see Part Number Core above) EI-112 X YAESU FL-2000B LV PWR T2 1.5" FILAMENT & CONTROL VOLTAGE TRANSFORMER 2 29GAM6 Approx. Weight Primary Secondary 0-100-110-117 & 0-100- S1) 6.5 VCT @ 8A CCS 110-117 VAC 60 HZ S2) 13 VAC @ 1A CCS (lbs) 4 S1) 0-425-620-850 VAC @ YAESU FL-2100B POWER XFMR EI-175 X 3" P/N 21002, T1, FOR PAIR OF 572B'S 29GAM6X 6 0-100-110-117 & 0-100- 1A ICAS 110-117 VAC 60 HZ S2) 6.5 VCT @ 8A CCS 19 S3) 13 VAC @ 1A CCS YAESU FT-901 POWER XFMR EI-137 X WITHOUT DC WINDINGS & DUAL PRIMARY 2.5 6 0-100-110-117 VAC 60 HZ 1 PH S1) 320 VCT @ 0.5A CCS S2) 0-120-190-250 VAC @ 0.1A CCS 10 S3) 11.5-0-11.5-12.6 VAC @ 2A CCS S1) 0-240-460-600 VAC @ 0.275A CCS EI-150 X YAESU TEMPO AC ONE PWR XFMR TEMPO AC ONE POWER SUPPLY WITH SPEAKER 2.5" 6 29GM6X 0-100-110-117 & 0-100- S2) 270 VCT @ 0.2A CCS 12 110-117 VAC 60 HZ S3) 100 VAC @ 0.1A CCS S4) 6.3 VAC @ 6A & 6.3 VAC @ 6A 7.5VCT @ 75A FILAMENT PWDF13207 0-220-240VAC, 60HZ 7.5VCT @ 100A FILAMENT PWDF13185 115/230 VAC, 50/60 HZ 7.5VCT @ 100A CCS 10.0 VCT @ 10A DUAL CCS G DUAL 10 VCT 10A FIL FOR PP 833A'S EI-150 X 2 10.0 VCT @ 10A E EI-150 X FIL XFMR FOR 810'S, 813'S OR SINGLE 833A 1.5 10.0 VCT @ 15A CCS R EI-125 X 1.25" 11.8 VAC 180-1000 HZ PRIMARY 10.0 VCT @ 17.5A 3CX5000A FILAMENT TRANSFORMER 10.0 VCT @ 20A CCS G FILAMENT TRANSFORMER 5 2 2 29GM6 EI-150 X 2 5 EI-150 X 2 5 10.5 VCT @ 140A CCS M A-0274/ C- FILAMENT TRANSFORMER, 4CX20000A/8990 CORE 1000 VAC @ 1.0A CCS A-0393/ C- PLATE TRANSFORMER CORE 1000 VAC @ 1.75A CCS K PLATE TRANSFORMER A-274 CCORE 1100 VAC @ 1.2A CCS I A-274 C- ADVERTISED UNIT CORE 1100 VAC @ 1.5A CCS I A-274 C- PLATE TRANSFORMER CORE 1100 VAC @ 2.8A ICAS I A-0459/ C- ADVERTISED UNIT CORE 1100 VAC @ 600 MA CCS H A-0016/ C- BERKSHIRE P/N 6181 CORE 1171 VAC @ 1.0A CCS G B-0393/ C- PLATE TRANSFORMER CORE 1175 VAC @ 3.5A CCS N A-0518/ C- PLATE TRANSFORMER CORE 1200 VAC @ 0.5A CCS & FIL A-393 C- WITH 6.3 VCT @ 16A FILAMENT WINDING CORE 1250 VAC @ 1.5A CCS G A-0480/ C- PLATE TRANSFORMER CORE 13.5 VCT @ 3A CCS N EI-125 X FILAMENT TRANSFORMER 1.25 13.5 VCT @ 5A & 18 VAC @ 2A EI-137 X 3CX800A7 FIL & CONTROL XFMR (3 TUBES) 1.375 10 115/230 VAC 60 HZ S1) 10.0 VCT @ 10A CCS 1PH S2) 10.0 VCT @ 10A CCS 0-105-117 VAC 60 Hz 1 S1) 10.0 VCT @ 10A CCS PH 11.8 VAC 180-1000 HZ 1 PH S1) 10.0 VCT @ 17.5A CCS 115/230 VAC 60 HZ 1PH 10 230 VAC 60 HZ 1 PH 10 120/240 VAC 60 Hz 10 10 10 120/240 VAC 60 HZ 1 PH CCS S1) 1000 VAC @ 1.0A CCS 1000 VAC @ 1.75A CCS S1) 1100 VAC @ 1.2A CCS 1100 VAC @ 1.5A CCS 120/240 VAC 60 HZ 1 S1) 1100 VAC @ 2.8A PH ICAS 117/234 VAC 60 HZ 1 S1) 1100 VAC @ 600 MA PH CC 115/230 VAC 60 HZ 1 S1) 1171 VAC @ 1.0A PH CCS 0-220-240 VAC 60 HZ 1 S1) 1175 VAC @ 3.5A PH 8 10 S1) 10.0 VCT @ 20A CCS 10 0-208-220-230-240-250 S1) 10.5 VCT @ 140A VAC 60 HZ 1 PH 10 S1) 10.0 VCT @ 15A CCS 4 1PH 115 VAC 60 HZ 1 PH 10 S2) 10.0 VCT @ 10A CCS 115/230 VAC 60 HZ 10 10 7.5 VCT @ 75A CCS CCS 37 23 37 37 37 40 17 23 66 S1) 1200 VAC @ 0.5A 10 115 VAC 60 HZ 1 PH CCS 23 S2) 6.3 VCT @ 16A