172B
172B
    HAMMONDMANUFACTURING
    TRANSFRMR ISOL 230 TO 115V 200VA
172B 数据手册
10/5/22, 9:00 AM Isolation - Step Down (230VAC to 115VAC) (172 Series) - Hammond Mfg. Quality Products. Service Excellence. Isolation - Step Down (230VAC to 115VAC) 172 Series Plug-In Features Primary 230VAC, 50/60 Hz. Secondary 115VAC Circuit breaker in primary. Provides circuit isolation & steps down primary voltage. Hi-pot tested to 2 KV RMS. Electrostatic shield between primary & secondary. Input (primary) connected to a 5 foot long cord & European (Schuko) grounded plug - NOTE: old inventory only. Input - due to U.L changes in 2007 - NEW production with the European (Shuko) parts would no longer be U.L. listed. Therefore, we have replaced this input plug with a standard North American 3-wire, 250V plug (NEMA 6-15P).   Output (secondary) connected to a 1 foot long cord & standard North American 3-wire grounded receptacle (NEMA 5-15R). North American Mark of Safety - C UL & UL listed (File #E211544). Indoor use only. Remember - These units do NOT convert line frequency   Accessories International Grounded Adaptor Plugs Full Load Total Capacitance Surge / Capacity Leakage Full Load Harmonic Noise Part Between Overall Dimensions Weight Windings at No. VA Current Efficiency Distortion Suppression 1KHz 172A 100 40.48 µA 40 pF 88% https://www.hammfg.com/electronics/transformers/line/172 0.19% -35 dB A B C D E 3.80 5.06 4.68 3.00 3.38 Lbs 6.5 1/2 10/5/22, 9:00 AM Isolation - Step Down (230VAC to 115VAC) (172 Series) - Hammond Mfg. Full Load Total Capacity Leakage Full Load Harmonic Capacitance Surge / Noise Between Overall Dimensions Weight Part No. VA Windings at Current Efficiency Distortion Suppression 1KHz 172B 200 41.97 µA 91% 0.18% -34.32 dB 20 pF 3.80 5.56 4.68 3.00 3.88 8.5 172D 500 68.22 µA 96% 0.23% -37.69 dB 28 pF 3.80 7.06 4.68 3.00 5.38 18.5 172E 750 79.58 µA 94% 0.19% -38.24 dB 20 pF 4.40 8.70 5.39 3.50 6.78 30 172F 1000 94.08 µA 96% 0.18% -32.74 dB 40 pF 5.28 7.75 6.38 4.25 6.00 34.5 A B C D E Lbs Data subject to change without notice © 2022. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/transformers/line/172 2/2
很抱歉,暂时无法提供与“172B”相匹配的价格&库存,您可以联系我们找货