CCS 10 4 5 https://www.hammfg.com/electronics/transformers/classic/pwdahl 115/230 VAC 60 HZ 0-220-240 VAC 60 HZ 1 PH S1) 1250 VAC @ 1.5A CCS S1) 13.5 VCT @ 3A CCS 0-210-220-230-240-250 S1) 13.5 VAC @ 5A CCS VAC 60 HZ 1 PH S2) 18 VAC @ 2A CCS 46 4 6 25/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond (see Part Number Core above) 13.5 VCT @ 5A G EI-137 X 3CX800A7 FILAMENT TRANSFORMER (3 TUBES) 1.375 1300/1175/1050/925V @ 2A CCS A-0480/ C- 1296 MHZ EME AMP POWER SUPPLY XFMR CORE 14 VAC @ 100A CCS F LV POWER TRANSFORMER 15 VAC @ 25A CCS OR 35A ICAS FOR 13.8 VDC REGULATED POWER SUPPLY 4 Approx. Weight Primary 115/230 VAC 60 HZ 1 PH 10 34 VAC 60 HZ 1 PH A-0203/ CCORE 10 110/220 VAC 60 HZ 1 PH EI-162 X 2 2 115 VAC 60 HZ 1 PH 2 120 VAC 60 HZ 1 PH 15.0 VCT @ 15A CCS D EI-175 X 3CX10000B7 FILAMENT TRANSFORMER 1.75 15.0 VCT @ 15A CCS SP LO-PRO EI-150 X 2" LO-PROFILE FILAMENT TRANSFORMER 29GAM6X 1500 VAC @ 0.5A & 7 VCT @ 8A A-393 C- POWER XFMR FOR DUAL 572B LINEAR AMP CORE 4 0-115-120-125-130 VAC 60 HZ 1 PH Secondary (lbs) S1) 13.5 VCT @ 5A CCS 6 S1) 0-925-1050-1175-1300 VAC @ 2.0A CCS 46 S1) 14 VAC @ 100A CCS 30 S1) 15 VAC @ 25A CCS OR 35A ICAS 15 S1) 15.0 VCT @ 15A CCS 12 S1) 15.0 VCT @ 15A CCS 10 S1) 1500 VAC @ 0.5A 10 120 VAC 60 HZ 1 PH CCS 23 S2) 7.0 VCT @ 8A CCS S1) 1500 VAC @ 0.5A 1500 VAC @ 0.5A CCS & S/B/F W/FIL, SCREEN & BIAS VOLTAGE SECONDARIES A-0393/ CCORE 1500 VAC @ 1.0A CCS A-0274/ C- PLATE TRANSFORMER CORE 10 120/240 VAC 60 HZ 1 PH CCS S2) 300 VAC @ 0.1A CCS 23 S3) 100 VAC @ 0.1A CCS S4) 6.3 VAC @ 6A CCS 1500 VAC @ 1.0A CCS PLATE TRANSFORMER PWDP13100 EI 1600 VAC @ 0.5A CCS H A-0393/ C- PLATE TRANSFORMER CORE 1600 VAC @ 1.5A CCS N PLATE TRANSFORMER A-480 CCORE 1650/1515/1375V @ 1.2A CCS K FOR 2000 VOLT SUPPLY IN ARRL HANDBOOK PWDP13078 A-0480/ CCORE 1770 VAC @ 2.0A CCS A-0518/ C- PLATE TRANSFORMER CORE 18 VAC @ 25A CCS OR 35A ICAS FOR 13.8 VDC REGULATED POWER SUPPLY EI-162 X 2 18/16 VAC @ 100A CCS A A-0274/ C- LV POWER XFMR WITH HI/LO PRIMARY TAPS CORE 1800 VAC & 1.5A CCS LV & FIL PLATE XFMR WITH LV & FILAMENT WINDINGS A-0518/ CCORE 10 4 0-220-240 VAC 60 HZ 1 S1) 1500 VAC @ 1.0A PH CCS 0-220-240 VAC 60 HZ 1 S1) 1500 VAC @ 1.0A PH CCS 117/234 VAC 60 HZ 1 S1) 1600 VAC @ 0.5A PH CCS 10 0-220-240 VAC 60 HZ S1) 0-1600 VAC @ 1.5A CCS 10 234 VAC 60 HZ 1 PH 10 10 0-1375-1515-1650 VAC @ 1.2A CCS 0-230-240-250 VAC 60 S1) 1770 VAC @ 2.0A HZ 1 PH 2 115 VAC 60 HZ 1 PH 10 110 VAC 60 HZ 1 PH CCS S1) 18 VAC @ 25A CCS OR 35A ICAS 0-16-18 VAC @ 100A CC 37 45 23 46 46 66 15 37 S1) 1800 VAC @ 1.5A 10 240 VAC 60 HZ 1 PH CCS 66 S2) 500 VCT @ 0.1A CCS S3) 6.3 VCT @ 12A CCS 1800 VAC @ 0.6A & 5 VCT @15A A-0274/ C- PLATE & FIL XFMR TRANSFORMER CORE 1800 VAC @ 1.5A CCS K A-0480/ C- PLATE TRANSFORMER CORE 1800 VAC @ 1A CCS G A-0274/ C- PLATE TRANSFORMER CORE 1800 VAC @ 2A CCS KN A-0518/ C- PLATE TRANSFORMER CORE 1800 VCT @ 3A CCS A-525 CCORE 1800/1200 VAC @ 0.5A CCS A-0393/ C- PLATE TRANSFORMER CORE 1800/1600/1500V @ 1.5A CCS N PLATE TRANSFORMER WITH 2 SEC TAPS A-0480/ CCORE S1) 1800 VAC @ 0.6A 10 117 VAC 60 HZ 1 PH CCS 37 S2) 5.0 VCT @ 15A CCS 10 10 10 10 230 VAC 60 HZ 1 PH 115/230 VAC 60 HZ 1 PH 0-220-230-240 VAC 60 HZ 1 PH S1) 1800 VAC @ 1.5A CCS 46 S1) 1800 VAC @ 1A CCS 37 1800 VAC @ 2A CCS 0-115 & 0-115 VAC 60 0-900-1800 VCT @ 3.0A HZ CCS 0-1200-1800 VAC @ 0.5A 10 120 VAC 60 HZ 1 PH 10 0-220-240 VAC 60 HZ 1 S1) 0-1500-1600-1800 PH VAC @ 1.5A CCS CCS 66 86 23 46 S1)1800VAC @ 175 MA 1800VCT @ 175 MA PWDP13048 EI CORE 120VAC, 60 HZ S2) 560 VAC @ 800 MA S3) 5V @ 2A S4) 5V @ 4A https://www.hammfg.com/electronics/transformers/classic/pwdahl 26/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond (see Part Number Core above) 19/18/17/16/15 VAC @ 30A CCS A-16 C- WITH 115 VAC VCB PRIMARY TAPS CORE 2.5 VCT @ 10A B (15 KV INS) EI-150 X PR 866A RECTIFIER FILAMENT TRANSFORMER 1.5 2000 VAC @ 0.5A CCS N A-0274/ C- PLATE TRANSFORMER CORE 2000 VAC @ 1.0A CCS I PLATE TRANSFORMER A-0480/ CCORE 2000 VAC @ 1.0A CCS N A-0480/ C- PLATE TRANSFORMER CORE 2000 VAC @ 1.0A ICAS J A-0274/ C- 3CX800A7 PLATE TRANSFORMER CORE A-0480/ C- 2000 VAC @ 1.5 AMP CCS CORE 2000 VAC @ 2A CCS N A-518 C- PLATE TRANSFORMER CORE 2000 VAC @ 2.5A CCS PLATE TRANSFORMER PWDP13059 EI CORE 2000 VAC @ 3.0A CCS N A-525 C- PLATE TRANSFORMER CORE 2000 VAC @ 500 MA CCS G A-0393/ C- HIGH VOLTAGE TRANSFORMER CORE 2000 VCT @ 0.5A CCS L PLATE TRANSFORMER FOR FWB A-0274/ CCORE 2000/1300 VAC @ 3.0A CCS N A-0525/ C- PLATE TRANSFORMER WITH SEC TAP CORE 2250/2000/1500 VAC @ 1A CCS A-480 C- PLATE TRANSFORMER CORE 2300 VCT @ 0.55A CCS D A-274 C- PLATE TRANSFORMER CORE 2300 VCT @ 2.0A CCS PLATE TRANSFORMER PWDP13190 EI 2350/1800/1700 VAC @ 1.0A CS A-0480/ C- PLATE TRANSFORMER CORE 24 VCT @ 25A CCS A-16 C- LOW VOLTAGE POWER TRANSFORMER CORE 2400 VAC @ .4A & 5 VCT @ 15A PLATE & FIL XFMR FOR SINGLE 3-500Z PWDP13004 PLATE TRANSFORMER 29GAM6X A-0393/ C- 2400 VAC @ 0.5A CCS 2400 VAC @ 1.0A CCS I EI-162 X 3" CORE PWDP13209 A-0480/ CCORE 10 5 10 10 10 Approx. Weight Primary Secondary 115 VAC 60 HZ WITH 4 S1) 19/18/17/16/15 VAC @ CB TAPS 115 VAC 60 HZ 1 PH 0-220-240 VAC 60 HZ 1 PH 120/240 VAC 60 HZ 1 PH 30A CCS 2.5 VCT @ 10A CCS (15 KVDC TEST) 2000 VAC @ 1.0A CCS 46 0-220-240 VAC 60 HZ 1 S1) 2000 VAC @ 1.0A 10 220 VAC 60 HZ 1 PH 2000 VAC @ 1.0A CCS 10 230 VAC 60 HZ 1PH 10 10 10 10 10 2000 VAC @ 1.5 AMP CCS CCS 240 VAC 60 HZ 1 PH 2000 VAC @ 2.5A CCS 84 2000 VAC @ 3.0A CCS 86 0-220-240 VAC 60 HZ 1 PH 115/230 VAC 60 HZ 1 PH 240 VAC 60 HZ 1 PH 2000 VCT @ 0.5A CCS 0-220-240 VAC 60 HZ 1 0-1300-2000 VAC @ 3.0A PH CCS 0-220-240 VAC 60 HZ 1 0-1500-2000-2250 VAC @ 37 86 46 PH 1.0A CCS 10 120 VAC 60 HZ 1 PH 2300 VCT @ 550 MA CCS 37 2 220 VAC 60 HZ 1 PH 2300 VCT @ 2.0A CCS 10 0-230-240-250 VAC 60 0-1700-1800-2350 VAC @ HZ 1 PH 1.0A CCS 10 115 VAC 60 HZ 1 PH 24 VCT @ 25A CCS 4 117 VAC 60 HZ 1 PH 85 46 17 S1) 2400 VAC @ 0.4A ICAS 21 S2) 5.0 VCT @ 15A CCS 10 10 120/240 VAC 60 HZ S1) 2400 VAC @ 0.5A 1PH CCS 120/240 VAC 60 HZ 1 S1) 2400 VAC C.T. @ 1.0A PH CCS A-0480/ C- PLATE XFMR FOR PAIR OF 3-500Z'S W/TB'S CORE 2400 VAC @ 2.0A CCS N A-0518/ C- ADVERTISED UNIT CORE 2400 VCT @ .5A & 5 VCT @ 15A PLATE & FIL XFMR FOR SINGLE 3-500Z EI-162 X 3" 4 29GAM6X 117 VAC 60 HZ 1 PH A-0393/ C- 120/240 VAC 60 HZ S1) 2400 VCT @ 0.5A 1PH CCS 10 10 10 10 10 https://www.hammfg.com/electronics/transformers/classic/pwdahl 110/220 VAC 60 HZ 1 PH CCS S2) 5.0 VCT @ 45A CCS 0-220-240 VAC @ 60 S1) 2400 VAC @ 1.5A HZ 1 PH ICAS 0-220-240 VAC 60 Hz 23 46 S1) 2400 VAC @ 1.5A 2400 VAC @ 1.5A ICAS N CORE 66 2000 VAC @ 500 MA CCS 23 CORE A-0518/ C- 46 S1) 2000 VAC @ 2.0A WITH 5.0 VCT @ 45A CCS FILAMENT WINDING 2400/1800 VAC @ 1.5A CCS N 37 PH A-0518/ C- CORE 46 220/240 VAC 60 HZ 1 2400 VAC @ 1.5A CCS & FIL F 2400 VCT @ 0.5A CCS 8 37 CCS 2 17 2000 VAC @ 0.5A CCS PH 10 (lbs) S1) 2400 VAC @ 2.0A CCS 66 46 66 S1) 2400 VCT @ 0.5A ICAS 21 S2) 5.0 VCT @ 15A CCS 0-220-240 VAC 60 HZ S1) 0-1800-2400 VAC @ 1.5A CCS 23 66 27/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond (see Part Number Core above) 2400/1800 VAC @ 1.5A ICAS G A-0480/ C- PLATE XFMR FOR PAIR OF 3-500Z'S CORE 2400/1800 VAC @ 1.5A ICAS N A-0480/ C- PLATE XFMR FOR PAIR OF 3-500Z'S CORE A-0518/ C- 2400/1800 VAC @ 2.0A CCS N CORE A-0525/ C- 2400/2000 VAC @ 3A CCS CORE 2500 VAC @ 0.3A CCS L A-0393/ C- PLATE TRANSFORMER CORE 2500 VAC @ 0.5A ICAS D A-0393/ C- PLATE TRANSFORMER CORE 2500 VAC @ 1.0A CCS D A-480 C- PLATE TRANSFORMER CORE 2500 VAC @ 1.0A CCS N PLATE TRANSFORMER A-0480/ CCORE 2500 VAC @ 1.5A CCS H A-518/C C- PLATE TRANSFORMER WITH 117/234 VAC PRI CORE 2500 VAC @ 1.5A CCS N A-518/C C- PLATE TRANSFORMER CORE 2500 VCT @ 1.5A CCS N A-518/C C- PLATE TRANSFORMER CORE 2500 VCT @ 2.5A CCS N PLATE TRANSFORMER FOR FWB RECTIFIER CORE 2500/1750 VAC @ 0.8A CCS G A-0274/ C- PLATE TRANSFORMER CORE 2600 VAC @ 1.5A CCS N A-0518/ C- PLATE XFMR FOR 3-4 EA 3-500Z (3250 VDC) CORE 2600/2400/1800 VAC @ 2A CCS PLATE XFMR FOR 4 EA 3-500Z'S A-0525/ CCORE 2650/1800 VAC @ 1.5A CCS N A-0518/ C- PLATE XFMR FOR 3-4 EA 3-500Z (3300 VDC) CORE EI-212 X 4 2800/2000 VAC @ 1.0A CCS A-0480/ C- PLATE TRANSFORMER CORE 2800/2700/2600 VAC @ 1.5A ICAS PLATE TRANSFORMER PWDP13182 EI 2800/2400 VAC @ 2.5A CCS N PLATE TRANSFORMER A-0525/ CPWDP13077 CORE 2850/1750 VAC @ 1.5A ICAS G A-0480/ C- PLATE TRANSFORMER CORE 2850/2150/1450V @ 1.5A ICAS A-0480/ C- SPECIAL FOR Q-PRODUCTS WITH EXTRA TAP CORE 290 VAC @ 0.1A CCS N 400 VDC 100 MA DC SCREEN SUPPLY XFMR EI-125 X 1.25 3000 VAC @ 1.0A CCS N A-0518/ C- PLATE TRANSFORMER CORE 3000 VAC @ 1.5A CCS HI/LO PRI LO TAP TO PROVIDE 2000 VAC 10 Weight Primary A-518 3000 VAC @ 2 AMP CCS A-0525/ C- WITH 2650 VAC TAP & 220-230-240-250V PRI CORE 3000/1800 VAC @ 1.0A CCS N A-0518/ C- PLATE TRANSFORMER WITH HI/LO SEC TAPS CORE 3000/2000 VCT @ 0.35A CCS SPECIAL FOR C&N SERVICES A-393 CCORE Secondary 115/230 VAC @ 60 HZ S1) 0-1800-2400 VAC @ 1 PH 1.5A ICAS 220/240 VAC @ 60 HZ S1) 0-1800-2400 VAC @ 1 PH 1.5A ICAS 0-220-240 VAC 60 HZ 1 0-1800-2400 VAC @ 2.0A PH CCS 0-2000-2400 VAC @ 3.0A 10 0-220-240 VAC 60 HZ 10 240 VAC 60 HZ 1 PH 10 120 VAC 60 HZ 1 PH 10 120 VAC 60 HZ 1 PH 10 0-220-240 VAC 60 HZ 1 S1) 2500 VAC @ 1.0A PH CCS 10 10 10 10 10 10 10 10 2 10 CCS S1) 2500 VAC @ 0.3A CCS S1) 2500 VAC @ 500 MA ICAS S1) 2500 VAC @ 1.0A CCS 117/234 VAC 60 HZ 1 S1) 2500 VAC @ 1.5A PH CCS 0-220-240 VAC 60 HZ 1 S1) 2500 VAC @ 1.5A PH CCS 0-220-240 VAC 60 HZ 1 S1) 2500 VAC @ 1.5A PH 120/240 VAC, 60 HZ A-0393/ C- PLATE TRANSFORMER 10 PWDP13228 2500 VCT @ 400 MA CCS B 2800 VCT @ 400 MA CCS 10 Approx. 115 VAC 60 HZ 1 PH CCS S1) 2500 VCT @ 400 MA CCS (FWB) S1) 0-1750-2500 VAC @ PH 0.8A CCS 0-220-240 VAC 60 HZ 1 S1) 2600 VAC @ 1.5A CCS 0-220-240 VAC 60 HZ 1 0-1800-2650 VAC @ 1.5A PH CCS 120/240 VAC 60 HZ 1 S1) 2800 VCT @ 400 MA PH CCS 0-220-240 VAC 60 HZ 1 S1) 2800 VAC @ 1.0A PH CCS 10 10 10 10 10 10 https://www.hammfg.com/electronics/transformers/classic/pwdahl 86 23 23 46 46 66 66 66 23 37 66 38 46 1.5A ICAS 115/230 VAC 60 HZ 1 S1) 0-1750-2850 VAC @ PH 1.5A ICAS 0-220-240 VAC 60 HZ 1 S1) 0-1450-2150-2850 PH 66 0-2600-2700-2800 VAC @ 0-220-240 VAC 60 HZ 1 S1) 0-2400-2800 VAC @ PH 2.5A CCS 4 66 0-220-230-240 VAC 60 0-1800-2400-2600 VAC @ 86 Hz 2A CCS 0-240 VAC 60 HZ 1 PH 10 46 CCS 2 10 46 S1) 2500 VAC @ 2.5A 115/230 VAC 60 HZ 1 PH (lbs) VAC @ 1.5 AMP ICAS 86 46 46 0-220-240 VAC 60 HZ 1 S1) 290 VAC @ 0.1A CCS 4 PH 0-220-240 VAC 60 HZ 1 S1) 3000 VAC @ 1.0A PH CCS 220 VAC 60 HZ WITH 3000/2000 VAC @ 1.5 HI/LO TAPS AMP CCS 0-220-230-240-250 S1) 0-2650-3000 VAC @ 2 VAC 60 HZ AMPS CCS OR 3A ICAS 0-220-240 VAC 60 HZ 1 S1) 0-1800-3000 VAC @ PH 1.0A CCS 120 VAC 60 HZ 1 PH 1500-1000-0-1000-1500 VAC @ 0.35A CCS 66 66 86 66 23 28/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond Part Number Core 3000/2000 VCT @ 0.5A CCS A-274 C- SPECIAL FOR C&N SERVICES CORE 3000/2400 VAC @ 1.5A CCS JKL A-518 C- PLATE TRANSFORMER CORE 3000/2500/2000 VAC @ 1A CCS A-0518/ C- PLATE TRANSFORMER CORE 3000/2800/2600V @ 1.5A CS JL PLATE TRANSFORMER A-518 CCORE 3100/2700/2300V @ 1.5A CCS PLATE TRANSFORMER PWDP13104 A-518 CCORE PROP PITCH PWR XFMR WITH 220 VAC 50/60HZ 2.5" 29GM6X 3200 VAC @ 1.0A CCS SP A-0518/ C- PLATE XFMR FOR 4000 VDC @ 0.8A FWB CAP-I CORE 3200 VAC @ 1.5A CCS JK A-0518/ C- PLATE TRANSFORMER CORE EI-162 X 3 PLATE & FIL XFMR FOR SINGLE 3-500Z A-0518/ C- CCS PLATE XFMR WITH SCREW LUGS ON COIL CORE PWDP13035 A-0525/ CCORE 3500 VAC @ 1.0A CCS A-518 C- PLATE TRANSFORMER CORE 3500 VAC @ 1.0A ICAS G A-0480/ C- ADVERTISED UNIT CORE 3500 VAC @ 1.5A CCS JK A-0518/ C- PLATE TRANSFORMER CORE 3500 VAC @ 1.5A ICAS N A-0518/ C- PLATE TRANSFORMER CORE 3500/2000 VAC @ 1.5A CCS JK A-0518/ C- PLATE TRANSFORMER CORE 3500/3200/3000 VAC @ 1A ICAS A-0480/ C- PLATE TRANSFORMER CORE 3600 VAC @ 1.0 AMP CCS G A-0518/ C- WITH TAPS AT 1900-2000-2600 VAC CORE 3600 VAC @ 1.5A ICAS N A-0518/ C- PLATE TRANSFORMER CORE 3600 VAC @ 2.0A ICAS J A-0525/ C- PLATE TRANSFORMER CORE A-518 C- 3750 VAC @ 1.0A CCS G CORE 3800/3500/2800V @ 1.0A CCS N A-0518/ C- PLATE TRANSFORMER CORE PLATE TRANSFORMER 3904 VAC @ 1.6A CCS PLATE TRANSFORMER PWDP13196 EI PWDP13214 A-0525/ CCORE 4000 VAC @ 1.0A CCS N A-0518/ C- PLATE TRANSFORMER CORE 4000 VAC @ 500 MA CCS 120 VAC 60 HZ 1 PH 10 10 10 10 2 10 10 1500-1000-0-1000-1500 VAC @ 0.5A CCS 0-220-230-240 VAC 60 0-2400-3000 VAC @ 1.5A HZ 1 PH CCS 115/230 VAC 60 HZ 1 S1) 0-2000-2500-3000 PH VAC @ 1.0 AMP CCS Weight (lbs) 37 66 66 0-220-240 VAC 60 HZ 1 0-2600-2800-3000 VAC @ 66 PH 1.5A CCS 0-220-230-240 VAC 60 0-2300-2700-3100 VAC @ HZ 1 PH 1.5A CCS 220 VAC 50/60 HZ 1 S1) 0-24-28-32 VAC @ PH 15A CCS 0-100-110-120 VAC 60 S1) 3200 VAC @ 1.0A HZ 1 PH CCS 0-220-230 VAC 60 HZ 1 S1) 3200 VAC @ 1.5A PH CCS 66 18 66 66 4 117 VAC 60 HZ 1 PH ICAS 21 S2) 5.0 VCT @ 15A CCS 3200/2800/2400 VAC @ 1.3A CS 3904 VAC @ 1.6A CCS 10 Secondary S1) 3200 VCT @ 0.4A 3200 VCT @ .4A & 5 VCT @ 15A 3300/2300 VAC @ 2.0A CCS KL PLATE TRANSFORMER Primary EI-162 X 32/28/24 VAC @ 15A CCS Approx. (see above) A-0480/ CCORE 4000 VCT @ 1.0A CCS N A-0518/ C- PLATE TRANSFORMER CORE 10 0-220-240 VAC 60 HZ 1 S1) 0-2400-2800-3200 PH VAC @ 1.3A CCS 10 0-230-240 VAC 60 HZ 1 S1) 0-2300-3300 VAC @ PH 2.0A CCS 10 220 VAC 60 HZ 1PH 10 10 10 10 10 10 10 10 10 10 S1) 3500 VAC @ 1.0A PH ICAS 0-220-230 VAC 60 HZ 1 S1) 3500 VAC @ 1.5A PH PH PH 1.5A CCS 0-230-240 VAC 60 HZ 1 0-3000-3200-3500 VAC @ PH 115/230 VAC 60 HZ 1 PH 1.0A ICAS PH 220 VAC 60 HZ 1 PH 3600 VAC @ 1.0 AMP ICAS S1) 3600 VAC @ 2.0A ICAS S1) 3750 VAC @ 1.0A PH CCS 0-220-240 VAC 60 HZ 1 S1) 0-2800-3500-3800 VAC @ 1.0A CCS S1) 0-3904 VAC @ 1.6A CCS S1) 0-3904 VAC @ 1.6A CCS 0-220-240 VAC 60 HZ 1 S1) 4000 VAC @ 1.0A PH CCS 230 VAC 50/60 HZ 1 S1) 4000 VAC @ 500 MA PH CCS 0-220-240 VAC 60 HZ 1 S1) 4000 VCT @ 1.0A PH 66 46 66 66 66 46 66 CCS 115/230 VAC 60 HZ 1 PH 86 S1) 0-1900-2000-2600- 0-220-240 VAC 60 HZ 1 S1) 3600 VAC @ 1.5A 0-240 VAC 60 HZ 1 PH https://www.hammfg.com/electronics/transformers/classic/pwdahl ICAS 0-220-230 VAC 60 HZ 1 S1) 0-2000-3500 VAC @ 10 10 CCS 0-220-240 VAC 60 HZ 1 S1) 3500 VAC @ 1.5A 0-240 VAC 60 HZ 1 PH 10 CCS 115/230 VAC 60 HZ 1 4 10 S1) 3500 VAC @ 1.0A 66 CCS 66 86 66 66 128 86 66 46 66 29/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style Description Hammond (see Part Number Core above) 4200 VAC @ 2.0A ICAS F A-0525/ C- PLATE TRANSFORMER CORE 4200 VCT @ 0.6A CCS I A-0480/ C- PLATE TRANSFORMER CORE 4600/4000 VAC @ 1.5A ICAS K A-0518/ C- PLATE TRANSFORMER CORE 5.0 VCT @ 10.5 AMP CCS D 10 10 10 Approx. Weight Primary Secondary 110/220 VAC 60 HZ 1 S1) 4200 VAC @ 2.0A PH ICAS 120/240 VAC 60 HZ 1 S1) 4200 VCT @ 0.6A PH CCS 230 VAC 60 HZ 1 PH I-125 X 1.25 2 120 VAC 60 HZ 1 PH 5.0 VCT @ 15A CCS F FILAMENT TRANSFORMER (3-500Z OR 4-400A) EI-137 X 1.375 110/220 VAC 60 HZ 1 PH 5.0 VCT @ 20A CCS JKL EI-175 X RECT FIL XFMR (10 KVDC) 1.75 5.0 VCT @ 20A CCS L EI-150 X 10 KVDC INSULATION 1.75 5.0 VCT @ 30A & 12 VAC @ 2A EI-150 X 2 5.0 VCT @ 30A G EI-150 X ADVERTISED UNIT (FIL XFMR PAIR 3-500Z'S) 1.5 5.0 VCT @ 30A W/BIAS G EI-150 X FIL XFMR FOR PR 3-500Z'S, WITH 90V BIAS 1.5 5.0 VCT @ 4A 10 KVDC FIL EI-087 X RECT FIL XFMR FOR 2 EA 816'S IN SERIES .875 120 VAC 60 HZ PRIMARY (SINGLE 8877) 5.0 VCT @ 60A CCS SP SPECIAL +5,0,-5,110,125 VAC TAPPED PRI 5.0 VCT @ 60A W/B&F H 90 VAC @ 0.2A BIAS & 12.6 VAC @ 1A LV 2 4 4 4 1 4 EI-175 X 2 5 EI-150 X 5" FITS UNDER 4" CHASSIS, SPCL TERRY GAISER 29GAM6X EI-175 X 3 FILAMENT TRANSFORMER FOR 6 EA 3-500Z'S 2 EI-175 X 2 5.0 VCT @ 90A CCS LO PROFILE 5.0 VCT @ 90A W/BIAS G 4 4 4 5.5 VCT @ 17.5A STP EI-150 X FIL XFMR WITH SPECIAL TAPPED PRIMARY 1.5 5000 VCT @ 500MA CCS I A-480 C- GENERAL PURPOSE PLATE XFMR FOR FWCT CORE 5000/4500 VAC @ 1.5A ICAS K 4500 VDC OR 4000 VDC @ 1.5A ICAS A-525/C C10 CORE 550 VCT @ 0.3A CCS D EI-150 X POWER TRANSFORMER 1.5 5600 VCT @ 1.5A CCS SP A-0525/ C- FWCT PLATE TRANSFORMER CORE 5800 VCT @ 1.0A CCS FWCT G A-518 C- 2.9 KVA FWCT PLATE TRANSFORMER CORE 6.3 VCT @ 10A CCS G EI-137 X FILAMENT TRANSFORMER 1.375 6.3 VCT @ 100A D EI-162 X FILAMENT TRANSFORMER 3.5 6.3 VCT @ 16A & 24 VCT @ 3A EI-150 X 2 FILAMENT & CONTROL TRANSFORMER 6.3 VCT @ 160A CCS N 3CX15000A7 FILAMENT TRANSFORMER 6.3 VCT @ 20A D FILAMENT TRANSFORMER -- ADVERTISED UNIT 6.3 VCT @ 30A CCS (G) FILAMENT TRANSFORMER PWDF13127 A-0393/ CCORE 4 10 2 10 10 4 2 5 10 EI-150 X 1.5 2 EI-150 X 2 4 6.3 VCT @ 50A CCS JKL EI-175 X 2" STYLE #5 WITH POTTED END BELLS 29GAM6X 5 https://www.hammfg.com/electronics/transformers/classic/pwdahl S1) 0-4000-4600 VAC @ 1.5A ICAS S1) 5.0 VCT @ 10.5 AMPS CCS S1) 5.0 VCT @ 15A CCS 0-220-230-240 VAC 60 S1) 5.0 VCT @ 20A CCS HZ 1 PH 240 VAC 60 HZ 1 PH (10 KVDC INSULATION) 5.0 VCT @ 20A CCS (10 KVDC INSULATION) 120/240 VAC 60 HZ 1 S1) 5.0 VCT @ 30A CCS PH S2) 12.0 VAC @ 2A CCS 115/230 VAC 60 HZ 1 PH S1) 5.0 VCT @ 30A CCS 115/230 VAC 60 HZ 1 S1) 5.0 VCT @ 30A CCS PH S2) 90 VAC @ 0.2A CCS 115 VAC 60 HZ 1 PH PR) +5,0,-5,110,125 VAC 60 HZ 1 PH 117/234 VAC 60 HZ 1 PH 0-220-230-240-250 VAC 60 HZ 1 PH 115/230 VAC 60 Hz 0-110-115-120-125 VAC 60 HZ 1 PH 120/240 VAC 60 HZ S1) 5.0 VCT @ 4A CCS (10 KVDC TEST) S1) 5.0 VCT @ 60A CCS (lbs) 86 46 66 4 6 12 9 4 8 8 2 14 S1) 5.0 VCT @ 60A CCS S2) 90 VAC @ 0.2A CCS 14 S3) 12.6 VAC @ 1A CCS S1) 5.0 VCT @ 90A CCS S1) 5.0 VCT @ 90A CCS S2) 90 VAC @ 200 MA 23 19 S1) 5.5 VCT @ 17.5A CCS 8 S1) 5000 VCT @ 500MA CCS 46 230 VAC 60 HZ 1 PH 0-4500-5000 VAC @ 1.5A 86 ICAS 120 VAC 60 HZ 1 PH S1) 550 VCT @ 0.3A CCS 8 0-220-240-260 VAC 60 S1) 2800-0-2800 VAC @ HZ 1 PH 1.5A CCS 115/230 VAC 60 HZ 1 S1) 5800 VCT @ 1.0A PH CCS FWCT 115/230 VAC 60 HZ 1 PH S1) 6.3 VCT @ 10A CCS 86 66 6 120 VAC 60 HZ 1PH S1) 6.3 VCT @ 100A CCS 24 115/230 VAC 60 HZ 1 S1) 6.3 VCT @ 16A CCS PH S2) 24 VCT @ 3A CCS 0-220-240 VAC 60 HZ 1PH 120 VAC 60 HZ 1 PH 115/230 VAC 60 HZ 1 PH 0-220-230-240 VAC 60 HZ 1 PH 10 6.3 VCT @ 160A CCS 23 6.3 VCT @ 20A CCS 8 S1) 6.3 VCT @ 30A CCS 10 S1) 6.3 VCT @ 50A CCS 14 30/31 3/1/22, 12:09 PM Peter W Dahl Transformers (PWDAHL Series) - Hammond Mfg. Style (see Hammond Description Part Number Core 6000 VCT @ 0.8A CCS G PLATE TRANSFORMER FOR FWCT RECTIFIER A-0480/ CCORE 6000/5000/4000/3000V @ 0.9A A-0525/ C- CCS PLATE TRANSFORMER CORE 7.0 VCT @ 160A CCS I A-0274/ C- DUAL 3CX6000A7/YU-148 FILAMENT XFMR CORE 7.0 VCT @ 85A N YU-148 FILAMENT TRANSFORMER PWDF13050 EI-162 X 3 7.5 VCT @ 100A CCS D EI-162 X FILAMENT TRANSFORMER 3.5 7.5 VCT @ 100A G FILAMENT TRANSFORMER PWDF13185 7.5 VCT @ 21A ABD 4-1000A OR 3-1000Z FILAMENT TRANSFORMER 7.5 VCT @ 21A E 4-1000A OR 3-1000Z FILAMENT TRANSFORMER 7.5 VCT @ 21A LO PROFILE FILAMENT TRANSFORMER 7.5 VCT @ 24A & 5.0 VCT @ 8A FIL XFMR FOR 2 EA #450TL & 1 EA #254 EI-162 X 3.5 10 46 10 10 2 2 2 5 EI-125 X 2 4 EI-175 X 2 4 EI-175 X 2" FILAMENT TRANSFORMER WITH SPECIAL PRI 29GAM6X 2 5 PWDF13081 EI-162 X 2 2 EI-162 X 3 2 EI-162 X 3 2 7.5 VCT @ 75A G ADVERTISED UNIT 7.5 VCT @ 75A N 220/240 VAC TAPPED PRIMARY 120/240 VAC DUAL PRIMARY (lbs) S1) 6000 VCT @ 0.8A CCS (FWCT RECTIFIER) EI-150 X 2 7.5 VCT @ 42A CCS SP 7.5 VCT @ 110A CCS FILAMENT TRANSFORMER Secondary 115/230 VAC 60 HZ 1 PH 5 2.5" 29GAM6 ADERVTISED UNIT Primary EI-150 X 2 LO PROFILE SPECIAL PRIMARY FOR T. GAISER 7.5 VCT @ 55A G above) EI-150 X 7.5 VCT @ 42A CCS LP SP PWDF13038 EI-162 X 3.5 7.5/6.3 VCT @ 160A CCS D A-0274/ C- DUAL VOLTAGE FIL XFMR WITH 120V PRI TAPS CORE 7.5/6.3 VCT @ 160A CCS L A-0274/ C- DUAL VOLTAGE FIL XFMR WITH 240V PRI TAPS CORE 7.5/6.3 VCT @ 26A & 26V @ 1A EI-175 X SPECIAL 3CX1200 & YU-121 FIL XFMR 1.75 7000 VCT @ 0.9A CCS N A-0525/ C- 4900 VDC @ 0.9A FWCT 4-1000A PLATE XFMR CORE 850 VAC @ 1.0A CCS D A-0393/ C- 120 VAC PRIMARY & WIRE LEADS CORE Approx. Weight 2 10 10 4 0-220-240 VAC 60 HZ 1 S1) 0-3000-4000-5000PH 120/240 VAC 60 HZ 1 PH 0-220-240 VAC 60 HZ 1 PH 120 VAC 60 HZ 1PH 115/230 VAC 50/60 HZ 1PH 0-110-115-120 VAC 60 HZ 1 PH 0-105-117 VAC 60 HZ 1 PH 10 S1) 7.0 VCT @ 85A CCS 0-115-125 VAC 60 HZ 1 PH 0-228-230-232 50 HZ 1 PH 115/230 VAC 60 HZ 1 PH 115/230 VAC 60 HZ 1 PH 0-220-240 VAC 60 HZ 1 PH 120/240 VAC 60 HZ 1 PH 0-120-143 VAC 60 HZ 1 PH 0-240-286 VAC 60 HZ 1 PH S1) 7.5 VCT @ 100A CCS 24 S1) 7.5 VCT @ 21A CCS 10 S1) 7.5 VCT @ 21A CCS 10 S2) 5.0 VCT @ 8A CCS PH 14 12 S1) 7.5 VCT @ 42A CCS 14 S1) 7.5 VCT @ 55A CCS 15 S1) 7.5 VCT @ 75A CCS 21 S1) 7.5 VCT @ 75A CCS 21 S1) 7.5 VCT @ 110A CCS 24 7.5/6.3 VCT @ 160A CCS 37 7.5/6.3 VCT @ 160A CCS 37 12 S2) 26 VAC @ 1A CCS 0-220-240 VAC 60 HZ 1 S1) 7000 VCT @ 0.9A PR) 120 VAC 60 HZ 1 7 S1) 7.5 VCT @ 42A CCS PR) S1) 7.5/6.3 VCT @ 26A +45,0,220,228,236,244 CCS PH 21 S1) 7.5 VCT @ 100A CCS 24 0-220-230-240 VAC 60 S1) 7.5 VCT @ 24A CCS HZ 1 PH 86 S1) 7.0 VCT @ 160A CCS 37 0-105-117 VAC 60 HZ 1 S1) 7.5 VCT @ 21A CCS PH VAC 60 HZ 1 PH 10 6000 VAC @ 0.9A CCS CCS (FWCT) 86 S1) 850 VAC @ 1.0A CCS 23 Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/classic/pwdahl 31/31 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hammond: PWDP13026 PWDI13024 PWDI13158 PWDI13161
PWDP13054 价格&库存
很抱歉,暂时无法提供与“PWDP13054”相匹配的价格&库存,您可以联系我们找货
